Vbscript Sql Error
I am trying to send a value to a stored procedure to a sql server. I have looked at all the voiceguide examples for vb script and still no luck.
When trying to use the example syntax i receive an error msg saying "arguments are of the wrong type, are out of acceptable range, or are inconflict with one another.
Code: 800A0BB9
Source: ADODB.Command
for this line .CommandType = adCmdStoredProc
With cmd
set .ActiveConnection = cn
.CommandText = "dbo.[ivr_hti_phoneval]"
Any help or other example sql stored procedure scripts would be greatly appreciated.
Not sure on the exact syntax of what you are doing here, but try using the proper RV substitution of "$RV[ModuleName]" intead of just [ModuleName], eg:
With cmd
CommandText = "dbo.$RV[ivr_hti_phoneval]
To see if this works as expected, look in the voiceguide directory for the temporary VBS files that hold the actual code run after RV substitution. (They either held in the TEMP directory for newer VG versions or the DATA directory. The one with the latest timestamps are the ones run most recently and the exact filenames can be found in the debug-trace.
Hope this helps - Tim.
What im trying to do is run a stored procedure on an sql server called ivr_hti_phoneval.
If i ran it in a sql query it would look like this "exec ivr_hti_phoneva someparameter"
I have a customer sql database that has a stored procedure that will accept the customer number and return 5 values such as balance, date of payment, etc.
I could not get the Database Query module to return the proper results so I trying to write a VB script to do the same thing.
This is some sample testing code to make the connection. The problem is with line 16 char 1
dim cmd, prm, rs, cn
set cn = CreateObject("ADODB.Connection")
set cmd = CreateObject("ADODB.Command")
cn.ConnectionString = "Provider=SQLOLEDB;Server=XXX.XXX.XXX.XXX;UID=XXXX;PWD=XXXX;Database=XXXX"
cn.open
With cmd
.CommandType = adCmdStoredProc 'line 16
.CommandText = "dbo.ivr_hti_phoneval"
set prm= .CreateParameter("@RETURN_VALUE", adInteger, adParamReturnValue, 4)
.Parameters.Append prm
set prm = .CreateParameter("@phone_nbr", adVarChar, adParamInput, 12)
set prm= .CreateParameter("@match", adVarChar, adParamOutput, 1)
set prm = .CreateParameter("@paid_thru_date", adVarChar, aadParamOutput, 8)
set prm= .CreateParameter("@active", adVarChar, adParamOutput, 1)
set prm = .CreateParameter("@current_balance", adVarChar, adParamOutput, 6)
set prm = .CreateParameter("@cust_id_nbr", adVarChar, adParamOutputt, 20)
set rs= cmd.execute
End With
cn.Close
set rs = Nothing
set cn = Nothing
set vg = Nothing
Set cmd = Nothing
WScript.Quit
Edited by SupportTeam
Have you defined the adCmdStoredProc constant?
Here are some of the constants you may need in your VBScript
Const adParamInput = 1
Const adParamOutput = 2
Const adInteger = 3
Const adCmdStoredProc = 4
Const adExecuteNoRecords = 128
Const adVarChar = 200
you will still need to find out value of adParamReturnValue and any others...
PS. we edited your previous post as per your request.
PPS.
This line has a spelling mistake (highlighted in bold):
You dont need to create and add each stored procedure paramater manually.
just call
cmd.Parameters.Refresh
This will fetch all parameters
