Voiceguide Does Not Take Down
Hello,
I installed voiceguide with PC windowsXP.
With 2 modems Compatible Analogic V90 Voice.
The problem, is that voiceGuide does not take down. OR sometime : - (
thank you for your assistance
K.
What do you mean by "VoiceGuide does not take down." ?
