Datetime Format -odbc - One Digit
I use MySQL where the date and time in this format:
2006-01-27 01:33:58
In the Vbscript I use this connection:
Driver={MySQL ODBC 3.51 Driver …
When I create a varible in the VBscript and place the Date-time data from the recordset with the following statement:
dteDate = (rsPayments.Fields("PaymentDate"))
the result will be 1/27/2006 1:33:58
It means that if the month, day and hour are only one digit, they will not be in two-digit format. All your examples in the Say Number module help file and lib_num2wav file functions assume the two-digit format, like MM or DD but sometimes I have only M or D.
How can I solve this problem?
check for values less then 10 and in these cases prefix a "0" to the expression containing the value before using the Say Numbers module.
Easiest done in a "Run VBScript" module.
