Which Isdn Dialogic Card?
Hello!
I have already two cards (D4PCI / D41JCT-LS) working on my system. I have now one ISDN line (with two phone numbers) connected to my Prestige 100IH router and to the D41JCT card, but for some reason that nobody knows when I make a 3-way conference the router locks itself, meaning that I have to restart it after each call.
I wonder if you could recomend me an ISDN dialogic card so that I can get rid of this useless ISDN router, but that this new card won´t introduce new problems.
I don´t think this new card should manage many features. I don´t know the limits of the cards I have now, but the features that I am using now are 3-way conference, call transfer and sending faxes.
Regards
Jose
You should probably look at using "Dial and Conference" instead of 3-way calls...
If 3-way conferencing is not supported by your telephone lines (and it sounds like it isn't) then there is nothing that you can really do about it...
Hello!
Yes, I thought about this "Dial and Conference" service but unfortunately I only have a few available ports in my dialogic cards. Beside, I think we are going to buy a couple of D4PCI cards, but they don´t support "Dial and Conference", right?
I want my application to be as free as possible, meaning that the application will run in any dialogic card without depending on any card.
Well, I am for sure that this service is available at my lines.
Could you recomend me any good ISDN card?
Thank you for your help!
Jose
You will need D/41JCT cards or higher to do 'Dial and Conference'.
If you want portability form site to sire then use Dial and Conference. Getting 3-way transfers to work is a lot more problematic, and many phone companies just do not support 3-way conferences.
There are a few listed on our WWW Recommended Hardware page, but you will not be able to do 3-way or 'Dial and Conference' on BRI ISDN.
You will be able to do 'Dial and Conference' on T1/E1 ISDN.
