Detect Line Hangup
Hello!
I would like to know if it is possible to detect when a caller hangs up the phone from a VBS module. I am using 3Way Conference Call and I have changed the 3WayMaxTalkTime variable to 5 minutes in the vg.ini file.
The problem is that voiceguide doesn´t hang up the phone until this time is passed. So if the caller or the called person just hangs up voiceguide will wait until this period of time is over.
Is there anyway or any variable that I can check periodically from this VBS module to "see" the status of $RV_LINEID??
Thank you!
Jose
Hello!
I have recorded this disconnect tone, analyzed it with Audacity and configured it in the ConfigLine.xml as you can see in the attached file "1104tw.txt". I am not sure that this disconnect tone is the problem since I have other scripts (about 6 or 7) running on the same cards (D/4PCI and D/41JCT-LS) and voiceguide has no problem to hang up on these when either the caller or the called person just hangs up.
092354,00 0 btn Exit (8 lines)
092354,00 1 line state =900
092354,00 2 line state =0
092354,00 3 line state =0
092354,00 4 line state =900
092354,05 5 line state =0
092354,05 6 line state =0
092354,05 7 line state =0
092354,05 8 line state =0
092354,08 1 state Exiting...
092354,09 2 state Exiting...
092354,09 3 state Exiting...
092354,09 4 state Exiting...
092354,09 5 state Exiting...
092354,09 6 state Exiting...
092354,09 7 state Exiting...
092354,11 8 state Exiting...
092355,17 0 exit closing all channels start
092355,63 0 exit close dxxxB1C1(1)=> []
092355,67 0 exit close dxxxB1C2(2)=> []
092355,70 0 exit close dxxxB1C3(3)=> []
092355,70 0 exit close dxxxB1C4(4)=> []
092355,73 0 exit close dxxxB2C1(5)=> []
092355,75 0 exit close dxxxB2C2(6)=> []
092355,75 0 exit close dxxxB2C3(7)=> []
092355,75 0 exit close dxxxB2C4(8)=> []
092355,77 0 exit closing all channels end
092357,58 0 ---------------------------------------------------
092357,58 0 Stopping VoiceGuide (Dialogic) start
092357,63 0 v6.0.2304
092357,63 0 Stopping VoiceGuide (Dialogic) end
092357,63 0 ---------------------------------------------------
092407,80 0 ---------------------------------------------------
092407,94 0 VoiceGuide for Dialogic
092407,94 0 v6.0.2304
092407,94 0 ---------------------------------------------------
092408,11 0 rv global loaded >>><<<
092408,34 0 cti Inband Signaling Config file not specified
092433,20 0 ---------------------------------------------------
092433,28 0 VoiceGuide for Dialogic
092433,28 0 v6.0.2304
092433,28 0 ---------------------------------------------------
092433,45 0 rv global loaded >>><<<
092433,67 0 cti Inband Signaling Config file not specified
092434,98 0 init ApiMode=[DialogicGC]
092435,16 0 vm loading VMB data begin
092435,17 0 vm loading VMB data - about to delete old entries
092435,25 0 vm loading VMB data - sorting/ordering
092435,25 0 vm loading VMB data end
092435,25 0 dial DbConnectString_ADO is blank
092435,73 0 init DB Workspaces
092435,83 0 init Voicemail LoadIniSettings
092435,86 0 init read Config.xml start
092435,88 0 dxxxB1C1 dxxxB1C1 C:\Voice\PetDirekt\petdirekt.vgs RV= allowDialout=1
092435,88 0 dxxxB1C2 dxxxB1C2 C:\Voice\PetDirekt\petdirekt.vgs RV= allowDialout=1
092435,88 0 dxxxB1C3 dxxxB1C3 C:\Voice\BagDirekt\bagdirekt.vgs RV= allowDialout=1
092435,88 0 dxxxB1C4 dxxxB1C4 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=1
092435,88 0 dxxxB2C1 dxxxB2C1 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=0
092435,88 0 dxxxB2C2 dxxxB2C2 C:\Voice_jose_testing\CallerID\callerid.vgs RV= allowDialout=1
092435,88 0 dxxxB2C3 dxxxB2C3 C:\Voice\Choice\Lang-Service.vgs RV= allowDialout=1
092435,88 0 dxxxB2C4 dxxxB2C4 C:\Voice\Choice\Lang-Service.vgs RV= allowDialout=1
092435,88 0 init read Config.xml end
092435,89 0 init LineOpenDialogic dxxxB1C1 => [1]
092435,89 1 iIvrDev=1
092436,00 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
092436,00 0 init distinct ring definitions found:2
092436,02 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
092436,02 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
092436,02 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
092436,02 0 init ring 2 [TelstraDoubleRing] cadences defined:2
092436,02 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
092436,02 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
092436,02 0 init load Distinct Ring definitions end
092436,02 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig)
092436,02 0 load start [C:\Voice\PetDirekt\petdirekt.vgs]
092436,02 0 MemStructVgs_ClearVgs [1]
092436,14 0 load end
092436,14 0 init hires timer setup start
092436,14 0 init hires timer setup end
092436,14 1 state Waiting for a call...
092436,14 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092436,14 1 event ScriptEventCode TDX_SETHOOK, code=135, state=0
092436,14 1 event callstate IDLE 1 1,0,0
092436,14 1 WorkingMode@Idle=
092436,14 1 timer clear
092436,14 1 LineState(iLineId).iVgsIdx = 0
092436,14 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092436,14 1 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092436,14 1 timer set ignored - waiting for line re-init to occur first
092436,14 0 init lineids: 0-1
092436,16 0 init LineOpenDialogic dxxxB1C2 => [2]
092436,16 2 iIvrDev=2
092436,23 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
092436,23 0 init distinct ring definitions found:2
092436,23 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
092436,23 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
092436,23 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
092436,23 0 init ring 2 [TelstraDoubleRing] cadences defined:2
092436,23 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
092436,23 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
092436,23 0 init load Distinct Ring definitions end
092436,23 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig)
092436,23 0 init hires timer setup start
092436,23 0 init hires timer setup end
092436,23 2 state Waiting for a call...
