Call Transfer
Hi ( yet again!)
Can someone help me with the call flow on this example ( im stumped )
At present I have a script (working) that answers calls and does a transfer on every fifth call to a customer services number. Others are just played a message and then dropped.
I need to check how many outbound calls I have on this service - if I have 2 outbounds allready i need to drop the call to the ivr message. I just cant figure out a way to get the number of outbound calls for this service. Sure, i could use a GLobal variable, but i dont understand where i initialise it. I also dont really understand where I would clean up the records to show a call has finished to the customer services.
any ideas?
call flow below:
1. Inbound Call
2. Check inbound ratio ( working )
3. If its the 5th call pass to customer services
4. else play pre-recorded message.
i need to modify section 3 above to say :
3. If its 5th caller AND theres not already 2 calls with customer servicess then
Thanks again.
VG.INI, section [scripts], entry "GlobalRV"
eg:
GlobalRV=[MyCounter1]{5}[MyCounter2]{0}
From within the "Script ran when call is finished".
