Transfer Call
Hello,
I have been reading many posts and the online tutorial about how to configure voiceguide and there are some parts that I don´t understand clearly.
Well, I have a Dialogic card D/41JCT-LS, version 6 of voiceguide and WindowsXP. I would like to configure my Dialogic card so that the signals(hookflah,..) generated by voiceguide can be understood by my converter (Linksys), which in turns communicates with the PBX system.
I have read that when using WindowsXP it is much better to configure the dialogic card using the .prm files than introducing the parameters in the TSP window. Is it truth? Because in that case I don´t have the .prm file for my Dialogic card; I live in Sweden and there are 2 or 3 files se_something.prm but none of them matches my Dialogic card (D/41JCT) se_d41j.prm.
I have a script using the transfer call module and I want to use the announced call. I would like to make several (at least 3) calls as long as nobody answers the phone. When I call the script, after introducing some information, the script tries to make the first call. So what I hear while waiting is some music. If the other person answers the phone then everything works fine, I mean voiceguide hangs up and the two person can talk to each other.
The problem appears when nobody answers the phone the first time; The script is writen in such a way that I iterate 3 times through the same transfer call module and a play module that says "sorry, nobody answered but we will try now
with another phone number" before it hangs up.
So voiceguide takes the fail path in the transfer call module, which it is the play module and sometimes I hear this message and sometimes I don´t. However, when voiceguide tries to call the second phone number, it is still ringing in the first one and I hear in my phone the message asking me if I want to accept the call, then press 1; if I press 1 then everything hangs up but If I don´t do anything but wait then after ~30 seconds voiceguide makes the third call and in this cases it really calls to the real phone. If this person answers the phone then the communication is established.
Could you tell me what I am doing wrong?
Thank you for your help!
Sounds like the hookflash setting is fine as issuing it for the first time results in the caller being placed on hold and the transfer destination number ringing.
Could you please post a copy of VoiceGuide's Debug Printouts which capture each of these scenarios, this will allow us to see what happened in each to give you a different result.
I think you would need to issue a hookflash to 'take back' the call.
It all depends on the PBX (or Linksys?) as to what needs to be done - but basically find out what hookflashes and buttons need to be pressed/sent in order for the transfer attempt to be abandoned and control returned back to VG so that it can start another transfer attempt. Usually just a hookflash is needed.
The signals issued are set in "PBX Strings" config window. See: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm
Hello,
The printout is too long for the event log trace so I´ll send you the whole file called "0909vgm.txt". As you will see from the file (I hope) voiceguide didn´t make any call, although I heard in my phone some music and then voiceguide just hanged up.
Thank you!
0909vgm.txt
From trace we see that calls arrived at:
085504,69 8 event callstate OFFERING 8 0 0
and
085630,83 8 event callstate OFFERING 8 0 0
What happened from callers perspective on each call? What did the caller hear on the line on each of the calls?
Well it depends:
- sometimes I hear dialing the numbers and then voiceguide (VG) ask me to press 1 to accept the call and no matter what I choose VG hangs up the phone.
- sometimes I hear playing some music while waiting and VG calls the first phone number. If nobody answers that phone the script tells the caller that nobody answered and it will try with the next phone number. And again, VG dials the second phone number but it is the caller who listens to the message; press 1 to accept the call or just hang up.
Here I´ll send you the file separeted with a line with this character - showing the two cases mentioned above.
0909vgm.txt
What happened from callers perspective on each of the two calls of which the traces were supplied? What did the caller hear on the line on each of the calls?
Hello!
As I said in the last post; sometimes the caller only hears some music while waiting for VG to make the first call and sometimes the caller hears when the numbers are being dialed and right after that the caller then hear that file that says press 1 to accept the call or just hang up. The fact is that I don´t know why I hear different things, even though I have not changed anything in the script during the tests, neither the way I executed the script.
Is it possible to iterate through a transfer call module several times trying to make calls until someone picks up the phone? Because this is what I am trying to do in my application.
Thanks!
Jose
What we would need to be able to make any comment on what happened is a debug trace capturing the call and a detailed descript of what the caller heard during that particular call.
Yes, if using announced or monitored transfers.
Hello!
What I meant was: Is it possible to iterate through a play module (info_to_customer) and a transfer call module several times trying to make calls until someone picks up the phone? Does this play module intefere with the transfer call module in any way? I mean Shall I add a hookflah after the sound file or any comma in this play module ?
Now, I have changed the hookflash to 50ms and I don´t hear any more the "press 1 to .." in my line the first time voiceguide makes a call. The idea isthat the application should try to iterate through 3 phone numbers (all of the phone numbers are a mobile phone number)and if nobody answers the phone then the application should play another play module (Sorry) saying that the phones are not available at the moment, please try later.
When voiceguide makes the first call the caller hears the info_to_customer message and then the music on hold and I hear that the mobile is ringing. Here it comes the debug trace:
130324,95 8 tw dtmf a (8,97,97)
130324,95 8 event a, code=97, state=0
130324,95 8 tw DialogicEvent 134,TDX_CST,97,0,0,DE_DIGITS,,
130324,95 8 event TDX_CST, code=134, state=0
130324,97 3 tw dtmf a (3,97,97)
130324,97 3 event a, code=97, state=0
130324,97 3 tw DialogicEvent 134,TDX_CST,97,0,0,DE_DIGITS,,
130324,98 3 event TDX_CST, code=134, state=0
130325,02 3 tw dtmf 4 (3,52,52)
130325,03 3 event 4, code=52, state=0
130325,03 3 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
130325,05 3 event TDX_CST, code=134, state=0
130325,06 8 tw dtmf 4 (8,52,52)
130325,06 8 event 4, code=52, state=0
130325,08 8 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
130325,08 8 event TDX_CST, code=134, state=0
130325,19 8 tw dtmf 1 (8,49,49)
130325,19 8 event 1, code=49, state=0
130325,20 8 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
130325,22 8 event TDX_CST, code=134, state=0
130325,23 3 tw dtmf 1 (3,49,49)
130325,25 3 event 1, code=49, state=0
130325,27 3 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
130325,28 3 event TDX_CST, code=134, state=0
130325,34 8 tw dtmf # (8,35,35)
130325,36 8 event #, code=35, state=0
130325,38 8 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
130325,39 8 event TDX_CST, code=134, state=0
130325,41 3 tw dtmf # (3,35,35)
130325,42 3 event #, code=35, state=0
130325,44 3 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
130325,47 3 event TDX_CST, code=134, state=0
130325,95 8 event callstate OFFERING 8 0 0
130325,97 8 script interpretor: VgMulti v6.0.2092
130325,98 8 fired OFFERING event to listeners
130326,00 8 iIvrDev=8
130326,02 8 set linestate CID vars
130326,03 8 call AnswerTheCallIfAllowed
130326,05 8 tw ring 1
130326,06 8 ring time since last ring (ms): 0
130326,08 8 rv clear all
130326,09 8 init LineState ResetAtStartOfNewCall.
130326,11 8 answer the call
130326,13 8 timer clear
130326,13 8 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
130326,16 8 event TDX_CST, code=134, state=6001
130326,67 8 event callstate CONNECTED 8 0 0
130326,69 8 WorkingModes tapi= script=
130326,72 8 Inband detection not enabled
130326,73 8 StartLoadedVgs at 2005-09-12 13:03:26
130326,75 8 set sScriptToRunOnHangup=[] in StartLoadedVgs
130326,77 8 init StartLoadedVgs_InitLineState start
130326,78 8 rv add [$RV_STARTTIME]{2005-09-12 13:03:26}
130326,80 8 rv add [$RV_DEVICEID]{8}
130326,81 8 rv add [$RV_CIDNAME]{}
130326,83 8 rvns add [PathApp]{C:\Program\VoiceGuide\}
130326,84 8 rvns add [scriptsPath]{C:\Voice_jose_problema\Locksmith\}
130326,86 8 rv add [$RV_CIDNUMBER]{}
130326,88 8 fn RunModule start
130326,89 8 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
130326,91 8 event TDX_SETHOOK, code=135, state=6001
130326,92 8 tw DialogicEvent 134,TDX_CST,7833,0,0,DE_LCON,,
130326,94 8 event TDX_CST, code=134, state=6001
130326,95 8 timer clear
130326,97 8 Play Module start
130326,98 8 state [WELCOME] Playing
130327,00 8 state [WELCOME] Playing (C:\Voice\Locksmith\voice\welcome_locksmith_1.wav)
130327,02 8 tw ConvertWav2Vox C:\Voice\Locksmith\voice\welcome_locksmith_1.wav
130327,03 8 timer clear
130327,11 8 tw wav->vox convert end 247515,C:\Voice\Locksmith\voice\welcome_locksmith_1.vox,1,0,,
130327,14 8 play start ok, lPlayId=247625
130333,56 0 sys cleanup Start
130333,58 0 sys cleanup End
130338,30 8 tw PlayEnd 8 247625
130338,31 8 play end id=247625, (current ID)
130338,33 8 event EV_PLAY_FINISHED, code=8001, state=1100
130338,34 8 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
130338,36 8 path {EV_PLAY_FINISHED} not found
130338,38 8 timer set 10 EV_TIMEOUT_HANGUP
130338,39 8 timer set 0 EV_TIMEOUT_GOTOMODULE
130338,41 8 event EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
130338,42 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
130338,44 8 path {EV_TIMEOUT_GOTOMODULE} not found
130338,45 8 fn RunModule start
130338,47 8 tw DialogicEvent 129,TDX_PLAY,247625,0,0,,,
130338,48 8 event TDX_PLAY, code=129, state=6001
130338,52 8 timer clear
130338,53 8 state [set_Sound_Files] Evaluate ["C:\Voice\Locksmith\voice\"]
130338,55 8 eval[Cstr("C:\Voice\Locksmith\voice\")]
130338,56 8 rvns add [set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}
130338,58 8 rvns add [set_Sound_Files]{C:\Voice\Locksmith\voice\}
130338,59 8 rvns add [DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}
130338,63 8 Eval Expr result:[C:\Voice\Locksmith\voice\] stored in $RV[DIRSYSTEMVOICE]
130338,64 8 path {C:\Voice\Locksmith\voice\} not found
130338,66 8 fn RunModule start
130338,67 8 timer clear
130338,69 8 state [Var_Result_Query] Evaluate []
130338,72 8 eval[]
130338,73 8 rvns add [Var_Result_Query_Input]{}
130338,75 8 rvns add [Var_Result_Query]{}
130338,77 8 rvns add [resultQuery]{}
130338,78 8 Eval Expr result:[] stored in $RV[resultQuery]
130338,80 8 path {} not found
130338,81 8 fn RunModule start
130338,83 8 timer clear
130338,84 8 state [selection_Choice] Number Input
130338,88 8 state [selection_Choice] Playing (C:\Voice\Locksmith\voice\selection_choice_1.wav)
130338,89 8 tw ConvertWav2Vox C:\Voice\Locksmith\voice\selection_choice_1.wav
130338,91 8 timer clear
130339,00 8 tw wav->vox convert end 259390,C:\Voice\Locksmith\voice\selection_choice_1.vox,1,0,,
130339,03 8 play start ok, lPlayId=259515
130344,89 8 tw dtmf 1 (8,49,49)
130344,91 8 event 1, code=49, state=1300
130344,92 8 LsGetNbrsPlayWelcMsg 1,1
130344,95 8 play PlaySoundStop ok
130344,97 8 state [selection_Choice] Number Input 1
130344,98 8 rv add [selection_Choice]{1}
130345,00 8 rvns add [selection_Choice_PathTaken]{1}
130345,02 8 fn RunModule start
130345,03 8 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
130345,05 8 event TDX_CST, code=134, state=6001
130345,06 8 tw PlayEnd 8 259515
130345,08 8 play end id=259515, (current ID)
130345,09 8 event EV_PLAY_FINISHED, code=8001, state=6001
130345,11 8 tw DialogicEvent 129,TDX_PLAY,259515,0,0,,,
130345,13 8 event TDX_PLAY, code=129, state=6001
130345,14 8 timer clear
130345,16 8 state [Get_Post_Code] Number Input
130345,17 8 state [Get_Post_Code] Playing (C:\Voice\Locksmith\voice\get_post_code_1.wav)
130345,19 8 tw ConvertWav2Vox C:\Voice\Locksmith\voice\get_post_code_1.wav
130345,22 8 timer clear
130345,33 8 tw wav->vox convert end 265687,C:\Voice\Locksmith\voice\get_post_code_1.vox,1,0,,
130345,34 8 play start ok, lPlayId=265843
130348,89 8 tw PlayEnd 8 265843
130348,91 8 play end id=265843, (current ID)
130348,92 8 event EV_PLAY_FINISHED, code=8001, state=1300
130348,94 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
130348,95 8 path {EV_PLAY_FINISHED} not found
130348,97 8 timer set 5 EV_TIMEOUT_REPLAYMSG
130348,98 8 tw DialogicEvent 129,TDX_PLAY,265843,0,0,,,
130349,00 8 event TDX_PLAY, code=129, state=1301
130349,02 8 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
130349,03 8 path {TDX_PLAY} not found
130350,11 8 tw dtmf 0 (8,48,48)
130350,13 8 event 0, code=48, state=1301
130350,14 8 LsGetNbrsRxDigits 0,0
130350,16 8 state [Get_Post_Code] Number Input 0
130350,17 8 path {0} not found
130350,19 8 timer set 6 EV_TIMEOUT_ENTERDATA
130350,20 8 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
130350,22 8 event TDX_CST, code=134, state=1301
130350,23 8 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
130350,25 8 path {TDX_CST} not found
130351,03 8 tw dtmf 0 (8,48,48)
130351,05 8 event 0, code=48, state=1301
130351,06 8 LsGetNbrsRxDigits 0,0
130351,08 8 state [Get_Post_Code] Number Input 00
130351,09 8 path {00} not found
130351,11 8 timer set 6 EV_TIMEOUT_ENTERDATA
130351,13 8 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
130351,14 8 event TDX_CST, code=134, state=1301
130351,16 8 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
130351,17 8 path {TDX_CST} not found
130355,05 8 tw dtmf 0 (8,48,48)
130355,06 8 event 0, code=48, state=1301
130355,08 8 LsGetNbrsRxDigits 0,0
130355,09 8 state [Get_Post_Code] Number Input 000
130355,11 8 path {000} not found
130355,13 8 timer set 6 EV_TIMEOUT_ENTERDATA
130355,14 8 timer clear
130355,16 8 rv add [Get_Post_Code]{000}
130355,17 8 path {000} not found
130355,19 8 rvns add [Get_Post_Code_PathTaken]{success}
130355,20 8 fn RunModule start
130355,22 8 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
130355,23 8 event TDX_CST, code=134, state=6001
130355,27 8 timer clear
130355,28 8 state [CASE_locksmith_post] DB Query
130355,30 8 db ODBC mode used
130355,52 8 rv replace start: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =$RV[Get_Post_Code]]
130355,53 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
ice]{1}[selection_Choice_PathTaken]{1}[Get_Post_Code]{000}[Get_Post_Code_PathTak
n]{success}
130355,56 8 rv replace end: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
130355,58 8 db About to execute a Retrieve type operation [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
130355,64 8 db [CASE_locksmith_post] row count=1
130355,66 8 rv add [CASE_locksmith_post_RowCount]{1}
130355,70 8 db get RecordsetGetRowsMax
130355,72 8 db get 999 records. (row count=1)
130355,75 8 db update RVs
130355,77 8 db about to close dbDbqDatabase
130355,78 8 db going down path [True]
130355,81 8 fn RunModule start
130355,83 8 timer clear
130355,84 8 state [Counter_post] Evaluate [1]
130355,88 8 eval[1]
130355,89 8 rvns add [Counter_post_Input]{1}
130355,91 8 rvns add [Counter_post]{1}
130355,92 8 rvns add [counter]{1}
130355,94 8 Eval Expr result:[1] stored in $RV[counter]
130355,95 8 path {1} not found
130355,97 8 fn RunModule start
130355,98 8 timer clear
130356,00 8 state [Check_columns_post] Running VB Script...
130356,02 8 rv replace start (strlen>500)
130356,03 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
n]{success}[CASE_locksmith_post_RowCount]{1}[CASE_locksmith_post_1_1]{+467393898
0}[CASE_locksmith_post_2_1]{+46739389890}[CASE_locksmith_post_3_1]{+46739389890}
Counter_post_Input]{1}[Counter_post]{1}[counter]{1}
130356,06 8 vbs ran [vbs_8_1.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_8_1.vbs" //I //T:60]
130356,14 8 Run Script waiting. iRunWait=1 (shellid=2368, process=1776)
130356,17 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
130356,23 8 cl RvSet resultQuery, 0739389890
130356,25 8 rv add [resultQuery]{0739389890}
130356,28 8 cl Run_ResultReturn >>success<<
130356,30 8 rv add [Check_columns_post_ResultReturn]{success}
130356,31 8 cl module's runwait=1, WavPlayHasNowFinished=0
130356,34 8 fn RunModule start
130356,36 8 timer clear
130356,38 8 Play Module start
130356,41 8 state [info_To_Customer] Playing
130356,42 8 state [info_To_Customer] Playing (c:\Voice\Locksmith\voice\nu_kopplar_1.wav)
130356,44 8 tw ConvertWav2Vox c:\Voice\Locksmith\voice\nu_kopplar_1.wav
130356,45 8 timer clear
130356,53 8 tw wav->vox convert end 276937,c:\Voice\Locksmith\voice\nu_kopplar_1.vox,1,0,,
130356,56 8 play start ok, lPlayId=277062
130401,30 8 tw PlayEnd 8 277062
130401,31 8 play end id=277062, (current ID)
130401,33 8 event EV_PLAY_FINISHED, code=8001, state=1100
130401,34 8 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
130401,36 8 path {EV_PLAY_FINISHED} not found
130401,38 8 timer set 10 EV_TIMEOUT_HANGUP
130401,39 8 timer set 0 EV_TIMEOUT_GOTOMODULE
130401,42 8 event EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
130401,44 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
130401,45 8 path {EV_TIMEOUT_GOTOMODULE} not found
130401,47 8 fn RunModule start
130401,48 8 timer clear
130401,50 8 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
130401,52 8 tw DialogicEvent 129,TDX_PLAY,277062,0,0,,,
130401,53 8 event TDX_PLAY, code=129, state=1901
130401,55 8 LsXfer_1_Start : 129(EV_UNKNOWN_129),TDX_PLAY,277062,0,0,,,
130401,56 8 path {TDX_PLAY} not found
130401,92 8 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
130401,94 8 event EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
130401,95 8 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
130401,97 8 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
130401,98 8 timeout on transfer attempt set by timeout path (35 sec)
130402,00 8 timer set 35 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
130402,03 8 rv replace start: [$RV[resultQuery],,]
130402,05 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
Counter_post_Input]{1}[Counter_post]{1}[counter]{1}[resultQuery]{0739389890}[Che
130402,09 8 rv replace end: [0739389890,,]
130402,11 8 state [Locksmith] Announced Hookflash Transfer to 0739389890,,
130402,41 8 tw PlayEnd 8 0
130402,42 8 play end id=0, (current ID)
130402,45 8 event EV_PLAY_FINISHED, code=8001, state=1902
130402,47 8 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
130402,50 8 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
130402,52 8 event TDX_DIAL, code=132, state=1902
130402,53 8 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
130402,56 8 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
130402,58 8 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
130404,69 8 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
130404,70 8 event EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
130404,72 8 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
130404,75 8 Dial(0739389890,,, cp on) call
130404,77 8 Dial(0739389890,,) ok
130404,78 8 timer set 35 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
I don´t pick up the mobile phone so after ~35 seconds it times out and voiceguide then will try with the second phone number (which is still the same mobile).Here, the caller hears the info_to_customer message, then it also hears that some numbers are being dialing in the same line, silence and then the music on hold. The mobile phone is ringing.
130415,78 8 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
130415,80 8 event RINGBACK, code=134, state=1903
130415,83 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,RINGBACK,199,0,0,DE_TONEON,TID_RNGBK1,
130415,84 8 event TID_RNGBK1, code=134, state=1903
130415,86 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TID_RNGBK1,199,0,0,DE_TONEON,TID_RNGBK1,
130415,88 8 event TDX_CST, code=134, state=1903
130416,00 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
130443,64 8 timer fired EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
130443,66 8 event EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG, code=9021, state=1903
130443,67 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 9021,EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG,0,0,0,,,
130443,69 8 Transfer timed out
130443,70 8 xfer dial !
130443,98 8 tw PlayEnd 8 0
130444,00 8 play end id=0, (current ID)
130444,03 8 event EV_PLAY_FINISHED, code=8001, state=1906
130444,05 8 LsXfer_5B : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
130444,06 8 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
130444,08 8 event TDX_DIAL, code=132, state=1906
130444,09 8 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
130444,11 8 sXferDialResult_SuccOrFail=
130444,14 8 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=timeout (2)= (3)=
130444,16 8 fn RunModule start
130444,17 8 timer clear
130444,19 8 state [Evaluate_Counter] Running VB Script...
130444,20 8 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
'msgbox(test)
counter = vg.RvGet($RV_LINEID, "RV[counter]")
counter = counter + 1
vg.RvSet $RV_LINEID, "counter", counter
if counter > 3 then '3 därför att det finns 3 telefonnummer
else
vg.Run_ResultReturn $RV_LINEID, "fail"
end if
set vg = Nothing
130444,22 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
130444,25 8 vbs ran [vbs_8_2.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_8_2.vbs" //I //T:60]
130444,31 8 Run Script waiting. iRunWait=1 (shellid=3808, process=1672)
130444,33 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
130444,41 8 cl RvGet RV[counter]
130444,42 8 rv replace start: [$RV[counter]]
130444,44 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
130444,48 8 rv replace end: [1]
130444,52 8 cl RvSet counter, 2
130444,53 8 rv add [counter]{2}
130444,55 8 cl Run_ResultReturn >>fail<<
130444,58 8 rv add [Evaluate_Counter_ResultReturn]{fail}
130444,59 8 cl module's runwait=1, WavPlayHasNowFinished=0
130444,63 8 fn RunModule start
130444,64 8 timer clear
130444,66 8 state [Which_One] Running VB Script...
