Dialogic And Vg
I am attempting to evaluate VG with a Dialogic D/4PCI. Simple, straightforward eval. However, the config wizard does not appear to recognize the Dialogic card. The following devices appear:
USR 56k external
RAS VPN Line 0
WAN Miniport (L2TP)
IPCONF LINE
H323 Line
Running the Intel DCM reports that the Dialogic card is green. So.... why can VG not find it? I am running on Windows 2000 on a Compaq DL380.
Thanks.
avi.deitcher@db.com
The Dialogic TAPI and Wave drivers need to be set up before TAPI programs like VoiceGuide or Dialogic's Talker32 will see the board.
Please follow the instructions provided in VoiceGuide Help file section: "Configuring VoiceGuide -> Dialogic TAPI/Wave Drivers"
The relevant section from the Help file can also be found here:
http://www.katalinatech.com/vghelp/html/In...allDialogic.htm
