Vb Script Issue Reading An Excel File
I get a type mismatch error line 17 character 1. Can someone help. I don't understand much about VB script. I want the IVR to remember, from the prior call, What line, of 2, the call was transfered to and then send the new call to the other line. I have no luck with the Eval funtions, it seams that $RV's become empty at the end of a call. I am now trying to set up a VB that changes an excel field, Cell (1,1), form a 1 to a 2 and then from a 2 to a 1 based on the prior call.
Am I making this too difficult ?? is their an easier way?
Dim xlApp 'Excel.Application
Dim xlBook 'Excel.Workbook
dim xlSht
Dim filename, value1, sReturnedRVs
filename = "c:\Agcy WAVS\Upagent.xls"
Set xlApp = CreateObject("Excel.Application")
set xlBook = xlApp.WorkBooks.Open(filename)
set xlSht = xlApp.activesheet
value1 = Abs(Cint(xlSht.Cells(1, 1).Value))
sReturnedRVs = "[value1]{" & value1 & "}"
iRet = WriteResultFile(sReturnedRVs)
workbook.close False
excel.quit
The script uses the "WriteResultFile" function - but that function itself has not been included:
function WriteResultFile(strResult)
const ForReading=1, ForWriting=2, ForAppending=8
Dim filename, fso, ts, outdata, outdata2, outdata3
filename = "VGRUNRESULT_$RV_DEVICEID.TXT"
set ts = fso.OpenTextFile(filename, ForWriting, True)
ts.WriteLine(strResult)
ts.Close
WriteResultFile = 0
end function
there were a few problems furhter down as well... try using this:
dim xlSht
filename = "c:\Agcy WAVS\Upagent2.xls"
xlBook.close False
xlApp.quit
ts.Close
WriteResultFile = 0
end function
Result Variables are only valid during the current call - but if you want to schedule a new call from within the current call you can pass the Result Variables as parameters - see the "Variables" text box of the "Send Phone Message" module...
Current versions of VoiceGuide no longer need to "Write a Result File" - they can just return info back to VG using one of the COM functions. See:
http://www.voiceguide.com/vghelp/html/com_...esultReturn.htm
http://www.voiceguide.com/vghelp/html/com_...Script_Goto.htm
http://www.voiceguide.com/vghelp/html/com_...cript_Gosub.htm
etc.
Some more VBScript samples are also at: http://www.voiceguide.com/vghelp/html/modVbs.htm
