Evaluation Duration
I will travel to a friend's home to make many phone calls to intensively test the VG Evaluation Version.
What exactly does the 60-minute limitation mean?
Is it only the total duration of the calls or is it the real time since I pressed the "Set and run the current script"?
What happens when the 60 minutes expires, if I am in the middle of the call? Will it hang up immidiately or just will not allow to make the next call?
It just means that after 60 mins the software will no longer answer any calls placed into it. All you need to do after this time is quit VG then restart it and it will run for a further 60 minutes and so on. You can continue this quit-restart cycle indefinitely as there is no other evaluation limitation, apart from a limit of 30 module scripts.
