Transfer Call
Using handset when I receive a call, I press "flash" button, and it prompts me to press 1 to transfer to an extension, I press extension 1234.
How am I supposed to do this thing in Voice Guide.
Do I need to put 1 before the extension?
Thanks in advance. I still have no clue how to make it work.
Here is the trace window
=================== thanks for help.
161253.94 1 event callstate OFFERING 1 2,0,0
161253.96 1 script interpretor: VgMulti v6.0.2322
161253.96 1 fired OFFERING event to listeners
161253.96 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
161253.98 1 cid CallerID vars set (in 'offering' event) [,,]
161253.98 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
161253.00 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
161254.01 1 tw ring 1
161254.02 1 ring time since last ring event (sec): 0.00
161254.03 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
161254.04 1 answer as number of rings reached
161254.05 1 rv clear all
161254.05 1 init LineState ResetAtStartOfNewCall.
161254.07 1 answer the call
161254.09 1 timer clear
161254.14 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
161254.14 1 event ScriptEventCode TDX_CST, code=134, state=6001
161254.81 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
161254.82 1 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
161254.84 1 event callstate CONNECTED 1 256,0,0
161254.86 1 LineEvCallState_Connected hDevice=1 params=256,0,0
161254.87 1 WorkingModes tapi= script= LineState().iState=6001
161255.97 1 Inband detection not enabled
161255.00 1 StartLoadedVgs at 12/22/2005 4:12:55 PM [VgMulti v6.0.2322]
161256.02 1 set LineState().iVgsIdx=5
161256.04 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
161256.06 1 init StartLoadedVgs_InitLineState start
161256.08 1 rv add [$RV_STARTTIME]{12/22/2005 4:12:55 PM}
161256.10 1 rv add [$RV_DEVICEID]{1}
161256.12 1 rv add [$RV_CIDNAME]{}
161256.14 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
161256.16 1 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Efmark IVR\}
161256.19 1 rv add [$RV_CIDNUMBER]{}
161256.21 1 fn RunModule start
161256.23 1 tw DialogicEvent 134,TDX_CST,13013,0,0,DE_LCON,,
161256.26 1 event ScriptEventCode TDX_CST, code=134, state=6001
161256.42 1 timer clear
161256.44 1 state [Get IVR Code] Number Input
161256.47 1 state [Get IVR Code] Playing (Welcome.wav, EnterUserID.wav)
161256.50 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.wav,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.wav
161256.53 1 timer clear
161256.59 1 tw wav->vox convert end 580095,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,,
161256.64 1 play start ok, lPlayId=580215
161304.10 1 tw dtmf 0 (1,48,48)
161304.13 1 event ScriptEventCode 0, code=48, state=1300
161304.16 1 LsGetNbrsPlayWelcMsg 0,0
161304.28 1 play PlaySoundStop ok
161304.35 1 state [Get IVR Code] Number Input 0
161304.42 1 rv add [Get IVR Code]{0}
161304.48 1 rvns add [Get IVR Code_PathTaken]{0}
161304.55 1 fn RunModule start
161304.62 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
161304.69 1 event ScriptEventCode TDX_CST, code=134, state=6001
161304.76 1 tw PlayEnd 1 580215
161304.83 1 play end id=580215, (current ID)
161304.90 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001
161304.97 1 tw DialogicEvent 129,TDX_PLAY,580215,0,0,,,
161305.04 1 event ScriptEventCode TDX_PLAY, code=129, state=6001
161305.27 1 timer clear
161305.35 1 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
161305.72 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
161305.79 1 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
161305.86 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
161305.93 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
161306.01 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec)
161306.08 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
161306.16 1 state [Operator] Blind Hookflash Transfer to 356
161306.49 1 tw PlayEnd 1 0
161306.57 1 play end id=0, (current ID)
161306.64 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902
161306.72 1 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
161306.80 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
161306.88 1 event ScriptEventCode TDX_DIAL, code=132, state=1902
161306.95 1 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
161307.04 1 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
161307.11 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
161309.13 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
161309.20 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
161309.28 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
161309.35 1 Dial(356cp off) call
161309.54 1 Dial(356) ok
161309.62 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
161309.96 1 tw PlayEnd 1 0
161310.03 1 play end id=0, (current ID)
161310.11 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1903
161310.19 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 8001,EV_PLAY_FINISHED,0,0,0,,,
161310.27 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
