How To Prompt Before Record Sound?
I want to play an audio prompt before recording a sound file. The Record module allows enabling a beep before recording, but doesn't have a Play tab/option.
I was thinking I could use the Play Sound module before the Record module, but how do I setup the Play module to play the sound, and then go to the next module in the path immediately after the sound is played?
There are path conditions for digits and timeout, but I don't want to force the user to press a key or wait for the timeout before the recording/beep occurs.
Thanks,
Jim
I think that I figured this out. If the Timeout in the Path is set to 0, then the Play module takes the Timeout path as soon as the sound playing is completed...
Jim
