Vg On D/4pci Doesn't Detect Busy Tone
I have a very strange problem
I have a VG script running on a Windows XP machine having Dialogic D/4PCI card.
The problem is that I have a module called "Tansfer Call" that should perform a PBX announced transfer to an extension read from database. The transfer operation works fine if the called number is answerd or not answered. When the dialed extension is busy VG doesn't detect the busy state and it moves through the Success path which causes a Hang Up. When VG hangs up the caller is still on Hold and after a long while the script is restarted with the Welcome message being played.
Here's the Log for the part where the extension called by VG is busy:
154007.38 6 linedevstate 2048 0 0
154007.39 6 callstate OFFERING 66506 0 4
154007.41 6 rv clear
154007.41 6 Answer the call at 21/08/2005 03:40:07 م
154007.45 6 lineAnswer(66506) => 66130
154007.48 6 callinfo CALLEDID
154007.50 6 callinfo ORIGIN
154007.50 6 ring 0
154008.05 6 callstate CONNECTED 66506 1 0
154008.06 6 callstate CONNECTED 66506,1,0
154008.06 6 WorkingModeTAPI@Connected=
154008.08 6 WorkingModeScript@Connected=
154008.08 6 Inband detection not enabled
154008.09 6 StartLoadedVgs at 21/08/2005 03:40:08 م, v5.2.3063
154008.11 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Auto Attendant\}
154008.11 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Auto Attendant}
154008.13 6 rv add [$RV_STARTTIME]{21/08/2005 03:40:08 م}
154008.14 6 rv add [$RV_DEVICEID]{6}
154008.14 6 rv add [$RV_CIDNAME]{}
154008.16 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
154008.18 6 rv add [$RV_CIDNUMBER]{}
154008.19 6 tapi Reply (LineEvReply) ok 66130 0
154008.20 6 callinfo MONITORMODES
154008.25 0 dial start any summary:|6:hc>0|7:idx=0|8:idx=0|9:idx=0|
154008.27 6 timer clear
154008.28 6 [Welcome] Playing
154008.28 6 [Welcome] Playing (welcomemusic.wav)
154008.30 6 play set playid=976625
154008.47 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Auto Attendant\welcomemusic.wav]
154008.48 6 timer clear
154008.50 6 RunModule PLAY end
154008.52 6 wa(26108,97662500)
154008.55 6 callinfo MONITORMODES
154010.60 6 dtmf 9 (66506,57,2)
154010.61 6 ScriptEventCode 57 iLineState=1100
154010.61 6 LsPlayMsg 9
154010.72 6 PlaySoundStop err=0
154010.72 6 rv add [Welcome]{9}
154010.79 6 timer clear
154010.80 6 [GetExtension] Number Input
154010.82 6 [GetExtension] Playing (insert.wav)
154010.83 6 play set playid=979156
154010.96 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Auto Attendant\insert.wav]
154010.97 6 timer clear
154010.99 6 wa(3700,97915600)
154011.00 6 callinfo MONITORMODES
154011.82 6 dtmf 4 (66506,52,2)
154011.83 6 ScriptEventCode 52 iLineState=1300
154011.85 6 LsGetNbrsPlayWelcMsg 4
154011.94 6 PlaySoundStop err=0
154011.96 6 [GetExtension] Number Input 4
154011.96 6 path {4} not found
154011.97 6 timer set 6 EV_TIMEOUT_ENTERDATA
154012.19 6 dtmf 1 (66506,49,2)
154012.21 6 ScriptEventCode 49 iLineState=1301
154012.22 6 LsGetNbrsRxDigits 1
154012.24 6 [GetExtension] Number Input 41
154012.25 6 path {41} not found
154012.27 6 timer set 6 EV_TIMEOUT_ENTERDATA
154012.36 6 dtmf 1 (66506,49,2)
154012.38 6 ScriptEventCode 49 iLineState=1301
154012.39 6 LsGetNbrsRxDigits 1
154012.41 6 [GetExtension] Number Input 411
154012.43 6 path {411} not found
154012.44 6 timer set 6 EV_TIMEOUT_ENTERDATA
154012.66 6 dtmf 3 (66506,51,2)
154012.66 6 ScriptEventCode 51 iLineState=1301
154012.68 6 LsGetNbrsRxDigits 3
154012.69 6 [GetExtension] Number Input 4113
154012.71 6 path {4113} not found
154012.72 6 timer set 6 EV_TIMEOUT_ENTERDATA
154012.74 6 timer clear
154012.75 6 rv add [GetExtension]{4113}
154012.77 6 path {4113} not found
154012.77 6 AddRVns [GetExtension_PathTaken]{success}
154012.79 6 timer clear
154012.80 6 [sqlGetRealExtension] DB Query
154012.82 6 db ODBC mode used
154012.89 6 rv replace start: [select VoiceMailNameWavFile,ExtensionId from voicemails where VoiceMailID = $RV[GetExtension]]
154012.91 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Auto Attendant\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Auto Attendant}[$RV_STARTTIME]{21/08/2005 03:40:08 م}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{9}[GetExtension]{4113}[GetExtension_PathTaken]{suc
ess}
154012.93 6 rv replace end: [select VoiceMailNameWavFile,ExtensionId from voicemails where VoiceMailID = 4113]
154012.94 6 db About to execute a Retrieve type operation [select VoiceMailNameWavFile,ExtensionId from voicemails where VoiceMailID = 4113]