130444,69 8 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
'msgbox(test)
if $RV[selection_Choice]= 1 then '1->post, 2->ort
else
end if
set vg = Nothing
130444,70 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
k_columns_post_ResultReturn]{success}[counter]{2}[Evaluate_Counter_ResultReturn]
fail}
130444,73 8 vbs ran [vbs_8_3.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_8_3.vbs" //I //T:60]
130444,80 8 Run Script waiting. iRunWait=1 (shellid=3532, process=1700)
130444,83 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
130444,91 8 cl Run_ResultReturn >>success<<
130444,92 8 rv add [Which_One_ResultReturn]{success}
130444,95 8 cl module's runwait=1, WavPlayHasNowFinished=0
130444,97 8 fn RunModule start
130445,00 8 timer clear
130445,02 8 state [Check_columns_post] Running VB Script...
130445,03 8 rv replace start (strlen>500)
130445,06 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
fail}[Which_One_ResultReturn]{success}
130445,09 8 vbs ran [vbs_8_4.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_8_4.vbs" //I //T:60]
130445,16 8 Run Script waiting. iRunWait=1 (shellid=3676, process=1468)
130445,19 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
130445,27 8 cl RvSet resultQuery, 0739389890
130445,28 8 rv add [resultQuery]{0739389890}
130445,31 8 cl Run_ResultReturn >>success<<
130445,33 8 rv add [Check_columns_post_ResultReturn]{success}
130445,36 8 cl module's runwait=1, WavPlayHasNowFinished=0
130445,38 8 fn RunModule start
130445,41 8 timer clear
130445,42 8 Play Module start
130445,44 8 state [info_To_Customer] Playing
130445,45 8 state [info_To_Customer] Playing (c:\Voice\Locksmith\voice\nu_kopplar_1.wav)
130445,48 8 tw ConvertWav2Vox c:\Voice\Locksmith\voice\nu_kopplar_1.wav
130445,50 8 timer clear
130445,58 8 tw wav->vox convert end 325984,c:\Voice\Locksmith\voice\nu_kopplar_1.vox,1,0,,
130445,61 8 play start ok, lPlayId=326093
130448,97 8 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
130448,98 8 event RINGBACK, code=134, state=1100
130449,00 8 LsPlayMsg EV_UNKNOWN_134,RINGBACK
130449,02 8 path {RINGBACK} not found
130449,03 8 event TID_RNGBK1, code=134, state=1100
130449,05 8 LsPlayMsg EV_UNKNOWN_134,TID_RNGBK1
130449,06 8 path {TID_RNGBK1} not found
130449,08 8 event TDX_CST, code=134, state=1100
130449,11 8 LsPlayMsg EV_UNKNOWN_134,TDX_CST
130449,13 8 path {TDX_CST} not found
130450,34 8 tw PlayEnd 8 326093
130450,36 8 play end id=326093, (current ID)
130450,38 8 event EV_PLAY_FINISHED, code=8001, state=1100
130450,39 8 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
130450,42 8 path {EV_PLAY_FINISHED} not found
130450,44 8 timer set 10 EV_TIMEOUT_HANGUP
130450,45 8 timer set 0 EV_TIMEOUT_GOTOMODULE
130450,47 8 event EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
130450,48 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
130450,50 8 path {EV_TIMEOUT_GOTOMODULE} not found
130450,53 8 fn RunModule start
130450,55 8 tw DialogicEvent 129,TDX_PLAY,326093,0,0,,,
130450,56 8 event TDX_PLAY, code=129, state=6001
130450,58 8 timer clear
130450,59 8 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
130451,02 8 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
130451,03 8 event EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
130451,05 8 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
130451,06 8 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
130451,08 8 timeout on transfer attempt set by timeout path (35 sec)
130451,11 8 timer set 35 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
130451,13 8 rv replace start: [$RV[resultQuery],,]
130451,14 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
fail}[Which_One_ResultReturn]{success}[resultQuery]{0739389890}[Check_columns_po
130451,17 8 rv replace end: [0739389890,,]
130451,20 8 state [Locksmith] Announced Hookflash Transfer to 0739389890,,
130451,48 8 tw PlayEnd 8 0
130451,52 8 play end id=0, (current ID)
130451,53 8 event EV_PLAY_FINISHED, code=8001, state=1902
130451,55 8 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
130451,58 8 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
130451,61 8 event TDX_DIAL, code=132, state=1902
130451,63 8 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
130451,64 8 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
130451,77 8 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
130453,86 8 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
130453,88 8 event EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
130453,89 8 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
130453,92 8 Dial(0739389890,,, cp on) call
130453,94 8 Dial(0739389890,,) ok
130453,95 8 timer set 35 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
And with the last part the caller hears that some numbers are being dialing in the same line and after the "press 1 to .." message:
130518,53 8 tw DialogicEvent 133,TDX_CALLP,9,0,0,CR_NORB,,
130518,55 8 event NORINGBACK, code=133, state=1903
130518,56 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,NORINGBACK,9,0,0,CR_NORB,,
130518,58 8 event CR_NORB, code=133, state=1903
130518,59 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CR_NORB,9,0,0,CR_NORB,,
130518,63 8 event TDX_CALLP, code=133, state=1903
130518,64 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,9,0,0,CR_NORB,,
130518,66 8 xfer dial !
130518,92 8 tw PlayEnd 8 0
130518,95 8 play end id=0, (current ID)
130518,97 8 event EV_PLAY_FINISHED, code=8001, state=1906
130518,98 8 LsXfer_5B : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
130519,00 8 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
130519,02 8 event TDX_DIAL, code=132, state=1906
130519,03 8 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
130519,05 8 sXferDialResult_SuccOrFail=
130519,06 8 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=CR_NORB (2)=TDX_CALLP (3)=
130519,14 8 path {CR_NORB} not found
130519,16 8 path {TDX_CALLP} not found
130519,17 8 going down False path (iXferType=13) state:LsXferCallRejected
130519,20 8 fn RunModule start
130519,22 8 timer clear
130519,23 8 state [Evaluate_Counter] Running VB Script...
130519,25 8 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
'msgbox(test)
else
end if
set vg = Nothing
130519,27 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
130519,30 8 vbs ran [vbs_8_5.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_8_5.vbs" //I //T:60]
130519,36 8 Run Script waiting. iRunWait=1 (shellid=1600, process=1644)
130519,39 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
130519,47 8 cl RvGet RV[counter]
130519,48 8 rv replace start: [$RV[counter]]
130519,52 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
130519,55 8 rv replace end: [2]
130519,58 8 cl RvSet counter, 3
130519,59 8 rv add [counter]{3}
130519,63 8 cl Run_ResultReturn >>fail<<
130519,64 8 rv add [Evaluate_Counter_ResultReturn]{fail}
130519,67 8 cl module's runwait=1, WavPlayHasNowFinished=0
130519,69 8 fn RunModule start
130519,72 8 timer clear
130519,73 8 state [Which_One] Running VB Script...
130519,75 8 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
'msgbox(test)
else
end if
set vg = Nothing
130519,78 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
t_ResultReturn]{success}[counter]{3}[Evaluate_Counter_ResultReturn]{fail}
130519,81 8 vbs ran [vbs_8_6.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_8_6.vbs" //I //T:60]
130519,88 8 Run Script waiting. iRunWait=1 (shellid=4068, process=1440)
130519,91 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
130519,97 8 cl Run_ResultReturn >>success<<
130520,00 8 rv add [Which_One_ResultReturn]{success}
130520,02 8 cl module's runwait=1, WavPlayHasNowFinished=0
130520,05 8 fn RunModule start
130520,06 8 timer clear
130520,08 8 state [Check_columns_post] Running VB Script...
130520,11 8 rv replace start (strlen>500)
130520,13 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
t_ResultReturn]{success}[counter]{3}[Evaluate_Counter_ResultReturn]{fail}[Which_
130520,17 8 vbs ran [vbs_8_7.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_8_7.vbs" //I //T:60]
130520,23 8 Run Script waiting. iRunWait=1 (shellid=136, process=1380)
130520,27 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
130520,34 8 cl RvSet resultQuery, 0739389890
130520,36 8 rv add [resultQuery]{0739389890}
130520,38 8 cl Run_ResultReturn >>success<<
130520,41 8 rv add [Check_columns_post_ResultReturn]{success}
130520,42 8 cl module's runwait=1, WavPlayHasNowFinished=0
130520,45 8 fn RunModule start
130520,48 8 timer clear
130520,50 8 Play Module start
130520,52 8 state [info_To_Customer] Playing
130520,53 8 state [info_To_Customer] Playing (c:\Voice\Locksmith\voice\nu_kopplar_1.wav)
130520,56 8 tw ConvertWav2Vox c:\Voice\Locksmith\voice\nu_kopplar_1.wav
130520,58 8 timer clear
130520,67 8 tw wav->vox convert end 361062,c:\Voice\Locksmith\voice\nu_kopplar_1.vox,1,0,,
130520,70 8 play start ok, lPlayId=361187
130525,44 8 tw PlayEnd 8 361187
130525,45 8 play end id=361187, (current ID)
130525,47 8 event EV_PLAY_FINISHED, code=8001, state=1100
130525,48 8 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
130525,50 8 path {EV_PLAY_FINISHED} not found
130525,52 8 timer set 10 EV_TIMEOUT_HANGUP
130525,53 8 timer set 0 EV_TIMEOUT_GOTOMODULE
130525,55 8 event EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
130525,56 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
130525,58 8 path {EV_TIMEOUT_GOTOMODULE} not found
130525,61 8 fn RunModule start
130525,63 8 tw DialogicEvent 129,TDX_PLAY,361187,0,0,,,
130525,64 8 event TDX_PLAY, code=129, state=6001
130525,67 8 timer clear
130525,69 8 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
130526,09 8 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
130526,11 8 event EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
130526,13 8 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
130526,14 8 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
130526,17 8 timeout on transfer attempt set by timeout path (35 sec)
130526,19 8 timer set 35 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
130526,20 8 rv replace start: [$RV[resultQuery],,]
130526,22 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
ne_ResultReturn]{success}[resultQuery]{0739389890}[Check_columns_post_ResultRetu
n]{success}
130526,27 8 rv replace end: [0739389890,,]
130526,36 8 state [Locksmith] Announced Hookflash Transfer to 0739389890,,
130526,64 8 tw PlayEnd 8 0
130526,67 8 play end id=0, (current ID)
130526,69 8 event EV_PLAY_FINISHED, code=8001, state=1902
130526,72 8 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
130526,75 8 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
130526,77 8 event TDX_DIAL, code=132, state=1902
130526,78 8 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
130526,81 8 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
130526,83 8 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
130528,95 8 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
130528,97 8 event EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
130528,98 8 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
130529,02 8 Dial(0739389890,,, cp on) call
130529,03 8 Dial(0739389890,,) ok
130529,05 8 timer set 35 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
130536,56 8 tw DialogicEvent 133,TDX_CALLP,10,4,0,TDX_CALLP,CR_CNCT,CON_PAMD
130536,58 8 event AM, code=133, state=1903
130536,59 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,AM,10,4,0,CR_CNCT,CON_PAMD,
130536,61 8 event CONNECT, code=133, state=1903
130536,63 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CONNECT,10,4,0,CR_CNCT,CON_PAMD,
130536,66 8 event CON_PAMD, code=133, state=1903
130536,67 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CON_PAMD,10,4,0,CR_CNCT,CON_PAMD,
130536,69 8 event CR_CNCT, code=133, state=1903
130536,70 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CR_CNCT,10,4,0,CR_CNCT,CON_PAMD,
130536,72 8 event TDX_CALLP, code=133, state=1903
130536,75 8 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,10,4,0,CR_CNCT,CON_PAMD,
130536,77 8 LsXfer_3 CR_CNCT on an XT_HOOK_ANNOUNCED
130536,78 8 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
130536,80 8 path {EV_PLAY_FINISHED} not found
130536,81 8 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
130536,84 8 path {EV_TIMEOUT_REPLAYMSG} not found
130536,86 8 state [Locksmith] Playing (C:\Voice\Locksmith\voice\call_transfer_1.wav)
130536,88 8 tw ConvertWav2Vox C:\Voice\Locksmith\voice\call_transfer_1.wav
130536,89 8 timer clear
130536,92 8 tw wav->vox convert end 377375,C:\Voice\Locksmith\voice\call_transfer_1.vox,1,0,,
130536,95 8 play start ok, lPlayId=377453
130545,61 8 tw PlayEnd 8 377453
130545,63 8 play end id=377453, (current ID)
130545,66 8 event EV_PLAY_FINISHED, code=8001, state=1904
130545,67 8 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
130545,69 8 path {EV_PLAY_FINISHED} not found
130545,70 8 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
130545,72 8 path {EV_TIMEOUT_REPLAYMSG} not found
130545,73 8 state [Locksmith] Playing (C:\Voice\Locksmith\voice\call_transfer_1.wav)
130545,75 8 tw ConvertWav2Vox C:\Voice\Locksmith\voice\call_transfer_1.wav
130545,77 8 timer clear
130545,80 8 tw DialogicEvent 129,TDX_PLAY,377453,0,0,,,
130545,81 8 event TDX_PLAY, code=129, state=1904
130545,83 8 LsXfer_4_PlayAnn : 129(EV_UNKNOWN_129),TDX_PLAY,377453,0,0,,,
130545,84 8 path {TDX_PLAY} not found
130545,86 8 tw wav->vox convert end 386250,C:\Voice\Locksmith\voice\call_transfer_1.vox,1,0,,
130545,89 8 play start ok, lPlayId=386375
130554,55 8 tw PlayEnd 8 386375
130554,56 8 play end id=386375, (current ID)
130554,58 8 event EV_PLAY_FINISHED, code=8001, state=1904
130554,59 8 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
130554,61 8 path {EV_PLAY_FINISHED} not found
130554,63 8 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
130554,64 8 path {EV_TIMEOUT_REPLAYMSG} not found
130554,66 8 state [Locksmith] Playing (C:\Voice\Locksmith\voice\call_transfer_1.wav)
130554,67 8 tw ConvertWav2Vox C:\Voice\Locksmith\voice\call_transfer_1.wav
130554,70 8 timer clear
130554,72 8 tw DialogicEvent 129,TDX_PLAY,386375,0,0,,,
130554,73 8 event TDX_PLAY, code=129, state=1904
130554,75 8 LsXfer_4_PlayAnn : 129(EV_UNKNOWN_129),TDX_PLAY,386375,0,0,,,
130554,77 8 path {TDX_PLAY} not found
130554,80 8 tw wav->vox convert end 395171,C:\Voice\Locksmith\voice\call_transfer_1.vox,1,0,,
130554,83 8 play start ok, lPlayId=395312
130601,09 8 tw DialogicEvent 134,TDX_CST,196,0,0,DE_TONEON,TID_DISCONNECT,
130601,11 8 event DISCONNECT, code=134, state=1904
130601,13 8 LsXfer_4_PlayAnn : 134(EV_UNKNOWN_134),DISCONNECT,196,0,0,DE_TONEON,TID_DISCONNECT,
130601,14 8 rv add [Locksmith]{DISCONNECT}
130601,17 8 fn RunModule start
130601,19 8 timer clear
130601,20 8 state [Evaluate_Counter] Running VB Script...
130601,22 8 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
'msgbox(test)
else
end if
set vg = Nothing
130601,23 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
n]{success}[Locksmith]{DISCONNECT}
130601,27 8 vbs ran [vbs_8_8.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_8_8.vbs" //I //T:60]
130601,34 8 Run Script waiting. iRunWait=1 (shellid=3484, process=1804)
130601,38 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
130601,41 8 event TID_DISCONNECT, code=134, state=1501
130601,45 8 LsRunWaitTillFinished EV_UNKNOWN_134
130601,47 8 event TDX_CST, code=134, state=1501
130601,48 8 LsRunWaitTillFinished EV_UNKNOWN_134
130601,55 8 cl RvGet RV[counter]
130601,56 8 rv replace start: [$RV[counter]]
130601,59 8 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-12 13:03:26}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice_jose_problema\Locksmith\}[$RV_CIDNUMBER]{}[set_Sound_Files_Input]{"C:\Voice\Locksmith\voice\"}[set_Sound_Files]{C:\Voice\Locksmith\voice\}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\}[Var_Result_Query_Input]{}[Var_Result_Query]{}[resultQuery]{}[selection_Ch
130601,63 8 rv replace end: [3]
130601,66 8 cl RvSet counter, 4
130601,67 8 rv add [counter]{4}
130601,70 8 cl Run_ResultReturn >>success<<
130601,73 8 rv add [Evaluate_Counter_ResultReturn]{success}
130601,75 8 cl module's runwait=1, WavPlayHasNowFinished=0
130601,77 8 fn RunModule start
130601,80 8 timer clear
130601,81 8 Play Module start
130601,83 8 state [sorry] Playing
130601,86 8 state [sorry] Playing (C:\Voice\Locksmith\voice\try_later_1.wav)
130601,88 8 tw ConvertWav2Vox C:\Voice\Locksmith\voice\try_later_1.wav
130601,89 8 timer clear
130601,98 8 tw wav->vox convert end 402375,C:\Voice\Locksmith\voice\try_later_1.vox,1,0,,
130602,00 8 play start ok, lPlayId=402500
130602,03 8 tw PlayEnd 8 395312
130602,05 8 play end id=395312, (old ID) current id=402500
130602,08 8 tw DialogicEvent 129,TDX_PLAY,395312,0,0,,,
130602,09 8 event TDX_PLAY, code=129, state=1100
130602,11 8 LsPlayMsg EV_UNKNOWN_129,TDX_PLAY
130602,13 8 path {TDX_PLAY} not found
130602,16 8 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,TID_BUSY1,
130602,17 8 event BUSY, code=134, state=1100
130602,19 8 LsPlayMsg EV_UNKNOWN_134,BUSY
130602,20 8 path {BUSY} not found
130602,22 8 rv add [Hangup Time]{2005-09-12 13:06:02}
130602,23 8 state Hanging up call...
130602,25 8 HangupCall_Common hCall=8
130602,28 8 rec RecSoundStop ok
130602,36 8 play PlaySoundStop ok
130602,39 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
130602,41 8 fnHangupCall end
130602,42 8 event TID_BUSY1, code=134, state=900
130602,44 8 LsAwaitingCalls EV_UNKNOWN_134
130602,45 8 event TDX_CST, code=134, state=900
130602,47 8 LsAwaitingCalls EV_UNKNOWN_134
130602,48 8 tw PlayEnd 8 402500
130602,50 8 play end id=402500, (current ID)
130602,52 8 event EV_PLAY_FINISHED, code=8001, state=900
130602,55 8 LsAwaitingCalls EV_PLAY_FINISHED
130602,56 8 tw DialogicEvent 129,TDX_PLAY,402500,0,0,,,
130602,58 8 event TDX_PLAY, code=129, state=900
130602,59 8 LsAwaitingCalls EV_UNKNOWN_129
130602,61 8 event callstate IDLE 8 0 0
130602,63 8 WorkingMode@Idle=
130602,64 8 timer clear
130602,66 8 rec RecSoundStop ok
130602,67 8 play PlaySoundStop ok
130602,69 8 rv add [CallEndTime]{2005-09-12 13:06:02}
130602,83 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
130602,84 8 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
130602,86 8 event TDX_SETHOOK, code=135, state=900
130602,88 8 LsAwaitingCalls EV_UNKNOWN_135
130603,95 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
130603,97 8 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
130603,98 8 init atidle reinit : start
130604,00 8 init atidle reinit iConferenceOtherLegLid=-1
130604,02 8 init atidle reinit : reset all LineState variables
130604,03 8 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
130604,05 8 state Waiting for a call...
130604,39 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
130604,41 8 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
Thank you for you help!
Jose
Yes.
No.
If you are using the latest version of VG and monitored or announced transfers then there is no need for any extra hookflashes. Call Transfer module issues those to take back the call.
What version of VG are you using?
What signal is required on this PBX to 'take back' a call? Just a hookflash or something more?
If you were hearing that this means the hookflash was not working - which probably means you would have also heard the digits being dialed and the destination phone would not have rung.
As the caller hears the sound file played:
then this means the hookflash issued by the Call Transfer module took back the call OK.
But the caller should not hear any numbers being dialed:
The hookflash issued before dialing the second number should have made the PBX put caller on hold straight away - so the caller should not have heard the digits being dialed... if the phone is ringing though then this means the PBX/Linksys would have still correctly heard the dialed digits even though the caller could hear them as well..
This is basically just the same problem which occurs on a bigger scale next time round:
and with the last part the caller hears that some numbers are being dialing in the same line and after the "press 1 to .." message:
when the PBX does not put caller on hold at all...
we don't come across many systems using the Linksys - but it looks like there may be some sort of an incompatibility there.
Are you able to do multiple transfer attempts during the same call manually with the Linksys?
Hello!
I am using voiceguide for dialogic version 6.0.2001 .
Just a hookflash.
QUOTE
/QUOTE
Well this is true when voiceguide is dialing the second phone number; the caller hears the digits being dialing and the "press 1 to.." message. In this scenario, if the caller does not do anything just wait for a while then voiceguide continues with the script making the third call and it the dialed phone number is answered then woiceguide finished the transfer and hangs up the phone. In other words,it does not work mostly when voiceguide is dialing the second phone number.
Jose
After first call transfer attempt:
We can see from trace that VG is issuing a hookflash
When it tries to take back the call - but for some reason the PBX is not recognizing it and is not taking the original incoming call off the hold state.
It does recognize the hookflash issued right before the second number is dialed:
and the result of that is that the incoming call is taken off hold - when at that time our intention was to put the call on hold again...
from your description it's not clear whether the hookflash issued next:
is ignored or not - but looks like either that hookflash or the hookflash from the 3rd transfer attempt:
again puts caller on hold and the number 0739389890 is dialed and rings.
It's pretty strange that the hookflash works at some time and at some time it does not. VoiceGuide issues both hookflashes in the same way (you can see same function calls when looking at MMDDtw.txt log file)
You should probably do some more testing with various hookflash lengths - remember to restart VoiceGuide after each change!
Also, use Play modules to issue hookflashes and see when they work and when they do not - have a chain of Play modules playing hookflashes and sound files and make a note of which sound files you can hear when you dial into the system - that way you will be able to quickly test hookflash recognition reliability.
Hello!
It has been a long time but I still have the same problem. Well, I´ve been testing different lengths in the hookflash but without any luck. The supportteam from my telephone company (we have voice over IP) are still working on the problems. They haven´t tested their system to work with this kind of applications.
Anyway, we are now back to our old telephone company and OF COURSE I have some problems, but now they are different. My problem now is that when the transfer module attempts to ring a mobile number, first the caller hears noise on the line then it desappears. And when the called person picks up the phone he hears the press 1 message to accept the call and when he presses 1 voiceguide hangs up and immediately starts again the script.