092436,23 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092436,23 2 event ScriptEventCode TDX_SETHOOK, code=135, state=0
092436,23 2 event callstate IDLE 2 1,0,0
092436,23 2 WorkingMode@Idle=
092436,23 2 timer clear
092436,23 2 LineState(iLineId).iVgsIdx = 0
092436,23 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092436,23 2 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092436,25 2 timer set ignored - waiting for line re-init to occur first
092436,25 0 init lineids: 0-2
092436,27 0 init LineOpenDialogic dxxxB1C3 => [3]
092436,27 3 iIvrDev=3
092436,33 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
092436,33 0 init distinct ring definitions found:2
092436,34 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
092436,34 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
092436,34 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
092436,34 0 init ring 2 [TelstraDoubleRing] cadences defined:2
092436,34 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
092436,34 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
092436,34 0 init load Distinct Ring definitions end
092436,34 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig)
092436,34 0 load start [C:\Voice\BagDirekt\bagdirekt.vgs]
092436,34 0 MemStructVgs_ClearVgs [2]
092436,48 0 load end
092436,48 0 init hires timer setup start
092436,48 0 init hires timer setup end
092436,48 3 state Waiting for a call...
092436,48 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092436,48 3 event ScriptEventCode TDX_SETHOOK, code=135, state=0
092436,48 3 event callstate IDLE 3 1,0,0
092436,48 3 WorkingMode@Idle=
092436,48 3 timer clear
092436,48 3 LineState(iLineId).iVgsIdx = 0
092436,48 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092436,48 3 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092436,48 3 timer set ignored - waiting for line re-init to occur first
092436,48 0 init lineids: 0-3
092436,50 0 init LineOpenDialogic dxxxB1C4 => [4]
092436,50 4 iIvrDev=4
092436,58 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
092436,58 0 init distinct ring definitions found:2
092436,58 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
092436,58 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
092436,58 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
092436,58 0 init ring 2 [TelstraDoubleRing] cadences defined:2
092436,58 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
092436,58 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
092436,58 0 init load Distinct Ring definitions end
092436,58 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig)
092436,58 0 load start [C:\Voice\Tele2\Two-Services.vgs]
092436,58 0 MemStructVgs_ClearVgs [3]
092436,61 0 load end
092436,61 0 init hires timer setup start
092436,61 0 init hires timer setup end
092436,61 4 state Waiting for a call...
092436,61 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092436,61 4 event ScriptEventCode TDX_SETHOOK, code=135, state=0
092436,63 4 event callstate IDLE 4 1,0,0
092436,63 4 WorkingMode@Idle=
092436,63 4 timer clear
092436,63 4 LineState(iLineId).iVgsIdx = 0
092436,63 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092436,63 4 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092436,63 4 timer set ignored - waiting for line re-init to occur first
092436,63 0 init lineids: 0-4
092436,63 0 init LineOpenDialogic dxxxB2C1 => [5]
092436,63 5 iIvrDev=5
092436,66 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
092436,66 0 init distinct ring definitions found:2
092436,66 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
092436,66 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
092436,66 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
092436,66 0 init ring 2 [TelstraDoubleRing] cadences defined:2
092436,66 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
092436,66 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
092436,66 0 init load Distinct Ring definitions end
092436,66 5 init strDlgcDevName_VoiceResource=[dxxxB2C1] (LoadXMLConfig)
092436,66 0 init hires timer setup start
092436,66 0 init hires timer setup end
092436,66 5 state Waiting for a call...
092436,66 5 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092436,66 5 event ScriptEventCode TDX_SETHOOK, code=135, state=0
092436,66 5 event callstate IDLE 5 1,0,0
092436,66 5 WorkingMode@Idle=
092436,66 5 timer clear
092436,66 5 LineState(iLineId).iVgsIdx = 0
092436,66 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092436,66 5 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092436,66 5 timer set ignored - waiting for line re-init to occur first
092436,66 0 init lineids: 0-5
092436,67 0 init LineOpenDialogic dxxxB2C2 => [6]
092436,67 6 iIvrDev=6
092436,69 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
092436,69 0 init distinct ring definitions found:2
092436,70 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
092436,70 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
092436,70 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
092436,70 0 init ring 2 [TelstraDoubleRing] cadences defined:2
092436,70 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
092436,70 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
092436,70 0 init load Distinct Ring definitions end
092436,70 6 init strDlgcDevName_VoiceResource=[dxxxB2C2] (LoadXMLConfig)
092436,70 0 load start [C:\Voice_jose_testing\CallerID\callerid.vgs]
092436,70 0 MemStructVgs_ClearVgs [4]
092436,72 0 load end
092436,72 0 init hires timer setup start
092436,72 0 init hires timer setup end
092436,72 6 state Waiting for a call...
092436,72 6 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092436,72 6 event ScriptEventCode TDX_SETHOOK, code=135, state=0
092436,72 6 event callstate IDLE 6 1,0,0
092436,72 6 WorkingMode@Idle=
092436,72 6 timer clear
092436,72 6 LineState(iLineId).iVgsIdx = 0
092436,72 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092436,72 6 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092436,72 6 timer set ignored - waiting for line re-init to occur first
092436,72 0 init lineids: 0-6
092436,73 0 init LineOpenDialogic dxxxB2C3 => [7]
092436,73 7 iIvrDev=7
092436,75 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
092436,75 0 init distinct ring definitions found:2
092436,75 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
092436,75 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
092436,75 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
092436,75 0 init ring 2 [TelstraDoubleRing] cadences defined:2
092436,75 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
092436,75 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
092436,75 0 init load Distinct Ring definitions end
092436,75 7 init strDlgcDevName_VoiceResource=[dxxxB2C3] (LoadXMLConfig)
092436,77 0 load start [C:\Voice\Choice\Lang-Service.vgs]
092436,77 0 MemStructVgs_ClearVgs [5]
092436,80 0 load end
092436,80 0 init hires timer setup start
092436,80 0 init hires timer setup end
092436,80 7 state Waiting for a call...