161310.35 1 event ScriptEventCode TDX_DIAL, code=132, state=1903
161310.43 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 132,TDX_DIAL,0,0,0,,,
161310.50 1 LsXfer_3 TDX_DIAL on a XT_HOOK_BLIND
161310.58 1 rv add [Hangup Time]{12/22/2005 4:13:10 PM}
161310.66 1 state Hanging up call... [LsXfer_3]
161310.74 1 HangupCall_Common hCall=1
161310.83 1 rec RecSoundStop ok
161310.91 1 play PlaySoundStop ok
161310.99 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
161311.07 1 fnHangupCall end
161311.21 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
161311.29 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900
161311.37 1 LsAwaitingCalls EV_UNKNOWN_135
161311.45 1 event callstate IDLE 1 1,0,0
161311.54 1 WorkingMode@Idle=
161311.62 1 timer clear
161311.70 1 rec RecSoundStop ok
161311.79 1 play PlaySoundStop ok
161311.87 1 rv add [CallEndTime]{12/22/2005 4:13:11 PM}
161311.96 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
161312.95 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
161313.03 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
161313.11 1 init atidle reinit : start
161313.19 1 init atidle reinit iConferenceOtherLegLid=-1
161313.28 1 init atidle reinit : reset all LineState variables
161313.36 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
161313.45 1 state Waiting for a call...
161313.86 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
161313.93 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
161603.65 0 load start [C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Efivr.vgs]
161603.67 0 MemStructVgs_ClearVgs [1]
161608.91 0 load end
161608.98 0 loaded Script Id 1: C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Efivr.vgs
161609.54 0 Erasing Script (new loaded) Id 5
161609.64 0 VgsScriptFree [5]
161609.74 0 MemStructVgs_ClearVgs [5]
161617.37 1 event callstate OFFERING 1 2,0,0
161617.47 1 script interpretor: VgMulti v6.0.2322
161617.56 1 fired OFFERING event to listeners
161617.65 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
161617.75 1 cid CallerID vars set (in 'offering' event) [,,]
161617.84 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
161617.93 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
161618.03 1 tw ring 1
161618.12 1 ring time since last ring event (sec): 0.00
161618.22 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
161618.31 1 answer as number of rings reached
161618.41 1 rv clear all
161618.50 1 init LineState ResetAtStartOfNewCall.
161618.59 1 answer the call
161618.69 1 timer clear
161618.80 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
161618.90 1 event ScriptEventCode TDX_CST, code=134, state=6001
161619.49 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
161619.58 1 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
161619.68 1 event callstate CONNECTED 1 256,0,0
161619.77 1 LineEvCallState_Connected hDevice=1 params=256,0,0
161619.87 1 WorkingModes tapi= script= LineState().iState=6001
161621.04 1 Inband detection not enabled
161621.14 1 StartLoadedVgs at 12/22/2005 4:16:21 PM [VgMulti v6.0.2322]
161621.24 1 set LineState().iVgsIdx=1
161621.34 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
161621.43 1 init StartLoadedVgs_InitLineState start
161621.54 1 rv add [$RV_STARTTIME]{12/22/2005 4:16:21 PM}
161621.63 1 rv add [$RV_DEVICEID]{1}
161621.72 1 rv add [$RV_CIDNAME]{}
161621.82 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
161621.93 1 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Efmark IVR\}
161622.02 1 rv add [$RV_CIDNUMBER]{}
161622.11 1 fn RunModule start
161622.21 1 tw DialogicEvent 134,TDX_CST,18824,0,0,DE_LCON,,
161622.32 1 event ScriptEventCode TDX_CST, code=134, state=6001
161622.57 1 timer clear
161622.68 1 state [Get IVR Code] Number Input
161622.77 1 state [Get IVR Code] Playing (Welcome.wav, EnterUserID.wav)
161622.87 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.wav,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.wav
161622.96 1 timer clear
161623.11 1 tw wav->vox convert end 786461,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,,
161623.24 1 play start ok, lPlayId=786802
161632.51 1 tw dtmf 0 (1,48,48)
161632.61 1 event ScriptEventCode 0, code=48, state=1300
161632.71 1 LsGetNbrsPlayWelcMsg 0,0
161632.83 1 play PlaySoundStop ok
161632.93 1 state [Get IVR Code] Number Input 0
161633.02 1 rv add [Get IVR Code]{0}
161633.12 1 rvns add [Get IVR Code_PathTaken]{0}
161633.23 1 fn RunModule start
161633.33 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
161633.43 1 event ScriptEventCode TDX_CST, code=134, state=6001
161633.52 1 tw PlayEnd 1 786802
161633.62 1 play end id=786802, (current ID)
161633.72 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001
161633.82 1 tw DialogicEvent 129,TDX_PLAY,786802,0,0,,,
161633.92 1 event ScriptEventCode TDX_PLAY, code=129, state=6001
161634.19 1 timer clear
161634.29 1 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
161634.69 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
161634.79 1 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
161634.89 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
