Record And Conference
hello i get a d41Epci with registred entreprise and dialer for four lines
conference works well on one module ,but i try to record the conversation during the conference and the module i use dont do thetransfer...
here the trace log for the call that didnt transfer:
102421,95 7 linedevstate 2048 0 0
102421,98 7 callstate OFFERING 66274 0 4
102422,00 7 callinfo CALLEDID
102422,02 7 callinfo ORIGIN
102422,03 7 ring 0
102422,97 0 dial start any summary:|5:idx=0|6:idx=0|7:hc>0|8:idx=0|
102427,97 7 ring 2
102427,97 7 rv clear
102427,98 7 Start without answering the call
102427,98 7 StartLoadedVgs at 30/12/2005 10:24:27, script interpretor VgMulti v5.2.5003 6
102428,00 7 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Call Recorders\lom\}
102428,00 7 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Call Recorders\lom}
102428,02 7 rv lg add [$RV_STARTTIME]{30/12/2005 10:24:27}
102428,03 7 rv lg add [$RV_DEVICEID]{7}
102428,03 7 rv lg add [$RV_CIDNAME]{}
102428,05 7 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
102428,06 7 rv lg add [$RV_CIDNUMBER]{}
102428,08 7 rv lg add [$RV_DNIS]{}
102428,09 7 rv lg add [DNIS]{}
102428,19 7 timer clear
102428,20 7 [Turn Off Silence Detection] Evaluate [0]
102428,22 7 .Eval(0)
102428,23 7 rv ns add [Turn Off Silence Detection_Input]{0}
102428,25 7 rv ns add [Turn Off Silence Detection]{0}
102428,27 7 rv ns add [silenceDetectLvl]{0}
102428,28 7 Eval Expr result:[0] stored in $RV[silenceDetectLvl]
102428,30 7 SilenceDetectSet(7, 30, 0)
102428,31 7 path {0} not found
102428,33 7 timer clear
102428,36 7 [Record Coversation] Recording
102428,39 7 lineAnswer(66274) => 65915
102428,94 7 callstate CONNECTED 66274 1 0
102428,95 7 callstate CONNECTED 66274,1,0
102428,97 7 WorkingModeTAPI@Connected=
102428,98 7 WorkingModeScript@Connected=BeforeAnswerRun
102429,02 7 Inband detection not enabled
102429,03 7 tapi Reply (LineEvReply) ok 65915 0
102429,06 7 timer clear
102429,08 7 [Record Coversation] Recording
102429,08 7 rv replace start: [$RV_CALLEDNUMBER_$RV_MM$RV_DD_$RV_HH$RV_NN$RV_SS.wav]
102429,13 7 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Call Recorders\lom\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Call Recorders\lom}[$RV_STARTTIME]{30/12/2005 10:24:27}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[Turn Off Silence Detection_Input]{0}[Turn Off Silence Detection]{0}[silenceDetectLvl]{0}
102429,14 7 rv replace end: [_1230_102429.wav]
102429,16 7 rv lg add [Record Coversation]{C:\Program Files\VoiceGuide\Scripts\Call Recorders\lom\_1230_102429.wav}
102429,31 7 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Call Recorders\lom\_1230_102429.wav] ok
102429,33 7 eng RecSoundStart [C:\Program Files\VoiceGuide\Scripts\Call Recorders\lom\_1230_102429.wav]
102429,34 7 timer set 3600 EV_TIMEOUT_GOTOMODULE
102429,38 7 callinfo MONITORMODES
102432,34 7 monitortone 1
102432,36 7 Not reacting to Dialogic silence detect as iSilenceDetectLvl<=0
102450,58 7 monitortone 1
102450,59 7 Not reacting to Dialogic silence detect as iSilenceDetectLvl<=0
102458,41 7 callstate DISCONNECTED 66274 0 0
102458,42 7 ScriptEventCode 9250 iLineState=1201
102458,44 7 LsRecRecording EV_REMOTEPARTY_DISCONNECT
102458,53 7 RecSoundStopTruncBytes ok
102458,55 7 rec length RV: Record Coversation_RecLen100ms = 292
102458,56 7 rv lg add [Record Coversation_RecLen100ms]{292}
102458,58 7 rv lg add [Record Coversation_EndRecCause]{disconnect}
102458,59 7 rv lg add [Hangup Time]{30/12/2005 10:24:58}
102458,61 7 Hanging up call... [During LsRecRecording]
102458,67 7 RecSoundStop ok
102458,70 7 PlaySoundStop err=0
102458,72 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
102458,77 7 fnHangupCall end
102458,86 7 ScriptEventCode 8003 iLineState=900
102458,86 7 LsAwaitingCalls EV_REC_FINISHED
102458,89 7 linedevstate 2048 0 0
102458,91 7 callstate IDLE 66274 0 0
102458,92 7 WorkingMode@Idle=
102458,94 7 timer clear
102458,97 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
102458,98 7 tapi Reply (LineEvReply) ok 65813 0
102500,02 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
102500,02 7 ScriptEventCode 9008 iLineState=900
102500,05 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
102500,05 7 ReinitTelephony due to IDLE
102500,11 7 tapic lineDeallocateCall(MainCall:66274) 0
102500,36 7 lineOpen(7)=>
102500,38 7 Waiting for a call...
102500,39 7 LineHandle=66171
102500,41 7 amchk set AMdet=False in Reinit@idle
102500,42 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
102501,13 0 dial start any summary:|5:idx=0|6:idx=0|7:rdy=0|8:idx=0|
102503,72 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
102503,73 7 ScriptEventCode 9013 iLineState=900
102504,19 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:idx=0|
103136,97 0 sys cleanup Start
103136,97 0 sys cleanup End
thanks
Dial_And_Record.vgs
First you should switch to using VG for Dialogic.
Then in your script you should do a transfer first, and then do a record.
should i use the upgrade section at 399$ ? for entrepise for lines with dialer ?
If you are currently using v5.x license then you can use this license to register VG for Dialogic. No need to upgrade.
i use 5.2.5003 so i need to reinstall all or just add the patch for dialogic?
very thanks
can you provide a link
everything is o k i get the creditcard script but i open the config file with internet explorer ? and i wasnt able to change the settings of scripts
very thanks