Here I send you both files.
103133,73 3 tw dtmf d (3,100,100)
103133,73 3 event d, code=100, state=900
103133,73 3 already IDLE. HangupCall ignored.
103133,73 3 init atidle reinit : start
103133,73 3 init atidle reinit iConferenceOtherLegLid=-1
103133,73 3 init atidle reinit : reset all LineState variables
103133,73 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
103133,73 3 state Waiting for a call...
103133,73 3 tw DialogicEvent 134,TDX_CST,100,0,0,DE_DIGITS,,
103133,73 3 event TDX_CST, code=134, state=900
103133,73 3 LsAwaitingCalls EV_UNKNOWN_134
103133,88 3 tw dtmf 0 (3,48,48)
103133,88 3 event 0, code=48, state=900
103133,88 3 LsAwaitingCalls 0
103133,88 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
103133,88 3 event TDX_CST, code=134, state=900
103133,88 3 LsAwaitingCalls EV_UNKNOWN_134
103133,95 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
103133,95 3 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
103134,00 3 tw dtmf 8 (3,56,56)
103134,00 3 event 8, code=56, state=900
103134,00 3 LsAwaitingCalls 8
103134,00 3 tw DialogicEvent 134,TDX_CST,56,0,0,DE_DIGITS,,
103134,00 3 event TDX_CST, code=134, state=900
103134,00 3 LsAwaitingCalls EV_UNKNOWN_134
103134,16 3 tw dtmf 4 (3,52,52)
103134,16 3 event 4, code=52, state=900
103134,16 3 LsAwaitingCalls 4
103134,16 3 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
103134,16 3 event TDX_CST, code=134, state=900
103134,16 3 LsAwaitingCalls EV_UNKNOWN_134
103134,30 3 tw dtmf 4 (3,52,52)
103134,30 3 event 4, code=52, state=900
103134,30 3 LsAwaitingCalls 4
103134,30 3 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
103134,31 3 event TDX_CST, code=134, state=900
103134,31 3 LsAwaitingCalls EV_UNKNOWN_134
103134,45 3 tw dtmf 2 (3,50,50)
103134,45 3 event 2, code=50, state=900
103134,45 3 LsAwaitingCalls 2
103134,45 3 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
103134,45 3 event TDX_CST, code=134, state=900
103134,45 3 LsAwaitingCalls EV_UNKNOWN_134
103134,61 3 tw dtmf 9 (3,57,57)
103134,61 3 event 9, code=57, state=900
103134,61 3 LsAwaitingCalls 9
103134,61 3 tw DialogicEvent 134,TDX_CST,57,0,0,DE_DIGITS,,
103134,61 3 event TDX_CST, code=134, state=900
103134,61 3 LsAwaitingCalls EV_UNKNOWN_134
103134,77 3 tw dtmf 0 (3,48,48)
103134,77 3 event 0, code=48, state=900
103134,77 3 LsAwaitingCalls 0
103134,77 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
103134,77 3 event TDX_CST, code=134, state=900
103134,77 3 LsAwaitingCalls EV_UNKNOWN_134
103134,91 3 tw dtmf 4 (3,52,52)
103134,91 3 event 4, code=52, state=900
103134,91 3 LsAwaitingCalls 4
103134,91 3 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
103134,91 3 event TDX_CST, code=134, state=900
103134,91 3 LsAwaitingCalls EV_UNKNOWN_134
103135,06 3 tw dtmf 0 (3,48,48)
103135,06 3 event 0, code=48, state=900
103135,06 3 LsAwaitingCalls 0
103135,06 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
103135,06 3 event TDX_CST, code=134, state=900
103135,06 3 LsAwaitingCalls EV_UNKNOWN_134
103135,19 3 tw dtmf c (3,99,99)
103135,19 3 event c, code=99, state=900
103135,19 3 LsAwaitingCalls c
103135,19 3 tw DialogicEvent 134,TDX_CST,99,0,0,DE_DIGITS,,
103135,19 3 event TDX_CST, code=134, state=900
103135,19 3 LsAwaitingCalls EV_UNKNOWN_134
103135,58 3 event callstate OFFERING 3 0 0
103135,58 3 script interpretor: VgMulti v6.0.2092
103135,58 3 fired OFFERING event to listeners
103135,58 3 iIvrDev=3
103135,58 3 set linestate CID vars
103135,58 3 call AnswerTheCallIfAllowed
103135,58 3 tw ring 1
103135,58 3 ring time since last ring (ms): 0
103135,58 3 rv clear all
103135,58 3 init LineState ResetAtStartOfNewCall.
103135,58 3 answer the call
103135,58 3 timer clear
103135,58 3 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
103135,58 3 event TDX_CST, code=134, state=6001
103136,13 3 event callstate CONNECTED 3 0 0
103136,13 3 WorkingModes tapi= script=
103136,13 3 Inband detection not enabled
103136,13 3 StartLoadedVgs at 2005-10-13 10:31:36
103136,13 3 set sScriptToRunOnHangup=[] in StartLoadedVgs
103136,13 3 init StartLoadedVgs_InitLineState start
103136,13 3 rv add [$RV_STARTTIME]{2005-10-13 10:31:36}
103136,13 3 rv add [$RV_DEVICEID]{3}
103136,13 3 rv add [$RV_CIDNAME]{}
103136,13 3 rvns add [PathApp]{C:\Program\VoiceGuide\}
103136,13 3 rvns add [scriptsPath]{C:\Voice\Tele2\}
103136,13 3 rv add [$RV_CIDNUMBER]{}
103136,13 3 fn RunModule start
103136,13 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
103136,13 3 event TDX_SETHOOK, code=135, state=6001
103136,13 3 timer clear
103136,13 3 Play Module start
103136,13 3 state [LANGUAGE] Playing
103136,13 3 state [LANGUAGE] Playing (C:\Voice\Tele2\Voice\language.wav)
103136,13 3 tw ConvertWav2Vox C:\Voice\Tele2\Voice\language.wav
103136,14 3 tw DialogicEvent 134,TDX_CST,31913,0,0,DE_LCON,,
103136,14 3 event TDX_CST, code=134, state=1100
103136,14 3 LsPlayMsg EV_UNKNOWN_134,TDX_CST
103136,14 3 path {TDX_CST} not found
103136,20 3 tw wav->vox convert end 507625,C:\Voice\Tele2\Voice\language.vox,1,0,,
103136,23 3 play start ok, lPlayId=507703
103141,88 3 tw PlayEnd 3 507703
103141,88 3 play end id=507703, (current ID)
103141,88 3 event EV_PLAY_FINISHED, code=8001, state=1100
103141,88 3 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
103141,88 3 path {EV_PLAY_FINISHED} not found
103141,88 3 timer set 5 EV_TIMEOUT_REPLAYMSG
103141,88 3 tw DialogicEvent 129,TDX_PLAY,507703,0,0,,,
103141,88 3 event TDX_PLAY, code=129, state=1101
103141,88 3 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
103141,88 3 path {TDX_PLAY} not found
103142,00 3 tw dtmf 2 (3,50,50)
103142,00 3 event 2, code=50, state=1101
103142,00 3 LsPlayMsgFinished 2,2
103142,00 3 rv add [LANGUAGE]{2}
103142,00 3 fn RunModule start
103142,00 3 timer clear
103142,00 3 state [init_COUNTER] Evaluate [0]
103142,00 3 eval[0]
103142,02 3 rvns add [init_COUNTER_Input]{0}
103142,02 3 rvns add [init_COUNTER]{0}
103142,02 3 rvns add [counter]{0}
103142,02 3 Eval Expr result:[0] stored in $RV[counter]
103142,02 3 path {0} not found
103142,02 3 fn RunModule start
103142,02 3 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
103142,02 3 event TDX_CST, code=134, state=6001
103142,02 3 timer clear
103142,02 3 Play Module start
103142,02 3 state [sERVICES] Playing
103142,02 3 rv replace start: [C:\Voice\Tele2\Voice\SERVICES_$RV[LANGUAGE].wav]
103142,02 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 10:31:36}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}
103142,02 3 rv replace end: [C:\Voice\Tele2\Voice\SERVICES_2.wav]
103142,02 3 state [sERVICES] Playing (C:\Voice\Tele2\Voice\SERVICES_2.wav)
103142,02 3 tw ConvertWav2Vox C:\Voice\Tele2\Voice\SERVICES_2.wav
103142,09 3 tw wav->vox convert end 513515,C:\Voice\Tele2\Voice\SERVICES_2.vox,1,0,,
103142,13 3 play start ok, lPlayId=513593
103153,14 3 tw dtmf 2 (3,50,50)
103153,14 3 event 2, code=50, state=1100
103153,14 3 LsPlayMsg 2,2
103153,14 3 rv add [scriptEnd_Time]{2005-10-13 10:31:53}
103153,14 3 rv add [scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}
103153,14 3 rv add [scriptEnd_Goto_Module]{WELCOME}
103153,16 3 rv add [scriptStart_Time]{2005-10-13 10:31:53}
103153,16 3 rv add [scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}
103153,16 3 rv add [scriptStart_CalledFrom_Module]{SERVICES}
103153,16 3 FindFullPathToScript_VgsOrVgp start [C:\Voice\Locksmith\locksmith.vgs]
103153,16 3 FindFullPathToScript_VgsOrVgp 1
103153,16 0 LoadedVgs_Find C:\Voice\Locksmith\locksmith.vgs at idx=3
103153,16 3 rvns add [scriptsPath]{C:\Voice\Locksmith\}
103153,19 3 play PlaySoundStop ok
103153,19 3 rv add [sERVICES]{2}
103153,19 3 fn RunModule start
103153,19 3 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
103153,19 3 event TDX_CST, code=134, state=6001
103153,19 3 timer clear
103153,19 3 Play Module start
103153,19 3 state [WELCOME] Playing
103153,19 3 rv replace start: [C:\Voice\Locksmith\voice\welcome_locksmith_$RV[LANGUAGE].wav]
103153,19 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 10:31:36}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}[scriptEnd_Time]{2005-10-13 10:31:53}[scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}[scriptEnd_Goto_Module]{WELCOME}[scriptStart_Time]{2005-10-13 10:31:53}[scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}[scriptStart_CalledFrom_Module]{SERVICES}[scriptsPath]{C:\Voice\Locksmith\}[sERVICES]{2}
103153,19 3 rv replace end: [C:\Voice\Locksmith\voice\welcome_locksmith_2.wav]
103153,19 3 state [WELCOME] Playing (C:\Voice\Locksmith\voice\welcome_locksmith_2.wav)
103153,19 3 tw ConvertWav2Vox C:\Voice\Locksmith\voice\welcome_locksmith_2.wav
103153,19 3 tw PlayEnd 3 513593
103153,19 3 play end id=513593, (old ID) current id=524687
103153,19 3 tw DialogicEvent 129,TDX_PLAY,513593,0,0,,,
103153,19 3 event TDX_PLAY, code=129, state=1100
103153,19 3 LsPlayMsg EV_UNKNOWN_129,TDX_PLAY
103153,19 3 path {TDX_PLAY} not found
103153,28 3 tw wav->vox convert end 524687,C:\Voice\Locksmith\voice\welcome_locksmith_2.vox,1,0,,
103153,31 3 play start ok, lPlayId=524781
103207,53 3 tw PlayEnd 3 524781
103207,53 3 play end id=524781, (current ID)
103207,53 3 event EV_PLAY_FINISHED, code=8001, state=1100
103207,53 3 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
103207,53 3 path {EV_PLAY_FINISHED} not found
103207,53 3 timer set 10 EV_TIMEOUT_HANGUP
103207,53 3 timer set 0 EV_TIMEOUT_GOTOMODULE
103207,53 3 event EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
103207,53 3 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
103207,53 3 path {EV_TIMEOUT_GOTOMODULE} not found
103207,53 3 fn RunModule start
103207,53 3 timer clear
103207,53 3 state [Var_Result_Query] Evaluate [1]
103207,53 3 eval[1]
103207,53 3 rvns add [Var_Result_Query_Input]{1}
103207,53 3 rvns add [Var_Result_Query]{1}
103207,53 3 rvns add [resultQuery]{1}
103207,53 3 Eval Expr result:[1] stored in $RV[resultQuery]
103207,53 3 path {1} not found
103207,53 3 tw DialogicEvent 129,TDX_PLAY,524781,0,0,,,
103207,53 3 event TDX_PLAY, code=129, state=6001
103207,55 3 state [selection_Choice] Number Input
103207,55 3 rv replace start: [C:\Voice\Locksmith\voice\selection_choice_$RV[LANGUAGE].wav]
103207,55 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 10:31:36}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}[scriptEnd_Time]{2005-10-13 10:31:53}[scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}[scriptEnd_Goto_Module]{WELCOME}[scriptStart_Time]{2005-10-13 10:31:53}[scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}[scriptStart_CalledFrom_Module]{SERVICES}[scriptsPath]{C:\Voice\Locksmith\}[sERVICES]{2}[Var_Result_Query_Input]{1}[Var_Result_Query]{1}[resultQuery]
1}
103207,55 3 rv replace end: [C:\Voice\Locksmith\voice\selection_choice_2.wav]
103207,55 3 state [selection_Choice] Playing (C:\Voice\Locksmith\voice\selection_choice_2.wav)
103207,55 3 tw ConvertWav2Vox C:\Voice\Locksmith\voice\selection_choice_2.wav
103207,55 3 timer clear
103207,61 3 tw wav->vox convert end 539046,C:\Voice\Locksmith\voice\selection_choice_2.vox,1,0,,
103207,64 3 play start ok, lPlayId=539109
103214,50 3 tw dtmf 1 (3,49,49)
103214,50 3 event 1, code=49, state=1300
103214,50 3 LsGetNbrsPlayWelcMsg 1,1
103214,53 3 play PlaySoundStop ok
103214,53 3 state [selection_Choice] Number Input 1
103214,53 3 rv add [selection_Choice]{1}
103214,53 3 rvns add [selection_Choice_PathTaken]{1}
103214,53 3 fn RunModule start
103214,53 3 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
103214,53 3 event TDX_CST, code=134, state=6001
103214,53 3 tw PlayEnd 3 539109
103214,53 3 play end id=539109, (current ID)
103214,53 3 event EV_PLAY_FINISHED, code=8001, state=6001
103214,53 3 tw DialogicEvent 129,TDX_PLAY,539109,0,0,,,
103214,53 3 event TDX_PLAY, code=129, state=6001
103214,53 3 timer clear
103214,53 3 state [Get_Post_Code] Number Input
103214,53 3 rv replace start: [C:\Voice\Locksmith\voice\get_post_code_$RV[LANGUAGE].wav]
103214,53 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 10:31:36}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
1}[selection_Choice]{1}[selection_Choice_PathTaken]{1}
103214,53 3 rv replace end: [C:\Voice\Locksmith\voice\get_post_code_2.wav]
103214,53 3 state [Get_Post_Code] Playing (C:\Voice\Locksmith\voice\get_post_code_2.wav)
103214,53 3 tw ConvertWav2Vox C:\Voice\Locksmith\voice\get_post_code_2.wav
103214,56 3 tw wav->vox convert end 546031,C:\Voice\Locksmith\voice\get_post_code_2.vox,1,0,,
103214,59 3 play start ok, lPlayId=546062
103218,73 3 tw PlayEnd 3 546062
103218,73 3 play end id=546062, (current ID)
103218,73 3 event EV_PLAY_FINISHED, code=8001, state=1300
103218,73 3 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
103218,73 3 path {EV_PLAY_FINISHED} not found
103218,73 3 timer set 5 EV_TIMEOUT_REPLAYMSG
103218,73 3 tw DialogicEvent 129,TDX_PLAY,546062,0,0,,,
103218,73 3 event TDX_PLAY, code=129, state=1301
103218,73 3 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
103218,73 3 path {TDX_PLAY} not found
103220,73 3 tw dtmf 0 (3,48,48)
103220,73 3 event 0, code=48, state=1301
103220,73 3 LsGetNbrsRxDigits 0,0
103220,73 3 state [Get_Post_Code] Number Input 0
103220,73 3 path {0} not found
103220,73 3 timer set 6 EV_TIMEOUT_ENTERDATA
103220,73 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
103220,73 3 event TDX_CST, code=134, state=1301
103220,73 3 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
103220,73 3 path {TDX_CST} not found
103221,34 3 tw dtmf 0 (3,48,48)
103221,34 3 event 0, code=48, state=1301
103221,34 3 LsGetNbrsRxDigits 0,0
103221,34 3 state [Get_Post_Code] Number Input 00
103221,34 3 path {00} not found
103221,34 3 timer set 6 EV_TIMEOUT_ENTERDATA
103221,34 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
103221,34 3 event TDX_CST, code=134, state=1301
103221,34 3 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
103221,34 3 path {TDX_CST} not found
103222,03 3 tw dtmf 0 (3,48,48)
103222,03 3 event 0, code=48, state=1301
103222,03 3 LsGetNbrsRxDigits 0,0
103222,03 3 state [Get_Post_Code] Number Input 000
103222,03 3 path {000} not found
103222,03 3 timer set 6 EV_TIMEOUT_ENTERDATA
103222,05 3 timer clear
103222,05 3 rv add [Get_Post_Code]{000}
103222,05 3 path {000} not found
103222,05 3 rvns add [Get_Post_Code_PathTaken]{success}
103222,05 3 fn RunModule start
103222,05 3 state [CASE_locksmith_post] DB Query
103222,05 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
103222,05 3 event TDX_CST, code=134, state=1400
103222,05 3 ERROR 6.0.2092 Unknown State [1400]
103222,05 3 db ODBC mode used
103222,23 3 rv replace start: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =$RV[Get_Post_Code]]
103222,23 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 10:31:36}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
1}[selection_Choice]{1}[selection_Choice_PathTaken]{1}[Get_Post_Code]{000}[Get_P
103222,23 3 rv replace end: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
103222,23 3 db About to execute a Retrieve type operation [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
103222,28 3 db [CASE_locksmith_post] row count=1
103222,28 3 rv add [CASE_locksmith_post_RowCount]{1}
103222,28 3 db get RecordsetGetRowsMax
103222,28 3 db get 999 records. (row count=1)
103222,28 3 db update RVs
103222,28 3 db about to close dbDbqDatabase
103222,28 3 db going down path [True]
103222,28 3 fn RunModule start
103222,28 3 timer clear
103222,28 3 state [Counter_post] Evaluate [1]
103222,28 3 eval[1]
103222,28 3 rvns add [Counter_post_Input]{1}
103222,28 3 rvns add [Counter_post]{1}
103222,28 3 rvns add [counter]{1}
103222,30 3 Eval Expr result:[1] stored in $RV[counter]
103222,30 3 path {1} not found
103222,30 3 fn RunModule start
103222,30 3 timer clear
103222,30 3 state [Check_columns_post] Running VB Script...
