CallerID sent as DTMF
Hello!
I need to know the caller telephone number ($RV_CIDNUMBER) for searching in a database.
My question is what I need to get this number? I know this service is set because if I connect a handset to the telephone line I can see in the display the phone number of the caller.
Here it is the log: (this line will answer after 4 rings, if this is of any help)
132520,49 0 btn Exit (8 lines)
132520,55 1 line state =900
132520,61 2 line state =0
132520,68 3 line state =900
132520,74 4 line state =900
132520,80 5 line state =0
132520,95 6 line state =0
132521,00 7 line state =0
132521,07 8 line state =900
132521,13 1 state Exiting...
132521,19 2 state Exiting...
132521,25 3 state Exiting...
132521,30 4 state Exiting...
132521,36 5 state Exiting...
132521,41 6 state Exiting...
132521,47 7 state Exiting...
132521,53 8 state Exiting...
132522,58 0 exit closing all channels start
132522,75 0 exit close dxxxB1C1(1)=> []
132522,82 0 exit close dxxxB1C2(2)=> []
132522,88 0 exit close dxxxB1C3(3)=> []
132522,94 0 exit close dxxxB1C4(4)=> []
132523,00 0 exit close dxxxB2C1(5)=> []
132523,07 0 exit close dxxxB2C2(6)=> []
132523,13 0 exit close dxxxB2C3(7)=> []
132523,19 0 exit close dxxxB2C4(8)=> []
132523,24 0 exit closing all channels end
132524,20 0 ---------------------------------------------------
132524,25 0 Stopping VoiceGuide (Dialogic) start
132524,32 0 v6.0.2275
132524,38 0 Stopping VoiceGuide (Dialogic) end
132524,43 0 ---------------------------------------------------
132538,63 0 ---------------------------------------------------
132538,74 0 VoiceGuide for Dialogic
132538,74 0 v6.0.2275
132538,74 0 ---------------------------------------------------
132538,91 0 rv global loaded >>><<<
132539,13 0 cti Inband Signaling Config file not specified
132605,28 0 ---------------------------------------------------
132605,38 0 VoiceGuide for Dialogic
132605,38 0 v6.0.2275
132605,38 0 ---------------------------------------------------
132605,55 0 rv global loaded >>><<<
132605,77 0 cti Inband Signaling Config file not specified
132606,63 0 init ApiMode=[DialogicGC]
132606,80 0 vm loading VMB data begin
132606,82 0 vm loading VMB data - about to delete old entries
132606,89 0 vm loading VMB data - sorting/ordering
132606,89 0 vm loading VMB data end
132606,89 0 dial DbConnectString_ADO is blank
132607,20 0 init DB Workspaces
132607,32 0 init Voicemail LoadIniSettings
132607,35 0 init read Config.xml start
132607,41 0 dxxxB1C1 dxxxB1C1 C:\Voice\PetDirekt\petdirekt.vgs RV= allowDialout=1
132607,41 0 dxxxB1C2 dxxxB1C2 C:\Voice\BagDirekt\bagdirekt.vgs RV= allowDialout=1
132607,41 0 dxxxB1C3 dxxxB1C3 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=0
132607,41 0 dxxxB1C4 dxxxB1C4 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=1
132607,41 0 dxxxB2C1 dxxxB2C1 C:\Voice\Choice\Lang-Service.vgs RV= allowDialout=0
132607,41 0 dxxxB2C2 dxxxB2C2 C:\Voice\Choice\Lang-Service.vgs RV= allowDialout=0
132607,41 0 dxxxB2C3 dxxxB2C3 C:\Voice\Choice\Lang-Service.vgs RV= allowDialout=1
132607,41 0 dxxxB2C4 dxxxB2C4 C:\Voice\Choice\Lang-Service.vgs RV= allowDialout=1
132607,41 0 init read Config.xml end
132607,43 0 init LineOpenDialogic dxxxB1C1 => [1]
132607,43 1 iIvrDev=1
132607,52 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
132607,52 0 init distinct ring definitions found:2
132607,52 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
132607,52 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
132607,52 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
132607,52 0 init ring 2 [TelstraDoubleRing] cadences defined:2
132607,52 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
132607,52 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
132607,52 0 init load Distinct Ring definitions end
132607,52 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig)
132607,52 0 load start [C:\Voice\PetDirekt\petdirekt.vgs]
132607,52 0 MemStructVgs_ClearVgs [1]
132607,61 0 load end
132607,61 0 init hires timer setup start
132607,61 0 init hires timer setup end
132607,61 1 state Waiting for a call...