154012.96 6 db [sqlGetRealExtension] row count=1
154012.97 6 rv add [sqlGetRealExtension_RowCount]{1}
154012.99 6 db get RecordsetGetRowsMax
154013.00 6 db get 999 records. (row count=1)
154013.02 6 db update RVs start
154013.04 6 db update RVs cols=2 rows=1
154013.05 6 db test vRetData(0, 0)=C:\Program Files\VoiceGuide\Scripts\Auto Attendant\1101091859_6_.wav
154013.07 6 db test CStr(vRetData(0, 0))=C:\Program Files\VoiceGuide\Scripts\Auto Attendant\1101091859_6_.wav
154013.08 6 db about to close dbDbqDatabase
154013.10 6 db going down path [True]
154013.11 6 timer clear
154013.13 6 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
154013.55 6 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
154013.57 6 ScriptEventCode 9012 iLineState=1900
154013.58 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
154013.58 6 timer set 10 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
154013.60 6 rv replace start: [$RV[sqlGetRealExtension_2_1]]
154013.61 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Auto Attendant\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Auto Attendant}[$RV_STARTTIME]{21/08/2005 03:40:08 م}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{9}[GetExtension]{4113}[GetExtension_PathTaken]{suc
ess}[sqlGetRealExtension_RowCount]{1}[sqlGetRealExtension_1_1]{C:\Program Files\VoiceGuide\Scripts\Auto Attendant\1101091859_6_.wav}[sqlGetRealExtension_2_1]{411}
154013.64 6 rv replace end: [411]
154013.66 6 [Transfer Call] Announced Transfer to 411 (Generate)
154013.68 6 tapic lineGenerateDigits(66506,!,100) => 0
154014.38 6 generate LINEGENERATETERM_DONE
154014.39 6 timer set 1 EV_TAPI_GENERATE
154015.45 6 timer fired EV_TAPI_GENERATE
154015.45 6 ScriptEventCode 9602 iLineState=1900
154015.46 6 LsXferStart EV_TAPI_GENERATE
154015.48 6 timer set 1 EV_HOOKFLASHFINISHED
154016.59 6 timer fired EV_HOOKFLASHFINISHED
154016.59 6 ScriptEventCode 9200 iLineState=1905
154016.60 6 LsXferPlayVts EV_HOOKFLASHFINISHED
154016.63 6 tapic lineGenerateDigits(66506,411,100) => 0
154017.20 6 generate LINEGENERATETERM_DONE
154017.21 6 timer set 1 EV_TAPI_GENERATE
154018.21 6 timer fired EV_TAPI_GENERATE
154018.21 6 ScriptEventCode 9602 iLineState=1905
154018.23 6 LsXferPlayVts EV_TAPI_GENERATE
154018.24 6 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits
154018.27 6 sVbsFunctionToUse=Digits
154018.46 6 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_6_SayNumber.vbs)
154018.63 6 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav
154018.66 6 play set playid=986984
154018.85 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav]
154018.87 6 timer clear
154018.90 6 wa(1845,98698400)
154018.91 6 callinfo MONITORMODES
154019.13 6 callstate DISCONNECTED 66506 0 0
154019.13 6 ScriptEventCode 9250 iLineState=1906
154019.15 6 LsXferPlayAnn EV_REMOTEPARTY_DISCONNECT
154019.16 6 timer set 1 EV_PLAY_FINISHED
154019.26 6 PlaySoundStop err=0
154020.32 6 timer fired EV_PLAY_FINISHED
154020.34 6 ScriptEventCode 8001 iLineState=1906
154020.34 6 LsXferPlayAnn EV_PLAY_FINISHED
154020.35 6 tapic lineGenerateDigits(66506,!,100) => LINEERR_INVALCALLSTATE [8000001C]
154020.37 6 rv add [Hangup Time]{21/08/2005 03:40:20 م}
154020.38 6 Hanging up call... [lineGenerateDigits ret=-2147483620]
154020.41 6 RecSoundStop ok
154020.45 6 PlaySoundStop err=0
154020.46 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
154020.52 6 fnHangupCall end
154020.57 6 linedevstate 2048 0 0
154020.59 6 callstate IDLE 66506 0 0
154020.60 6 WorkingMode@Idle=
154020.62 6 timer clear
154020.65 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
154020.66 6 tapi Reply (LineEvReply) ok 65635 0
154021.66 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
154021.68 6 ScriptEventCode 9008 iLineState=900
154021.70 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
154021.70 6 ReinitTelephony due to IDLE
154021.73 6 tapic lineDeallocateCall(MainCall:66506) 0
154022.04 6 lineOpen(6)=>
154022.06 6 Waiting for a call...
154022.07 6 LineHandle=65788
154022.09 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
154022.59 0 dial start any summary:|6:rdy=0|7:idx=0|8:idx=0|9:idx=0|
154025.39 6 timer fired EV_TIMEOUT_ATERIDLE_AL0LOWOUT
154025.40 6 ScriptEventCode 9013 iLineState=900
154025.65 0 dial start any summary:|6:idx=0|7:idx=0|8:idx=0|9:idx=0|
The trace provided did not show this happening.
Please change to using VG for Dialogic (see our Downloads page).
The call transfers are better handled under VG for Dialogic.
