Transfer Call Paths
Hello!
I am working with the transfer call module. In the case when tha receiver accepts the call the succes path from the transfer module works fine. My problem is when the receiver, for some reason, does not answer the phone then I am not able to continue with anything. I mean VoiceGuide hangs up in both lines.
What I would like to know is if there is any way of knowing that a call did not succeed to call another module? I´ve tried with:
on {fail} goto [Another_Module] but VoiceGuide does not care, I mean it just hangs up.
Thank you!
Jose
Which version of VG are you using?
