Text To Speech
How does VG control Text To Speech (TTS)?
How do I select the TTS engine I want to use?
How do I select the voice I want to use?
Can I use different voices within a script?
Can I use different voices within a module?
For prompts that do not change would it not be better to perform the TTS once and save it as a WAV file? Then use that WAV file in the "Sound File To Play" box. Wouldn't you speed VG up by not having to convert "Fixed Text" on the fly to a WAV file?
VoiceGuide will use the default TTS engine. Some TTS engines allow you to change voices midway through. eg: AT&T Natural Voices. See the AT&T help file for info on how to do this.
Yes, that's a much better approach. If you are using mostly static TTS text then it would be better to design the script using that approach.