092436,80 7 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092436,80 7 event ScriptEventCode TDX_SETHOOK, code=135, state=0
092436,81 7 event callstate IDLE 7 1,0,0
092436,81 7 WorkingMode@Idle=
092436,81 7 timer clear
092436,81 7 LineState(iLineId).iVgsIdx = 0
092436,81 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092436,81 7 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092436,81 7 timer set ignored - waiting for line re-init to occur first
092436,81 0 init lineids: 0-7
092436,81 0 init LineOpenDialogic dxxxB2C4 => [8]
092436,81 8 iIvrDev=8
092436,84 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
092436,84 0 init distinct ring definitions found:2
092436,84 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
092436,84 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
092436,84 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
092436,84 0 init ring 2 [TelstraDoubleRing] cadences defined:2
092436,84 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
092436,84 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
092436,84 0 init load Distinct Ring definitions end
092436,84 8 init strDlgcDevName_VoiceResource=[dxxxB2C4] (LoadXMLConfig)
092436,84 0 init hires timer setup start
092436,84 0 init hires timer setup end
092436,84 8 state Waiting for a call...
092436,84 8 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092436,84 8 event ScriptEventCode TDX_SETHOOK, code=135, state=0
092436,84 8 event callstate IDLE 8 1,0,0
092436,84 8 WorkingMode@Idle=
092436,84 8 timer clear
092436,84 8 LineState(iLineId).iVgsIdx = 0
092436,84 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092436,84 8 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092436,84 8 timer set ignored - waiting for line re-init to occur first
092436,84 0 init lineids: 0-8
092436,84 0 init route channels start
092437,00 0 init route channels => []
092437,00 0 init no dti channels opened. Not opening signaling channel.
092437,02 0 cti Link1 serial init complete
092437,03 0 cti serial1 closed not sending HeartbeatCheck
092437,03 0 init iLineDevicesControlled=8
092437,06 0 init main form load end
092438,11 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
092438,11 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
092438,13 1 init atidle reinit : start
092438,13 1 init atidle reinit iConferenceOtherLegLid=-1
092438,13 1 init atidle reinit : reset all LineState variables
092438,13 1 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,13 1 state Waiting for a call...
092438,13 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
092438,13 2 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
092438,13 2 init atidle reinit : start
092438,13 2 init atidle reinit iConferenceOtherLegLid=-1
092438,13 2 init atidle reinit : reset all LineState variables
092438,13 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,13 2 state Waiting for a call...
092438,23 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
092438,23 3 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
092438,23 3 init atidle reinit : start
092438,23 3 init atidle reinit iConferenceOtherLegLid=-1
092438,23 3 init atidle reinit : reset all LineState variables
092438,23 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,23 3 state Waiting for a call...
092438,34 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
092438,34 4 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
092438,34 4 init atidle reinit : start
092438,34 4 init atidle reinit iConferenceOtherLegLid=-1
092438,34 4 init atidle reinit : reset all LineState variables
092438,34 4 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,34 4 state Waiting for a call...
092438,34 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
092438,34 5 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
092438,34 5 init atidle reinit : start
092438,34 5 init atidle reinit iConferenceOtherLegLid=-1
092438,34 5 init atidle reinit : reset all LineState variables
092438,34 5 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,34 5 state Waiting for a call...
092438,34 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
092438,34 6 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
092438,34 6 init atidle reinit : start
092438,34 6 init atidle reinit iConferenceOtherLegLid=-1
092438,34 6 init atidle reinit : reset all LineState variables
092438,34 6 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,34 6 state Waiting for a call...
092438,45 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,45 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
092438,45 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,45 2 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
092438,45 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
092438,45 7 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
092438,45 7 init atidle reinit : start
092438,45 7 init atidle reinit iConferenceOtherLegLid=-1
092438,45 7 init atidle reinit : reset all LineState variables
092438,45 7 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,45 7 state Waiting for a call...
092438,45 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
092438,45 8 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
092438,45 8 init atidle reinit : start
092438,45 8 init atidle reinit iConferenceOtherLegLid=-1
092438,45 8 init atidle reinit : reset all LineState variables
092438,45 8 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,45 8 state Waiting for a call...
