VoiceGuide Questions!
I'm Thinking I can set up a nice equipment for what I need, with 120
lines; so the specific cuestions I have are:
1.- Can the "Voice Guide (Katarina Technologies)
(http://www.voiceguide.com) handle 120 lines as a software?
2.- Does the board: DM/V1200A-4E1 (Intel) Works for 120 lines and if
it works whit no problem whit the "VoiceGuide" Software ?
3.- What else wold I need to integrate these software(VoiceGuide) and
Hardware (DM/V1200A-4E1) (obviously ather than the computer and telefone
lines).
4.- do I need a server? what is a CT Bus? do I ned one of does or does
the board comes whit it?
THANKS GUY!
1.- Can the "Voice Guide handle 120 lines as a software?
Yes.
Yes, that board is fine.
lines).
Nothing else apart from what you mention above.
You can run the system on any computer - whether you choose to use a basic PC (eg DELL SC430) or a Server class PC is up to you.
A CT bus is used to interconnect various cards together. The DMV1200 cards have it - but looks like you would not be using it as it does not sound like you'll have other cards in the system.