132607,61 1 event callstate IDLE 1 1,0,0
132607,61 1 WorkingMode@Idle=
132607,61 1 timer clear
132607,61 1 LineState(iLineId).iVgsIdx = 0
132607,61 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
132607,61 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
132607,61 1 event ScriptEventCode TDX_SETHOOK, code=135, state=0
132607,61 1 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132607,61 1 timer set ignored - waiting for line re-init to occur first
132607,61 0 init lineids: 0-1
132607,63 0 init LineOpenDialogic dxxxB1C2 => [2]
132607,64 2 iIvrDev=2
132607,70 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
132607,70 0 init distinct ring definitions found:2
132607,70 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
132607,70 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
132607,70 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
132607,70 0 init ring 2 [TelstraDoubleRing] cadences defined:2
132607,72 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
132607,72 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
132607,72 0 init load Distinct Ring definitions end
132607,72 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig)
132607,72 0 load start [C:\Voice\BagDirekt\bagdirekt.vgs]
132607,72 0 MemStructVgs_ClearVgs [2]
132607,85 0 load end
132607,85 0 init hires timer setup start
132607,85 0 init hires timer setup end
132607,85 2 state Waiting for a call...
132607,85 2 event callstate IDLE 2 1,0,0
132607,85 2 WorkingMode@Idle=
132607,85 2 timer clear
132607,85 2 LineState(iLineId).iVgsIdx = 0
132607,85 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
132607,85 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
132607,85 2 event ScriptEventCode TDX_SETHOOK, code=135, state=0
132607,86 2 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132607,86 2 timer set ignored - waiting for line re-init to occur first
132607,86 0 init lineids: 0-2
132607,88 0 init LineOpenDialogic dxxxB1C3 => [3]
132607,88 3 iIvrDev=3
132607,94 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
132607,95 0 init distinct ring definitions found:2
132607,95 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
132607,95 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
132607,95 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
132607,95 0 init ring 2 [TelstraDoubleRing] cadences defined:2
132607,95 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
132607,95 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
132607,95 0 init load Distinct Ring definitions end
132607,95 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig)
132607,95 0 load start [C:\Voice\Tele2\Two-Services.vgs]
132607,95 0 MemStructVgs_ClearVgs [3]
132607,99 0 load end
132607,99 0 init hires timer setup start
132607,99 0 init hires timer setup end
132607,99 3 state Waiting for a call...
132607,99 3 event callstate IDLE 3 1,0,0
132607,99 3 WorkingMode@Idle=
132607,99 3 timer clear
132607,99 3 LineState(iLineId).iVgsIdx = 0
132607,99 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
132607,99 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
132607,99 3 event ScriptEventCode TDX_SETHOOK, code=135, state=0
132607,99 3 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132607,99 3 timer set ignored - waiting for line re-init to occur first
132607,99 0 init lineids: 0-3
132608,00 0 init LineOpenDialogic dxxxB1C4 => [4]
132608,00 4 iIvrDev=4
132608,08 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
132608,08 0 init distinct ring definitions found:2
132608,08 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
132608,08 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
132608,08 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
132608,08 0 init ring 2 [TelstraDoubleRing] cadences defined:2
132608,08 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
132608,08 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
132608,08 0 init load Distinct Ring definitions end
132608,08 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig)
132608,08 0 init hires timer setup start
132608,10 0 init hires timer setup end
132608,10 4 state Waiting for a call...
