Vg.play_start
Im using the vbscript module to call vg.play_start with a couple of sound files which is working will.
However, i cant seem to flag to VG when the vg.play_start has finished playing the samples so i can move onto the next module. Voiceguide just stays in the vbscript module, but if i call vg.result_return after the vg.play_start then the system exits the vbscript module immediatly.
Any ideas how to acheive this?
Regards
David
What are you trying to achieve?
Usually there are alternatives to playing sound files from VBScript modules using play_start COM commands.
Ive actually achieved this now using my own formating in .Vbx and then calling the say numbers - worked a treat.
thanks
David
I assume you're referring to modifying the lib_num2wav.vbs file located in VoiceGuide's \system\vbs\ subdirectory (?)