092438,56 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,56 3 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
092438,67 4 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,67 4 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
092438,67 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,67 5 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
092438,67 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,67 6 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
092438,78 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,78 7 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
092438,78 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092438,78 8 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
092511,59 4 tw dtmf a (4,97,97)
092511,59 4 event ScriptEventCode a, code=97, state=0
092511,59 4 tw DialogicEvent 134,TDX_CST,97,0,0,DE_DIGITS,,
092511,59 4 event ScriptEventCode TDX_CST, code=134, state=0
092511,64 4 tw dtmf 8 (4,56,56)
092511,64 4 event ScriptEventCode 8, code=56, state=0
092511,64 4 tw DialogicEvent 134,TDX_CST,56,0,0,DE_DIGITS,,
092511,64 4 event ScriptEventCode TDX_CST, code=134, state=0
092511,78 4 tw dtmf 4 (4,52,52)
092511,78 4 event ScriptEventCode 4, code=52, state=0
092511,78 4 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
092511,78 4 event ScriptEventCode TDX_CST, code=134, state=0
092511,92 4 tw dtmf 4 (4,52,52)
092511,92 4 event ScriptEventCode 4, code=52, state=0
092511,92 4 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
092511,92 4 event ScriptEventCode TDX_CST, code=134, state=0
092512,06 4 tw dtmf 2 (4,50,50)
092512,06 4 event ScriptEventCode 2, code=50, state=0
092512,06 4 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
092512,06 4 event ScriptEventCode TDX_CST, code=134, state=0
092512,20 4 tw dtmf 9 (4,57,57)
092512,20 4 event ScriptEventCode 9, code=57, state=0
092512,20 4 tw DialogicEvent 134,TDX_CST,57,0,0,DE_DIGITS,,
092512,20 4 event ScriptEventCode TDX_CST, code=134, state=0
092512,36 4 tw dtmf 0 (4,48,48)
092512,36 4 event ScriptEventCode 0, code=48, state=0
092512,36 4 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
092512,36 4 event ScriptEventCode TDX_CST, code=134, state=0
092512,47 4 tw dtmf 4 (4,52,52)
092512,47 4 event ScriptEventCode 4, code=52, state=0
092512,47 4 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
092512,47 4 event ScriptEventCode TDX_CST, code=134, state=0
092512,63 4 tw dtmf 0 (4,48,48)
092512,63 4 event ScriptEventCode 0, code=48, state=0
092512,63 4 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
092512,63 4 event ScriptEventCode TDX_CST, code=134, state=0
092512,78 4 tw dtmf # (4,35,35)
092512,78 4 event ScriptEventCode #, code=35, state=0
092512,78 4 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
092512,78 4 event ScriptEventCode TDX_CST, code=134, state=0
092513,64 4 event callstate OFFERING 4 2,0,0
092513,64 4 script interpretor: VgMulti v6.0.2304
092513,64 4 fired OFFERING event to listeners
092513,64 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
092513,64 4 iIvrDev=4
092513,64 4 CallerID vars clear
092513,64 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
092513,64 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
092513,64 4 tw ring 1
092513,64 4 ring time since last ring event (sec): 0,00
092513,64 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
092513,64 4 answer as number of rings reached
092513,64 4 rv clear all
092513,64 4 init LineState ResetAtStartOfNewCall.
092513,64 4 cid LastCidMessage values [,,]
092513,64 4 cid CallerID vars set (in reset at start of call)
092513,64 4 answer the call
092513,66 4 timer clear
092513,67 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
092513,67 4 event ScriptEventCode TDX_CST, code=134, state=6001
092514,44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
092514,44 4 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
092514,44 4 event callstate CONNECTED 4 256,0,0
092514,45 4 LineEvCallState_Connected hDevice=4 params=256,0,0
092514,45 4 WorkingModes tapi= script= LineState().iState=6001
092514,53 4 Inband detection not enabled
092514,53 4 StartLoadedVgs at 2005-11-04 09:25:14 [VgMulti v6.0.2304]
092514,53 4 set LineState().iVgsIdx=3
092514,53 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
092514,53 4 init StartLoadedVgs_InitLineState start
092514,53 4 rv add [$RV_STARTTIME]{2005-11-04 09:25:14}
092514,53 4 rv add [$RV_DEVICEID]{4}
092514,53 4 rv add [$RV_CIDNAME]{}
092514,53 4 rvns add [PathApp]{C:\Program\VoiceGuide\}
092514,53 4 rvns add [scriptsPath]{C:\Voice\Tele2\}
092514,53 4 rv add [$RV_CIDNUMBER]{}
092514,53 4 fn RunModule start
092514,53 4 tw DialogicEvent 134,TDX_CST,65535,0,0,DE_LCON,,
092514,53 4 event ScriptEventCode TDX_CST, code=134, state=6001
092514,53 4 timer clear
092514,53 4 Play Module start
092514,53 4 state [LANGUAGE] Playing
092514,53 4 state [LANGUAGE] Playing (C:\Voice\Tele2\Voice\language.wav)
092514,53 4 tw ConvertWav2Vox C:\Voice\Tele2\Voice\language.wav
092514,56 4 tw wav->vox convert end 791031,C:\Voice\Tele2\Voice\language.vox,1,0,,
092514,63 4 play start ok, lPlayId=791062
092517,02 4 tw dtmf 2 (4,50,50)
092517,02 4 event ScriptEventCode 2, code=50, state=1100
092517,03 4 LsPlayMsg 2,2
092517,06 4 play PlaySoundStop ok
092517,06 4 rv add [LANGUAGE]{2}
092517,06 4 fn RunModule start
092517,06 4 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