132608,10 4 event callstate IDLE 4 1,0,0
132608,10 4 WorkingMode@Idle=
132608,10 4 timer clear
132608,10 4 LineState(iLineId).iVgsIdx = 0
132608,10 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
132608,10 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
132608,10 4 event ScriptEventCode TDX_SETHOOK, code=135, state=0
132608,10 4 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132608,10 4 timer set ignored - waiting for line re-init to occur first
132608,10 0 init lineids: 0-4
132608,10 0 init LineOpenDialogic dxxxB2C1 => [5]
132608,10 5 iIvrDev=5
132608,13 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
132608,13 0 init distinct ring definitions found:2
132608,13 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
132608,13 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
132608,13 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
132608,13 0 init ring 2 [TelstraDoubleRing] cadences defined:2
132608,13 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
132608,13 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
132608,13 0 init load Distinct Ring definitions end
132608,13 5 init strDlgcDevName_VoiceResource=[dxxxB2C1] (LoadXMLConfig)
132608,13 0 load start [C:\Voice\Choice\Lang-Service.vgs]
132608,13 0 MemStructVgs_ClearVgs [4]
132608,14 0 load end
132608,14 0 init hires timer setup start
132608,14 0 init hires timer setup end
132608,14 5 state Waiting for a call...
132608,14 5 event callstate IDLE 5 1,0,0
132608,14 5 WorkingMode@Idle=
132608,14 5 timer clear
132608,14 5 LineState(iLineId).iVgsIdx = 0
132608,14 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
132608,14 5 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
132608,14 5 event ScriptEventCode TDX_SETHOOK, code=135, state=0
132608,14 5 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132608,14 5 timer set ignored - waiting for line re-init to occur first
132608,14 0 init lineids: 0-5
132608,16 0 init LineOpenDialogic dxxxB2C2 => [6]
132608,16 6 iIvrDev=6
132608,18 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
132608,18 0 init distinct ring definitions found:2
132608,18 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
132608,18 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
132608,18 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
132608,18 0 init ring 2 [TelstraDoubleRing] cadences defined:2
132608,18 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
132608,18 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
132608,18 0 init load Distinct Ring definitions end
132608,18 6 init strDlgcDevName_VoiceResource=[dxxxB2C2] (LoadXMLConfig)
132608,19 0 init hires timer setup start
132608,19 0 init hires timer setup end
132608,19 6 state Waiting for a call...
132608,19 6 event callstate IDLE 6 1,0,0
132608,19 6 WorkingMode@Idle=
132608,19 6 timer clear
132608,19 6 LineState(iLineId).iVgsIdx = 0
132608,19 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
132608,19 6 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
132608,19 6 event ScriptEventCode TDX_SETHOOK, code=135, state=0
132608,19 6 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132608,19 6 timer set ignored - waiting for line re-init to occur first
132608,19 0 init lineids: 0-6
132608,19 0 init LineOpenDialogic dxxxB2C3 => [7]
132608,20 7 iIvrDev=7
132608,22 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
132608,22 0 init distinct ring definitions found:2
132608,22 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
132608,22 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
132608,22 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
132608,22 0 init ring 2 [TelstraDoubleRing] cadences defined:2
132608,22 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
132608,22 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
132608,22 0 init load Distinct Ring definitions end
132608,22 7 init strDlgcDevName_VoiceResource=[dxxxB2C3] (LoadXMLConfig)
132608,22 0 init hires timer setup start
132608,22 0 init hires timer setup end
132608,22 7 state Waiting for a call...
