Chosing A Different Line
Can I chose a different line? I am using a registered version of VG 1 line. The dialogic card I am using will not respond to line 1 anymore.
If I use the VG demo, line 1 still won't respond but line 2,3,4 work fine. Is there a way to force registered VG 1 line, to use a different line, than line 1?
Yes. You can select any of the 4 lines...
If using v5.x just re-run the config wizard.
If using v6.x then change the Config.xml to use a different line.