092517,06 4 event ScriptEventCode TDX_CST, code=134, state=6001
092517,06 4 timer clear
092517,06 4 state [init_COUNTER] Evaluate [0]
092517,06 4 eval[0]
092517,09 4 rvns add [init_COUNTER_Input]{0}
092517,09 4 rvns add [init_COUNTER]{0}
092517,09 4 rvns add [counter]{0}
092517,09 4 Eval Expr result:[0] stored in $RV[counter]
092517,09 4 path {0} not found
092517,09 4 fn RunModule start
092517,09 4 tw PlayEnd 4 791062
092517,09 4 play end id=791062, (current ID)
092517,09 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001
092517,09 4 tw DialogicEvent 129,TDX_PLAY,791062,0,0,,,
092517,09 4 event ScriptEventCode TDX_PLAY, code=129, state=6001
092517,09 4 timer clear
092517,09 4 Play Module start
092517,09 4 state [sERVICES] Playing
092517,09 4 rv replace start: [C:\Voice\Tele2\Voice\SERVICES_$RV[LANGUAGE].wav]
092517,09 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}
092517,09 4 rv replace end: [C:\Voice\Tele2\Voice\SERVICES_2.wav]
092517,09 4 state [sERVICES] Playing (C:\Voice\Tele2\Voice\SERVICES_2.wav)
092517,09 4 tw ConvertWav2Vox C:\Voice\Tele2\Voice\SERVICES_2.wav
092517,11 4 tw wav->vox convert end 793593,C:\Voice\Tele2\Voice\SERVICES_2.vox,1,0,,
092517,17 4 play start ok, lPlayId=793609
092529,19 4 tw PlayEnd 4 793609
092529,19 4 play end id=793609, (current ID)
092529,19 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
092529,19 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092529,19 4 path {EV_PLAY_FINISHED} not found
092529,19 4 timer set 5 EV_TIMEOUT_REPLAYMSG
092529,19 4 tw DialogicEvent 129,TDX_PLAY,793609,0,0,,,
092529,19 4 event ScriptEventCode TDX_PLAY, code=129, state=1101
092529,19 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
092529,19 4 path {TDX_PLAY} not found
092531,11 4 tw dtmf 2 (4,50,50)
092531,11 4 event ScriptEventCode 2, code=50, state=1101
092531,11 4 LsPlayMsgFinished 2,2
092531,11 4 rv add [scriptEnd_Time]{2005-11-04 09:25:31}
092531,11 4 rv add [scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}
092531,11 4 rv add [scriptEnd_Goto_Module]{WELCOME}
092531,27 4 rv add [scriptStart_Time]{2005-11-04 09:25:31}
092531,27 4 rv add [scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}
092531,27 4 rv add [scriptStart_CalledFrom_Module]{SERVICES}
092531,27 4 FindFullPathToScript_VgsOrVgp start [C:\Voice\Locksmith\locksmith.vgs]
092531,27 4 FindFullPathToScript_VgsOrVgp 1
092531,27 0 load start [C:\Voice\Locksmith\locksmith.vgs]
092531,27 0 MemStructVgs_ClearVgs [6]
092531,36 0 load end
092531,36 4 loaded [C:\Voice\Locksmith\locksmith.vgs] into:6
092531,36 4 rvns add [scriptsPath]{C:\Voice\Locksmith\}
092531,36 4 rv add [sERVICES]{2}
092531,36 4 fn RunModule start
092531,36 4 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
092531,36 4 event ScriptEventCode TDX_CST, code=134, state=6001
092531,39 4 timer clear
092531,39 4 Play Module start
092531,39 4 state [WELCOME] Playing
092531,39 4 rv replace start: [C:\Voice\Locksmith\voice\welcome_locksmith_$RV[LANGUAGE].wav]
092531,39 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}[scriptEnd_Time]{2005-11-04 09:25:31}[scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}[scriptEnd_Goto_Module]{WELCOME}[scriptStart_Time]{2005-11-04 09:25:31}[scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}[scriptStart_CalledFrom_Module]{SERVICES}[scriptsPath]{C:\Voice\Locksmith\}[sERVICES]{2}
092531,39 4 rv replace end: [C:\Voice\Locksmith\voice\welcome_locksmith_2.wav]
092531,39 4 state [WELCOME] Playing (C:\Voice\Locksmith\voice\welcome_locksmith_2.wav)
092531,39 4 tw ConvertWav2Vox C:\Voice\Locksmith\voice\welcome_locksmith_2.wav
092531,44 4 tw wav->vox convert end 807890,C:\Voice\Locksmith\voice\welcome_locksmith_2.vox,1,0,,
092531,48 4 play start ok, lPlayId=807937
092532,36 0 sys cleanup Start
092532,36 0 sys cleanup End
092543,58 4 tw PlayEnd 4 807937
092543,58 4 play end id=807937, (current ID)
092543,58 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
092543,58 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092543,58 4 path {EV_PLAY_FINISHED} not found
092543,58 4 timer set 10 EV_TIMEOUT_HANGUP
092543,58 4 timer set 0 EV_TIMEOUT_GOTOMODULE
092543,58 4 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
092543,58 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
092543,58 4 path {EV_TIMEOUT_GOTOMODULE} not found
092543,58 4 fn RunModule start
092543,58 4 tw DialogicEvent 129,TDX_PLAY,807937,0,0,,,
092543,58 4 event ScriptEventCode TDX_PLAY, code=129, state=6001
092543,61 4 timer clear
092543,61 4 state [Var_Result_Query] Evaluate [1]
092543,61 4 eval[1]
092543,61 4 rvns add [Var_Result_Query_Input]{1}
092543,61 4 rvns add [Var_Result_Query]{1}
092543,61 4 rvns add [resultQuery]{1}
092543,61 4 Eval Expr result:[1] stored in $RV[resultQuery]
092543,61 4 path {1} not found
092543,61 4 fn RunModule start
092543,61 4 state [selection_Choice] Number Input
092543,61 4 rv replace start: [C:\Voice\Locksmith\voice\selection_choice_$RV[LANGUAGE].wav]
092543,61 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}[scriptEnd_Time]{2005-11-04 09:25:31}[scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}[scriptEnd_Goto_Module]{WELCOME}[scriptStart_Time]{2005-11-04 09:25:31}[scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}[scriptStart_CalledFrom_Module]{SERVICES}[scriptsPath]{C:\Voice\Locksmith\}[sERVICES]{2}[Var_Result_Query_Input]{1}[Var_Result_Query]{1}[resultQuery]