103222,30 3 rv replace start (strlen>500)
103222,30 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 10:31:36}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
st_Code_PathTaken]{success}[CASE_locksmith_post_RowCount]{1}[CASE_locksmith_post
1_1]{+46739389890}[CASE_locksmith_post_2_1]{+46708430642}[CASE_locksmith_post_3_
]{+46708430642}[Counter_post_Input]{1}[Counter_post]{1}[counter]{1}
103222,30 3 vbs ran [vbs_3_1.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_3_1.vbs" //I //T:60]
103222,36 3 Run Script waiting. iRunWait=1 (shellid=3776, process=1660)
103222,36 3 timer set 1 EV_TIMEOUT_CHECKONSTATE
103222,39 3 cl RvSet resultQuery, 0739389890
103222,39 3 rv add [resultQuery]{0739389890}
103222,39 3 cl Run_ResultReturn >>success<<
103222,39 3 rv add [Check_columns_post_ResultReturn]{success}
103222,41 3 cl module's runwait=1, WavPlayHasNowFinished=0
103222,41 3 fn RunModule start
103222,41 3 timer clear
103222,41 3 Play Module start
103222,41 3 state [info_To_Customer] Playing
103222,41 3 rv replace start: [c:\Voice\Locksmith\voice\nu_kopplar_$RV[LANGUAGE].wav]
103222,41 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 10:31:36}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{+46708430642}[Counter_post_Input]{1}[Counter_post]{1}[counter]{1}[resultQuery]
0739389890}[Check_columns_post_ResultReturn]{success}
103222,41 3 rv replace end: [c:\Voice\Locksmith\voice\nu_kopplar_2.wav]
103222,41 3 state [info_To_Customer] Playing (c:\Voice\Locksmith\voice\nu_kopplar_2.wav)
103222,41 3 tw ConvertWav2Vox c:\Voice\Locksmith\voice\nu_kopplar_2.wav
103222,45 3 tw wav->vox convert end 553906,c:\Voice\Locksmith\voice\nu_kopplar_2.vox,1,0,,
103222,48 3 play start ok, lPlayId=553953
103227,52 3 tw PlayEnd 3 553953
103227,52 3 play end id=553953, (current ID)
103227,52 3 event EV_PLAY_FINISHED, code=8001, state=1100
103227,52 3 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
103227,52 3 path {EV_PLAY_FINISHED} not found
103227,52 3 timer set 10 EV_TIMEOUT_HANGUP
103227,52 3 timer set 0 EV_TIMEOUT_GOTOMODULE
103227,52 3 event EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
103227,53 3 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
103227,53 3 path {EV_TIMEOUT_GOTOMODULE} not found
103227,53 3 fn RunModule start
103227,53 3 tw DialogicEvent 129,TDX_PLAY,553953,0,0,,,
103227,53 3 event TDX_PLAY, code=129, state=6001
103227,53 3 timer clear
103227,53 3 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
103227,95 3 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
103227,95 3 event EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
103227,95 3 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
103227,95 3 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
103227,95 3 timeout on transfer attempt set by timeout path (50 sec)
103227,95 3 timer set 50 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
103227,95 3 rv replace start: [$RV[resultQuery]]
103227,95 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 10:31:36}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
103227,95 3 rv replace end: [0739389890]
103227,95 3 state [Locksmith] Announced Hookflash Transfer to 0739389890
103228,22 3 tw PlayEnd 3 0
103228,22 3 play end id=0, (current ID)
103228,22 3 event EV_PLAY_FINISHED, code=8001, state=1902
103228,22 3 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
103228,22 3 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
103228,22 3 event TDX_DIAL, code=132, state=1902
103228,22 3 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
103228,22 3 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
103228,22 3 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
103230,36 3 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
103230,36 3 event EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
103230,36 3 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
103230,36 3 Dial(0739389890, cp on) call
103230,36 3 Dial(0739389890) ok
103230,36 3 timer set 50 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
103243,11 3 tw DialogicEvent 133,TDX_CALLP,10,3,0,TDX_CALLP,CR_CNCT,CON_PVD
103243,11 3 event VOICE, code=133, state=1903
103243,11 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,VOICE,10,3,0,CR_CNCT,CON_PVD,
103243,11 3 event CONNECT, code=133, state=1903
103243,11 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CONNECT,10,3,0,CR_CNCT,CON_PVD,
103243,11 3 event CON_PVD, code=133, state=1903
103243,11 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CON_PVD,10,3,0,CR_CNCT,CON_PVD,
103243,11 3 event CR_CNCT, code=133, state=1903
103243,11 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CR_CNCT,10,3,0,CR_CNCT,CON_PVD,
103243,11 3 event TDX_CALLP, code=133, state=1903
103243,11 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,10,3,0,CR_CNCT,CON_PVD,
103243,11 3 LsXfer_3 CR_CNCT on an XT_HOOK_ANNOUNCED
103243,11 3 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
103243,11 3 path {EV_PLAY_FINISHED} not found
103243,11 3 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
103243,11 3 path {EV_TIMEOUT_REPLAYMSG} not found
103243,11 3 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits
103243,13 3 sVbsFunctionToUse=Digits
103243,17 3 say numbers vbs ran shell[wscript "C:\Program\VoiceGuide\data\vbs_3_SayNumber.vbs" //I //T:60]
103243,22 3 Started SayNumber VBScript OK. (C:\Program\VoiceGuide\data\vbs_3_SayNumber.vbs)
103243,31 3 cl Play_Start C:\Program\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program\VoiceGuide\system\voice\TsfrAskAccept.wav
103243,31 3 tw ConvertWav2Vox C:\Program\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program\VoiceGuide\system\voice\TsfrAskAccept.wav
103243,31 3 timer clear
103243,31 3 tw wav->vox convert end 574812,C:\Program\VoiceGuide\system\voice\TsfrCallFrom.vox,C:\Program\VoiceGuide\system\voice\TsfrAskAccept.vox,1,0,,
103243,34 3 play start ok, lPlayId=574812
103252,55 3 tw dtmf 1 (3,49,49)
103252,55 3 event 1, code=49, state=1904
103252,55 3 LsXfer_4_PlayAnn : 49(1),1,0,0,0,,,
103252,55 3 rv add [Locksmith]{1}
103252,55 3 timer set 0,5 EV_PLAY_FINISHED
103252,58 3 play PlaySoundStop ok
103252,58 3 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
103252,58 3 event TDX_CST, code=134, state=1904
103252,58 3 LsXfer_4_PlayAnn : 134(EV_UNKNOWN_134),TDX_CST,49,0,0,DE_DIGITS,,
103252,58 3 path {TDX_CST} not found
103252,58 3 tw PlayEnd 3 574812
103252,58 3 play end id=574812, (current ID)
103252,58 3 event EV_PLAY_FINISHED, code=8001, state=1904
103252,58 3 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
103252,58 3 path {EV_PLAY_FINISHED} not found
103252,58 3 dial from LsXfer_4_PlayAnn
103252,58 3 tw DialogicEvent 129,TDX_PLAY,574812,0,0,,,
103252,58 3 event TDX_PLAY, code=129, state=1906
103252,59 3 LsXfer_5B : 129(EV_UNKNOWN_129),TDX_PLAY,574812,0,0,,,
103252,61 3 tw PlayEnd 3 0
103252,61 3 play end id=0, (current ID)
103252,61 3 event EV_PLAY_FINISHED, code=8001, state=1906
103252,61 3 LsXfer_5B : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
103252,61 3 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
103252,61 3 event TDX_DIAL, code=132, state=1906
103252,61 3 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
103252,61 3 sXferDialResult_SuccOrFail=XferToGoAhead
103252,61 3 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=CON_PVD (2)=PVD (3)=voice
103252,61 3 path {CON_PVD} not found
103252,61 3 path {PVD} not found
103252,61 3 path {voice} not found
103252,61 3 going down True path (iXferType=13) state:LsXferCallRejected
103252,61 3 fn RunModule start
103252,61 3 timer clear
103252,61 3 rv add [Hangup Time]{2005-10-13 10:32:52}
103252,61 3 state Hanging up call... [Hangup Module]
103252,61 3 HangupCall_Common hCall=3
103252,61 3 rec RecSoundStop ok
103252,61 3 play PlaySoundStop ok
103252,61 3 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
103252,63 3 fnHangupCall end
103252,67 3 event callstate IDLE 3 0 0
103252,67 3 WorkingMode@Idle=
103252,67 3 timer clear
103252,67 3 rec RecSoundStop ok
103252,69 3 play PlaySoundStop ok
103252,69 3 rv add [CallEndTime]{2005-10-13 10:32:52}
103252,83 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
103252,83 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
103252,83 3 event TDX_SETHOOK, code=135, state=900
103252,83 3 LsAwaitingCalls EV_UNKNOWN_135
103252,83 3 tw dtmf 1 (3,49,49)
103252,83 3 event 1, code=49, state=900
103252,83 3 LsAwaitingCalls 1
103252,83 3 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
103252,83 3 event TDX_CST, code=134, state=900
103252,83 3 LsAwaitingCalls EV_UNKNOWN_134
103253,81 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
103253,81 3 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
103253,81 3 init atidle reinit : start
103253,81 3 init atidle reinit iConferenceOtherLegLid=-1
103253,81 3 init atidle reinit : reset all LineState variables
103253,81 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
103253,81 3 state Waiting for a call...
103254,14 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
103254,14 3 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
103255,39 3 event callstate OFFERING 3 0 0
103255,39 3 script interpretor: VgMulti v6.0.2092
103255,39 3 fired OFFERING event to listeners
103255,39 3 iIvrDev=3
103255,39 3 set linestate CID vars
103255,41 3 call AnswerTheCallIfAllowed
103255,41 3 tw ring 1
103255,41 3 ring time since last ring (ms): 0
103255,41 3 rv clear all
103255,41 3 init LineState ResetAtStartOfNewCall.
103255,41 3 No old processes from last call (could not obtain handle) 288, 1660
103255,41 3 answer the call
103255,41 3 timer clear
103255,41 3 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
103255,41 3 event TDX_CST, code=134, state=6001
103255,94 3 event callstate CONNECTED 3 0 0
103255,94 3 WorkingModes tapi= script=
103255,95 3 Inband detection not enabled
103255,95 3 StartLoadedVgs at 2005-10-13 10:32:55
103255,95 3 set sScriptToRunOnHangup=[] in StartLoadedVgs
103255,95 3 init StartLoadedVgs_InitLineState start
103255,95 3 rv add [$RV_STARTTIME]{2005-10-13 10:32:55}
103255,95 3 rv add [$RV_DEVICEID]{3}
103255,95 3 rv add [$RV_CIDNAME]{}
103255,95 3 rvns add [PathApp]{C:\Program\VoiceGuide\}
103255,95 3 rvns add [scriptsPath]{C:\Voice\Tele2\}
103255,95 3 rv add [$RV_CIDNUMBER]{}
103255,95 3 fn RunModule start
103255,95 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
103255,95 3 event TDX_SETHOOK, code=135, state=6001
103255,95 3 timer clear
103255,95 3 Play Module start
103255,95 3 state [LANGUAGE] Playing
103255,95 3 state [LANGUAGE] Playing (C:\Voice\Tele2\Voice\language.wav)
103255,95 3 tw ConvertWav2Vox C:\Voice\Tele2\Voice\language.wav
103255,95 3 tw DialogicEvent 134,TDX_CST,326,0,0,DE_LCON,,
103255,95 3 event TDX_CST, code=134, state=1100
103255,95 3 LsPlayMsg EV_UNKNOWN_134,TDX_CST
103255,95 3 path {TDX_CST} not found
103256,03 3 tw wav->vox convert end 587453,C:\Voice\Tele2\Voice\language.vox,1,0,,
103256,06 3 play start ok, lPlayId=587531
103259,77 3 event callstate DISCONNECTED 3 0 0
103259,77 3 event EV_REMOTEPARTY_DISCONNECT, code=9250, state=1100
103259,77 3 LsPlayMsg EV_REMOTEPARTY_DISCONNECT,EV_REMOTEPARTY_DISCONNECT
103259,77 3 path {EV_REMOTEPARTY_DISCONNECT} not found
103259,77 3 rv add [Hangup Time]{2005-10-13 10:32:59}
103259,77 3 state Hanging up call...
103259,77 3 HangupCall_Common hCall=3
103259,80 3 rec RecSoundStop ok
103259,81 3 play PlaySoundStop ok
103259,81 3 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
103259,81 3 fnHangupCall end
103259,81 3 tw DialogicEvent 134,TDX_CST,382,0,0,DE_LCOF,,
103259,81 3 event TDX_CST, code=134, state=900
103259,81 3 LsAwaitingCalls EV_UNKNOWN_134
103259,81 3 tw PlayEnd 3 587531
103259,81 3 play end id=587531, (current ID)
103259,81 3 event EV_PLAY_FINISHED, code=8001, state=900
103259,81 3 LsAwaitingCalls EV_PLAY_FINISHED
103259,81 3 tw DialogicEvent 129,TDX_PLAY,587531,0,0,,,
103259,81 3 event TDX_PLAY, code=129, state=900
103259,81 3 LsAwaitingCalls EV_UNKNOWN_129
103259,81 3 tw DialogicEvent 134,TDX_CST,1,0,0,DE_LCON,,
103259,86 3 event callstate IDLE 3 0 0
103259,86 3 WorkingMode@Idle=
103259,86 3 timer clear
103259,88 3 rec RecSoundStop ok
103259,89 3 play PlaySoundStop ok
103259,89 3 rv add [CallEndTime]{2005-10-13 10:32:59}
103259,91 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
103259,91 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
103259,91 3 event TDX_SETHOOK, code=135, state=900
103259,91 3 LsAwaitingCalls EV_UNKNOWN_135
103300,92 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
103300,92 3 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
103300,92 3 init atidle reinit : start
103300,92 3 init atidle reinit iConferenceOtherLegLid=-1
103300,92 3 init atidle reinit : reset all LineState variables
103300,92 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
103300,92 3 state Waiting for a call...
103301,25 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
103301,25 3 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
103506,08 4 tw DialogicEvent 134,TDX_CST,194,0,0,DE_TONEON,TID_DIAL_INTL,
103506,08 4 event DIALTONE, code=134, state=0
103506,08 4 event TID_DIAL_INTL, code=134, state=0
103506,08 4 event TDX_CST, code=134, state=0
103606,06 3 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
103606,06 3 event RINGBACK, code=134, state=900
103606,06 3 LsAwaitingCalls EV_UNKNOWN_134
103606,06 3 event TID_RNGBK1, code=134, state=900
103606,06 3 event TDX_CST, code=134, state=900
103629,23 3 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
103629,23 3 event RINGBACK, code=134, state=900
103629,23 3 LsAwaitingCalls EV_UNKNOWN_134
103629,23 3 event TID_RNGBK1, code=134, state=900
103629,23 3 event TDX_CST, code=134, state=900
103803,41 3 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
103803,41 3 event RINGBACK, code=134, state=900
103803,41 3 LsAwaitingCalls EV_UNKNOWN_134
103803,41 3 event TID_RNGBK1, code=134, state=900
103803,41 3 event TDX_CST, code=134, state=900
103945,19 4 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
103945,19 4 event RINGBACK, code=134, state=0
103945,19 4 event TID_RNGBK1, code=134, state=0
103945,19 4 event TDX_CST, code=134, state=0
104038,95 4 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
104038,95 4 event RINGBACK, code=134, state=0
104038,95 4 event TID_RNGBK1, code=134, state=0
104038,95 4 event TDX_CST, code=134, state=0
104150,98 0 load start [C:\Voice\Locksmith\locksmith.vgs]
104151,03 0 loaded Script Id 4: C:\Voice\Locksmith\locksmith.vgs
104151,03 0 Erasing Script (new loaded) Id 3
104159,03 0 load start [C:\Voice\Locksmith\locksmith.vgs]
104159,06 0 loaded Script Id 3: C:\Voice\Locksmith\locksmith.vgs
104159,08 0 Erasing Script (new loaded) Id 4
104214,08 0 load start [C:\Voice\Tele2\Two-Services.vgs]
104214,08 0 loaded Script Id 4: C:\Voice\Tele2\Two-Services.vgs
104214,08 0 Erasing Script (new loaded) Id 2
104215,33 0 btn Exit (8 lines)
104215,33 1 line state =0
104215,33 2 line state =0
104215,33 3 line state =900
104215,33 4 line state =0
104215,33 0 line state =0
104215,34 1 state Exiting...
104215,34 2 state Exiting...
104215,34 3 state Exiting...
104215,34 4 state Exiting...
104215,34 0 state Exiting...
104216,45 0 exit closing all channels start
104216,45 0 exit close dxxxB1C1(1)=> []
104216,45 0 exit close dxxxB1C2(2)=> []
104216,45 0 exit close dxxxB1C3(3)=> []
104216,45 0 exit close dxxxB1C4(4)=> []
104216,45 0 exit close dxxxB2C1(0)=> [dlgc dx_close(-1) error, dx_fileerrno=2]
104216,47 0 exit close dxxxB2C2(0)=> [dlgc dx_close(-1) error, dx_fileerrno=2]
104216,47 0 exit close dxxxB2C3(0)=> [dlgc dx_close(-1) error, dx_fileerrno=2]
104216,47 0 exit close dxxxB2C4(0)=> [dlgc dx_close(-1) error, dx_fileerrno=2]
104216,47 0 exit closing all channels end
104216,88 0 ---------------------------------------------------
104216,88 0 Stopping VoiceGuide (Dialogic) start
104216,88 0 v6.0.2092
104216,88 0 Stopping VoiceGuide (Dialogic) end
104219,64 0 ---------------------------------------------------
104219,73 0 VoiceGuide for Dialogic
104219,73 0 v6.0.2092
104219,73 0 ---------------------------------------------------
104219,75 0 rv global loaded >>><<<
104219,75 0 Inband Signaling Config file not specified
104220,11 0 init ApiMode=[DialogicGC]
104220,14 0 vm loading VMB data begin
104220,16 0 vm loading VMB data - about to delete old entries
104220,22 0 vm loading VMB data - sorting/ordering
104220,22 0 vm loading VMB data end
104220,23 0 dial DbConnectString_ADO is blank
104220,28 0 init DB Workspaces
104220,30 0 init Voicemail LoadIniSettings
104220,33 0 init read Config.xml start
104220,34 0 dxxxB1C1 dxxxB1C1 C:\Voice\PetDirekt\petdirekt.vgs allowDialout=1
104220,34 0 dxxxB1C2 dxxxB1C2 C:\Voice\PetDirekt\petdirekt.vgs allowDialout=1
104220,34 0 dxxxB1C3 dxxxB1C3 C:\Voice\Tele2\Two-Services.vgs allowDialout=1
104220,34 0 dxxxB1C4 dxxxB1C4 C:\Voice\Tele2\Two-Services.vgs allowDialout=1
104220,34 0 dxxxB2C1 dxxxB2C1 C:\Voice\Locksmith\locksmith.vgs allowDialout=1
104220,34 0 dxxxB2C2 dxxxB2C2 C:\Voice\Choice\Lang-Service.vgs allowDialout=1
104220,34 0 dxxxB2C3 dxxxB2C3 C:\Voice\Choice\Lang-Service.vgs allowDialout=1
104220,34 0 dxxxB2C4 dxxxB2C4 C:\Voice\Choice\Lang-Service.vgs allowDialout=1
104220,34 0 init read Config.xml end
104220,38 0 init LineOpenDialogic dxxxB1C1 => [1]
104220,38 1 iIvrDev=1
104220,83 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig)
104220,83 0 load start [C:\Voice\PetDirekt\petdirekt.vgs]
104220,92 0 init hires timer setup start
104220,92 0 init hires timer setup end
104220,92 1 state Waiting for a call...
104220,92 1 event callstate IDLE 1 0 0
104220,92 1 WorkingMode@Idle=
104220,92 1 timer clear
104220,92 1 LineState(iLineId).iVgsIdx = 0
104220,92 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104220,92 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
104220,92 1 event TDX_SETHOOK, code=135, state=0
104220,92 1 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104220,92 1 timer set ignored - waiting for line re-init to occur first
104220,92 0 init lineids: 0-1
104220,94 0 init LineOpenDialogic dxxxB1C2 => [2]
104220,94 2 iIvrDev=2
104221,41 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig)
104221,41 0 init hires timer setup start
104221,41 0 init hires timer setup end
104221,41 2 state Waiting for a call...
104221,42 2 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104221,42 0 init lineids: 0-2
104221,44 0 init LineOpenDialogic dxxxB1C3 => [3]
104221,44 3 iIvrDev=3
104221,89 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig)
104221,89 0 load start [C:\Voice\Tele2\Two-Services.vgs]
104221,91 0 init hires timer setup start
104221,91 0 init hires timer setup end
104221,91 3 state Waiting for a call...
104221,91 2 event callstate IDLE 2 0 0
104221,91 2 WorkingMode@Idle=
104221,91 2 timer clear
104221,91 2 LineState(iLineId).iVgsIdx = 0
104221,91 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104221,91 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
104221,91 2 event TDX_SETHOOK, code=135, state=0
104221,91 3 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104221,91 0 init lineids: 0-3
104221,94 0 init LineOpenDialogic dxxxB1C4 => [4]
104221,94 4 iIvrDev=4
104222,41 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig)
104222,41 0 init hires timer setup start
104222,41 0 init hires timer setup end
104222,41 4 state Waiting for a call...
104222,41 3 event callstate IDLE 3 0 0
104222,41 3 WorkingMode@Idle=
104222,41 3 timer clear
104222,41 3 LineState(iLineId).iVgsIdx = 0
104222,41 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104222,41 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
104222,41 3 event TDX_SETHOOK, code=135, state=0
104222,44 4 event callstate IDLE 4 0 0
104222,44 4 WorkingMode@Idle=
104222,44 4 timer clear
104222,44 4 LineState(iLineId).iVgsIdx = 0
104222,44 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104222,44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
104222,44 4 event TDX_SETHOOK, code=135, state=0
104222,44 4 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104222,44 4 timer set ignored - waiting for line re-init to occur first
104222,44 0 init lineids: 0-4
104222,44 0 init LineOpenDialogic dxxxB2C1 => [dlgc dx_open(dxxxB2C1) C error 2]
104222,44 5 Check if Dialogic Service is started
104222,44 0 init LineOpenDialogic dxxxB2C2 => [dlgc dx_open(dxxxB2C2) C error 2]
104222,44 6 Check if Dialogic Service is started
104222,44 0 init LineOpenDialogic dxxxB2C3 => [dlgc dx_open(dxxxB2C3) C error 2]
104222,44 7 Check if Dialogic Service is started
104222,44 0 init LineOpenDialogic dxxxB2C4 => [dlgc dx_open(dxxxB2C4) C error 2]
104222,44 8 Check if Dialogic Service is started
104222,44 0 init route channels start
104222,56 0 init route channels => []
104222,56 0 init no dti channels opened. Not opening signaling channel.
104222,56 0 init iLineDevicesControlled=8
104222,59 0 init main form load end
104223,25 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
104223,25 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
104223,25 1 init atidle reinit : start
104223,25 1 init atidle reinit iConferenceOtherLegLid=-1
104223,25 1 init atidle reinit : reset all LineState variables
104223,25 1 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104223,25 1 state Waiting for a call...
104223,36 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
104223,36 2 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
104223,36 2 init atidle reinit : start
104223,36 2 init atidle reinit iConferenceOtherLegLid=-1
104223,36 2 init atidle reinit : reset all LineState variables
104223,36 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104223,36 2 state Waiting for a call...
104223,47 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
104223,47 3 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
104223,47 3 init atidle reinit : start
104223,47 3 init atidle reinit iConferenceOtherLegLid=-1
104223,47 3 init atidle reinit : reset all LineState variables
104223,47 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104223,47 3 state Waiting for a call...
104223,58 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104223,58 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
104223,58 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
104223,58 4 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
104223,58 4 init atidle reinit : start
104223,58 4 init atidle reinit iConferenceOtherLegLid=-1
104223,58 4 init atidle reinit : reset all LineState variables
104223,58 4 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104223,58 4 state Waiting for a call...
104223,69 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104223,69 2 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
104223,80 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104223,80 3 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
104223,91 4 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104223,91 4 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
104252,25 4 tw DialogicEvent 134,TDX_CST,194,0,0,DE_TONEON,TID_DIAL_INTL,
104252,25 4 event DIALTONE, code=134, state=0
104252,25 4 event TID_DIAL_INTL, code=134, state=0
104252,25 4 event TDX_CST, code=134, state=0
104253,14 4 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
104253,14 4 event RINGBACK, code=134, state=0
104253,14 4 event TID_RNGBK1, code=134, state=0
104253,14 4 event TDX_CST, code=134, state=0
104318,52 0 sys cleanup Start
104318,52 0 sys cleanup End
Thank you!
Jose
1013tw.txt
What sort of a noise and for how long? Anyway that is probably not related to the problems as the second number gets dialed OK:
I see that you are using v6.0.2092 of VoiceGuide - please try updating to v6.0.2275 and post the trace from that version.
Hello!
I have installed the new version but still the same problem.
Here it comes the vgm file:
115233,22 0 btn Exit (4 lines)
115233,22 1 line state =0
115233,22 2 line state =0
115233,22 3 line state =900
115233,22 4 line state =0
115233,23 1 state Exiting...
115233,23 2 state Exiting...
115233,23 3 state Exiting...
115233,23 4 state Exiting...
115234,34 0 exit closing all channels start
115234,34 0 exit close dxxxB1C1(1)=> []
115234,34 0 exit close dxxxB1C2(2)=> []
115234,34 0 exit close dxxxB1C3(3)=> []
115234,34 0 exit close dxxxB1C4(4)=> []
115234,34 0 exit closing all channels end
115234,75 0 ---------------------------------------------------
115234,75 0 Stopping VoiceGuide (Dialogic) start
115234,75 0 v6.0.2275
115234,75 0 Stopping VoiceGuide (Dialogic) end
115239,84 0 ---------------------------------------------------
115239,94 0 VoiceGuide for Dialogic
115239,94 0 v6.0.2275
115239,94 0 ---------------------------------------------------
115239,95 0 rv global loaded >>><<<
115239,95 0 cti Inband Signaling Config file not specified
115240,27 0 init ApiMode=[DialogicGC]
115240,28 0 vm loading VMB data begin
115240,28 0 vm loading VMB data - about to delete old entries
115240,36 0 vm loading VMB data - sorting/ordering
115240,36 0 vm loading VMB data end
115240,38 0 dial DbConnectString_ADO is blank
115240,39 0 init DB Workspaces
115240,39 0 init Voicemail LoadIniSettings
115240,42 0 init read Config.xml start
115240,44 0 dxxxB1C1 dxxxB1C1 C:\Voice\PetDirekt\petdirekt.vgs RV= allowDialout=1
115240,44 0 dxxxB1C2 dxxxB1C2 C:\Voice\PetDirekt\petdirekt.vgs RV= allowDialout=1
115240,44 0 dxxxB1C3 dxxxB1C3 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=1
115240,44 0 dxxxB1C4 dxxxB1C4 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=1
115240,44 0 init read Config.xml end
115240,45 0 init LineOpenDialogic dxxxB1C1 => [1]
115240,45 1 iIvrDev=1
115240,53 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
115240,53 0 init distinct ring definitions found:2
115240,53 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
115240,53 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
115240,53 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
115240,53 0 init ring 2 [TelstraDoubleRing] cadences defined:2
115240,53 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
115240,53 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
115240,53 0 init load Distinct Ring definitions end
115240,53 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig)
115240,53 0 load start [C:\Voice\PetDirekt\petdirekt.vgs]
115240,53 0 MemStructVgs_ClearVgs [1]
115240,63 0 load end
115240,63 0 init hires timer setup start
115240,63 0 init hires timer setup end
115240,63 1 state Waiting for a call...
115240,63 1 event callstate IDLE 1 1,0,0
115240,63 1 WorkingMode@Idle=
115240,63 1 timer clear
115240,63 1 LineState(iLineId).iVgsIdx = 0
115240,63 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
115240,63 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
115240,63 1 event ScriptEventCode TDX_SETHOOK, code=135, state=0
115240,63 1 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115240,63 1 timer set ignored - waiting for line re-init to occur first
115240,63 0 init lineids: 0-1
115240,64 0 init LineOpenDialogic dxxxB1C2 => [2]
115240,64 2 iIvrDev=2
115240,72 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
115240,72 0 init distinct ring definitions found:2
115240,72 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
115240,72 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
115240,72 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
115240,72 0 init ring 2 [TelstraDoubleRing] cadences defined:2
115240,72 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
115240,72 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
115240,72 0 init load Distinct Ring definitions end
115240,72 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig)
115240,72 0 init hires timer setup start
115240,72 0 init hires timer setup end
115240,72 2 state Waiting for a call...
115240,72 2 event callstate IDLE 2 1,0,0
115240,72 2 WorkingMode@Idle=
115240,72 2 timer clear
115240,72 2 LineState(iLineId).iVgsIdx = 0
115240,72 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
115240,72 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
115240,72 2 event ScriptEventCode TDX_SETHOOK, code=135, state=0
115240,72 2 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115240,72 2 timer set ignored - waiting for line re-init to occur first
115240,72 0 init lineids: 0-2
115240,75 0 init LineOpenDialogic dxxxB1C3 => [3]
115240,75 3 iIvrDev=3
115240,81 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
115240,83 0 init distinct ring definitions found:2
115240,83 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
115240,83 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
115240,83 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
115240,83 0 init ring 2 [TelstraDoubleRing] cadences defined:2
115240,83 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
115240,83 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
115240,83 0 init load Distinct Ring definitions end
115240,83 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig)
115240,83 0 load start [C:\Voice\Tele2\Two-Services.vgs]
115240,83 0 MemStructVgs_ClearVgs [2]
115240,83 0 load end
115240,83 0 init hires timer setup start
115240,83 0 init hires timer setup end
115240,83 3 state Waiting for a call...
115240,83 3 event callstate IDLE 3 1,0,0
115240,83 3 WorkingMode@Idle=
115240,83 3 timer clear
115240,83 3 LineState(iLineId).iVgsIdx = 0
115240,83 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
115240,83 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
115240,83 3 event ScriptEventCode TDX_SETHOOK, code=135, state=0
115240,83 3 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115240,83 3 timer set ignored - waiting for line re-init to occur first
115240,83 0 init lineids: 0-3
115240,86 0 init LineOpenDialogic dxxxB1C4 => [4]
115240,86 4 iIvrDev=4
115240,92 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
115240,94 0 init distinct ring definitions found:2
115240,94 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
115240,94 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
115240,94 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
115240,94 0 init ring 2 [TelstraDoubleRing] cadences defined:2
115240,94 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
115240,94 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
115240,94 0 init load Distinct Ring definitions end
115240,94 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig)
115240,94 0 init hires timer setup start
115240,94 0 init hires timer setup end
115240,94 4 state Waiting for a call...
115240,94 4 event callstate IDLE 4 1,0,0
115240,94 4 WorkingMode@Idle=
115240,94 4 timer clear
115240,94 4 LineState(iLineId).iVgsIdx = 0
115240,94 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
115240,94 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
115240,94 4 event ScriptEventCode TDX_SETHOOK, code=135, state=0
115240,94 4 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115240,94 4 timer set ignored - waiting for line re-init to occur first
115240,94 0 init lineids: 0-4
115240,94 0 init route channels start
115241,05 0 init route channels => []
115241,05 0 init no dti channels opened. Not opening signaling channel.
115241,05 0 cti Link1 serial init complete
115241,05 0 cti serial1 closed not sending HeartbeatCheck
115241,05 0 init iLineDevicesControlled=4
115241,08 0 init main form load end
115241,84 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
115241,84 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
115241,84 1 init atidle reinit : start
115241,84 1 init atidle reinit iConferenceOtherLegLid=-1
115241,84 1 init atidle reinit : reset all LineState variables
115241,84 1 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115241,84 1 state Waiting for a call...
115241,84 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
115241,84 2 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
115241,84 2 init atidle reinit : start
115241,84 2 init atidle reinit iConferenceOtherLegLid=-1
115241,84 2 init atidle reinit : reset all LineState variables
115241,84 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115241,84 2 state Waiting for a call...
115241,95 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
115241,95 3 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
115241,95 3 init atidle reinit : start
115241,95 3 init atidle reinit iConferenceOtherLegLid=-1
115241,95 3 init atidle reinit : reset all LineState variables
115241,95 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115241,95 3 state Waiting for a call...
115242,06 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
115242,06 4 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
115242,06 4 init atidle reinit : start
115242,06 4 init atidle reinit iConferenceOtherLegLid=-1
115242,06 4 init atidle reinit : reset all LineState variables
115242,06 4 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115242,06 4 state Waiting for a call...
115242,17 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
115242,17 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
115242,17 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
115242,17 2 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
115242,28 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
115242,28 3 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
115242,39 4 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
115242,39 4 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
115312,31 3 tw dtmf d (3,100,100)
115312,31 3 event ScriptEventCode d, code=100, state=0
115312,31 3 already IDLE. HangupCall ignored.
115312,31 3 init atidle reinit : start
115312,33 3 init atidle reinit iConferenceOtherLegLid=-1
115312,33 3 init atidle reinit : reset all LineState variables
115312,33 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115312,33 3 state Waiting for a call...
115312,33 3 tw DialogicEvent 134,TDX_CST,100,0,0,DE_DIGITS,,
115312,33 3 event ScriptEventCode TDX_CST, code=134, state=900
115312,33 3 LsAwaitingCalls EV_UNKNOWN_134
115312,47 3 tw dtmf 0 (3,48,48)
115312,47 3 event ScriptEventCode 0, code=48, state=900
115312,47 3 LsAwaitingCalls 0
115312,47 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
115312,47 3 event ScriptEventCode TDX_CST, code=134, state=900
115312,47 3 LsAwaitingCalls EV_UNKNOWN_134
115312,59 3 tw dtmf 8 (3,56,56)
115312,59 3 event ScriptEventCode 8, code=56, state=900
115312,59 3 LsAwaitingCalls 8
115312,59 3 tw DialogicEvent 134,TDX_CST,56,0,0,DE_DIGITS,,
115312,59 3 event ScriptEventCode TDX_CST, code=134, state=900
115312,59 3 LsAwaitingCalls EV_UNKNOWN_134
115312,64 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
115312,64 3 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
115312,73 3 tw dtmf 4 (3,52,52)
115312,73 3 event ScriptEventCode 4, code=52, state=900
115312,73 3 LsAwaitingCalls 4
115312,73 3 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
115312,73 3 event ScriptEventCode TDX_CST, code=134, state=900
115312,73 3 LsAwaitingCalls EV_UNKNOWN_134
115312,89 3 tw dtmf 4 (3,52,52)
115312,89 3 event ScriptEventCode 4, code=52, state=900
115312,89 3 LsAwaitingCalls 4
115312,89 3 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
115312,89 3 event ScriptEventCode TDX_CST, code=134, state=900
115312,89 3 LsAwaitingCalls EV_UNKNOWN_134
115313,05 3 tw dtmf 2 (3,50,50)
115313,05 3 event ScriptEventCode 2, code=50, state=900
115313,05 3 LsAwaitingCalls 2
115313,05 3 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
115313,05 3 event ScriptEventCode TDX_CST, code=134, state=900
115313,05 3 LsAwaitingCalls EV_UNKNOWN_134
115313,19 3 tw dtmf 9 (3,57,57)
115313,19 3 event ScriptEventCode 9, code=57, state=900
115313,19 3 LsAwaitingCalls 9
115313,19 3 tw DialogicEvent 134,TDX_CST,57,0,0,DE_DIGITS,,
115313,19 3 event ScriptEventCode TDX_CST, code=134, state=900
115313,19 3 LsAwaitingCalls EV_UNKNOWN_134
115313,34 3 tw dtmf 0 (3,48,48)
115313,34 3 event ScriptEventCode 0, code=48, state=900
115313,36 3 LsAwaitingCalls 0
115313,36 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
115313,36 3 event ScriptEventCode TDX_CST, code=134, state=900
115313,36 3 LsAwaitingCalls EV_UNKNOWN_134
115313,48 3 tw dtmf 4 (3,52,52)
115313,48 3 event ScriptEventCode 4, code=52, state=900
115313,48 3 LsAwaitingCalls 4
115313,48 3 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
115313,48 3 event ScriptEventCode TDX_CST, code=134, state=900
115313,48 3 LsAwaitingCalls EV_UNKNOWN_134
115313,66 3 tw dtmf 0 (3,48,48)
115313,66 3 event ScriptEventCode 0, code=48, state=900
115313,66 3 LsAwaitingCalls 0
115313,66 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
115313,66 3 event ScriptEventCode TDX_CST, code=134, state=900
115313,66 3 LsAwaitingCalls EV_UNKNOWN_134
115313,78 3 tw dtmf c (3,99,99)
115313,78 3 event ScriptEventCode c, code=99, state=900
115313,78 3 LsAwaitingCalls c
115313,78 3 tw DialogicEvent 134,TDX_CST,99,0,0,DE_DIGITS,,
115313,78 3 event ScriptEventCode TDX_CST, code=134, state=900
115313,78 3 LsAwaitingCalls EV_UNKNOWN_134
115314,14 3 event callstate OFFERING 3 2,0,0
115314,14 3 script interpretor: VgMulti v6.0.2275
115314,14 3 fired OFFERING event to listeners
115314,14 3 set LineState().hCall = 3 in LINECALLSTATE_OFFERING
115314,14 3 iIvrDev=3
115314,14 3 set linestate CID vars
115314,14 3 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
115314,14 3 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
115314,14 3 tw ring 1
115314,14 3 ring time since last ring event (sec): 0,00
115314,14 3 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
115314,14 3 rv clear all
115314,14 3 init LineState ResetAtStartOfNewCall.
115314,14 3 answer the call
115314,14 3 timer clear
115314,16 3 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
115314,16 3 event ScriptEventCode TDX_CST, code=134, state=6001
115314,92 3 event callstate CONNECTED 3 256,0,0
115314,92 3 LineEvCallState_Connected hDevice=3 params=256,0,0
115314,92 3 WorkingModes tapi= script= LineState().iState=6001
115314,94 3 Inband detection not enabled
115314,94 3 StartLoadedVgs at 2005-10-13 11:53:14 [VgMulti v6.0.2275]
115314,94 3 set LineState().iVgsIdx=2
115314,94 3 set sScriptToRunOnHangup=[] in StartLoadedVgs
115314,94 3 init StartLoadedVgs_InitLineState start
115314,94 3 rv add [$RV_STARTTIME]{2005-10-13 11:53:14}
115314,94 3 rv add [$RV_DEVICEID]{3}
115314,94 3 rv add [$RV_CIDNAME]{}
115314,94 3 rvns add [PathApp]{C:\Program\VoiceGuide\}
115314,94 3 rvns add [scriptsPath]{C:\Voice\Tele2\}
115314,94 3 rv add [$RV_CIDNUMBER]{}
115314,94 3 fn RunModule start
115314,94 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
115314,94 3 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
115314,94 3 tw DialogicEvent 134,TDX_CST,9368,0,0,DE_LCON,,
115314,95 3 event ScriptEventCode TDX_CST, code=134, state=6001
115314,95 3 timer clear
115314,95 3 Play Module start
115314,95 3 state [LANGUAGE] Playing
115314,95 3 state [LANGUAGE] Playing (C:\Voice\Tele2\Voice\language.wav)
115314,95 3 tw ConvertWav2Vox C:\Voice\Tele2\Voice\language.wav
115314,95 3 tw wav->vox convert end 406453,C:\Voice\Tele2\Voice\language.vox,1,0,,
115314,98 3 play start ok, lPlayId=406453
115320,63 3 tw PlayEnd 3 406453
115320,63 3 play end id=406453, (current ID)
115320,63 3 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
115320,63 3 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
115320,63 3 path {EV_PLAY_FINISHED} not found
115320,63 3 timer set 5 EV_TIMEOUT_REPLAYMSG
115320,63 3 tw DialogicEvent 129,TDX_PLAY,406453,0,0,,,
115320,63 3 event ScriptEventCode TDX_PLAY, code=129, state=1101
115320,63 3 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
115320,63 3 path {TDX_PLAY} not found
115321,72 3 tw dtmf 2 (3,50,50)
115321,72 3 event ScriptEventCode 2, code=50, state=1101
115321,72 3 LsPlayMsgFinished 2,2
115321,72 3 rv add [LANGUAGE]{2}
115321,72 3 fn RunModule start
115321,72 3 timer clear
115321,72 3 state [init_COUNTER] Evaluate [0]
115321,72 3 eval[0]
115321,72 3 rvns add [init_COUNTER_Input]{0}
115321,72 3 rvns add [init_COUNTER]{0}
115321,72 3 rvns add [counter]{0}
115321,72 3 Eval Expr result:[0] stored in $RV[counter]
115321,72 3 path {0} not found
115321,72 3 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
115321,72 3 event ScriptEventCode TDX_CST, code=134, state=6001
115321,72 3 Play Module start
115321,72 3 state [sERVICES] Playing
115321,72 3 rv replace start: [C:\Voice\Tele2\Voice\SERVICES_$RV[LANGUAGE].wav]
115321,72 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}
115321,72 3 rv replace end: [C:\Voice\Tele2\Voice\SERVICES_2.wav]
115321,72 3 state [sERVICES] Playing (C:\Voice\Tele2\Voice\SERVICES_2.wav)
115321,72 3 tw ConvertWav2Vox C:\Voice\Tele2\Voice\SERVICES_2.wav
115321,81 3 tw wav->vox convert end 413218,C:\Voice\Tele2\Voice\SERVICES_2.vox,1,0,,
115321,84 3 play start ok, lPlayId=413312
115328,80 3 tw dtmf 2 (3,50,50)
115328,80 3 event ScriptEventCode 2, code=50, state=1100
115328,80 3 LsPlayMsg 2,2
115328,80 3 rv add [scriptEnd_Time]{2005-10-13 11:53:28}
115328,80 3 rv add [scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}
115328,80 3 rv add [scriptEnd_Goto_Module]{Init_SYSTEM_DIR}
115328,81 3 rv add [scriptStart_Time]{2005-10-13 11:53:28}
115328,81 3 rv add [scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}
115328,81 3 rv add [scriptStart_CalledFrom_Module]{SERVICES}
115328,81 3 FindFullPathToScript_VgsOrVgp start [C:\Voice\Locksmith\locksmith.vgs]
115328,81 3 FindFullPathToScript_VgsOrVgp 1
115328,81 0 load start [C:\Voice\Locksmith\locksmith.vgs]
115328,81 0 MemStructVgs_ClearVgs [3]
115328,86 0 load end
115328,86 3 loaded [C:\Voice\Locksmith\locksmith.vgs] into:3
115328,86 3 rvns add [scriptsPath]{C:\Voice\Locksmith\}
115328,89 3 play PlaySoundStop ok
115328,89 3 rv add [sERVICES]{2}
115328,89 3 fn RunModule start
115328,89 3 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
115328,89 3 event ScriptEventCode TDX_CST, code=134, state=6001
115328,89 3 timer clear
115328,89 3 state [init_SYSTEM_DIR] Evaluate [1]
115328,89 3 eval[1]
115328,89 3 rvns add [init_SYSTEM_DIR_Input]{1}
115328,89 3 rvns add [init_SYSTEM_DIR]{1}
115328,89 3 rvns add [systemDirVoice]{1}
115328,89 3 Eval Expr result:[1] stored in $RV[systemDirVoice]
115328,89 3 path {1} not found
115328,89 3 tw PlayEnd 3 413312
115328,89 3 play end id=413312, (current ID)
115328,89 3 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001
115328,91 3 tw DialogicEvent 129,TDX_PLAY,413312,0,0,,,
115328,91 3 event ScriptEventCode TDX_PLAY, code=129, state=6001
115328,91 3 timer clear
115328,91 3 state [init_HomeDir] Running VB Script...
115328,91 3 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
lang = vg.RvGet($RV_LINEID, "RV[LANGUAGE]")
'msgbox(counter2)
if lang=1 then 'engelska
vg.RvSet $RV_LINEID, "systemDirVoice", "C:\Voice\Locksmith\voice\engelska"
else
vg.RvSet $RV_LINEID, "systemDirVoice", "C:\Voice\Locksmith\voice\svenska"
end if
set vg = Nothing
115328,91 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}[scriptEnd_Time]{2005-10-13 11:53:28}[scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}[scriptEnd_Goto_Module]{Init_SYSTEM_DIR}[scriptStart_Time]{20
5-10-13 11:53:28}[scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}[scriptStart_CalledFrom_Module]{SERVICES}[scriptsPath]{C:\Voice\Locksmith\}[sERVICES]{2}[init_SYSTEM_DIR_Input]{1}[init_SYSTEM_DIR]{1}[systemDirVoice
{1}
115328,91 3 vbs ran [vbs_3_1.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_3_1.vbs" //I //T:60]
115328,95 3 Run Script waiting. iRunWait=1 (shellid=248, process=1572)
115328,95 3 timer set 1 EV_TIMEOUT_CHECKONSTATE
115329,00 3 cl RvGet RV[LANGUAGE]
115329,00 3 rv replace start: [$RV[LANGUAGE]]
115329,00 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
{1}
115329,00 3 rv replace end: [2]
115329,00 3 cl RvSet systemDirVoice, C:\Voice\Locksmith\voice\svenska
115329,02 3 rv add [systemDirVoice]{C:\Voice\Locksmith\voice\svenska}
115329,02 3 cl Run_ResultReturn >>success<<
115329,02 3 rv add [init_HomeDir_ResultReturn]{success}
115329,02 3 cl module's runwait=1, WavPlayHasNowFinished=0
115329,02 3 fn RunModule start
115329,02 3 timer clear
115329,02 3 state [Change_Dir] Evaluate [$rv[systemDirVoice]]
115329,02 3 rv replace start: [$rv[systemDirVoice]]
115329,02 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
{1}[systemDirVoice]{C:\Voice\Locksmith\voice\svenska}[init_HomeDir_ResultReturn]{success}
115329,02 3 rv replace end: [C:\Voice\Locksmith\voice\svenska]
115329,02 3 eval[C:\Voice\Locksmith\voice\svenska]
115329,02 3 Error: 1002
115329,02 3 rvns add [Change_Dir_Input]{C:\Voice\Locksmith\voice\svenska}
115329,02 3 rvns add [Change_Dir]{C:\Voice\Locksmith\voice\svenska}
115329,02 3 rvns add [DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\svenska}
115329,02 3 Eval Expr result:[C:\Voice\Locksmith\voice\svenska] stored in $RV[DIRSYSTEMVOICE]
115329,02 3 path {C:\Voice\Locksmith\voice\svenska} not found
115329,02 3 Play Module start
115329,02 3 state [WELCOME] Playing
115329,02 3 rv replace start: [C:\Voice\Locksmith\voice\welcome_locksmith_$RV[LANGUAGE].wav]
{1}[systemDirVoice]{C:\Voice\Locksmith\voice\svenska}[init_HomeDir_ResultReturn]{success}[Change_Dir_Input]{C:\Voice\Locksmith\voice\svenska}[Change_Dir]{C:\Voice\Locksmith\voice\svenska}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\svenska}
115329,02 3 rv replace end: [C:\Voice\Locksmith\voice\welcome_locksmith_2.wav]
115329,02 3 state [WELCOME] Playing (C:\Voice\Locksmith\voice\welcome_locksmith_2.wav)
115329,02 3 tw ConvertWav2Vox C:\Voice\Locksmith\voice\welcome_locksmith_2.wav
115329,09 3 tw wav->vox convert end 420515,C:\Voice\Locksmith\voice\welcome_locksmith_2.vox,1,0,,
115329,13 3 play start ok, lPlayId=420593
115338,73 0 sys cleanup Start
115338,73 0 sys cleanup End
115343,34 3 tw PlayEnd 3 420593
115343,34 3 play end id=420593, (current ID)
115343,34 3 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
115343,34 3 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
115343,34 3 path {EV_PLAY_FINISHED} not found
115343,34 3 timer set 10 EV_TIMEOUT_HANGUP
115343,34 3 timer set 0 EV_TIMEOUT_GOTOMODULE
115343,34 3 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
115343,36 3 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
115343,36 3 path {EV_TIMEOUT_GOTOMODULE} not found
115343,36 3 fn RunModule start
115343,36 3 timer clear
115343,36 3 state [Var_Result_Query] Evaluate [1]
115343,36 3 eval[1]
115343,36 3 rvns add [Var_Result_Query_Input]{1}
115343,36 3 rvns add [Var_Result_Query]{1}
115343,36 3 rvns add [resultQuery]{1}
115343,36 3 Eval Expr result:[1] stored in $RV[resultQuery]
115343,36 3 path {1} not found
115343,36 3 tw DialogicEvent 129,TDX_PLAY,420593,0,0,,,
115343,36 3 event ScriptEventCode TDX_PLAY, code=129, state=6001
115343,36 3 state [selection_Choice] Number Input
115343,36 3 rv replace start: [C:\Voice\Locksmith\voice\selection_choice_$RV[LANGUAGE].wav]
115343,36 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
{1}[systemDirVoice]{C:\Voice\Locksmith\voice\svenska}[init_HomeDir_ResultReturn]{success}[Change_Dir_Input]{C:\Voice\Locksmith\voice\svenska}[Change_Dir]{C:\Voice\Locksmith\voice\svenska}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\svenska}[Var_Result_Query_Input]{1}[Var_Result_Query]{1}[resultQuery]{1}
115343,36 3 rv replace end: [C:\Voice\Locksmith\voice\selection_choice_2.wav]
115343,36 3 state [selection_Choice] Playing (C:\Voice\Locksmith\voice\selection_choice_2.wav)
115343,36 3 tw ConvertWav2Vox C:\Voice\Locksmith\voice\selection_choice_2.wav
115343,39 3 tw wav->vox convert end 434859,C:\Voice\Locksmith\voice\selection_choice_2.vox,1,0,,
115343,42 3 play start ok, lPlayId=434890
115350,16 3 tw dtmf 1 (3,49,49)
115350,16 3 event ScriptEventCode 1, code=49, state=1300
115350,16 3 LsGetNbrsPlayWelcMsg 1,1
115350,17 3 play PlaySoundStop ok
115350,19 3 state [selection_Choice] Number Input 1
115350,19 3 rv add [selection_Choice]{1}
115350,19 3 rvns add [selection_Choice_PathTaken]{1}
115350,19 3 fn RunModule start
115350,19 3 timer clear
115350,19 3 state [Get_Post_Code] Number Input
115350,19 3 rv replace start: [C:\Voice\Locksmith\voice\get_post_code_$RV[LANGUAGE].wav]
115350,19 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
{1}[systemDirVoice]{C:\Voice\Locksmith\voice\svenska}[init_HomeDir_ResultReturn]{success}[Change_Dir_Input]{C:\Voice\Locksmith\voice\svenska}[Change_Dir]{C:\Voice\Locksmith\voice\svenska}[DIRSYSTEMVOICE]{C:\Voice\Locksmith\voice\svenska}[Var_Result_Query_Input]{1}[Var_Result_Query]{1}[resultQuery]{1}[se
115350,19 3 rv replace end: [C:\Voice\Locksmith\voice\get_post_code_2.wav]
115350,19 3 state [Get_Post_Code] Playing (C:\Voice\Locksmith\voice\get_post_code_2.wav)
115350,19 3 tw ConvertWav2Vox C:\Voice\Locksmith\voice\get_post_code_2.wav
115350,19 3 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
115350,19 3 event ScriptEventCode TDX_CST, code=134, state=1300
115350,19 3 LsGetNbrsPlayWelcMsg EV_UNKNOWN_134,TDX_CST
115350,19 3 path {TDX_CST} not found
115350,19 3 tw PlayEnd 3 434890
115350,19 3 play end id=434890, (old ID) current id=441687
115350,19 3 tw DialogicEvent 129,TDX_PLAY,434890,0,0,,,
115350,19 3 event ScriptEventCode TDX_PLAY, code=129, state=1300
115350,19 3 LsGetNbrsPlayWelcMsg EV_UNKNOWN_129,TDX_PLAY
115350,19 3 path {TDX_PLAY} not found
115350,25 3 tw wav->vox convert end 441687,C:\Voice\Locksmith\voice\get_post_code_2.vox,1,0,,
115350,28 3 play start ok, lPlayId=441750
115354,42 3 tw PlayEnd 3 441750
115354,42 3 play end id=441750, (current ID)
115354,42 3 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1300
115354,42 3 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
115354,42 3 path {EV_PLAY_FINISHED} not found
115354,42 3 timer set 5 EV_TIMEOUT_REPLAYMSG
115354,42 3 tw DialogicEvent 129,TDX_PLAY,441750,0,0,,,
115354,42 3 event ScriptEventCode TDX_PLAY, code=129, state=1301
115354,42 3 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
115354,42 3 path {TDX_PLAY} not found
115354,75 3 tw dtmf 0 (3,48,48)
115354,75 3 event ScriptEventCode 0, code=48, state=1301
115354,75 3 LsGetNbrsRxDigits 0,0
115354,75 3 state [Get_Post_Code] Number Input 0
115354,75 3 path {0} not found
115354,75 3 timer set 6 EV_TIMEOUT_ENTERDATA
115354,75 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
115354,75 3 event ScriptEventCode TDX_CST, code=134, state=1301
115354,75 3 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
115354,75 3 path {TDX_CST} not found
115355,28 3 tw dtmf 0 (3,48,48)
115355,28 3 event ScriptEventCode 0, code=48, state=1301
115355,28 3 LsGetNbrsRxDigits 0,0
115355,28 3 state [Get_Post_Code] Number Input 00
115355,28 3 path {00} not found
115355,28 3 timer set 6 EV_TIMEOUT_ENTERDATA
115355,28 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
115355,28 3 event ScriptEventCode TDX_CST, code=134, state=1301
115355,28 3 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
115355,28 3 path {TDX_CST} not found
115355,84 3 tw dtmf 0 (3,48,48)
115355,84 3 event ScriptEventCode 0, code=48, state=1301
115355,84 3 LsGetNbrsRxDigits 0,0
115355,84 3 state [Get_Post_Code] Number Input 000
115355,84 3 path {000} not found
115355,84 3 timer set 6 EV_TIMEOUT_ENTERDATA
115355,84 3 timer clear
115355,84 3 rv add [Get_Post_Code]{000}
115355,84 3 rvns add [Get_Post_Code_PathTaken]{success}
115355,84 3 fn RunModule start
115355,84 3 state [CASE_locksmith_post] DB Query
115355,84 3 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
115355,84 3 event ScriptEventCode TDX_CST, code=134, state=1400
115355,84 3 ERROR 6.0.2275 Unknown State [1400]
115355,84 3 db ODBC mode used
115356,00 3 rv replace start: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =$RV[Get_Post_Code]]
115356,00 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
ection_Choice]{1}[selection_Choice_PathTaken]{1}[Get_Post_Code]{000}[Get_Post_Co
115356,00 3 rv replace end: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
115356,00 3 db About to execute a Retrieve type operation [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
115356,05 3 db [CASE_locksmith_post] row count=1
115356,05 3 rv add [CASE_locksmith_post_RowCount]{1}
115356,05 3 db get RecordsetGetRowsMax
115356,05 3 db get 999 records. (row count=1)
115356,05 3 db update RVs
115356,05 3 db about to close dbDbqDatabase
115356,05 3 db going down path [True]
115356,05 3 fn RunModule start
115356,05 3 timer clear
115356,05 3 state [Counter_post] Evaluate [1]
115356,05 3 eval[1]
115356,05 3 rvns add [Counter_post_Input]{1}
115356,05 3 rvns add [Counter_post]{1}
115356,05 3 rvns add [counter]{1}
115356,05 3 Eval Expr result:[1] stored in $RV[counter]
115356,05 3 path {1} not found
115356,05 3 state [Check_columns_post] Running VB Script...
115356,05 3 rv replace start (strlen>500)
115356,05 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
e_PathTaken]{success}[CASE_locksmith_post_RowCount]{1}[CASE_locksmith_post_1_1]{
46739389890}[CASE_locksmith_post_2_1]{+46708430642}[CASE_locksmith_post_3_1]{+46
115356,06 3 vbs ran [vbs_3_2.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_3_2.vbs" //I //T:60]
115356,09 3 Run Script waiting. iRunWait=1 (shellid=1264, process=1660)
115356,09 3 timer set 1 EV_TIMEOUT_CHECKONSTATE
115356,14 3 cl RvSet resultQuery, 0739389890
115356,14 3 rv add [resultQuery]{0739389890}
115356,14 3 cl Run_ResultReturn >>success<<
115356,14 3 rv add [Check_columns_post_ResultReturn]{success}
115356,14 3 cl module's runwait=1, WavPlayHasNowFinished=0
115356,14 3 fn RunModule start
115356,14 3 timer clear
115356,14 3 Play Module start
115356,14 3 state [info_To_Customer] Playing
115356,14 3 rv replace start: [c:\Voice\Locksmith\voice\nu_kopplar_$RV[LANGUAGE].wav]
115356,14 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
08430642}[Counter_post_Input]{1}[Counter_post]{1}[counter]{1}[resultQuery]{07393
115356,14 3 rv replace end: [c:\Voice\Locksmith\voice\nu_kopplar_2.wav]
115356,14 3 state [info_To_Customer] Playing (c:\Voice\Locksmith\voice\nu_kopplar_2.wav)
115356,14 3 tw ConvertWav2Vox c:\Voice\Locksmith\voice\nu_kopplar_2.wav
115356,20 3 tw wav->vox convert end 447640,c:\Voice\Locksmith\voice\nu_kopplar_2.vox,1,0,,
115356,23 3 play start ok, lPlayId=447703
115401,28 3 tw PlayEnd 3 447703
115401,28 3 play end id=447703, (current ID)
115401,28 3 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
115401,28 3 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
115401,28 3 path {EV_PLAY_FINISHED} not found
115401,28 3 timer set 10 EV_TIMEOUT_HANGUP
115401,28 3 timer set 0 EV_TIMEOUT_GOTOMODULE
115401,28 3 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
115401,28 3 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
115401,28 3 path {EV_TIMEOUT_GOTOMODULE} not found
115401,28 3 fn RunModule start
115401,28 3 timer clear
115401,28 3 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
115401,28 3 tw DialogicEvent 129,TDX_PLAY,447703,0,0,,,
115401,28 3 event ScriptEventCode TDX_PLAY, code=129, state=1901
115401,28 3 LsXfer_1_Start : 129(EV_UNKNOWN_129),TDX_PLAY,447703,0,0,,,
115401,28 3 path {TDX_PLAY} not found
115401,67 3 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
115401,67 3 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
115401,67 3 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
115401,67 3 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
115401,67 3 timeout on transfer attempt set by timeout path (50 sec)
115401,67 3 timer set 50 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
115401,67 3 rv replace start: [$RV[resultQuery]]
115401,67 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
115401,67 3 rv replace end: [0739389890]
115401,67 3 state [Locksmith] Announced Hookflash Transfer to 0739389890
115401,94 3 tw PlayEnd 3 0
115401,94 3 play end id=0, (current ID)
115401,94 3 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902
115401,94 3 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
115401,94 3 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
115401,94 3 event ScriptEventCode TDX_DIAL, code=132, state=1902
115401,94 3 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
115401,94 3 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
115401,94 3 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
115404,08 3 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
115404,08 3 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
115404,08 3 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
115404,08 3 Dial(0739389890, cp on) call
115404,31 3 Dial(0739389890) ok
115404,31 3 timer set 50 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
115416,09 3 tw DialogicEvent 133,TDX_CALLP,10,3,0,TDX_CALLP,CR_CNCT,CON_PVD
115416,09 3 event ScriptEventCode VOICE, code=133, state=1903
115416,09 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,VOICE,10,3,0,CR_CNCT,CON_PVD,
115416,09 3 event ScriptEventCode CONNECT, code=133, state=1903
115416,09 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CONNECT,10,3,0,CR_CNCT,CON_PVD,
115416,09 3 event ScriptEventCode CON_PVD, code=133, state=1903
115416,09 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CON_PVD,10,3,0,CR_CNCT,CON_PVD,
115416,09 3 event ScriptEventCode CR_CNCT, code=133, state=1903
115416,09 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CR_CNCT,10,3,0,CR_CNCT,CON_PVD,
115416,09 3 event ScriptEventCode TDX_CALLP, code=133, state=1903
115416,09 3 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,10,3,0,CR_CNCT,CON_PVD,
115416,09 3 LsXfer_3 CR_CNCT on an XT_HOOK_ANNOUNCED
115416,09 3 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
115416,09 3 path {EV_PLAY_FINISHED} not found
115416,09 3 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
115416,09 3 path {EV_TIMEOUT_REPLAYMSG} not found
115416,09 3 rv replace start: [C:\Voice\Locksmith\voice\call_transfer_$RV[LANGUAGE].wav]
115416,09 3 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-13 11:53:14}[$RV_DEVICEID]{3}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
9890}[Check_columns_post_ResultReturn]{success}
115416,09 3 rv replace end: [C:\Voice\Locksmith\voice\call_transfer_2.wav]
115416,09 3 state [Locksmith] Playing (C:\Voice\Locksmith\voice\call_transfer_2.wav)
115416,09 3 tw ConvertWav2Vox C:\Voice\Locksmith\voice\call_transfer_2.wav
115416,09 3 timer clear
115416,14 3 tw wav->vox convert end 467593,C:\Voice\Locksmith\voice\call_transfer_2.vox,1,0,,
115416,17 3 play start ok, lPlayId=467640
115426,44 3 tw dtmf 1 (3,49,49)
115426,44 3 event ScriptEventCode 1, code=49, state=1904
115426,44 3 LsXfer_4_PlayAnn : 49(1),1,0,0,0,,,
115426,44 3 rv add [Locksmith]{1}
115426,44 3 timer set 0,5 EV_PLAY_FINISHED
115426,45 3 play PlaySoundStop ok
115426,45 3 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
115426,45 3 event ScriptEventCode TDX_CST, code=134, state=1904
115426,45 3 LsXfer_4_PlayAnn : 134(EV_UNKNOWN_134),TDX_CST,49,0,0,DE_DIGITS,,
115426,45 3 path {TDX_CST} not found
115426,45 3 tw PlayEnd 3 467640
115426,45 3 play end id=467640, (current ID)
115426,45 3 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1904
115426,45 3 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
115426,45 3 path {EV_PLAY_FINISHED} not found
115426,45 3 dial from LsXfer_4_PlayAnn
115426,45 3 tw DialogicEvent 129,TDX_PLAY,467640,0,0,,,
115426,45 3 event ScriptEventCode TDX_PLAY, code=129, state=1906
115426,45 3 LsXfer_5B : 129(EV_UNKNOWN_129),TDX_PLAY,467640,0,0,,,
115426,48 3 tw PlayEnd 3 0
115426,48 3 play end id=0, (current ID)
115426,48 3 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1906
115426,48 3 LsXfer_5B : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
115426,48 3 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
115426,48 3 event ScriptEventCode TDX_DIAL, code=132, state=1906
115426,48 3 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
115426,48 3 sXferDialResult_SuccOrFail=XferToGoAhead
115426,48 3 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=CON_PVD (2)=PVD (3)=voice
115426,48 3 path {CON_PVD} not found
115426,48 3 path {PVD} not found
115426,48 3 path {voice} not found
115426,48 3 going down True path (iXferType=13) state:LsXferCallRejected
115426,48 3 fn RunModule start
115426,48 3 timer clear
115426,48 3 rv add [Hangup Time]{2005-10-13 11:54:26}
115426,48 3 state Hanging up call... [Hangup Module]
115426,48 3 HangupCall_Common hCall=3
115426,48 3 rec RecSoundStop ok
115426,48 3 play PlaySoundStop ok
115426,48 3 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
115426,50 3 fnHangupCall end
115426,53 3 event callstate IDLE 3 1,0,0
115426,55 3 WorkingMode@Idle=
115426,55 3 timer clear
115426,55 3 rec RecSoundStop ok
115426,55 3 play PlaySoundStop ok
115426,55 3 rv add [CallEndTime]{2005-10-13 11:54:26}
115426,70 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
115426,70 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
115426,70 3 event ScriptEventCode TDX_SETHOOK, code=135, state=900
115426,70 3 LsAwaitingCalls EV_UNKNOWN_135
115426,70 3 tw dtmf 1 (3,49,49)
115426,70 3 event ScriptEventCode 1, code=49, state=900
115426,70 3 LsAwaitingCalls 1
115426,70 3 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
115426,70 3 event ScriptEventCode TDX_CST, code=134, state=900
115426,70 3 LsAwaitingCalls EV_UNKNOWN_134
115427,69 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
115427,69 3 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
115427,69 3 init atidle reinit : start
115427,69 3 init atidle reinit iConferenceOtherLegLid=-1
115427,69 3 init atidle reinit : reset all LineState variables
115427,69 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115427,69 3 state Waiting for a call...
115428,02 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
115428,02 3 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
115429,39 3 event callstate OFFERING 3 2,0,0
115429,39 3 script interpretor: VgMulti v6.0.2275
115429,39 3 fired OFFERING event to listeners
115429,39 3 set LineState().hCall = 3 in LINECALLSTATE_OFFERING
115429,39 3 iIvrDev=3
115429,39 3 set linestate CID vars
115429,39 3 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
115429,41 3 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
115429,41 3 tw ring 1
115429,41 3 ring time since last ring event (sec): 0,00
115429,41 3 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
115429,41 3 rv clear all
115429,41 3 init LineState ResetAtStartOfNewCall.
115429,41 3 Terminating process (new call).
115429,41 3 answer the call
115429,41 3 timer clear
115429,42 3 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
115429,42 3 event ScriptEventCode TDX_CST, code=134, state=6001
115430,19 3 event callstate CONNECTED 3 256,0,0
115430,19 3 LineEvCallState_Connected hDevice=3 params=256,0,0
115430,19 3 WorkingModes tapi= script= LineState().iState=6001
115430,19 3 Inband detection not enabled
115430,19 3 StartLoadedVgs at 2005-10-13 11:54:30 [VgMulti v6.0.2275]
115430,19 3 set LineState().iVgsIdx=2
115430,19 3 set sScriptToRunOnHangup=[] in StartLoadedVgs
115430,19 3 init StartLoadedVgs_InitLineState start
115430,20 3 rv add [$RV_STARTTIME]{2005-10-13 11:54:30}
115430,20 3 rv add [$RV_DEVICEID]{3}
115430,20 3 rv add [$RV_CIDNAME]{}
115430,20 3 rvns add [PathApp]{C:\Program\VoiceGuide\}
115430,20 3 rvns add [scriptsPath]{C:\Voice\Tele2\}
115430,20 3 rv add [$RV_CIDNUMBER]{}
115430,20 3 fn RunModule start
115430,20 3 timer clear
115430,20 3 Play Module start
115430,20 3 state [LANGUAGE] Playing
115430,20 3 state [LANGUAGE] Playing (C:\Voice\Tele2\Voice\language.wav)
115430,20 3 tw ConvertWav2Vox C:\Voice\Tele2\Voice\language.wav
115430,20 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
115430,20 3 event ScriptEventCode TDX_SETHOOK, code=135, state=1100
115430,20 3 LsPlayMsg EV_UNKNOWN_135,TDX_SETHOOK
115430,20 3 path {TDX_SETHOOK} not found
115430,20 3 tw DialogicEvent 134,TDX_CST,364,0,0,DE_LCON,,
115430,20 3 event ScriptEventCode TDX_CST, code=134, state=1100
115430,20 3 LsPlayMsg EV_UNKNOWN_134,TDX_CST
115430,20 3 path {TDX_CST} not found
115430,25 3 tw wav->vox convert end 481703,C:\Voice\Tele2\Voice\language.vox,1,0,,
115430,28 3 play start ok, lPlayId=481750
115433,77 3 event callstate DISCONNECTED 3 16384,0,0
115433,77 3 event ScriptEventCode EV_REMOTEPARTY_DISCONNECT, code=9250, state=1100
115433,78 3 LsPlayMsg EV_REMOTEPARTY_DISCONNECT,EV_REMOTEPARTY_DISCONNECT
115433,78 3 path {EV_REMOTEPARTY_DISCONNECT} not found
115433,78 3 rv add [Hangup Time]{2005-10-13 11:54:33}
115433,78 3 state Hanging up call...
115433,78 3 HangupCall_Common hCall=3
115433,80 3 rec RecSoundStop ok
115433,81 3 play PlaySoundStop ok
115433,81 3 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
115433,81 3 fnHangupCall end
115433,81 3 tw DialogicEvent 134,TDX_CST,357,0,0,DE_LCOF,,
115433,81 3 event ScriptEventCode TDX_CST, code=134, state=900
115433,81 3 LsAwaitingCalls EV_UNKNOWN_134
115433,81 3 tw PlayEnd 3 481750
115433,81 3 play end id=481750, (current ID)
115433,81 3 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=900
115433,81 3 LsAwaitingCalls EV_PLAY_FINISHED
115433,81 3 tw DialogicEvent 129,TDX_PLAY,481750,0,0,,,
115433,81 3 event ScriptEventCode TDX_PLAY, code=129, state=900
115433,81 3 LsAwaitingCalls EV_UNKNOWN_129
115433,81 3 tw DialogicEvent 134,TDX_CST,1,0,0,DE_LCON,,
115433,83 3 event ScriptEventCode TDX_CST, code=134, state=900
115433,83 3 LsAwaitingCalls EV_UNKNOWN_134
115433,86 3 event callstate IDLE 3 1,0,0
115433,86 3 WorkingMode@Idle=
115433,86 3 timer clear
115433,86 3 rec RecSoundStop ok
115433,88 3 play PlaySoundStop ok
115433,88 3 rv add [CallEndTime]{2005-10-13 11:54:33}
115433,89 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
115433,89 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
115433,89 3 event ScriptEventCode TDX_SETHOOK, code=135, state=900
115433,89 3 LsAwaitingCalls EV_UNKNOWN_135
115434,91 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
115434,91 3 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
115434,91 3 init atidle reinit : start
115434,91 3 init atidle reinit iConferenceOtherLegLid=-1
115434,91 3 init atidle reinit : reset all LineState variables
115434,91 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
115434,91 3 state Waiting for a call...
115435,23 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
115435,23 3 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
Thank you!
Jose
1013tw.txt
Can you do call transfers manually on that phone line (using just a normal phone handset) ? Do you need to press anything before being able to hang up the phone yourself and allow the call to continue being connected to the party to which you transferred it?
Trace shows VoiceGuide doing what it should be doing. After the transferred call was accepted by the receiving party VoiceGuide basically just hung up - but the Telco is then sending the call straight back to VoiceGuide.
It looks like call transfers are not enabled on that line...
Hello!
I don´t know if I should ask this question in this thread. I have problem with the same script and I know now that all problems until now were because of my equipment.
I still have the same dialogic cards ( D/4PCI and D/41JCT-LS) but now we are using ISDN instead of Voice Over IP. What a difference!
Now, I can iterate calling different phone numbers, so if a person doesn´t pick up the phone voiceguide continues calling the next phone number and so on. The problem now is that when a person picks up the phone he hears the "press 1 message to accept the call" and the caller doesn´t hear anything which is good since I don´t have yet a Music on hold file, but as soon as the third person presses One to accept the call then voiceguide hangs up so the communication dies.
Only when I choose the "3 Way Conference Call- Announced" in the transfer call module, the caller is able to listen the third party for a second more or less then voiceguide hangs up the phone.
But in all the alternatives whithin this transfer call module the hookflash works, I mean the caller never hears any dialing numbers or the press One message, ...
Here it is the trace log for this.
181901,39 0 btn Exit (8 lines)
181901,39 1 line state =0
181901,39 2 line state =0
181901,39 3 line state =0
181901,39 4 line state =0
181901,39 5 line state =0
181901,39 6 line state =0
181901,39 7 line state =900
181901,39 8 line state =0
181901,39 1 state Exiting...
181901,39 2 state Exiting...
181901,39 3 state Exiting...
181901,39 4 state Exiting...
181901,39 5 state Exiting...
181901,41 6 state Exiting...
181901,41 7 state Exiting...
181901,41 8 state Exiting...
181902,49 0 exit closing all channels start
181902,49 0 exit close dxxxB1C1(1)=> []
181902,49 0 exit close dxxxB1C2(2)=> []
181902,49 0 exit close dxxxB1C3(3)=> []
181902,49 0 exit close dxxxB1C4(4)=> []
181902,52 0 exit close dxxxB2C1(5)=> []
181902,55 0 exit close dxxxB2C2(6)=> []
181902,59 0 exit close dxxxB2C3(7)=> []
181902,64 0 exit close dxxxB2C4(8)=> []
181902,64 0 exit closing all channels end
181903,05 0 ---------------------------------------------------
181903,05 0 Stopping VoiceGuide (Dialogic) start
181903,05 0 v6.0.2275
181903,05 0 Stopping VoiceGuide (Dialogic) end
181915,95 0 ---------------------------------------------------
181916,06 0 VoiceGuide for Dialogic
181916,06 0 v6.0.2275
181916,06 0 ---------------------------------------------------
181916,08 0 rv global loaded >>><<<
181916,08 0 cti Inband Signaling Config file not specified
181916,44 0 init ApiMode=[DialogicGC]
181916,45 0 vm loading VMB data begin
181916,47 0 vm loading VMB data - about to delete old entries
181916,55 0 vm loading VMB data - sorting/ordering
181916,55 0 vm loading VMB data end
181916,55 0 dial DbConnectString_ADO is blank
181916,58 0 init DB Workspaces
181916,58 0 init Voicemail LoadIniSettings
181916,59 0 init read Config.xml start
181916,61 0 dxxxB1C1 dxxxB1C1 C:\Voice\PetDirekt\petdirekt.vgs RV= allowDialout=1
181916,62 0 dxxxB1C2 dxxxB1C2 C:\Voice\PetDirekt\petdirekt.vgs RV= allowDialout=1
181916,62 0 dxxxB1C3 dxxxB1C3 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=0
181916,62 0 dxxxB1C4 dxxxB1C4 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=1
181916,62 0 dxxxB2C1 dxxxB2C1 C:\Voice\Choice\Lang-Service.vgs RV= allowDialout=1
181916,62 0 dxxxB2C2 dxxxB2C2 C:\Voice\Choice\Lang-Service.vgs RV= allowDialout=1
181916,62 0 dxxxB2C3 dxxxB2C3 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=0
181916,62 0 dxxxB2C4 dxxxB2C4 C:\Voice\Tele2\Two-Services.vgs RV= allowDialout=1
181916,62 0 init read Config.xml end
181916,64 0 init LineOpenDialogic dxxxB1C1 => [1]
181916,64 1 iIvrDev=1
181916,72 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
181916,72 0 init distinct ring definitions found:2
181916,72 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
181916,72 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
181916,72 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
181916,72 0 init ring 2 [TelstraDoubleRing] cadences defined:2
181916,72 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
181916,72 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
181916,72 0 init load Distinct Ring definitions end
181916,73 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig)
181916,73 0 load start [C:\Voice\PetDirekt\petdirekt.vgs]
181916,73 0 MemStructVgs_ClearVgs [1]
181916,83 0 load end
181916,83 0 init hires timer setup start
181916,83 0 init hires timer setup end
181916,83 1 state Waiting for a call...
181916,83 1 event callstate IDLE 1 1,0,0
181916,83 1 WorkingMode@Idle=
181916,83 1 timer clear
181916,83 1 LineState(iLineId).iVgsIdx = 0
181916,83 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181916,83 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
181916,83 1 event ScriptEventCode TDX_SETHOOK, code=135, state=0
181916,83 1 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181916,83 1 timer set ignored - waiting for line re-init to occur first
181916,83 0 init lineids: 0-1
181916,86 0 init LineOpenDialogic dxxxB1C2 => [2]
181916,86 2 iIvrDev=2
181916,92 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
181916,92 0 init distinct ring definitions found:2
181916,92 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
181916,92 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
181916,94 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
181916,94 0 init ring 2 [TelstraDoubleRing] cadences defined:2
181916,94 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
181916,94 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
181916,94 0 init load Distinct Ring definitions end
181916,94 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig)
181916,94 0 init hires timer setup start
181916,94 0 init hires timer setup end
181916,94 2 state Waiting for a call...
181916,94 2 event callstate IDLE 2 1,0,0
181916,94 2 WorkingMode@Idle=
181916,94 2 timer clear
181916,94 2 LineState(iLineId).iVgsIdx = 0
181916,94 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181916,94 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
181916,94 2 event ScriptEventCode TDX_SETHOOK, code=135, state=0
181916,94 2 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181916,94 2 timer set ignored - waiting for line re-init to occur first
181916,94 0 init lineids: 0-2
181916,95 0 init LineOpenDialogic dxxxB1C3 => [3]
181916,95 3 iIvrDev=3
181917,03 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
181917,03 0 init distinct ring definitions found:2
181917,03 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
181917,03 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
181917,03 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
181917,03 0 init ring 2 [TelstraDoubleRing] cadences defined:2
181917,05 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
181917,05 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
181917,05 0 init load Distinct Ring definitions end
181917,05 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig)
181917,05 0 load start [C:\Voice\Tele2\Two-Services.vgs]
181917,05 0 MemStructVgs_ClearVgs [2]
181917,05 0 load end
181917,05 0 init hires timer setup start
181917,05 0 init hires timer setup end
181917,05 3 state Waiting for a call...
181917,05 3 event callstate IDLE 3 1,0,0
181917,05 3 WorkingMode@Idle=
181917,05 3 timer clear
181917,05 3 LineState(iLineId).iVgsIdx = 0
181917,05 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181917,05 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
181917,05 3 event ScriptEventCode TDX_SETHOOK, code=135, state=0
181917,05 3 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181917,05 3 timer set ignored - waiting for line re-init to occur first
181917,05 0 init lineids: 0-3
181917,06 0 init LineOpenDialogic dxxxB1C4 => [4]
181917,08 4 iIvrDev=4
181917,14 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
181917,14 0 init distinct ring definitions found:2
181917,14 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
181917,14 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
181917,14 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
181917,14 0 init ring 2 [TelstraDoubleRing] cadences defined:2
181917,14 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
181917,16 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
181917,16 0 init load Distinct Ring definitions end
181917,16 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig)
181917,16 0 init hires timer setup start
181917,16 0 init hires timer setup end
181917,16 4 state Waiting for a call...
181917,16 4 event callstate IDLE 4 1,0,0
181917,16 4 WorkingMode@Idle=
181917,16 4 timer clear
181917,16 4 LineState(iLineId).iVgsIdx = 0
181917,16 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181917,16 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
181917,16 4 event ScriptEventCode TDX_SETHOOK, code=135, state=0
181917,16 4 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181917,16 4 timer set ignored - waiting for line re-init to occur first
181917,16 0 init lineids: 0-4
181917,16 0 init LineOpenDialogic dxxxB2C1 => [5]
181917,17 5 iIvrDev=5
181917,23 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
181917,23 0 init distinct ring definitions found:2
181917,23 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
181917,23 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
181917,23 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
181917,23 0 init ring 2 [TelstraDoubleRing] cadences defined:2
181917,23 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
181917,23 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
181917,23 0 init load Distinct Ring definitions end
181917,23 5 init strDlgcDevName_VoiceResource=[dxxxB2C1] (LoadXMLConfig)
181917,23 0 load start [C:\Voice\Choice\Lang-Service.vgs]
181917,23 0 MemStructVgs_ClearVgs [3]
181917,23 0 load end
181917,23 0 init hires timer setup start
181917,23 0 init hires timer setup end
181917,24 5 state Waiting for a call...
181917,24 5 event callstate IDLE 5 1,0,0
181917,24 5 WorkingMode@Idle=
181917,24 5 timer clear
181917,24 5 LineState(iLineId).iVgsIdx = 0
181917,24 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181917,24 5 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
181917,24 5 event ScriptEventCode TDX_SETHOOK, code=135, state=0
181917,24 5 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181917,24 5 timer set ignored - waiting for line re-init to occur first
181917,24 0 init lineids: 0-5
181917,24 0 init LineOpenDialogic dxxxB2C2 => [6]
181917,24 6 iIvrDev=6
181917,33 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
181917,33 0 init distinct ring definitions found:2
181917,33 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
181917,33 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
181917,33 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
181917,33 0 init ring 2 [TelstraDoubleRing] cadences defined:2
181917,33 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
181917,33 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
181917,33 0 init load Distinct Ring definitions end
181917,33 6 init strDlgcDevName_VoiceResource=[dxxxB2C2] (LoadXMLConfig)
181917,33 0 init hires timer setup start
181917,33 0 init hires timer setup end
181917,33 6 state Waiting for a call...
181917,33 6 event callstate IDLE 6 1,0,0
181917,33 6 WorkingMode@Idle=
181917,33 6 timer clear
181917,33 6 LineState(iLineId).iVgsIdx = 0
181917,33 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181917,33 6 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
181917,33 6 event ScriptEventCode TDX_SETHOOK, code=135, state=0
181917,33 6 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181917,33 6 timer set ignored - waiting for line re-init to occur first
181917,33 0 init lineids: 0-6
181917,36 0 init LineOpenDialogic dxxxB2C3 => [7]
181917,36 7 iIvrDev=7
181917,44 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
181917,44 0 init distinct ring definitions found:2
181917,44 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
181917,44 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
181917,44 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
181917,44 0 init ring 2 [TelstraDoubleRing] cadences defined:2
181917,44 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
181917,44 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
181917,44 0 init load Distinct Ring definitions end
181917,44 7 init strDlgcDevName_VoiceResource=[dxxxB2C3] (LoadXMLConfig)
181917,44 0 init hires timer setup start
181917,44 0 init hires timer setup end
181917,44 7 state Waiting for a call...
181917,44 7 event callstate IDLE 7 1,0,0
181917,44 7 WorkingMode@Idle=
181917,44 7 timer clear
181917,44 7 LineState(iLineId).iVgsIdx = 0
181917,44 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181917,44 7 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
181917,44 7 event ScriptEventCode TDX_SETHOOK, code=135, state=0
181917,45 7 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181917,45 7 timer set ignored - waiting for line re-init to occur first
181917,45 0 init lineids: 0-7
181917,45 0 init LineOpenDialogic dxxxB2C4 => [8]
181917,45 8 iIvrDev=8
181917,52 0 init load Distinct Ring definitions start [C:\Program\VoiceGuide\data\ConfigLine.xml]
181917,55 0 init distinct ring definitions found:2
181917,55 0 init ring 1 [TestPBXDoubleRing] cadences defined:2
181917,56 0 init distinct ring 1 [TestPBXDoubleRing] cadence 1 [55:10,55:10][110:20]
181917,56 0 init distinct ring 1 [TestPBXDoubleRing] cadence 2 [55:10,285:10][340:20]
181917,56 0 init ring 2 [TelstraDoubleRing] cadences defined:2
181917,56 0 init distinct ring 2 [TelstraDoubleRing] cadence 1 [58:5,27:5][85:10]
181917,56 0 init distinct ring 2 [TelstraDoubleRing] cadence 2 [58:5,260:10][318:15]
181917,56 0 init load Distinct Ring definitions end
181917,56 8 init strDlgcDevName_VoiceResource=[dxxxB2C4] (LoadXMLConfig)
181917,56 0 init hires timer setup start
181917,56 0 init hires timer setup end
181917,56 8 state Waiting for a call...
181917,56 8 event callstate IDLE 8 1,0,0
181917,56 8 WorkingMode@Idle=
181917,56 8 timer clear
181917,56 8 LineState(iLineId).iVgsIdx = 0
181917,56 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181917,56 8 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
181917,56 8 event ScriptEventCode TDX_SETHOOK, code=135, state=0
181917,58 8 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181917,58 8 timer set ignored - waiting for line re-init to occur first
181917,58 0 init lineids: 0-8
181917,58 0 init route channels start
181917,73 0 init route channels => []
181917,73 0 init no dti channels opened. Not opening signaling channel.
181917,74 0 cti Link1 serial init complete
181917,74 0 cti serial1 closed not sending HeartbeatCheck
181917,74 0 init iLineDevicesControlled=8
181917,78 0 init main form load end
181918,11 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
181918,11 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
181918,11 1 init atidle reinit : start
181918,11 1 init atidle reinit iConferenceOtherLegLid=-1
181918,11 1 init atidle reinit : reset all LineState variables
181918,11 1 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,11 1 state Waiting for a call...
181918,22 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
181918,22 2 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
181918,22 2 init atidle reinit : start
181918,22 2 init atidle reinit iConferenceOtherLegLid=-1
181918,22 2 init atidle reinit : reset all LineState variables
181918,22 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,22 2 state Waiting for a call...
181918,33 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
181918,33 3 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
181918,33 3 init atidle reinit : start
181918,33 3 init atidle reinit iConferenceOtherLegLid=-1
181918,33 3 init atidle reinit : reset all LineState variables
181918,33 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,33 3 state Waiting for a call...
181918,44 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,44 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
181918,44 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
181918,44 4 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
181918,44 4 init atidle reinit : start
181918,44 4 init atidle reinit iConferenceOtherLegLid=-1
181918,44 4 init atidle reinit : reset all LineState variables
181918,44 4 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,44 4 state Waiting for a call...
181918,44 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
181918,44 5 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
181918,44 5 init atidle reinit : start
181918,44 5 init atidle reinit iConferenceOtherLegLid=-1
181918,44 5 init atidle reinit : reset all LineState variables
181918,44 5 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,44 5 state Waiting for a call...
181918,55 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,55 2 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
181918,55 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
181918,55 6 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
181918,55 6 init atidle reinit : start
181918,55 6 init atidle reinit iConferenceOtherLegLid=-1
181918,55 6 init atidle reinit : reset all LineState variables
181918,55 6 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,55 6 state Waiting for a call...
181918,66 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,66 3 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
181918,66 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
181918,66 7 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
181918,66 7 init atidle reinit : start
181918,66 7 init atidle reinit iConferenceOtherLegLid=-1
181918,66 7 init atidle reinit : reset all LineState variables
181918,66 7 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,66 7 state Waiting for a call...
181918,77 4 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,77 4 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
181918,77 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,77 5 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
181918,77 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
181918,77 8 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
181918,77 8 init atidle reinit : start
181918,77 8 init atidle reinit iConferenceOtherLegLid=-1
181918,77 8 init atidle reinit : reset all LineState variables
181918,77 8 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,77 8 state Waiting for a call...
181918,87 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,87 6 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
181918,98 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181918,98 7 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
181919,09 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181919,09 8 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
181958,12 7 tw dtmf a (7,97,97)
181958,12 7 event ScriptEventCode a, code=97, state=0
181958,12 7 tw DialogicEvent 134,TDX_CST,97,0,0,DE_DIGITS,,
181958,12 7 event ScriptEventCode TDX_CST, code=134, state=0
181958,22 7 tw dtmf 8 (7,56,56)
181958,22 7 event ScriptEventCode 8, code=56, state=0
181958,23 7 tw DialogicEvent 134,TDX_CST,56,0,0,DE_DIGITS,,
181958,23 7 event ScriptEventCode TDX_CST, code=134, state=0
181958,37 7 tw dtmf 4 (7,52,52)
181958,37 7 event ScriptEventCode 4, code=52, state=0
181958,37 7 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
181958,37 7 event ScriptEventCode TDX_CST, code=134, state=0
181958,52 7 tw dtmf 4 (7,52,52)
181958,52 7 event ScriptEventCode 4, code=52, state=0
181958,52 7 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
181958,52 7 event ScriptEventCode TDX_CST, code=134, state=0
181958,64 7 tw dtmf 2 (7,50,50)
181958,64 7 event ScriptEventCode 2, code=50, state=0
181958,64 7 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
181958,64 7 event ScriptEventCode TDX_CST, code=134, state=0
181958,80 7 tw dtmf 9 (7,57,57)
181958,80 7 event ScriptEventCode 9, code=57, state=0
181958,80 7 tw DialogicEvent 134,TDX_CST,57,0,0,DE_DIGITS,,
181958,80 7 event ScriptEventCode TDX_CST, code=134, state=0
181958,95 7 tw dtmf 0 (7,48,48)
181958,95 7 event ScriptEventCode 0, code=48, state=0
181958,95 7 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
181958,95 7 event ScriptEventCode TDX_CST, code=134, state=0
181959,06 7 tw dtmf 4 (7,52,52)
181959,06 7 event ScriptEventCode 4, code=52, state=0
181959,06 7 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
181959,06 7 event ScriptEventCode TDX_CST, code=134, state=0
181959,22 7 tw dtmf 0 (7,48,48)
181959,22 7 event ScriptEventCode 0, code=48, state=0
181959,22 7 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
181959,22 7 event ScriptEventCode TDX_CST, code=134, state=0
181959,36 7 tw dtmf # (7,35,35)
181959,36 7 event ScriptEventCode #, code=35, state=0
181959,36 7 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
181959,37 7 event ScriptEventCode TDX_CST, code=134, state=0
182000,23 7 event callstate OFFERING 7 2,0,0
182000,23 7 script interpretor: VgMulti v6.0.2275
182000,23 7 fired OFFERING event to listeners
182000,23 7 set LineState().hCall = 7 in LINECALLSTATE_OFFERING
182000,23 7 iIvrDev=7
182000,23 7 set linestate CID vars
182000,23 7 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
182000,23 7 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
182000,23 7 tw ring 1
182000,23 7 ring time since last ring event (sec): 0,00
182000,23 7 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
182000,23 7 rv clear all
182000,23 7 init LineState ResetAtStartOfNewCall.
182000,23 7 answer the call
182000,23 7 timer clear
182000,23 7 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
182000,23 7 event ScriptEventCode TDX_CST, code=134, state=6001
182000,84 7 event callstate CONNECTED 7 256,0,0
182000,84 7 LineEvCallState_Connected hDevice=7 params=256,0,0
182000,84 7 WorkingModes tapi= script= LineState().iState=6001
182000,86 7 Inband detection not enabled
182000,86 7 StartLoadedVgs at 2005-10-18 18:20:00 [VgMulti v6.0.2275]
182000,86 7 set LineState().iVgsIdx=2
182000,86 7 set sScriptToRunOnHangup=[] in StartLoadedVgs
182000,86 7 init StartLoadedVgs_InitLineState start
182000,86 7 rv add [$RV_STARTTIME]{2005-10-18 18:20:00}
182000,86 7 rv add [$RV_DEVICEID]{7}
182000,86 7 rv add [$RV_CIDNAME]{}
182000,86 7 rvns add [PathApp]{C:\Program\VoiceGuide\}
182000,86 7 rvns add [scriptsPath]{C:\Voice\Tele2\}
182000,86 7 rv add [$RV_CIDNUMBER]{}
182000,86 7 fn RunModule start
182000,86 7 timer clear
182000,86 7 Play Module start
182000,86 7 state [LANGUAGE] Playing
182000,86 7 state [LANGUAGE] Playing (C:\Voice\Tele2\Voice\language.wav)
182000,86 7 tw ConvertWav2Vox C:\Voice\Tele2\Voice\language.wav
182000,86 7 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
182000,87 7 event ScriptEventCode TDX_SETHOOK, code=135, state=1100
182000,87 7 LsPlayMsg EV_UNKNOWN_135,TDX_SETHOOK
182000,87 7 path {TDX_SETHOOK} not found
182000,87 7 tw DialogicEvent 134,TDX_CST,4344,0,0,DE_LCON,,
182000,87 7 event ScriptEventCode TDX_CST, code=134, state=1100
182000,87 7 LsPlayMsg EV_UNKNOWN_134,TDX_CST
182000,87 7 path {TDX_CST} not found
182000,92 7 tw wav->vox convert end 668140,C:\Voice\Tele2\Voice\language.vox,1,0,,
182000,94 7 play start ok, lPlayId=668203
182003,98 7 tw dtmf 2 (7,50,50)
182003,98 7 event ScriptEventCode 2, code=50, state=1100
182003,98 7 LsPlayMsg 2,2
182003,99 7 play PlaySoundStop ok
182003,99 7 rv add [LANGUAGE]{2}
182003,99 7 fn RunModule start
182003,99 7 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
182003,99 7 event ScriptEventCode TDX_CST, code=134, state=6001
182003,99 7 timer clear
182003,99 7 state [init_COUNTER] Evaluate [0]
182003,99 7 eval[0]
182003,99 7 rvns add [init_COUNTER_Input]{0}
182003,99 7 rvns add [init_COUNTER]{0}
182003,99 7 rvns add [counter]{0}
182003,99 7 Eval Expr result:[0] stored in $RV[counter]
182003,99 7 path {0} not found
182003,99 7 tw PlayEnd 7 668203
182003,99 7 play end id=668203, (current ID)
182004,02 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001
182004,02 7 tw DialogicEvent 129,TDX_PLAY,668203,0,0,,,
182004,02 7 event ScriptEventCode TDX_PLAY, code=129, state=6001
182004,02 7 timer clear
182004,02 7 Play Module start
182004,02 7 state [sERVICES] Playing
182004,02 7 rv replace start: [C:\Voice\Tele2\Voice\SERVICES_$RV[LANGUAGE].wav]
182004,02 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}
182004,02 7 rv replace end: [C:\Voice\Tele2\Voice\SERVICES_2.wav]
182004,02 7 state [sERVICES] Playing (C:\Voice\Tele2\Voice\SERVICES_2.wav)
182004,02 7 tw ConvertWav2Vox C:\Voice\Tele2\Voice\SERVICES_2.wav
182004,05 7 tw wav->vox convert end 671296,C:\Voice\Tele2\Voice\SERVICES_2.vox,1,0,,
182004,06 7 play start ok, lPlayId=671328
182011,49 7 tw dtmf 2 (7,50,50)
182011,49 7 event ScriptEventCode 2, code=50, state=1100
182011,49 7 LsPlayMsg 2,2
182011,49 7 rv add [scriptEnd_Time]{2005-10-18 18:20:11}
182011,49 7 rv add [scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}
182011,49 7 rv add [scriptEnd_Goto_Module]{WELCOME}
182011,53 7 rv add [scriptStart_Time]{2005-10-18 18:20:11}
182011,53 7 rv add [scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}
182011,53 7 rv add [scriptStart_CalledFrom_Module]{SERVICES}
182011,53 7 FindFullPathToScript_VgsOrVgp start [C:\Voice\Locksmith\locksmith.vgs]
182011,53 7 FindFullPathToScript_VgsOrVgp 1
182011,53 0 load start [C:\Voice\Locksmith\locksmith.vgs]
182011,53 0 MemStructVgs_ClearVgs [4]
182011,58 0 load end
182011,58 7 loaded [C:\Voice\Locksmith\locksmith.vgs] into:4
182011,58 7 rvns add [scriptsPath]{C:\Voice\Locksmith\}
182011,61 7 play PlaySoundStop ok
182011,61 7 rv add [sERVICES]{2}
182011,61 7 fn RunModule start
182011,61 7 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
182011,61 7 event ScriptEventCode TDX_CST, code=134, state=6001
182011,61 7 tw PlayEnd 7 671328
182011,61 7 play end id=671328, (current ID)
182011,61 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=6001
182011,61 7 tw DialogicEvent 129,TDX_PLAY,671328,0,0,,,
182011,61 7 event ScriptEventCode TDX_PLAY, code=129, state=6001
182011,61 7 timer clear
182011,61 7 Play Module start
182011,61 7 state [WELCOME] Playing
182011,61 7 rv replace start: [C:\Voice\Locksmith\voice\welcome_locksmith_$RV[LANGUAGE].wav]
182011,62 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}[scriptEnd_Time]{2005-10-18 18:20:11}[scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}[scriptEnd_Goto_Module]{WELCOME}[scriptStart_Time]{2005-10-18 18:20:11}[scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}[scriptStart_CalledFrom_Module]{SERVICES}[scriptsPath]{C:\Voice\Locksmith\}[sERVICES]{2}
182011,62 7 rv replace end: [C:\Voice\Locksmith\voice\welcome_locksmith_2.wav]
182011,62 7 state [WELCOME] Playing (C:\Voice\Locksmith\voice\welcome_locksmith_2.wav)
182011,62 7 tw ConvertWav2Vox C:\Voice\Locksmith\voice\welcome_locksmith_2.wav
182011,62 7 timer clear
182011,70 7 tw wav->vox convert end 678906,C:\Voice\Locksmith\voice\welcome_locksmith_2.vox,1,0,,
182011,72 7 play start ok, lPlayId=678984
182014,83 0 sys cleanup Start
182014,83 0 sys cleanup End
182023,78 7 tw PlayEnd 7 678984
182023,78 7 play end id=678984, (current ID)
182023,78 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
182023,78 7 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
182023,78 7 path {EV_PLAY_FINISHED} not found
182023,78 7 timer set 10 EV_TIMEOUT_HANGUP
182023,78 7 timer set 0 EV_TIMEOUT_GOTOMODULE
182023,78 7 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
182023,78 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
182023,78 7 path {EV_TIMEOUT_GOTOMODULE} not found
182023,78 7 fn RunModule start
182023,78 7 timer clear
182023,78 7 state [Var_Result_Query] Evaluate [1]
182023,78 7 eval[1]
182023,78 7 rvns add [Var_Result_Query_Input]{1}
182023,78 7 rvns add [Var_Result_Query]{1}
182023,78 7 rvns add [resultQuery]{1}
182023,78 7 Eval Expr result:[1] stored in $RV[resultQuery]
182023,78 7 path {1} not found
182023,78 7 tw DialogicEvent 129,TDX_PLAY,678984,0,0,,,
182023,78 7 event ScriptEventCode TDX_PLAY, code=129, state=6001
182023,78 7 state [selection_Choice] Number Input
182023,78 7 rv replace start: [C:\Voice\Locksmith\voice\selection_choice_$RV[LANGUAGE].wav]
182023,78 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{0}[scriptEnd_Time]{2005-10-18 18:20:11}[scriptEnd_Goto_Script]{C:\Voice\Locksmith\locksmith.vgs}[scriptEnd_Goto_Module]{WELCOME}[scriptStart_Time]{2005-10-18 18:20:11}[scriptStart_CalledFrom_Script]{C:\Voice\Tele2\Two-Services.vgs}[scriptStart_CalledFrom_Module]{SERVICES}[scriptsPath]{C:\Voice\Locksmith\}[sERVICES]{2}[Var_Result_Query_Input]{1}[Var_Result_Query]{1}[resultQuery]
1}
182023,78 7 rv replace end: [C:\Voice\Locksmith\voice\selection_choice_2.wav]
182023,78 7 state [selection_Choice] Playing (C:\Voice\Locksmith\voice\selection_choice_2.wav)
182023,78 7 tw ConvertWav2Vox C:\Voice\Locksmith\voice\selection_choice_2.wav
182023,78 7 tw wav->vox convert end 691062,C:\Voice\Locksmith\voice\selection_choice_2.vox,1,0,,
182023,80 7 play start ok, lPlayId=691062
182027,84 7 tw dtmf 1 (7,49,49)
182027,84 7 event ScriptEventCode 1, code=49, state=1300
182027,84 7 LsGetNbrsPlayWelcMsg 1,1
182027,86 7 play PlaySoundStop ok
182027,86 7 state [selection_Choice] Number Input 1
182027,86 7 rv add [selection_Choice]{1}
182027,86 7 rvns add [selection_Choice_PathTaken]{1}
182027,86 7 fn RunModule start
182027,86 7 timer clear
182027,86 7 state [Get_Post_Code] Number Input
182027,86 7 rv replace start: [C:\Voice\Locksmith\voice\get_post_code_$RV[LANGUAGE].wav]
182027,86 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
1}[selection_Choice]{1}[selection_Choice_PathTaken]{1}
182027,86 7 rv replace end: [C:\Voice\Locksmith\voice\get_post_code_2.wav]
182027,86 7 state [Get_Post_Code] Playing (C:\Voice\Locksmith\voice\get_post_code_2.wav)
182027,86 7 tw ConvertWav2Vox C:\Voice\Locksmith\voice\get_post_code_2.wav
182027,86 7 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
182027,86 7 event ScriptEventCode TDX_CST, code=134, state=1300
182027,86 7 LsGetNbrsPlayWelcMsg EV_UNKNOWN_134,TDX_CST
182027,86 7 path {TDX_CST} not found
182027,86 7 tw PlayEnd 7 691062
182027,86 7 play end id=691062, (old ID) current id=695140
182027,86 7 tw DialogicEvent 129,TDX_PLAY,691062,0,0,,,
182027,86 7 event ScriptEventCode TDX_PLAY, code=129, state=1300
182027,86 7 LsGetNbrsPlayWelcMsg EV_UNKNOWN_129,TDX_PLAY
182027,86 7 path {TDX_PLAY} not found
182027,92 7 tw wav->vox convert end 695140,C:\Voice\Locksmith\voice\get_post_code_2.vox,1,0,,
182027,92 7 play start ok, lPlayId=695203
182030,58 7 tw dtmf 0 (7,48,48)
182030,58 7 event ScriptEventCode 0, code=48, state=1300
182030,58 7 LsGetNbrsPlayWelcMsg 0,0
182030,59 7 play PlaySoundStop ok
182030,59 7 state [Get_Post_Code] Number Input 0
182030,59 7 path {0} not found
182030,59 7 timer set 6 EV_TIMEOUT_ENTERDATA
182030,59 7 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
182030,59 7 event ScriptEventCode TDX_CST, code=134, state=1301
182030,59 7 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
182030,59 7 path {TDX_CST} not found
182030,59 7 tw PlayEnd 7 695203
182030,59 7 play end id=695203, (current ID)
182030,59 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1301
182030,59 7 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
182030,59 7 path {EV_PLAY_FINISHED} not found
182030,59 7 tw DialogicEvent 129,TDX_PLAY,695203,0,0,,,
182030,59 7 event ScriptEventCode TDX_PLAY, code=129, state=1301
182030,59 7 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
182030,59 7 path {TDX_PLAY} not found
182031,37 7 tw dtmf 0 (7,48,48)
182031,37 7 event ScriptEventCode 0, code=48, state=1301
182031,37 7 LsGetNbrsRxDigits 0,0
182031,37 7 state [Get_Post_Code] Number Input 00
182031,37 7 path {00} not found
182031,37 7 timer set 6 EV_TIMEOUT_ENTERDATA
182031,37 7 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
182031,37 7 event ScriptEventCode TDX_CST, code=134, state=1301
182031,37 7 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
182031,37 7 path {TDX_CST} not found
182032,74 7 tw dtmf 0 (7,48,48)
182032,74 7 event ScriptEventCode 0, code=48, state=1301
182032,74 7 LsGetNbrsRxDigits 0,0
182032,74 7 state [Get_Post_Code] Number Input 000
182032,74 7 path {000} not found
182032,74 7 timer set 6 EV_TIMEOUT_ENTERDATA
182032,74 7 timer clear
182032,74 7 rv add [Get_Post_Code]{000}
182032,74 7 rvns add [Get_Post_Code_PathTaken]{success}
182032,74 7 fn RunModule start
182032,74 7 state [CASE_locksmith_post] DB Query
182032,74 7 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
182032,74 7 event ScriptEventCode TDX_CST, code=134, state=1400
182032,74 7 ERROR 6.0.2275 Unknown State [1400]
182032,77 7 db ODBC mode used
182032,91 7 rv replace start: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =$RV[Get_Post_Code]]
182032,91 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
1}[selection_Choice]{1}[selection_Choice_PathTaken]{1}[Get_Post_Code]{000}[Get_P
182032,91 7 rv replace end: [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
182032,91 7 db About to execute a Retrieve type operation [sELECT telAlt1, telAlt2, telAlt3 FROM locksmith WHERE postNr =000]
182032,95 7 db [CASE_locksmith_post] row count=1
182032,95 7 rv add [CASE_locksmith_post_RowCount]{1}
182032,95 7 db get RecordsetGetRowsMax
182032,97 7 db get 999 records. (row count=1)
182032,97 7 db update RVs
182032,97 7 db about to close dbDbqDatabase
182032,97 7 db going down path [True]
182032,97 7 fn RunModule start
182032,97 7 timer clear
182032,97 7 state [Counter_post] Evaluate [1]
182032,97 7 eval[1]
182032,97 7 rvns add [Counter_post_Input]{1}
182032,97 7 rvns add [Counter_post]{1}
182032,97 7 rvns add [counter]{1}
182032,97 7 Eval Expr result:[1] stored in $RV[counter]
182032,97 7 path {1} not found
182032,97 7 state [Check_columns_post] Running VB Script...
182032,97 7 rv replace start (strlen>500)
182032,97 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
st_Code_PathTaken]{success}[CASE_locksmith_post_RowCount]{1}[CASE_locksmith_post
1_1]{+46739389890}[CASE_locksmith_post_2_1]{+46739389890}[CASE_locksmith_post_3_
]{+46739389890}[Counter_post_Input]{1}[Counter_post]{1}[counter]{1}
182032,97 7 vbs ran [vbs_7_1.vbs], cmd [wscript "C:\Program\VoiceGuide\data\vbs_7_1.vbs" //I //T:60]
182033,05 7 Run Script waiting. iRunWait=1 (shellid=2080, process=1632)
182033,06 7 timer set 1 EV_TIMEOUT_CHECKONSTATE
182033,09 7 cl RvSet resultQuery, 0739389890
182033,09 7 rv add [resultQuery]{0739389890}
182033,09 7 cl Run_ResultReturn >>success<<
182033,09 7 rv add [Check_columns_post_ResultReturn]{success}
182033,09 7 cl module's runwait=1, WavPlayHasNowFinished=0
182033,09 7 fn RunModule start
182033,09 7 timer clear
182033,09 7 Play Module start
182033,09 7 state [info_To_Customer] Playing
182033,09 7 rv replace start: [c:\Voice\Locksmith\voice\nu_kopplar_$RV[LANGUAGE].wav]
182033,09 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
]{+46739389890}[Counter_post_Input]{1}[Counter_post]{1}[counter]{1}[resultQuery]
0739389890}[Check_columns_post_ResultReturn]{success}
182033,09 7 rv replace end: [c:\Voice\Locksmith\voice\nu_kopplar_2.wav]
182033,09 7 state [info_To_Customer] Playing (c:\Voice\Locksmith\voice\nu_kopplar_2.wav)
182033,09 7 tw ConvertWav2Vox c:\Voice\Locksmith\voice\nu_kopplar_2.wav
182033,16 7 tw wav->vox convert end 700375,c:\Voice\Locksmith\voice\nu_kopplar_2.vox,1,0,,
182033,17 7 play start ok, lPlayId=700437
182038,03 7 tw PlayEnd 7 700437
182038,03 7 play end id=700437, (current ID)
182038,03 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
182038,03 7 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
182038,03 7 path {EV_PLAY_FINISHED} not found
182038,03 7 timer set 10 EV_TIMEOUT_HANGUP
182038,03 7 timer set 0 EV_TIMEOUT_GOTOMODULE
182038,03 7 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
182038,03 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
182038,03 7 path {EV_TIMEOUT_GOTOMODULE} not found
182038,03 7 fn RunModule start
182038,03 7 timer clear
182038,03 7 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
182038,03 7 tw DialogicEvent 129,TDX_PLAY,700437,0,0,,,
182038,03 7 event ScriptEventCode TDX_PLAY, code=129, state=1901
182038,03 7 LsXfer_1_Start : 129(EV_UNKNOWN_129),TDX_PLAY,700437,0,0,,,
182038,03 7 path {TDX_PLAY} not found
182038,42 7 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
182038,42 7 event ScriptEventCode EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
182038,42 7 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
182038,42 7 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
182038,42 7 timeout on transfer attempt set by timeout path (30 sec)
182038,42 7 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
182038,42 7 rv replace start: [$RV[resultQuery]]
182038,42 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
182038,42 7 rv replace end: [0739389890]
182038,42 7 state [Locksmith] Announced 3-Way Conference to 0739389890
182038,67 7 tw PlayEnd 7 0
182038,67 7 play end id=0, (current ID)
182038,67 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1902
182038,67 7 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
182038,67 7 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
182038,67 7 event ScriptEventCode TDX_DIAL, code=132, state=1902
182038,67 7 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
182038,67 7 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
182038,67 7 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
182040,83 7 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
182040,83 7 event ScriptEventCode EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902
182040,83 7 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
182040,83 7 Dial(0739389890, cp on) call
182040,89 7 Dial(0739389890) ok
182040,89 7 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
182052,52 7 tw DialogicEvent 133,TDX_CALLP,10,3,0,TDX_CALLP,CR_CNCT,CON_PVD
182052,52 7 event ScriptEventCode VOICE, code=133, state=1903
182052,52 7 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,VOICE,10,3,0,CR_CNCT,CON_PVD,
182052,52 7 event ScriptEventCode CONNECT, code=133, state=1903
182052,52 7 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CONNECT,10,3,0,CR_CNCT,CON_PVD,
182052,52 7 event ScriptEventCode CON_PVD, code=133, state=1903
182052,52 7 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CON_PVD,10,3,0,CR_CNCT,CON_PVD,
182052,52 7 event ScriptEventCode CR_CNCT, code=133, state=1903
182052,52 7 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CR_CNCT,10,3,0,CR_CNCT,CON_PVD,
182052,52 7 event ScriptEventCode TDX_CALLP, code=133, state=1903
182052,52 7 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,10,3,0,CR_CNCT,CON_PVD,
182052,52 7 LsXfer_3 CR_CNCT on an XT_3WAY_ANNOUNCED
182052,52 7 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
182052,52 7 path {EV_PLAY_FINISHED} not found
182052,52 7 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
182052,52 7 path {EV_TIMEOUT_REPLAYMSG} not found
182052,52 7 rv replace start: [voice\call_transfer_$RV[LANGUAGE].wav]
182052,52 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
182052,52 7 rv replace end: [voice\call_transfer_2.wav]
182052,52 7 state [Locksmith] Playing (voice\call_transfer_2.wav)
182052,52 7 tw ConvertWav2Vox C:\Voice\Locksmith\voice\call_transfer_2.wav
182052,52 7 timer clear
182052,58 7 tw wav->vox convert end 719796,C:\Voice\Locksmith\voice\call_transfer_2.vox,1,0,,
182052,59 7 play start ok, lPlayId=719859
182103,05 7 tw PlayEnd 7 719859
182103,05 7 play end id=719859, (current ID)
182103,05 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1904
182103,05 7 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
182103,05 7 path {EV_PLAY_FINISHED} not found
182103,05 7 LsXfer_4_PlayAnn : 9005(EV_TIMEOUT_REPLAYMSG),EV_TIMEOUT_REPLAYMSG,0,0,0,,,
182103,05 7 path {EV_TIMEOUT_REPLAYMSG} not found
182103,05 7 rv replace start: [voice\call_transfer_$RV[LANGUAGE].wav]
182103,05 7 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-10-18 18:20:00}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Tele2\}[$RV_CIDNUMBER]{}[LANGUAGE]{2}[init_COUNTER_Input]{0}[init_COUNTER]{0}[counte
182103,05 7 rv replace end: [voice\call_transfer_2.wav]
182103,05 7 state [Locksmith] Playing (voice\call_transfer_2.wav)
182103,05 7 tw ConvertWav2Vox C:\Voice\Locksmith\voice\call_transfer_2.wav
182103,05 7 timer clear
182103,06 7 tw DialogicEvent 129,TDX_PLAY,719859,0,0,,,
182103,06 7 event ScriptEventCode TDX_PLAY, code=129, state=1904
182103,06 7 LsXfer_4_PlayAnn : 129(EV_UNKNOWN_129),TDX_PLAY,719859,0,0,,,
182103,06 7 path {TDX_PLAY} not found
182103,14 7 tw wav->vox convert end 730328,C:\Voice\Locksmith\voice\call_transfer_2.vox,1,0,,
182103,16 7 play start ok, lPlayId=730421
182104,12 7 tw dtmf 1 (7,49,49)
182104,12 7 event ScriptEventCode 1, code=49, state=1904
182104,12 7 LsXfer_4_PlayAnn : 49(1),1,0,0,0,,,
182104,12 7 rv add [Locksmith]{1}
182104,12 7 timer set 0,5 EV_PLAY_FINISHED
182104,14 7 play PlaySoundStop ok
182104,14 7 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
182104,14 7 event ScriptEventCode TDX_CST, code=134, state=1904
182104,14 7 LsXfer_4_PlayAnn : 134(EV_UNKNOWN_134),TDX_CST,49,0,0,DE_DIGITS,,
182104,14 7 path {TDX_CST} not found
182104,14 7 tw PlayEnd 7 730421
182104,14 7 play end id=730421, (current ID)
182104,14 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1904
182104,14 7 LsXfer_4_PlayAnn : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
182104,14 7 path {EV_PLAY_FINISHED} not found
182104,14 7 dial !,3 from LsXfer_4_PlayAnn
182104,16 7 tw DialogicEvent 129,TDX_PLAY,730421,0,0,,,
182104,16 7 event ScriptEventCode TDX_PLAY, code=129, state=1905
182104,16 7 LsXfer_5A : 129(EV_UNKNOWN_129),TDX_PLAY,730421,0,0,,,
182104,62 7 timer fired EV_PLAY_FINISHED
182104,62 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1905
182104,62 7 LsXfer_5A : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
182105,36 7 tw PlayEnd 7 0
182105,36 7 play end id=0, (current ID)
182105,36 7 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1905
182105,36 7 LsXfer_5A : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,,
182105,36 7 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
182105,36 7 event ScriptEventCode TDX_DIAL, code=132, state=1905
182105,36 7 LsXfer_5A : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
182105,36 7 sXferDialResult_SuccOrFail=XferToGoAhead
182105,36 7 LsXfer_5A Going down Success path (iXferType=23)
182105,36 7 fn RunModule start
182105,36 7 timer clear
182105,36 7 rv add [Hangup Time]{2005-10-18 18:21:05}
182105,36 7 state Hanging up call... [Hangup Module]
182105,36 7 HangupCall_Common hCall=7
182105,36 7 rec RecSoundStop ok
182105,36 7 play PlaySoundStop ok
182105,36 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
182105,36 7 fnHangupCall end
182105,41 7 event callstate IDLE 7 1,0,0
182105,41 7 WorkingMode@Idle=
182105,41 7 timer clear
182105,41 7 rec RecSoundStop ok
182105,41 7 play PlaySoundStop ok
182105,41 7 rv add [CallEndTime]{2005-10-18 18:21:05}
182105,59 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
182105,59 7 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
182105,59 7 event ScriptEventCode TDX_SETHOOK, code=135, state=900
182105,59 7 LsAwaitingCalls EV_UNKNOWN_135
182106,58 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
182106,58 7 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
182106,58 7 init atidle reinit : start
182106,58 7 init atidle reinit iConferenceOtherLegLid=-1
182106,58 7 init atidle reinit : reset all LineState variables
182106,58 7 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
182106,58 7 state Waiting for a call...
182106,91 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
182106,91 7 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
Thank you for your help!
Jose
1018tw_old.txt
From the trace it looks as if you have a Success path in the call transfer module
leading straight to Hangup module.. is that right?
The Success path, if defined, is taken immediately after the call transfer is successful. Pointing to a Hangup module will end the call.
Please post in future also the script with which you are experiencing the problem on your system.
