Empty Call Log
I just noticed that my call log file quit recording info. It shows only a <,> after the date and time field. It was logging calls fine before. ?? any way to fix this. I also checked the Excel log file it was the same way.
Dan
Could you please post a copy of VoiceGuide's Debug Printout which captures an incoming call, and the log file (.vgl) as it is after the call which has been captured in the trace completes.
