Error 53: File Not Found
HELP!!! This VG system has been running OK .. Today, I wondered why I had not received any messages and called to check in .... the Dialogic card did not answer. Upon retun to the office, a dialog box was displayed:
"Error 53, File Not Found." The box title was "VoiceGuide" ....
The machine was "locked" and only wanted me to click "OK". Clicking "OK" wiped out the Trace file which I usually keep running. No other information as to what file it is looking for. I can start VG, but the message displays in about 10 seconds, or whenever I click on any of the toolbar offerings. I am about to go out of town...... HELP!!!!
Once we fix this, I think it would be best to LOG these kind of errors someplace so we can at least see WHAT file you are looking for..... HELP!!!
.... abe
When viewing the VoiceGuide log there is an check option to "Save to File" - this keeps a permanent record of the logs as well as displaying the log in the trace window.
You can also modify the VG.INI file to contain:
[TraceLog]
LogDebugToFile=1
Does the error occur when you start the Script Designer or only when you start VoiceGuide itself?
The "Error 53, File Not Found." suggests that a data file or a control used by VoiceGuide can no longer be located on the system... you get these sort of errors when a hard disk gets corrupt, or when the file itself just plain gets deleted...
Hard to say what the software is looking for, but if the VG.INI file is modified as outlined above and the software started again to cause the error then the trace file (C:\VoiceGuideLogMMDD.txt) should provide us with more information.
Which version of Windows are you using, and for how long has the system been running before you found the problem?
Which version of VoiceGuide are you using? Have you tried to re-install VoiceGuide?
Are the Dialogic card's services starting/running OK?
Thanks for the reply.... no luck yet in resolving this......
All Dialogic Diagnostics run without any anomalies.
Here are the logs ... (How do I ATTACH files on this append system?)
Written by VG..
Tapi device 8 is: Analog Line 4(dxxxB1C4)
Tapi device 7 is: Analog Line 3(dxxxB1C3)
Tapi device 6 is: Analog Line 2(dxxxB1C2)
Tapi device 5 is: Analog Line 1(dxxxB1C1)
Tapi device 4 is: H323 Line
Tapi device 3 is: IPCONF LINE
Tapi device 2 is: LPT1T
Tapi device 1 is: WAN Miniport (L2TP)
Tapi device 0 is: RAS VPN Line 0
68818 0 Inband Signaling Config file not specified
69019 0 Loading VMB data begin
69049 0 Loading VMB data end
74537 5 Initialising...
74937 0 Calling .lineOpen on device 1
76389 0 Calling .GetLineHandle on LineId 5
76389 5 hLine=66201
76650 0 Calling .GetProviderInfo on LineId 5
76670 5 Line 5 Provider: D41MT.TSP: Dialogic D41 Service Provider
76670 0 Calling lineSetNumRings on lLineHandle 66201
76670 5 Waiting for a call...
A Section of TapiWrapLog.txt ...
0418 084422.508 ------------------------------------------------
0418 084422.508 TAPIWrap OCX v1.31.0, Apr 14 2003 18:25:46
0418 084422.508 init c:\TapiWrapLogSelect.txt not found. Tracing not enabled.
0418 084431.410 ------------------------------------------------
0418 084431.420 TAPIWrap OCX v1.31.0, Apr 14 2003 18:25:46
0418 084431.420 ------------------------------------------------
0418 084431.420 init c:\TapiWrapLogSelect.txt not found. Tracing not enabled.
0418 111922.550 ------------------------------------------------
0418 111922.550 TAPIWrap OCX v1.31.0, Apr 14 2003 18:25:46
0418 111922.550 init c:\TapiWrapLogSelect.txt not found. Tracing not enabled.
0418 113122.081 ------------------------------------------------
0418 113122.091 TAPIWrap OCX v1.31.0, Apr 14 2003 18:25:46
0418 113122.091 ------------------------------------------------
ApplEventsLog ...............................
6/19/2003 11:42:48 PM McLogEvent Information None 5000 NT AUTHORITY\SYSTEM A98DEV02 The description for Event ID ( 5000 ) in Source ( McLogEvent ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: 74780, EXTRA.DAT, 0, , VirusScan, 4.2.60, 4272.
6/19/2003 11:42:44 PM SramPerf Information None 2001 N/A A98DEV02 SramPerf.dll has closed the Event Log
6/19/2003 11:42:44 PM SramPerf Error None 2008 N/A A98DEV02 Unable to send the command to stop performance montoring.