1}
092543,61 4 rv replace end: [C:\Voice\Locksmith\voice\selection_choice_2.wav]
092543,61 4 state [selection_Choice] Playing (C:\Voice\Locksmith\voice\selection_choice_2.wav)
092543,61 4 tw ConvertWav2Vox C:\Voice\Locksmith\voice\selection_choice_2.wav
092543,63 4 tw wav->vox convert end 820109,C:\Voice\Locksmith\voice\selection_choice_2.vox,1,0,,
092543,67 4 play start ok, lPlayId=820125
092552,56 4 tw PlayEnd 4 820125
092552,56 4 play end id=820125, (current ID)
092552,56 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1300
092552,56 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092552,56 4 path {EV_PLAY_FINISHED} not found
092552,56 4 timer set 5 EV_TIMEOUT_REPLAYMSG
092552,56 4 tw DialogicEvent 129,TDX_PLAY,820125,0,0,,,
092552,56 4 event ScriptEventCode TDX_PLAY, code=129, state=1301
092552,56 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
092552,56 4 path {TDX_PLAY} not found
092557,17 4 tw dtmf 1 (4,49,49)
092557,17 4 event ScriptEventCode 1, code=49, state=1301
092557,17 4 LsGetNbrsRxDigits 1,1
092557,17 4 state [selection_Choice] Number Input 1
092557,17 4 rv add [selection_Choice]{1}
092557,17 4 rvns add [selection_Choice_PathTaken]{1}
092557,17 4 fn RunModule start
092557,17 4 timer clear
092557,17 4 state [Get_Post_Code] Number Input
092557,17 4 rv replace start: [C:\Voice\Locksmith\voice\get_post_code_$RV[LANGUAGE].wav]
092557,17 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
1}[selection_Choice]{1}[selection_Choice_PathTaken]{1}
092557,17 4 rv replace end: [C:\Voice\Locksmith\voice\get_post_code_2.wav]
092557,17 4 state [Get_Post_Code] Playing (C:\Voice\Locksmith\voice\get_post_code_2.wav)
092557,17 4 tw ConvertWav2Vox C:\Voice\Locksmith\voice\get_post_code_2.wav
092557,19 4 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
092557,19 4 event ScriptEventCode TDX_CST, code=134, state=1300
092557,19 4 LsGetNbrsPlayWelcMsg EV_UNKNOWN_134,TDX_CST
092557,19 4 path {TDX_CST} not found
092557,19 4 tw wav->vox convert end 833671,C:\Voice\Locksmith\voice\get_post_code_2.vox,1,0,,
092557,23 4 play start ok, lPlayId=833687
092600,53 4 tw PlayEnd 4 833687
092600,53 4 play end id=833687, (current ID)
092600,53 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1300
092600,53 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092600,53 4 path {EV_PLAY_FINISHED} not found
092600,53 4 timer set 5 EV_TIMEOUT_REPLAYMSG
092600,53 4 tw DialogicEvent 129,TDX_PLAY,833687,0,0,,,
092600,53 4 event ScriptEventCode TDX_PLAY, code=129, state=1301
092600,53 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
092600,53 4 path {TDX_PLAY} not found
092602,58 4 tw dtmf 0 (4,48,48)
092602,58 4 event ScriptEventCode 0, code=48, state=1301
092602,58 4 LsGetNbrsRxDigits 0,0
092602,58 4 state [Get_Post_Code] Number Input 0
092602,58 4 path {0} not found
092602,58 4 timer set 6 EV_TIMEOUT_ENTERDATA
092602,58 4 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
092602,58 4 event ScriptEventCode TDX_CST, code=134, state=1301
092602,58 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
092602,58 4 path {TDX_CST} not found
092603,47 4 tw dtmf 0 (4,48,48)
092603,47 4 event ScriptEventCode 0, code=48, state=1301
092603,47 4 LsGetNbrsRxDigits 0,0
092603,47 4 state [Get_Post_Code] Number Input 00
092603,47 4 path {00} not found
092603,47 4 timer set 6 EV_TIMEOUT_ENTERDATA
092603,47 4 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
092603,47 4 event ScriptEventCode TDX_CST, code=134, state=1301
092603,47 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
092603,47 4 path {TDX_CST} not found
092604,52 4 tw dtmf 0 (4,48,48)
092604,52 4 event ScriptEventCode 0, code=48, state=1301
092604,52 4 LsGetNbrsRxDigits 0,0
092604,52 4 state [Get_Post_Code] Number Input 000
092604,52 4 path {000} not found
092604,52 4 timer set 6 EV_TIMEOUT_ENTERDATA
092604,52 4 timer clear
092604,52 4 rv add [Get_Post_Code]{000}
092604,52 4 rvns add [Get_Post_Code_PathTaken]{success}
092604,52 4 fn RunModule start
092604,52 4 state [CASE_locksmith_post] DB Query
092604,52 4 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
092604,52 4 event ScriptEventCode TDX_CST, code=134, state=1400
092604,52 4 ERROR 6.0.2304 Unknown State [1400]
092604,53 4 db ODBC mode used
092605,03 4 rv replace start: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =$RV[Get_Post_Code]]
092605,03 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
1}[selection_Choice]{1}[selection_Choice_PathTaken]{1}[Get_Post_Code]{000}[Get_P
092605,03 4 rv replace end: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
092605,03 4 db About to execute a Retrieve type operation [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
092605,09 4 db [CASE_locksmith_post] row count=1
092605,09 4 rv add [CASE_locksmith_post_RowCount]{1}
092605,09 4 db get RecordsetGetRowsMax
092605,11 4 db get 999 records. (row count=1)
092605,11 4 db update RVs
092605,11 4 db about to close dbDbqDatabase
092605,13 4 db going down path [True]
092605,13 4 fn RunModule start
092605,13 4 timer clear
092605,13 4 state [Counter_post] Evaluate [1]
092605,13 4 eval[1]
092605,13 4 rvns add [Counter_post_Input]{1}
092605,13 4 rvns add [Counter_post]{1}
092605,13 4 rvns add [counter]{1}
092605,13 4 Eval Expr result:[1] stored in $RV[counter]
092605,13 4 path {1} not found
092605,13 4 state [Check_columns_post] Running VB Script...