161634.99 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
161635.09 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec)
161635.20 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
161635.29 1 state [Operator] Announced Hookflash Transfer to 356
161635.80 1 tw PlayEnd 1 0
161635.91 1 play end id=0, (current ID)
161635.00 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902
161636.11 1 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
161636.20 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
161636.30 1 event ScriptEventCode TDX_DIAL, code=132, state=1902
161636.41 1 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
161636.52 1 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
161636.62 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
161638.67 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
161638.77 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
161638.87 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
161638.97 1 Dial(356, cp on) call
161639.20 1 Dial(356) ok
161639.30 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
161710.22 1 timer fired EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
161710.32 1 event ScriptEventCode EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG, code=9021, state=1903
161710.43 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 9021,EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG,0,0,0,,,
161710.54 1 Transfer timed out
161710.64 1 xfer dial !
161711.02 1 tw PlayEnd 1 0
161711.11 1 play end id=0, (current ID)
161711.23 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1906
161711.34 1 LsXfer_5B : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
161711.44 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
161711.54 1 event ScriptEventCode TDX_DIAL, code=132, state=1906
161711.64 1 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
161711.76 1 sXferDialResult_SuccOrFail=
161711.86 1 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=timeout (2)= (3)=
161711.96 1 path 'timeout' not found
161712.07 1 XferGoDownSpecifiedPath: going down False path (iXferType=13)
161712.17 1 fn RunModule start
161712.44 1 timer clear
161712.54 1 state [Get IVR Code] Number Input
161712.64 1 state [Get IVR Code] Playing (Welcome.wav, EnterUserID.wav)
161712.75 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.wav,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.wav
161712.86 1 timer clear
161712.00 1 tw wav->vox convert end 836343,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,,
161713.13 1 play start ok, lPlayId=836694
161723.97 1 tw dtmf 0 (1,48,48)
161724.07 1 event ScriptEventCode 0, code=48, state=1300
161724.18 1 LsGetNbrsPlayWelcMsg 0,0
161724.30 1 play PlaySoundStop ok
161724.41 1 state [Get IVR Code] Number Input 0
161724.52 1 rv add [Get IVR Code]{0}
161724.63 1 rvns add [Get IVR Code_PathTaken]{0}
161724.73 1 fn RunModule start
161724.84 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
161724.95 1 event ScriptEventCode TDX_CST, code=134, state=6001
161725.05 1 tw PlayEnd 1 836694
161725.16 1 play end id=836694, (current ID)
161725.26 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001
161725.37 1 tw DialogicEvent 129,TDX_PLAY,836694,0,0,,,
161725.48 1 event ScriptEventCode TDX_PLAY, code=129, state=6001
161725.73 1 timer clear
161725.85 1 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
161726.25 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
161726.35 1 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
161726.45 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
161726.56 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
161726.66 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec)
161726.77 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
161726.87 1 state [Operator] Announced Hookflash Transfer to 356
161727.38 1 tw PlayEnd 1 0
161727.48 1 play end id=0, (current ID)
161727.59 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902
161727.70 1 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
161727.81 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
161727.91 1 event ScriptEventCode TDX_DIAL, code=132, state=1902
161728.02 1 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
161728.13 1 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
161728.24 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
161730.29 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
161730.40 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
161730.51 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
161730.62 1 Dial(356, cp on) call
161730.86 1 Dial(356) ok
161730.96 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
161802.15 1 timer fired EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
161802.26 1 event ScriptEventCode EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG, code=9021, state=1903
161802.36 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 9021,EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG,0,0,0,,,
161802.47 1 Transfer timed out
161802.58 1 xfer dial !
