Voice Guide Enterprise Version
i have a question about Voicguide enterprise version:
Does the script "internet inquiry" who give the nasdaq cotation will works with enterprise version?
Can I add my personnal text to speech software to voice guide?
Yes.
Yes. Any SAPI compatible TTS engine can be used. Just select it as the default TTS engine in Control Panels SAPI TTS applet and VG will use that engine.
I just tryed to setup the script but it don't works,i installed TTS engine sdk:
In the log I have the message:
124414,46 1 ERROR: COM interface not supported in this version.
I installed patch for Dialogic, is it because Of that version?
124414,23 1 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,TID_BUSY1,
124414,25 1 event BUSY, code=134, state=1501
124414,28 1 LsRunWaitTillFinished EV_UNKNOWN_134
124414,30 1 event TID_BUSY1, code=134, state=1501
124414,32 1 LsRunWaitTillFinished EV_UNKNOWN_134
124414,33 1 event TDX_CST, code=134, state=1501
124414,35 1 LsRunWaitTillFinished EV_UNKNOWN_134
124414,37 1 cl Run_ResultReturn >>[MarketDow]{10569}[MarketNasdaq]{2141}[MarketSP500]{1221}<<
124414,94 1 timer fired EV_TIMEOUT_CHECKONSTATE
124414,96 1 event EV_TIMEOUT_CHECKONSTATE, code=9007, state=1501
124414,97 1 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
124414,99 1 task completed (shellid=592, process=2024) vgm=10, iRunWait=1, iRunWait_ExeResult_NextVgm=0
124415,03 1 no result file returned from program (VGRUNRESULT_1.TXT or SHLRESLT.TXT)
124415,04 1 task completed LsRunWaitChooseNext iNextVgm=13
124415,06 1 fn RunModule start
Are you running an Enterprise version of VoiceGuide?
When running VG go to "Help"->"About VoiceGuide" menu and see what it says in the window which displays.
I made a mistake I have a professionnal version. How can change the script to work in pro version? I only need to call an url to speak a code with letters, id like after VB module success redirect to a play module and play, for exemple if the code is ABC, play a.wav b.wav and c.wav