092605,13 4 rv replace start (strlen>500)
092605,13 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
st_Code_PathTaken]{success}[CASE_locksmith_post_RowCount]{1}[CASE_locksmith_post
1_1]{+46739389890}[CASE_locksmith_post_2_1]{+46739389890}[CASE_locksmith_post_3_
]{+46739389890}[Counter_post_Input]{1}[Counter_post]{1}[counter]{1}
092605,14 4 vbs ran [vbs_4_1.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_4_1.vbs" //I //T:60]
092605,64 4 Run Script waiting. iRunWait=1 (shellid=2508, process=1636)
092605,64 4 timer set 1 EV_TIMEOUT_CHECKONSTATE
092605,73 4 cl RvSet resultQuery, 0739389890
092605,73 4 rv add [resultQuery]{0739389890}
092605,75 4 cl Run_ResultReturn >>success<<
092605,75 4 rv add [Check_columns_post_ResultReturn]{success}
092605,75 4 cl module's runwait=1, WavPlayHasNowFinished=0
092605,77 4 fn RunModule start
092605,77 4 timer clear
092605,77 4 Play Module start
092605,77 4 state [info_To_Customer] Playing
092605,77 4 rv replace start: [c:\Voice\Locksmith\voice\nu_kopplar_$RV[LANGUAGE].wav]
092605,77 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{+46739389890}[Counter_post_Input]{1}[Counter_post]{1}[counter]{1}[resultQuery]
0739389890}[Check_columns_post_ResultReturn]{success}
092605,77 4 rv replace end: [c:\Voice\Locksmith\voice\nu_kopplar_2.wav]
092605,77 4 state [info_To_Customer] Playing (c:\Voice\Locksmith\voice\nu_kopplar_2.wav)
092605,77 4 tw ConvertWav2Vox c:\Voice\Locksmith\voice\nu_kopplar_2.wav
092605,77 4 tw wav->vox convert end 842265,c:\Voice\Locksmith\voice\nu_kopplar_2.vox,1,0,,
092605,83 4 play start ok, lPlayId=842265
092610,70 4 tw PlayEnd 4 842265
092610,70 4 play end id=842265, (current ID)
092610,70 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
092610,70 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092610,70 4 path {EV_PLAY_FINISHED} not found
092610,70 4 timer set 10 EV_TIMEOUT_HANGUP
092610,70 4 timer set 0 EV_TIMEOUT_GOTOMODULE
092610,70 4 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
092610,70 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
092610,72 4 path {EV_TIMEOUT_GOTOMODULE} not found
092610,72 4 fn RunModule start
092610,72 4 timer clear
092610,72 4 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
092610,72 4 tw DialogicEvent 129,TDX_PLAY,842265,0,0,,,
092610,72 4 event ScriptEventCode TDX_PLAY, code=129, state=1901
092610,77 4 LsXfer_1_Start : 129(EV_UNKNOWN_129),TDX_PLAY,842265,0,0,,,
092610,77 4 path {TDX_PLAY} not found
092611,11 4 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
092611,11 4 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
092611,11 4 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
092611,11 4 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
092611,11 4 timeout on transfer attempt set by timeout path (30 sec)
092611,11 4 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
092611,11 4 rv replace start: [$RV[resultQuery]]
092611,11 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
092611,11 4 rv replace end: [0739389890]
092611,11 4 state [Locksmith] Announced 3-Way Conference to 0739389890
092611,41 4 tw PlayEnd 4 0
092611,41 4 play end id=0, (current ID)
092611,41 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902
092611,41 4 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
092611,41 4 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
092611,41 4 event ScriptEventCode TDX_DIAL, code=132, state=1902
092611,41 4 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
092611,41 4 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
092611,41 4 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
092613,53 4 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
092613,53 4 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
092613,53 4 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
092613,53 4 Dial(0739389890, cp on) call
092613,75 4 Dial(0739389890) ok
092613,75 4 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
092628,02 4 tw DialogicEvent 133,TDX_CALLP,10,4,0,TDX_CALLP,CR_CNCT,CON_PAMD
092628,02 4 event ScriptEventCode AM, code=133, state=1903
092628,02 4 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,AM,10,4,0,CR_CNCT,CON_PAMD,
092628,02 4 event ScriptEventCode CONNECT, code=133, state=1903
092628,02 4 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CONNECT,10,4,0,CR_CNCT,CON_PAMD,
092628,02 4 event ScriptEventCode CON_PAMD, code=133, state=1903
092628,02 4 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CON_PAMD,10,4,0,CR_CNCT,CON_PAMD,
092628,02 4 event ScriptEventCode CR_CNCT, code=133, state=1903
092628,02 4 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CR_CNCT,10,4,0,CR_CNCT,CON_PAMD,
092628,02 4 event ScriptEventCode TDX_CALLP, code=133, state=1903
092628,02 4 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,10,4,0,CR_CNCT,CON_PAMD,
092628,02 4 LsXfer_3 CR_CNCT on an XT_3WAY_ANNOUNCED
092628,02 4 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
092628,02 4 path {EV_PLAY_FINISHED} not found
092628,02 4 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
092628,02 4 path {EV_TIMEOUT_REPLAYMSG} not found
092628,02 4 rv replace start: [voice\call_transfer_$RV[LANGUAGE].wav]
092628,02 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
092628,02 4 rv replace end: [voice\call_transfer_2.wav]
092628,02 4 state [Locksmith] Playing (voice\call_transfer_2.wav)
092628,03 4 tw ConvertWav2Vox C:\Voice\Locksmith\voice\call_transfer_2.wav
092628,03 4 timer clear
092628,06 4 tw wav->vox convert end 864531,C:\Voice\Locksmith\voice\call_transfer_2.vox,1,0,,
092628,13 4 play start ok, lPlayId=864562
092638,61 4 tw PlayEnd 4 864562
092638,61 4 play end id=864562, (current ID)
092638,61 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1904
092638,61 4 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
092638,61 4 path {EV_PLAY_FINISHED} not found
092638,61 4 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
092638,61 4 path {EV_TIMEOUT_REPLAYMSG} not found