161803.03 1 tw PlayEnd 1 0
161803.14 1 play end id=0, (current ID)
161803.25 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1906
161803.36 1 LsXfer_5B : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
161803.51 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
161803.61 1 event ScriptEventCode TDX_DIAL, code=132, state=1906
161803.73 1 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
161803.84 1 sXferDialResult_SuccOrFail=
161803.95 1 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=timeout (2)= (3)=
161804.06 1 path 'timeout' not found
161804.17 1 XferGoDownSpecifiedPath: going down False path (iXferType=13)
161804.28 1 fn RunModule start
161804.48 1 timer clear
161804.59 1 state [Get IVR Code] Number Input
161804.70 1 state [Get IVR Code] Playing (Welcome.wav, EnterUserID.wav)
161804.82 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.wav,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.wav
161804.93 1 timer clear
161805.17 1 tw wav->vox convert end 888418,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,,
161805.45 1 play start ok, lPlayId=889009
161817.26 1 tw PlayEnd 1 889009
161817.39 1 play end id=889009, (current ID)
161817.51 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1300
161817.63 1 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
161817.74 1 path {EV_PLAY_FINISHED} not found
161817.85 1 timer set 10 EV_TIMEOUT_HANGUP
161817.96 1 timer set 6 EV_TIMEOUT_ENTERDATA
161818.07 1 tw DialogicEvent 129,TDX_PLAY,889009,0,0,,,
161818.18 1 event ScriptEventCode TDX_PLAY, code=129, state=1301
161818.29 1 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
161818.40 1 path {TDX_PLAY} not found
161819.81 1 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,DISCONNECT_TAPI1,
161819.93 1 event ScriptEventCode DISCONNECT_TAPI1, code=134, state=1301
161820.04 1 LsGetNbrsRxDigits EV_UNKNOWN_134,DISCONNECT_TAPI1
161820.14 1 path {DISCONNECT_TAPI1} not found
161820.25 1 rv add [Hangup Time]{12/22/2005 4:18:20 PM}
161820.36 1 state Hanging up call... [Default Handler 20: DISCONNECT_TAPI1]
161820.48 1 HangupCall_Common hCall=1
161820.59 1 rec RecSoundStop ok
161820.70 1 play PlaySoundStop ok
161820.82 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
161820.93 1 fnHangupCall end
161821.05 1 event ScriptEventCode TDX_CST, code=134, state=900
161821.16 1 LsAwaitingCalls EV_UNKNOWN_134
161821.27 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
161821.39 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900
161821.52 1 LsAwaitingCalls EV_UNKNOWN_135
161821.65 1 event callstate IDLE 1 1,0,0
161821.78 1 WorkingMode@Idle=
161821.90 1 timer clear
161822.03 1 rec RecSoundStop ok
161822.16 1 play PlaySoundStop ok
161822.28 1 rv add [CallEndTime]{12/22/2005 4:18:22 PM}
161822.40 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
161823.43 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
161823.53 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
161823.65 1 init atidle reinit : start
161823.76 1 init atidle reinit iConferenceOtherLegLid=-1
161823.88 1 init atidle reinit : reset all LineState variables
161824.01 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
161824.12 1 state Waiting for a call...
161824.53 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
161824.63 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
161857.09 0 load start [C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Efivr.vgs]
161857.12 0 MemStructVgs_ClearVgs [5]
161901.05 0 load end
161901.09 0 loaded Script Id 5: C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Efivr.vgs
161901.31 0 Erasing Script (new loaded) Id 1
161901.34 0 VgsScriptFree [1]
161901.36 0 MemStructVgs_ClearVgs [1]
I changed to use PBX hookflash Blind, transfer is done, but it is not transfered.
When i use handset I need press 1 before enter extension, where do I tell "1" is the key before extension is pressed.
???? thanks.
164041.88 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
164043.94 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
164044.05 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
164044.16 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
164044.27 1 Dial(356cp off) call
164044.39 1 Dial(356) ok
164044.50 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
164044.79 1 tw PlayEnd 1 0
164044.90 1 play end id=0, (current ID)
164045.02 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1903
164045.13 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 8001,EV_PLAY_FINISHED,0,0,0,,,
164045.25 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
164045.36 1 event ScriptEventCode TDX_DIAL, code=132, state=1903
164045.48 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 132,TDX_DIAL,0,0,0,,,
164045.59 1 LsXfer_3 TDX_DIAL on a XT_HOOK_BLIND
164045.71 1 rv add [Hangup Time]{12/22/2005 4:40:45 PM}
164045.82 1 state Hanging up call... [LsXfer_3]
Sounds like you should be specifying 1 as the first digit, followed by the extension. You may want to use pause between the 1 and the extension, eg:
1,356
I tried 1,356 and it beeps 1, quickly followed by 356, then LsXfer_3 shows in VG line state, and it hangs up.