6/19/2003 11:42:44 PM SramPerf Error None 2007 N/A A98DEV02 Unable to send the command to start performance montoring.
6/19/2003 11:42:44 PM SramPerf Information None 2000 N/A A98DEV02 SramPerf.dll has opened the Event Log
6/19/2003 11:42:19 PM AnmChannelServer Information None 0 N/A A98DEV02 The description for Event ID ( 0 ) in Source ( AnmChannelServer ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: Service started.
6/19/2003 11:42:19 PM AnmChannelFactoryServer Information None 0 N/A A98DEV02 The description for Event ID ( 0 ) in Source ( AnmChannelFactoryServer ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: Service started.
6/19/2003 11:42:13 PM Kiwi Syslog Daemon Information None 105 N/A A98DEV02 The service was started.
6/19/2003 11:42:11 PM AnmSupplierServer Information None 0 N/A A98DEV02 The description for Event ID ( 0 ) in Source ( AnmSupplierServer ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: Service started.
6/19/2003 11:42:11 PM AnmLoggerServer Information None 0 N/A A98DEV02 The description for Event ID ( 0 ) in Source ( AnmLoggerServer ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: Service started.
SystemEventsLog..........................
6/19/2003 11:42:43 PM dlgc_log Information None 1 N/A A98DEV02 Dialogic System Service started
6/19/2003 11:42:43 PM dlgc_log Warning None 1 N/A A98DEV02 Cannot find Timeslot Requirements file: C:\PROGRA~1\Dialogic\cfg\sctscfg
Exiting timeslot assignment program
6/19/2003 11:42:41 PM dlgc_log Information None 1 N/A A98DEV02 StartDrv.exe: Started device:dxxxB1
6/19/2003 11:42:40 PM dlgc_log Information None 1 N/A A98DEV02 "Dialogic Generic Downloader Version 5.11 (Build 31)
Copyright © 1992-2000 by Dialogic Corp.
System Download ...................................
D/4PCI (PCI ID 0) Download .. BCV Firmware Version 6.53
1 Dialogic Board Successfully Installed
6/19/2003 11:42:24 PM dlgc_log Information None 1 N/A A98DEV02 "CTBBAPI.exe 01.50 bld 3 (release).
CTBB_AddToTDMBus() returned ""CTBB_ERROR_NO_FRU_ATTACHED_TO_TDM_BUS: No FRU in the set specified was attached to the TDM bus"". Ignoring.
0x20000000 : CTBB_ERROR_SUCCESS: Function completed properly.
Exit value : 0x0.
6/19/2003 11:42:23 PM dlgc_log Information None 1 N/A A98DEV02 Dialogic System Service starting
6/19/2003 11:41:51 PM cryp$ Information None 4 N/A A98DEV02 Cryp driver (\Device\CRYP) June 2001 v3.70 (multi-adapter) loaded.
6/19/2003 11:42:13 PM CTBusBroker Warning None 2 N/A A98DEV02 TDM bus user settings were rewritten because of bus configuration failure 0x20000060. This will happen if the resources have changed and is usually not cause for alarm.
6/19/2003 11:42:08 PM EventLog Information None 6005 N/A A98DEV02 The Event log service was started.
6/19/2003 11:42:08 PM EventLog Information None 6009 N/A A98DEV02 Microsoft ® Windows 2000 ® 5.0 2195 Service Pack 3 Uniprocessor Free.
Well, Here is the DAMN problem......
I installed the "Fix" for 4.9.0 to Run After Hangup.
I do not (currently) have anything that I want to run after hangup right now, therefore nothing is specified.
Apparently it is looking for some default file that YOU specified and I get the 53 File Not Found Error.
I installed to older VGMulti.exe (which I had the foresight to save) and it works as before.
I spent HOURS and HOURS on this. Thanks.
... abe
Aha... so it was the installation of that patch which caused the problems....
Yes, there is a problem with that patch... patches are often quick fixes for a specific purpose and not thoroughly tested in all other areas...
I suspect that the file that it was looking for is the one that I attach here, but as it sounds like the system works well without the need for any of the specific patches that were recently released, so I'd suggest not updating the system with any until release of a next point version (v4.9.1).
VgEmailSender_beta1.zip
