Winfax Control
I am using the following vbscript to execute winfax for sending file. But how to set a path for folder and a file name which can be sent through the same script? I wish to use filename and folder to be identified using Result Variable. Please advice on the suitable modification in the vbscript.
<script language="VBScript">
Dim sendObj
Set sendObj = CreateObject("WinFax.SDKSend8.0")
sendObj.SetTypeByName "Fax"
sendObj.ShowSendScreen (0)
sendObj.SetSubject ("Test Faxing")
sendObj.SetCoverText ("Test of cover Page")
sendObj.SetNumber ("172233")
sendObj.AddRecipient
sendObj.Send (1)
sendObj.Done
sendObj.LeaveRunning
</script>
regards
Thanks for the reply. It helpe me to some extent. But then it will only send word document. I wish to send a graph or image also. Can it be doen? Kindly advice
You would need to do your own research into this - you maybe should also look at other faxing packages.
It will be my pleasure to do the ncecessary research. But may I request you to help me in obtaining the SDK of Winfax pro.? Even its demo version please?
