Answer Disconnect
I call into voice guide using D4/PCIU card, and it disconnects after picking up. Ocassionally it will run whole script. Here's the results:
173748.92 7 linedevstate 2048 0 0
173748.94 7 callstate OFFERING 65827 0 4
173748.94 7 rv clear
173748.94 7 Answer the call at 9/22/2005 5:37:48 PM
173748.95 7 lineAnswer(65827) => 65810
173748.95 7 ev Lev_CallerID [12545191000,NOBLE PHONE SER,2542471458]
173748.95 7 rv lg add [DNIS]{2542471458}
173748.95 7 callinfo CALLEDID
173748.95 7 callinfo ORIGIN
173748.95 7 ring 0
173749.48 7 callstate CONNECTED 65827 1 0
173749.50 7 callstate CONNECTED 65827,1,0
173749.50 7 WorkingModeTAPI@Connected=
173749.50 7 WorkingModeScript@Connected=
173749.50 7 Inband detection not enabled
173749.50 7 StartLoadedVgs at 9/22/2005 5:37:49 PM, script interpretor VgMulti v5.2.5003 3
173749.50 7 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\Call Transfer\}
173749.52 7 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\Call Transfer}
173749.52 7 rv lg add [$RV_STARTTIME]{9/22/2005 5:37:49 PM}
173749.52 7 rv lg add [$RV_DEVICEID]{7}
173749.53 7 rv lg add [$RV_CIDNAME]{NOBLE PHONE SER}
173749.53 7 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
173749.53 7 rv lg add [$RV_CIDNUMBER]{12545191000}
173749.55 7 rv lg add [$RV_DNIS]{2542471458}
173749.55 7 rv lg add [DNIS]{2542471458}
173749.55 7 tapi Reply (LineEvReply) ok 65810 0
173749.55 7 callinfo MONITORMODES
173749.56 7 timer clear
173749.56 7 [CallerIDCheck] Evaluate [$RV_CIDNUMBER]
173749.56 7 rv replace start: [$RV_CIDNUMBER]
173749.58 7 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DNIS]{2542471458}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\Call Transfer\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\Call Transfer}[$RV_STARTTIME]{9/22/2005 5:37:49 PM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{NOBLE PHONE SER}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{12545191000}[$RV_DNIS]{2542471458}[DNIS]{2542471458}
173749.58 7 rv replace end: [12545191000]
173749.58 7 .Eval(12545191000)
173749.61 7 rv ns add [CallerIDCheck_Input]{12545191000}
173749.61 7 rv ns add [CallerIDCheck]{12545191000}
173749.61 7 Eval Expr result:[12545191000]
173749.61 7 callstate DISCONNECTED 65827 0 0
173749.63 7 ScriptEventCode 9250 iLineState=5900
173749.63 7 rv lg add [Hangup Time]{9/22/2005 5:37:49 PM}
173749.63 7 Hanging up call... [LsModuleTransition]
173749.64 7 RecSoundStop ok
173749.64 7 PlaySoundStop err=0
173749.64 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
173749.64 7 fnHangupCall end
173749.66 0 dial start any summary:|7:hc>0|
173749.66 7 ERROR RunModule called while iHangupCalledForThisLine>0 (strWorkingModeScript=)
173751.52 7 linedevstate 2048 0 0
173751.52 7 callstate IDLE 65827 0 0
173751.53 7 WorkingMode@Idle=
173751.53 7 timer clear
173751.55 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
173751.55 7 tapi Reply (LineEvReply) ok 65793 0
173752.53 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
173752.53 7 ScriptEventCode 9008 iLineState=900
173752.53 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
173752.53 7 ReinitTelephony due to IDLE
173752.55 7 tapic lineDeallocateCall(MainCall:65827) 0
173752.59 7 lineOpen(7)=>
173752.61 7 Waiting for a call...
173752.61 7 LineHandle=65776
173752.61 7 amchk set AMdet=False in Reinit@idle
173752.63 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
173752.66 0 dial start any summary:|7:rdy=0|
173755.91 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
173755.91 7 ScriptEventCode 9013 iLineState=900
173756.66 0 dial start any summary:|7:idx=0|
Please help me resolve soon. Thankyou
From the timing data it looks like the card may be detecting a loop current drop on the line...
To find out more what's causing it you will need to use VG for Dialogic which will show exactly why call ended (in the MMDDtw.txt log file).
I thought I was using VG for Dialogic. Where can I find "(in the MMDDtw.txt log file)."
Thank you,
Thomas
You're using v5.2.5003 of VoiceGuide. That versio is not VoiceGuidefor Dialogic. Please see our Downloads page from where you can download VoiceGuide for Dialogic.
Logs to files are saved in Voiceguide's \log\ subdirectory.
