90 Ports
We have a requirement of 90 ports, I want to now which dialogic card we can use. And how many server we should use. Or all can be connected with a single server.
Please guide me I am a really newbie in this field.
Jahangir
You will need to use E1 ISDN lines.
The cards you should be looking at are:
D/300JCT - one E1 port per card
D/600JCT - two E1 ports per card
DMV600B - two E1 ports per card
DMV1200B - four E1 ports per card
All 90 lines can be on one server.
If you're doing this on a tight budget have a look at using seconds hand cards from Ebay or from www.thetelecomlink.com
You could also use the older D/300PCI cards (not sold brand new anymore).
Thanks for your as usual cooperation.
So, its clear that we can use one server for 90 lines.
I will be very glade to you if you could suggest me how many cards we should take or specifically suggest me what cards should I take.
And what price of 90 lines for vg enterpricese version.
And any idea you can suggest for server.
The DMV1200B is the best choice.
But if you want to use D/300JCTs or D/600JCTor D/300PCIs that’s fine as well.
If there is a possibility of ever going to 120 lines the DMV1200B would be the way to go.
For server the popular choice is the DELL SC430 with 1GB RAM.
Price of 90 line license is 1.5 times the price of 60 line license which is listed on our WWW.
So, its mean we should take DMV1200B for 90 lines. It will be enough for our requirement. As you said four E1 ports so in one port 30 lines can be connected so in 4 E1 ports 120 lines can be connected in one server.
Please can you tell me that I am correct in my understanding Or if there is any mistake please can you correct it.
BEST REGARDS