132608,22 7 event callstate IDLE 7 1,0,0
132608,22 7 WorkingMode@Idle=
132608,22 7 timer clear
132608,22 7 LineState(iLineId).iVgsIdx = 0
132608,22 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
132608,24 7 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
132608,24 7 event ScriptEventCode TDX_SETHOOK, code=135, state=0
132608,24 7 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132608,24 7 timer set ignored - waiting for line re-init to occur first
132608,24 0 init lineids: 0-7
132608,24 0 init LineOpenDialogic dxxxB2C4 => [8]
132608,24 8 iIvrDev=8
132608,27 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
132608,27 0 init distinct ring definitions found:2
132608,27 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
132608,27 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
132608,27 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
132608,27 0 init ring 2 [TelstraDoubleRing] cadences defined:2
132608,27 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
132608,27 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
132608,27 0 init load Distinct Ring definitions end
132608,27 8 init strDlgcDevName_VoiceResource=[dxxxB2C4] (LoadXMLConfig)
132608,27 0 init hires timer setup start
132608,27 0 init hires timer setup end
132608,27 8 state Waiting for a call...
132608,27 8 event callstate IDLE 8 1,0,0
132608,27 8 WorkingMode@Idle=
132608,27 8 timer clear
132608,27 8 LineState(iLineId).iVgsIdx = 0
132608,27 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
132608,27 8 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
132608,27 8 event ScriptEventCode TDX_SETHOOK, code=135, state=0
132608,28 8 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132608,28 8 timer set ignored - waiting for line re-init to occur first
132608,28 0 init lineids: 0-8
132608,28 0 init route channels start
132608,43 0 init route channels => []
132608,43 0 init no dti channels opened. Not opening signaling channel.
132608,47 0 cti Link1 serial init complete
132608,47 0 cti serial1 closed not sending HeartbeatCheck
132608,47 0 init iLineDevicesControlled=8
132608,52 0 init main form load end
132609,07 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
132609,07 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
132609,07 1 init atidle reinit : start
132609,07 1 init atidle reinit iConferenceOtherLegLid=-1
132609,07 1 init atidle reinit : reset all LineState variables
132609,07 1 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,07 1 state Waiting for a call...
132609,18 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
132609,18 2 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
132609,18 2 init atidle reinit : start
132609,18 2 init atidle reinit iConferenceOtherLegLid=-1
132609,18 2 init atidle reinit : reset all LineState variables
132609,18 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,18 2 state Waiting for a call...
132609,28 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
132609,28 3 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
132609,28 3 init atidle reinit : start
132609,28 3 init atidle reinit iConferenceOtherLegLid=-1
132609,28 3 init atidle reinit : reset all LineState variables
132609,28 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,28 3 state Waiting for a call...
132609,39 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,39 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
132609,39 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
132609,39 4 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
132609,39 4 init atidle reinit : start
132609,39 4 init atidle reinit iConferenceOtherLegLid=-1
132609,39 4 init atidle reinit : reset all LineState variables
132609,39 4 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,39 4 state Waiting for a call...
132609,39 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
132609,39 5 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
132609,39 5 init atidle reinit : start
132609,39 5 init atidle reinit iConferenceOtherLegLid=-1
132609,39 5 init atidle reinit : reset all LineState variables
132609,39 5 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,39 5 state Waiting for a call...
132609,39 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
132609,39 6 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
132609,39 6 init atidle reinit : start
132609,39 6 init atidle reinit iConferenceOtherLegLid=-1
132609,39 6 init atidle reinit : reset all LineState variables
132609,39 6 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,39 6 state Waiting for a call...
132609,50 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,50 2 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
132609,50 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
132609,50 7 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
132609,50 7 init atidle reinit : start
132609,50 7 init atidle reinit iConferenceOtherLegLid=-1
132609,50 7 init atidle reinit : reset all LineState variables
132609,50 7 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,50 7 state Waiting for a call...
132609,50 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
132609,50 8 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
132609,50 8 init atidle reinit : start
132609,50 8 init atidle reinit iConferenceOtherLegLid=-1
132609,50 8 init atidle reinit : reset all LineState variables
132609,50 8 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,50 8 state Waiting for a call...
132609,61 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,61 3 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
132609,72 4 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,72 4 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
132609,72 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,72 5 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
132609,72 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,72 6 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
132609,83 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,83 7 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
132609,83 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132609,83 8 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
132620,77 0 load start [C:\Voice_jose_testing\CallerID\callerid.vgs]
132620,77 0 MemStructVgs_ClearVgs [5]
132620,77 0 load end
132638,69 8 tw dtmf d (8,100,100)
132638,69 8 event ScriptEventCode d, code=100, state=0
132638,69 8 already IDLE. HangupCall ignored.