092638,61 4 rv replace start: [voice\call_transfer_$RV[LANGUAGE].wav]
092638,61 4 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-11-04 09:25:14}[$RV_DEVICEID]{4}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
092638,61 4 rv replace end: [voice\call_transfer_2.wav]
092638,61 4 state [Locksmith] Playing (voice\call_transfer_2.wav)
092638,61 4 tw ConvertWav2Vox C:\Voice\Locksmith\voice\call_transfer_2.wav
092638,61 4 timer clear
092638,61 4 tw DialogicEvent 129,TDX_PLAY,864562,0,0,,,
092638,61 4 event ScriptEventCode TDX_PLAY, code=129, state=1904
092638,61 4 LsXfer_4_PlayAnn : 129(EV_UNKNOWN_129),TDX_PLAY,864562,0,0,,,
092638,61 4 path {TDX_PLAY} not found
092638,63 4 tw wav->vox convert end 875109,C:\Voice\Locksmith\voice\call_transfer_2.vox,1,0,,
092638,66 4 play start ok, lPlayId=875125
092640,08 4 tw dtmf 1 (4,49,49)
092640,08 4 event ScriptEventCode 1, code=49, state=1904
092640,08 4 LsXfer_4_PlayAnn : 49(1),1,0,0,0,,,
092640,08 4 rv add [Locksmith]{1}
092640,08 4 timer set 0,5 EV_PLAY_FINISHED
092640,11 4 play PlaySoundStop ok
092640,11 4 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
092640,11 4 event ScriptEventCode TDX_CST, code=134, state=1904
092640,11 4 LsXfer_4_PlayAnn : 134(EV_UNKNOWN_134),TDX_CST,49,0,0,DE_DIGITS,,
092640,11 4 path {TDX_CST} not found
092640,11 4 tw PlayEnd 4 875125
092640,11 4 play end id=875125, (current ID)
092640,11 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1904
092640,11 4 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
092640,11 4 path {EV_PLAY_FINISHED} not found
092640,11 4 dial [!,3] from LsXfer_4_PlayAnn
092640,11 4 tw DialogicEvent 129,TDX_PLAY,875125,0,0,,,
092640,11 4 event ScriptEventCode TDX_PLAY, code=129, state=1905
092640,13 4 LsXfer_5A : 129(EV_UNKNOWN_129),TDX_PLAY,875125,0,0,,,
092640,59 4 timer fired EV_PLAY_FINISHED
092640,59 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1905
092640,59 4 LsXfer_5A : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
092641,34 4 tw PlayEnd 4 0
092641,34 4 play end id=0, (current ID)
092641,34 4 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1905
092641,34 4 LsXfer_5A : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
092641,34 4 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
092641,34 4 event ScriptEventCode TDX_DIAL, code=132, state=1905
092641,34 4 LsXfer_5A : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
092641,34 4 sXferDialResult_SuccOrFail=XferToGoAhead
092641,34 4 LsXfer_5A->LS_XFER_8_WAITENDCALL and wait till 'end conference' conditon detected
092641,34 4 state [Locksmith] 3-Way Conference with 0739389890
092641,34 4 As no timeout path specified, setting max talk time to 300 seconds. (VG.INI [Pbx] 3WayMaxTalkTime)
092641,34 4 timer set 300 EV_TIMEOUT_HANGUP
I pressed the hang up button after the caller and the called person had hanged up, otherwise voiceguide would hang up after the 5 minutes set in the vg.ini file.
092728,03 0 btn Hangup on line 4
092728,03 4 event ScriptEventCode EV_TIMEOUT_HANGUP, code=9001, state=1910
092728,03 4 LsXfer_8_WaitEndCall_RequestXferSide : 9001(EV_TIMEOUT_HANGUP),EV_TIMEOUT_HANGUP,0,0,0,,, (iModuleIdx=105)
092728,03 4 path {ev_timeout_hangup} not found
092728,03 4 rv add [Hangup Time]{2005-11-04 09:27:28}
092728,03 4 state Hanging up call... [Default Handler 60: 9001]
092728,03 4 HangupCall_Common hCall=4
092728,03 4 rec RecSoundStop ok
092728,03 4 play PlaySoundStop ok
092728,03 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
092728,05 4 fnHangupCall end
092728,08 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092728,09 4 event ScriptEventCode TDX_SETHOOK, code=135, state=900
092728,09 4 LsAwaitingCalls EV_UNKNOWN_135
092728,09 4 event callstate IDLE 4 1,0,0
092728,09 4 WorkingMode@Idle=
092728,09 4 timer clear
092728,09 4 rec RecSoundStop ok
092728,09 4 play PlaySoundStop ok
092728,09 4 rv add [CallEndTime]{2005-11-04 09:27:28}
092728,47 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
092729,45 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
092729,45 4 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
092729,45 4 init atidle reinit : start
092729,45 4 init atidle reinit iConferenceOtherLegLid=-1
092729,45 4 init atidle reinit : reset all LineState variables
092729,45 4 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092729,45 4 state Waiting for a call...
092729,78 4 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092729,78 4 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
Thank you for your help!
Jose
1104tw.txt
Looks like your phone company is not playing any disconnect tones after the two other callers in the 3-way conference hang up...
Hello!
I see in the above attached file that I have an Error each time the script make a request to the database. See here:
I´ve been looking around but I can´t find what this line means, or where the errors appears. Any ideas?
I´ll talk to the phone company about this disconnect tone.
Jose
This message happens because the caller pressed a digit while the database query was running.
Right now these keypresses are ignored and the database queries are allowed to complete first. The message should not be an error message - we'll have it changed to that the wording of it is more appropriate.
Hello!
According to my telephone company only the person that presses the "R" key (hookflash) can controll the 3-way conference. I mean if this person hangs up the phone then the other two called person will not be able to talk to each other. So, in my case is voiceguide that "presses" the "R" key.
Could you tell me how I can detect from my script that any/or both of the called person just hung up the phone?
jose
The only way tot detect hangup on analog lines is if the disconnect tone is heard or a loop current drop occurs.
If nether of this is done by your phone company when the other parties in the 3 way conference end their calls then there is no way for Dialogic card & VoiceGuide detect that the call has ended.
