Call Hangs After A Few Seconds
My modem is softk56 data fax voice speakerphone with good voice quality. I am testing it from single line and picking up the same receiver to enter number. When I enter any single digit then the modem hangs up. But same script is running on the same modem on a diffferent office PC. Both PCs are having windowsXP. Kindly read the log below and help me please.
LOG is given below
223429.89 0 sys cleanup Start
223429.91 0 sys cleanup End
223453.89 0 callstate OFFERING 66099 0 4
223453.92 0 Start without answering the call
223453.94 0 StartLoadedVgs at 11/10/2005 10:34:53 PM
223453.94 0 AddRVns [scriptsPath]{D:\VoiceGuide\KuanYinScripts\}
223453.95 0 AddRVns [scriptPath]{D:\VoiceGuide\KuanYinScripts}
223453.95 0 rv add [$RV_STARTTIME]{11/10/2005 10:34:53 PM}
223453.95 0 rv add [$RV_DEVICEID]{0}
223453.95 0 rv add [$RV_CIDNAME]{}
223453.95 0 AddRVns [PathApp]{D:\Program Files\VoiceGuide\}
223453.95 0 rv add [$RV_CIDNUMBER]{}
223453.97 0 ring 1
223453.97 0 timer clear
223453.97 0 [Welcome] Number Input
223453.97 0 lineAnswer(66099) => 66082
223453.98 0 callstate ACCEPTED 66099 0 0
223454.03 0 tapi Reply (LineEvReply) ok 66082 0
223454.05 0 callstate CONNECTED 66099 0 0
223454.05 0 callstate CONNECTED 66099,0,0
223454.05 0 WorkingModeTAPI@Connected=
223454.06 0 WorkingModeScript@Connected=BeforeAnswerRun
223454.06 0 Inband detection not enabled
223454.06 0 timer clear
223454.06 0 [Welcome] Number Input
223454.08 0 [Welcome] Playing (d:\VoiceGuide\AmitabhaSoundFiles\SeekDonateUpdate.wav)
223454.08 0 play set playid=552640
223454.39 0 PlaySoundStart ok [d:\VoiceGuide\AmitabhaSoundFiles\SeekDonateUpdate.wav]
223454.39 0 timer clear
223454.39 0 wa(17747,55264000)
223459.44 0 dtmf 1 (66099,49,2)
223459.44 0 ScriptEventCode 49 iLineState=1300
223459.47 0 LsGetNbrsPlayWelcMsg 1
223500.20 0 PlaySoundStop err=0
223500.20 0 [Welcome] Number Input 1
223500.20 0 rv add [Welcome]{1}
223500.23 0 callstate DISCONNECTED 66099 1 0
223500.23 0 ScriptEventCode 9250 iLineState=5900
223500.23 0 rv add [Hangup Time]{11/10/2005 10:35:00 PM}
223500.23 0 Hanging up call... [LsModuleTransition]
223500.25 0 RecSoundStop ok
223500.25 0 PlaySoundStop err=0
223500.25 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
223500.28 0 fnHangupCall end
223500.28 0 ERROR RunModule called while iHangupCalledForThisLine>0 (strWorkingModeScript=)
223500.48 0 callstate IDLE 66099 0 0
223500.48 0 WorkingMode@Idle=
223500.48 0 timer clear
223500.52 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
223500.52 0 tapi Reply (LineEvReply) ok 66065 0
223501.56 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
223501.56 0 ScriptEventCode 9008 iLineState=900
223501.56 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
223501.56 0 ReinitTelephony due to IDLE
223501.56 0 tapic lineDeallocateCall(MainCall:66099) 0
223501.81 0 lineOpen(0)=>
223501.81 0 Waiting for a call...
223501.81 0 LineHandle=66048
223501.81 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
223502.28 0 dial start any summary:|0:rdy=0|
223503.28 0 dial start any summary:|0:rdy=0|
223504.28 0 dial start any summary:|0:rdy=0|
223505.25 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
223505.25 0 ScriptEventCode 9013 iLineState=900
224058.84 0 Unloading Main Window
1110tw.txt
Trace shows modem has reported hearing the Disconnect tone - and informs VoiceGuide that the call has ended.
This is a common problem with 'Soft' and 'Win' modems. The only solution is to try another modem or get a Dialogic card.
Thanks for the reply. But I wonder why it works on a different PC and the same modem. Does it mean that I require to update OS or modem drivers?
Kindly advice.
Is the same phone line plugged into the modem when it is used on another PC?
Was the call made from the same phone?
Updating the OS would not have any effect on how the modem detects disconnect tones, but updating the modem drivers may have an effect.
The modem which worked on a different PC was Intex Internal modem. And the telephone line is different. I will test the case under similar conditions and then report.