132638,69 8 init atidle reinit : start
132638,69 8 init atidle reinit iConferenceOtherLegLid=-1
132638,69 8 init atidle reinit : reset all LineState variables
132638,69 8 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132638,69 8 state Waiting for a call...
132638,69 8 tw DialogicEvent 134,TDX_CST,100,0,0,DE_DIGITS,,
132638,69 8 event ScriptEventCode TDX_CST, code=134, state=900
132638,69 8 LsAwaitingCalls EV_UNKNOWN_134
132638,83 8 tw dtmf 0 (8,48,48)
132638,83 8 event ScriptEventCode 0, code=48, state=900
132638,83 8 LsAwaitingCalls 0
132638,83 8 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
132638,83 8 event ScriptEventCode TDX_CST, code=134, state=900
132638,83 8 LsAwaitingCalls EV_UNKNOWN_134
132638,94 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132638,94 8 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
132638,97 8 tw dtmf 8 (8,56,56)
132638,97 8 event ScriptEventCode 8, code=56, state=900
132638,97 8 LsAwaitingCalls 8
132638,97 8 tw DialogicEvent 134,TDX_CST,56,0,0,DE_DIGITS,,
132638,97 8 event ScriptEventCode TDX_CST, code=134, state=900
132638,97 8 LsAwaitingCalls EV_UNKNOWN_134
132639,13 8 tw dtmf 4 (8,52,52)
132639,13 8 event ScriptEventCode 4, code=52, state=900
132639,13 8 LsAwaitingCalls 4
132639,13 8 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
132639,13 8 event ScriptEventCode TDX_CST, code=134, state=900
132639,13 8 LsAwaitingCalls EV_UNKNOWN_134
132639,27 8 tw dtmf 4 (8,52,52)
132639,27 8 event ScriptEventCode 4, code=52, state=900
132639,27 8 LsAwaitingCalls 4
132639,27 8 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
132639,27 8 event ScriptEventCode TDX_CST, code=134, state=900
132639,27 8 LsAwaitingCalls EV_UNKNOWN_134
132639,43 8 tw dtmf 2 (8,50,50)
132639,43 8 event ScriptEventCode 2, code=50, state=900
132639,43 8 LsAwaitingCalls 2
132639,43 8 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
132639,43 8 event ScriptEventCode TDX_CST, code=134, state=900
132639,43 8 LsAwaitingCalls EV_UNKNOWN_134
132639,57 8 tw dtmf 9 (8,57,57)
132639,57 8 event ScriptEventCode 9, code=57, state=900
132639,57 8 LsAwaitingCalls 9
132639,57 8 tw DialogicEvent 134,TDX_CST,57,0,0,DE_DIGITS,,
132639,57 8 event ScriptEventCode TDX_CST, code=134, state=900
132639,57 8 LsAwaitingCalls EV_UNKNOWN_134
132639,72 8 tw dtmf 0 (8,48,48)
132639,72 8 event ScriptEventCode 0, code=48, state=900
132639,72 8 LsAwaitingCalls 0
132639,72 8 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
132639,72 8 event ScriptEventCode TDX_CST, code=134, state=900
132639,72 8 LsAwaitingCalls EV_UNKNOWN_134
132639,86 8 tw dtmf 4 (8,52,52)
132639,86 8 event ScriptEventCode 4, code=52, state=900
132639,86 8 LsAwaitingCalls 4
132639,86 8 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
132639,86 8 event ScriptEventCode TDX_CST, code=134, state=900
132639,86 8 LsAwaitingCalls EV_UNKNOWN_134
