Callque Id
can i get any scripts of an out dial
that select a (phone number and message) from data base, dial the phone number and play the message
then go to the next record in data base
the data base containe a liste of records ( outdial number, message to play, valid call(yes/no) )
can i get the ID of records from CallQue table in data base after dailing out the phone number found in table
i have insert a record into CallQue table : id, phone,script , ..., msg1, msg2, msg3
the table may contain many records with the same phone number but with differents messages to play
after runing, the script must search in CallQue table the liste of message to play specified for this phone number dialed out:
SELECT msg1, msg2, msg3, msg4 FROM CallQue WHERE CallQue.ID = (varible)
what is the "variable" that can i use in my SELECT
The ID field is an indexing 'auto-number'...
I think you'd be better served sticking your own information in the RV column - then you could search for entries which contain in the RV column the substring you're seeking.
Or you could just store the sound files as RVs (Result Variables) themselves...
There is no direct way to find out what is the ID of the call just queued.
yes i have read this page.
and i have run the out dialer but i have to get the field CallQue.ID for the actual out call in order to play a liste of message specific for The phone number that is called
the structure of table CallQue is :
ID, PhoneNumber, ActivateTime,..., msg1, msg2, msg3
SELECT msg1, msg2, mg3 FROM CallQue where ID = "VARIABLE ID"
how can i get the "VARIABLE ID" from system?
after the system dial out a phone number, how can i affect the CallQue.ID (of actual call) to Result variables (in Telephone Numbers Loader) in order to use it in my SELECT?
after runing the script when a real person answers, i have to play a liste of messages (in data base CallQue) to this person
SELECT msg1, msg2, msg3, msg4 FROM CallQue WHERE CallQue.ID = (Result variable)
The answer provided before still applies:
