Vbscript Questions
Daniel wrote:
Do you have any idea why vbscript's returned value
for Cos would be different than the rest of the world's?
When I use a calculator, online, microsoft's, or traditional, I get
Cos(.59722) = .99994
However, voiceguide is receiving Cos(.59722)=.89670 (I rounded the values
involved)
I verified that it was the Cos function that was causing this to happen. I
verified that the values going into the Cos function were what they should
be.
Would you have any idea why this would happen? Perhaps you know of a way to
test the value outside of voiceguide? I don't think the trace would be of
any value because once the vbscript starts, it doesn't seem to leave any
traces other than it's entry and exit.
The Microsoft calculator takes COS input in Degrees, while VBScript takes input in Radians.
Radian = Angle * 3.14159265 / 180.0
a sample test VBScript showing this is attached - just download and double-click it and the script will run.
The VBScript's that VoiceGuide runs are available for viewing as well. See bottom of the Help file's page on VBScript module. ( online copy here: http://www.voiceguide.com/vghelp/html/modVbs.htm )
CosTest.vbs
Ok, I see. Doh, that was dumb of me. So I was getting the right value in vbscript because I had already converted it to radians, thinking that's what the world used.
WOW! Someone using a trigonometry in a CTI script !! Awesome. ;-)
And qudos to support for spotting radian base - cool !!