132640,02 8 tw dtmf 0 (8,48,48)
132640,02 8 event ScriptEventCode 0, code=48, state=900
132640,02 8 LsAwaitingCalls 0
132640,02 8 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
132640,02 8 event ScriptEventCode TDX_CST, code=134, state=900
132640,02 8 LsAwaitingCalls EV_UNKNOWN_134
132640,16 8 tw dtmf c (8,99,99)
132640,16 8 event ScriptEventCode c, code=99, state=900
132640,16 8 LsAwaitingCalls c
132640,16 8 tw DialogicEvent 134,TDX_CST,99,0,0,DE_DIGITS,,
132640,16 8 event ScriptEventCode TDX_CST, code=134, state=900
132640,16 8 LsAwaitingCalls EV_UNKNOWN_134
132640,61 8 event callstate OFFERING 8 2,0,0
132640,61 8 script interpretor: VgMulti v6.0.2275
132640,61 8 fired OFFERING event to listeners
132640,61 8 set LineState().hCall = 8 in LINECALLSTATE_OFFERING
132640,61 8 iIvrDev=8
132640,63 8 set linestate CID vars
132640,63 8 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
132640,63 8 rings=0, min rings before answer=4 (iCallerIdHasArrived=0)
132640,63 8 tw ring 1
132640,63 8 ring time since last ring event (sec): 0,00
132640,63 8 rings=1, min rings before answer=4 (iCallerIdHasArrived=0)
132640,63 8 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
132640,63 8 event ScriptEventCode TDX_CST, code=134, state=900
132640,63 8 LsAwaitingCalls EV_UNKNOWN_134
132646,64 8 tw ring 2
132646,64 8 ring time since last ring event (sec): 6,02
132646,64 8 ring match against pattern 1, cadences=1
132646,64 8 ring template 1, cadence 1 = [110|20] edge time=601,6
132646,64 8 ring match distinct ring pattern 1 cycle 1 fail
132646,64 8 ring match against pattern 2, cadences=1
132646,64 8 ring template 2, cadence 1 = [85|10] edge time=601,6
132646,64 8 ring match distinct ring pattern 2 cycle 1 fail
132646,64 8 rings=2, min rings before answer=4 (iCallerIdHasArrived=0)
132646,64 8 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
132646,64 8 event ScriptEventCode TDX_CST, code=134, state=900
132646,64 8 LsAwaitingCalls EV_UNKNOWN_134
132652,66 8 tw ring 3
132652,66 8 ring time since last ring event (sec): 6,01
132652,66 8 ring match against pattern 1, cadences=2
132652,66 8 ring template 1, cadence 1 = [110|20] edge time=601,6
132652,66 8 ring match distinct ring pattern 1 cycle 1 fail
132652,66 8 ring match against pattern 2, cadences=2
132652,66 8 ring template 2, cadence 1 = [85|10] edge time=601,6
132652,66 8 ring match distinct ring pattern 2 cycle 1 fail
132652,66 8 rings=3, min rings before answer=4 (iCallerIdHasArrived=0)
132652,66 8 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
132652,66 8 event ScriptEventCode TDX_CST, code=134, state=900
132652,66 8 LsAwaitingCalls EV_UNKNOWN_134
132658,69 8 tw ring 4
132658,69 8 ring time since last ring event (sec): 6,04
132658,69 8 rings=4, min rings before answer=4 (iCallerIdHasArrived=0)
132658,69 8 rv clear all
132658,70 8 init LineState ResetAtStartOfNewCall.
