Xml & Vxml
Use of XML is made throughout the software.
And ability to use VBScripts within VoiceGuide scripts allows you to easily use Web Services and other remote data sources without the added complexity of having to set up a web server for VXML scripts...
Our opinion is that it is a lot easier and quicker to develop scripts and deploy systems using this approach then to use VXML type systems. It is also a lot easier to see what happened if things ever don’t go as expected...
