Vg For Dialogic
I am using VG for Dialogic v6.0.2214, no matter what I do, I cant get it to answer the call, say, at the 3rd or 4th ring. Of course, I used the CONFIG.XML file to change the RingsBeforeAnswer parameter, to no avail.
Could you help please. Thanx
Just tested this with current v6.0.2275 and it worked fine. Here is the relevant trace aftere we set the <RingsBeforeAnswer> entry in Config.xml to 5:
100750.25  1 event callstate OFFERING 1 2,0,0
100750.28  1      script interpretor: VgMulti v6.0.2275
100750.29  1      fired OFFERING event to listeners
100750.29  1      set LineState().hCall = 1 in LINECALLSTATE_OFFERING
100750.29  1      iIvrDev=1
100750.30  1      set linestate CID vars
100750.30  1      call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
100750.30  1      rings=0, min rings before answer=5 (iCallerIdHasArrived=0)
100750.30  1 tw    ring 1
100750.31  1 ring  time since last ring event (sec): 0.00
100750.31  1      rings=1, min rings before answer=5 (iCallerIdHasArrived=0)
100750.31  1 tw    DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
100750.31  1 event ScriptEventCode TDX_CST, code=134, state=0
100751.52  1 tw    ring 2
100751.52  1 ring  time since last ring event (sec): 1.20
100751.52  1      rings=2, min rings before answer=5 (iCallerIdHasArrived=0)
100751.52  1 tw    DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
100751.52  1 event ScriptEventCode TDX_CST, code=134, state=0
100754.97  1 tw    ring 3
100754.97  1 ring  time since last ring event (sec): 3.45
100754.98  1      rings=3, min rings before answer=5 (iCallerIdHasArrived=0)
100754.98  1 tw    DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
100754.98  1 event ScriptEventCode TDX_CST, code=134, state=0
100756.17  1 tw    ring 4
100756.17  1 ring  time since last ring event (sec): 1.20
100756.18  1      rings=4, min rings before answer=5 (iCallerIdHasArrived=0)
100756.18  1 tw    DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
100756.18  1 event ScriptEventCode TDX_CST, code=134, state=0
100759.61  1 tw    ring 5
100759.61  1 ring  time since last ring event (sec): 3.43
100759.62  1      rings=5, min rings before answer=5 (iCallerIdHasArrived=0)
100759.62  1 rv    clear all
100759.62  1 init  LineState ResetAtStartOfNewCall.
100759.63  1      answer the call
If you still have problems please try updating to v6.0.2275 and then if you still have problems please post the Config.xml file you are using as well as the trace capturing the incoming call and the script which you are using.
Well, here is what my log looks like :
051529.21 1 event callstate OFFERING 1 2,0,0
051529.21 1 script interpretor: VgMulti v6.0.2275
051529.21 1 fired OFFERING event to listeners
051529.21 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
051529.21 1 iIvrDev=1
051529.21 1 set linestate CID vars
051529.21 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
051529.21 1 rings=0, min rings before answer=5 (iCallerIdHasArrived=0)
051529.21 1 tw ring 1
051529.22 1 ring time since last ring event (sec): 0.00
051529.22 1 rings=1, min rings before answer=5 (iCallerIdHasArrived=0)
051529.22 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
051529.22 1 event ScriptEventCode TDX_CST, code=134, state=0
051532.19 1 tw lev_CallerID [092328331,,]
051532.19 1 rings=1, min rings before answer=5 (iCallerIdHasArrived=1)
051532.19 1 rv clear all
051532.19 1 init LineState ResetAtStartOfNewCall.
051532.19 1 answer the call
051532.19 1 timer clear
051532.20 1 tw ring 2
051532.20 1 ring time since last ring event (sec): 2.98
051532.20 1 ring match against pattern 1, cadences=1
051532.20 1 ring template 1, cadence 1 = [110|20] edge time=298.2
051532.20 1 ring match distinct ring pattern 1 cycle 1 fail
051532.20 1 ring match against pattern 2, cadences=1
051532.20 1 ring template 2, cadence 1 = [85|10] edge time=298.2
051532.20 1 ring match distinct ring pattern 2 cycle 1 fail
051532.20 1 rings=2, min rings before answer=5 (iCallerIdHasArrived=1)
051532.20 1 rv clear all
051532.20 1 init LineState ResetAtStartOfNewCall.
051532.20 1 answer the call
Any clues as to why it is answering before the 5th ring ??
and here is the config.xml
<?xml version="1.0"?>
<VoiceGuideConfig>
<Devices_Dialogic>
<Channels>
<Channel>
<Name>dxxxB1C1</Name>
<NetworkIf>dxxxB1C1</NetworkIf>
<Protocol>pdk_na_an_io</Protocol>
<RingsBeforeAnswer>5</RingsBeforeAnswer>
<script>C:\CardCustomer\CardCustomer.vgs</Script>
<ConfigLine></ConfigLine>
<PopupCallerId>1</PopupCallerId>
<RV></RV>
</Channel>
<Channel>
<Name>dxxxB1C2</Name>
<NetworkIf>dxxxB1C2</NetworkIf>
<RingsBeforeAnswer>0</RingsBeforeAnswer>
<PopupCallerId>0</PopupCallerId>
<RV></RV>
</Channel>
<Channel>
<Name>dxxxB1C3</Name>
<NetworkIf>dxxxB1C3</NetworkIf>
<RingsBeforeAnswer>2</RingsBeforeAnswer>
<RV></RV>
</Channel>
<Channel>
<Name>dxxxB1C4</Name>
<NetworkIf>dxxxB1C4</NetworkIf>
<RV></RV>
</Channel>
</Channels>
<Parms>
<SetParm>
<Description>DTMF Interdigit Delay. Time between digits in DTMF dialing (10ms units)</Description>
<Key>DXBD_T_IDD</Key>
<Value>15</Value>
<Default>10</Default>
</SetParm>
<SetParm>
<Description>DTMF length (duration) for dialing (10ms units)</Description>
<Key>DXBD_TTDATA</Key>
<Value>10</Value>
</SetParm>
<SetParm>
<Description>Pause Time. Delay caused by a comma in the dialing string</Description>
<Key>DXBD_PAUSETM</Key>
<Value>100</Value>
<Default>100</Default>
</SetParm>
<SetParm>
<Description>Flash time during dialing</Description>
<Key>DXBD_FLASHTM</Key>
<Value>10</Value>
</SetParm>
<SetParm>
<Description>Silence on and off debounce time </Description>
<Notes>debunce length should be really small so that
we can easily tell when the transition happens</Notes>
<Key>DXBD_S_BNC</Key>
<Value>4</Value>
<Default>4</Default>
</SetParm>
</Parms>
</Devices_Dialogic>
<Devices_CTI>
<CtiLink>
<CommsLink>
<Target></Target>
<Notes></Notes>
<IP></IP>
<Port></Port>
<Params></Params>
</CommsLink>
<MonitoredDevices>
<Ext></Ext>
<Ext></Ext>
</MonitoredDevices>
</CtiLink>
</Devices_CTI>
</VoiceGuideConfig>