132658,70 8 answer the call
132658,70 8 timer clear
132658,70 8 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
132658,70 8 event ScriptEventCode TDX_CST, code=134, state=6001
132659,32 8 event callstate CONNECTED 8 256,0,0
132659,32 8 LineEvCallState_Connected hDevice=8 params=256,0,0
132659,32 8 WorkingModes tapi= script= LineState().iState=6001
132659,38 8 Inband detection not enabled
132659,38 8 StartLoadedVgs at 2005-10-26 13:26:59 [VgMulti v6.0.2275]
132659,38 8 set LineState().iVgsIdx=5
132659,38 8 set sScriptToRunOnHangup=[] in StartLoadedVgs
132659,38 8 init StartLoadedVgs_InitLineState start
132659,38 8 rv add [$RV_STARTTIME]{2005-10-26 13:26:59}
132659,38 8 rv add [$RV_DEVICEID]{8}
132659,38 8 rv add [$RV_CIDNAME]{}
132659,38 8 rvns add [PathApp]{C:\Program\VoiceGuide\}
132659,38 8 rvns add [scriptsPath]{C:\Voice_jose_testing\CallerID\}
132659,38 8 rv add [$RV_CIDNUMBER]{}
132659,38 8 fn RunModule start
132659,38 8 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
132659,38 8 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
132659,38 8 tw DialogicEvent 134,TDX_CST,53345,0,0,DE_LCON,,
132659,38 8 event ScriptEventCode TDX_CST, code=134, state=6001
132659,38 8 timer clear
132659,38 8 state [Eva_CallerID] Evaluate [$RV_CIDNUMBER]
132659,38 8 rv replace start: [$RV_CIDNUMBER]
132659,38 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-26 13:26:59}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_testing\CallerID\}[$RV_CIDNUMBER]{}
132659,38 8 rv replace end: []
132659,38 8 eval[]
132659,38 8 rvns add [Eva_CallerID_Input]{}
132659,38 8 rvns add [Eva_CallerID]{}
132659,39 8 Eval Expr result:[]
132659,39 8 fn RunModule start
132659,41 8 timer clear
132659,41 8 Play Module start
132659,41 8 state [No_CallerID] Playing
132659,41 8 state [No_CallerID] Playing (C:\Voice_jose_testing\CallerID\voice\2.wav)
132659,41 8 tw ConvertWav2Vox C:\Voice_jose_testing\CallerID\voice\2.wav
132659,47 8 tw wav->vox convert end 863593,C:\Voice_jose_testing\CallerID\voice\2.vox,1,0,,
132659,50 8 play start ok, lPlayId=863656
132700,36 8 tw PlayEnd 8 863656
132700,36 8 play end id=863656, (current ID)
132700,36 8 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
132700,36 8 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
132700,36 8 path {EV_PLAY_FINISHED} not found
132700,36 8 timer set 10 EV_TIMEOUT_HANGUP
132700,36 8 timer set 0 EV_TIMEOUT_GOTOMODULE
132700,36 8 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
132700,36 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
132700,36 8 path {EV_TIMEOUT_GOTOMODULE} not found
132700,36 8 fn RunModule start
132700,36 8 timer clear
132700,36 8 rv add [Hangup Time]{2005-10-26 13:27:00}
132700,36 8 state Hanging up call... [Hangup Module]
132700,36 8 HangupCall_Common hCall=8
132700,36 8 rec RecSoundStop ok
132700,36 8 play PlaySoundStop ok
132700,36 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
132700,36 8 fnHangupCall end
132700,36 8 tw DialogicEvent 129,TDX_PLAY,863656,0,0,,,
132700,36 8 event ScriptEventCode TDX_PLAY, code=129, state=900
132700,36 8 LsAwaitingCalls EV_UNKNOWN_129
132701,28 8 event callstate IDLE 8 1,0,0
132701,28 8 WorkingMode@Idle=
132701,28 8 timer clear
132701,28 8 rec RecSoundStop ok
132701,28 8 play PlaySoundStop ok
132701,28 8 rv add [CallEndTime]{2005-10-26 13:27:01}
132701,33 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
132701,33 8 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
132701,33 8 event ScriptEventCode TDX_SETHOOK, code=135, state=900
132701,33 8 LsAwaitingCalls EV_UNKNOWN_135
132702,35 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
132702,35 8 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
132702,35 8 init atidle reinit : start
132702,35 8 init atidle reinit iConferenceOtherLegLid=-1
132702,35 8 init atidle reinit : reset all LineState variables
132702,35 8 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
132702,35 8 state Waiting for a call...
132702,68 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
132702,68 8 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
132704,11 0 sys cleanup Start
132704,11 0 sys cleanup End
Thank you for your help!
