Vg Only Answering Probleme
I am runnibg VG with Win 2000 and it can answer the first call perfectely but does not answer anymore after. I have tried with 2 modems
#1 - my onboard modem HSP56 MR, #2 - PCI modem AOpen FM56-P 56K and does the same thing.
Please help !
:o)
Thanx
Hi thanx for your answer.
This the trace log you have requested:
83804 2 tapie callstate OFFERING 65536 0 4
83804 2 tapie ring 1
89703 2 tapie ring 2
89703 2 Answer the call
89703 2 lineAnswer(65536) => 66526
89713 2 tapie callstate ACCEPTED 65536 0 0
91015 2 tapi Reply 66526 0
91025 2 tapie callstate CONNECTED 65536,0,0
91025 2 WorkingModeTAPI=
91025 2 WorkingModeScript=
91025 2 Inband detection not enabled
91065 2 [Welcome] Number Input
91065 2 [Welcome] Playing (VmailSysWelc.wav)
91165 2 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail Server\VmailSysWelc.wav]
03162 2 Play End line[2] (id=991065)
03162 2 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
06607 2 tapie monitordigits 48 2
06607 2 LsGetNbrsRxDigits [0]
06617 2 [Welcome] Number Input 0
07328 2 tapie monitordigits 48 2
07328 2 LsGetNbrsRxDigits [0]
07338 2 [Welcome] Number Input 00
08169 2 tapie monitordigits 48 2
08169 2 LsGetNbrsRxDigits [0]
08169 2 [Welcome] Number Input 000
09401 2 tapie monitordigits 49 2
09401 2 LsGetNbrsRxDigits [1]
09401 2 [Welcome] Number Input 0001
09411 2 RVreplace start: [{Success}[Voicemail Box $RV[Welcome]][Welcome]{Fail}[Voicemail Retrieve]]
09411 2 RVreplace end: [{Success}[Voicemail Box 0001][Welcome]{Fail}[Voicemail Retrieve]]
09421 2 RVreplace start: [Voicemail Box $RV[Welcome]]
09421 2 RVreplace end: [Voicemail Box 0001]
09431 2 [0001] Playing Welcome Message
09561 2 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\VmbWelcomeMsgDefault.wav]
09571 2 [0001] Play welcome message
12435 2 Play End line[2] (id=9481)
12445 2 LsVmLm_PlayWelc EV_PLAY_FINISHED
12515 2 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
12896 2 Play End line[2] (id=12455)
12906 2 LsVmLm_PlayWelc_Beep EV_PLAY_FINISHED
12966 2 RecSoundStart file[C:\Program Files\VoiceGuide\data\VmSave\0001_0618124608_1_2_.wav] ok
12976 2 [0001] Recording Message
23972 2 LsVmLm_Rec EV_SILENCE_DETECTED
23982 2 Silence Detected
24012 2 LsVmLm_Rec EV_REC_FINISHED
24042 2 HangupCall called from [srvm]
24042 2 Hanging up call...
24042 2 PlaySoundStop ok
24052 2 fnHangupCall end
24743 2 tapie callstate DISCONNECTED 65536,1,0
24753 2 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
24753 2 PlaySoundStop ok
24753 2 HangupCall called from []
24763 2 Hanging up call...
24763 2 PlaySoundStop ok
24773 2 fnHangupCall end
24783 2 tapie callstate IDLE 65536 0 0
24783 2 WorkingMode@Idle=
24873 2 set EV_TIMEOUT_TIMETOREINITLINE 2
24873 2 tapi Reply 66475 0
24883 2 tapi Reply 66492 0
25785 2 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
25785 2 ReinitTelephony due to IDLE start
25805 2 tapic lineDeallocateCall(MainCall:65536) 0
26415 2 lineOpen(2) => 0
26425 2 Waiting for a call...
26425 2 lineOpen(2)LineHandle=66441
Thank you again abd have a nice day :o) !
General X
I presume the trace is for the first call - and all looks fine there... is there anything displayed in the event trace when the second call arrives?