I tried monitored hookflash, no luck.
Is there any configuration anywhere I need to change anything to make this work?
It now works only in handset.
Thanks.
Kevin
I am using windows 2003 server Dialogic card 4PCIU
I tried the following options to no avail.
,1,356,,
1,,356
what else can be done to make this work? The project is overdue and the customer is waiting......and this is holiday season, no one is working ...?
154130.73 1 timer clear
154130.82 1 tw wav->vox convert end 94280,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\Welcome.vox,C:\Program Files\VoiceGuide\Scripts\Efmark IVR\EnterUserID.vox,1,0,,
154130.00 1 play start ok, lPlayId=94450
154137.54 1 tw dtmf 0 (1,48,48)
154137.57 1 event ScriptEventCode 0, code=48, state=1300
154137.59 1 LsGetNbrsPlayWelcMsg 0,0
154137.63 1 play PlaySoundStop ok
154137.66 1 state [Get IVR Code] Number Input 0
154137.68 1 rv add [Get IVR Code]{0}
154137.70 1 rvns add [Get IVR Code_PathTaken]{0}
154137.70 1 fn RunModule start
154137.75 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
154137.79 1 event ScriptEventCode TDX_CST, code=134, state=6001
154137.80 1 tw PlayEnd 1 94450
154137.82 1 play end id=94450, (current ID)
154137.84 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001
154137.86 1 tw DialogicEvent 129,TDX_PLAY,94450,0,0,,,
154137.89 1 event ScriptEventCode TDX_PLAY, code=129, state=6001
154138.05 1 timer clear
154138.09 1 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
154138.46 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
154138.48 1 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
154138.51 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
154138.54 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
154138.57 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec)
154138.60 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
154138.64 1 state [Operator] Blind Hookflash Transfer to 1,,2,6,0,,
154138.93 1 tw PlayEnd 1 0
154138.95 1 play end id=0, (current ID)
154138.00 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902
154139.02 1 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
154139.05 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
154139.08 1 event ScriptEventCode TDX_DIAL, code=132, state=1902
154139.10 1 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
154139.13 1 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
154139.16 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
154141.17 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
154141.20 1 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
154141.23 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
154141.26 1 Dial(1,,2,6,0,,cp off) call
154141.29 1 Dial(1,,2,6,0,,) ok
154141.32 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
154147.90 1 tw PlayEnd 1 0
154147.92 1 play end id=0, (current ID)
154147.95 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1903
154147.97 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 8001,EV_PLAY_FINISHED,0,0,0,,,
154148.00 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
154148.03 1 event ScriptEventCode TDX_DIAL, code=132, state=1903
154148.06 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 132,TDX_DIAL,0,0,0,,,
154148.08 1 LsXfer_3 TDX_DIAL on a XT_HOOK_BLIND
154148.12 1 rv add [Hangup Time]{12/23/2005 3:41:48 PM}
154148.16 1 state Hanging up call... [LsXfer_3]
154148.19 1 HangupCall_Common hCall=1
154148.22 1 rec RecSoundStop ok
154148.25 1 play PlaySoundStop ok
154148.27 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
154148.30 1 fnHangupCall end
154148.42 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
154148.45 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900
154148.48 1 LsAwaitingCalls EV_UNKNOWN_135
154148.51 1 event callstate IDLE 1 1,0,0
154148.54 1 WorkingMode@Idle=
154148.56 1 timer clear
154148.60 1 rec RecSoundStop ok
154148.64 1 play PlaySoundStop ok
154148.66 1 rv add [CallEndTime]{12/23/2005 3:41:48 PM}
154148.74 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
154149.67 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
154149.70 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
154149.73 1 init atidle reinit : start
154149.76 1 init atidle reinit iConferenceOtherLegLid=-1
154149.78 1 init atidle reinit : reset all LineState variables
154149.81 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
154149.84 1 state Waiting for a call...
154150.19 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
154150.21 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
154159.45 0 sys cleanup Start
154159.51 0 sys cleanup End