Jose
Hello!
Do I need such a file? I´ve been talking with my phone provider and they don´t know how these DTMF tones are sent, they are just sent.
Looking below in the log file, I can see this:
. So this really means that my provider sends DTMF tones. Looking at this line, can you see the pattern in order to generate the inband file?
I think the 8 in (8,48,48) should be the channel number for this call.
Please, any idea, suggestion!
Jose
Hello!
I need to know how I can get the caller ID from my ISDN telephone company. I have a D/4PCI card which is connected to an ISDN router and the telephone line from the company is connected to this router. This router has 2 analogue ports. If I connect a handset to one of these two ports, I can see the caller ID.
How can I find out these DTMF tones if my telephone company don´t know? Do I need an inband signalling configuration file?
Thanks for your help!
Jose
Hello!
Would the Caller ID on this call have been: 084429040 ?
Yes
Any ideas?
Thanks in advance!
Jose
Please try updating to v6.0.2303 release (available now) - that version should capture the DTMF tones arriving before the first ring and report these as the CallerID.
Hello!
I did it but still I can´t get the CallerID.
In the log file below, I see now that with this new version of voiceguide the first dtmf tone is the letter 'a' instead of a zero from the caller phone number (08-442 90 40).
By the way, I have an inband signalling configuration file that I created by intuation with the following pattern:
Pattern=??
Rv=Inband_Calling,1,2
I have only 2 question mark because I see two characters in here
132638,83 8 tw dtmf 0 (8,[U]48[/U],48)
. However, I don´t see in the log file that voiceguide tries to matches any of the DTMF tones with this pattern.
I just spoke to my telophone company and they told me that they just send DTMF tones. So the question is wheter I need this inband file in order to get the caller ID or not? After all, you say that this version of voiceguide can capture the DTMF tones and initialize the RV_CIDNUMBER, which is system variable.
Jose
1027vgm.txt
Hello again!
Now, it is working (more or less). The problem is that instead of getting the caller phone number, which is 084429040 the RV_CIDNUMBER gets the number between the parenthesis. But the first zero dissaperars.
For example in the above file the RV_CIDNUMBER varaible gets the following numbers:
dtmf a (8, 97, 97 )
dtmf 8 (8, 56, 56)
dtmf 4 (8, 52, 52)
dtmf 4 (8, 52, 52)
dtmf 2 (8, 50, 50)
dtmf 9 (8, 57, 57)
dtmf 0 (8, 48, 48)
dtmf 4 (8, 52, 52)
dtmf 0 (8, 48, 48)
dtmf # (8, 35, 35)
rv add [$RV_CIDNUMBER] {5652525057485248}.
Ok, I think these are the ASCII-code but the question now is how I convert those ASCII-codes to decimal numbers AND why the first zero dissapears?
Thank you!
Jose
Please update with attached .exe
This should report the received DTMFs as actual characters.
VoiceGuide will just capture whatever DTMFs are sent. You should speak with the phone company about what DTMFs it is sending.
Do not us inband configuration files - the DTMFs here are sent before the phone starts ringing, not after the call is answered. The 'inband signaling' definition file is used to listen for and categorize tones sent after the call is answered only.
Please post full trace showing start of call (up to answer only) if you still have any further questions.
VgMulti_6.0.2304.zip
Hello!
Shall I just move this exe file to the voiceguide directory? Or should I also run the regsvr32 commands on a DOS Window? I ask you this because my configuration is now stable so I don´t want to do any mistakes.
Another question, regarding this caller ID is that in my Config.xml file I see for each channel this tag <PopupCallerId>, which I set to 1 thinking that this should change in the voiceguide window the default alternative, "Do not popup Caller ID info" to "Popup Caller ID when Numbers received". But it doesn´t change anything. Is it possible to change this from the Config.xml file?
Thank you!
Jose
Place the attached file in VoiceGuide directory, overwriting existing file. No need to regsvr32.
We've confirmed that there is a problem with this setting - we should be able to have this config bug fixed in next update of VG for Dialogic.