On the second call, the trace log stands still and does notings else.
Here is a new trace log from this morning test.
I called twice...
05640 2 tapie callstate OFFERING 65740 0 4
05640 2 tapie ring 1
11528 2 tapie ring 2
11528 2 Answer the call
11528 2 lineAnswer(65740) => 65706
11538 2 tapie callstate ACCEPTED 65740 0 0
12850 2 tapi Reply 65706 0
12860 2 tapie callstate CONNECTED 65740,0,0
12860 2 WorkingModeTAPI=
12860 2 WorkingModeScript=
12860 2 Inband detection not enabled
12890 2 [Welcome] Number Input
12890 2 [Welcome] Playing (VmailSysWelc.wav)
12990 2 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Voicemail Server\VmailSysWelc.wav]
24987 2 Play End line[2] (id=412900)
24997 2 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
27281 2 tapie monitordigits 48 2
27281 2 LsGetNbrsRxDigits [0]
27291 2 [Welcome] Number Input 0
28032 2 tapie monitordigits 48 2
28042 2 LsGetNbrsRxDigits [0]
28042 2 [Welcome] Number Input 00
28743 2 tapie monitordigits 48 2
28753 2 LsGetNbrsRxDigits [0]
28753 2 [Welcome] Number Input 000
29945 2 tapie monitordigits 49 2
29945 2 LsGetNbrsRxDigits [1]
29955 2 [Welcome] Number Input 0001
29955 2 RVreplace start: [{Success}[Voicemail Box $RV[Welcome]][Welcome]{Fail}[Voicemail Retrieve]]
29965 2 RVreplace end: [{Success}[Voicemail Box 0001][Welcome]{Fail}[Voicemail Retrieve]]
29975 2 RVreplace start: [Voicemail Box $RV[Welcome]]
29975 2 RVreplace end: [Voicemail Box 0001]
29985 2 [0001] Playing Welcome Message
30115 2 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\VmbWelcomeMsgDefault.wav]
30125 2 [0001] Play welcome message
32989 2 Play End line[2] (id=430035)
32999 2 LsVmLm_PlayWelc EV_PLAY_FINISHED
33079 2 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
33460 2 Play End line[2] (id=433019)
33470 2 LsVmLm_PlayWelc_Beep EV_PLAY_FINISHED
33540 2 RecSoundStart file[C:\Program Files\VoiceGuide\data\VmSave<!--POST BOX-->01_0619125742_1_2_.wav] ok
33540 2 [0001] Recording Message
42543 2 tapie monitortone 0
44546 2 LsVmLm_Rec EV_SILENCE_DETECTED
44556 2 Silence Detected
44586 2 LsVmLm_Rec EV_REC_FINISHED
44606 2 HangupCall called from [srvm]
44616 2 Hanging up call...
44616 2 PlaySoundStop ok
44626 2 fnHangupCall end
45327 2 tapie callstate DISCONNECTED 65740,1,0
45327 2 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
45337 2 PlaySoundStop ok
45337 2 HangupCall called from []
45347 2 Hanging up call...
45347 2 PlaySoundStop ok
45357 2 fnHangupCall end
45357 2 tapie callstate IDLE 65740 0 0
45367 2 WorkingMode@Idle=
45427 2 set EV_TIMEOUT_TIMETOREINITLINE 2
45437 2 tapi Reply 65689 0
45437 2 tapi Reply 65672 0
46348 2 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
46348 2 ReinitTelephony due to IDLE start
46378 2 tapic lineDeallocateCall(MainCall:65740) 0
46989 2 lineOpen(2) => 0
46999 2 Waiting for a call...
46999 2 lineOpen(2)LineHandle=65655
Thanx
Looks like on the second call this modem does not even report that it is detecting an incoming RING - the only course of action that I can suggest is to try downloading the modem's latest drivers from the manufacturer and reinstalling your modem.
If that does not work then I would suggest trying to use the modem(s) on a different PC...
