Using Return Variable From Vb Script
Hi there,
I have a VBS module in my script with the code below:
MODULE: vbGetEffectiveDate
' Declare and Set our variables
Dim strDate
' Set our date based on the Result Variable
If $RV[modMakeEffective] = 1 Then
strDate = Now()
ElseIf $RV[modMakeEffective] = 2 Then
strDate = DateAdd("d", 1, Now())
End If
' Clean up our control characters
strDate = Mid(strDate, 1, InStr(strDate, " ")-1)
' Return our result and deallocate
vg.RvSet($RV_LINEID, "EffectiveDate", strDate)
set vg = Nothing
I would like to know how do I use my result variable in another module. Like I'm using it in another Update statement can I do it like this?
MODULE: modUpdateStatus
Update MessageEvent Set EndDate='$RV[EffectiveDate]', ModDateTime='$RV_MM/$RV_DD/$RV_YY' Where OrgID=$RV[modGetID] And intMsgSourceID=2
Yes, all this should work.
$RV[EffectiveDate] will be replaced by the value specified in strDate
I've tried everything and it's still returning a blank within my query string. It's not working. Any other suggestions ??
Could you please post your script and a copy of VoiceGuide's Debug Printout which captures the call, this will allow us to see what happened.
When posting traces please .ZIP them up and post them as attachments.
Ok, I've simplified the script to narrow the problem. I'm still having no luck. I've rebooted the server and I'm still getting nothing. Please keep me posted. I've attached the zip file with my scripts and logs.
OPENS.zip
The Trace Log did not contain much info. Please set trace level to 9 and then make another test call.
Guys, I went ahead and set the level to 9 on the trace log as you requested. I've attached the latest version. I'm still getting a vbError on Line 5 Col 5 on the frist vbModule. I've imported my code to VS.Net to make sure there is no malformed syntax. Please let me know what you come up with.
USViking_Trace_Log.txt
Guys, I figured out why the VBScript was not working properly. After setting the Trace Log Level to 10, I ran through the log and found this ...
143524.91 1 cl RvSet EffectiveDate, 12/7/2005
143524.92 1 ERROR: COM interface not supported in this version.
Although my code works, it seems that my version of VoiceGuide doesn't support VBScripting. But hence raises the question, why give me a VBScript editor if VBScript is not supported in my version? Hmmmmmmmm ???
Thank you again for all your time and effort on this matter. I really appreciate it. I'll look into having our company get the version that supports VBScripting.
Hey Guys, I wrote a solution below. Since my basic version of VoiceGuide doesn't support COM objects - which means I'm unable to create $RV[xxxx] programatically, I went ahead and did my VBScript below including writing to the SQL database. But you must keep in mind, because COM isn't supported, I would set the Path's property to:
on {fail} goto [modThankYou]
See in this way I get to update/insert into my database using VBScripting and then when VoiceGuide can't proceed to the next module, because COM isn't supported, it will fail, then I simply tell it "Thank You", because now I know my database has been updated.
Script below:
' This script was designed by Joseph Jagrup
' For USViking LLC 12/05/2005
Dim strDate
Dim strQuery
strDate = Now()
End If
' If the Organization already have an event in our database then
' Update it, else Insert an event
If $RV[modExists_RowCount] > 0 Then
strQuery = "Update MessageEvent Set EndDate='" & strDate & "', ModDateTime='$RV_MM/$RV_DD/$RV_YY' Where OrgID=$RV[modGetID] And intMsgSourceID=2"
ElseIf $RV[modExists_RowCount] = 0 Then
strQuery = "Insert Into MessageEvent (EndDate, ModDateTime) Values ('" & strDate & "', '$RV_MM/$RV_DD/$RV_YY $RV_HH:$RV_NN:$RV_SS')"
End If
' Open our SQL connection and exectue our query
set cn = CreateObject("ADODB.Connection")
cn.Open "DSN=myDSN;UID=jagrup;PWD=****;Database=myDb"
cn.Execute strQuery
cn.Close
Set cn = Nothing
A number of different approaches can be used to return data back from a VBScript module or Run Program module.
The easiest way is usually to use the "VGRUNRESULT" result file. Detailed info on this is in the help file's sections on Run Program and Run VBScript.
