Vg Thinks Someone Is Calling But No One Is
If you hang up in the middle of a transaction VG Displays"Hanging up call" Followed by "Waiting for call" and then mysteriously picks up like someone is calling. It is impossible that someone else is calling. Here is the trace surrounding the hangup.
151447.19 1 state [Welcome] Number Input
151447.20 1 tts generate start[Welcome to the TMG OneSource Phone Ordering system. Please enter your customer number followed by the pound sign. ]
151447.20 1 tts generate wait
151447.31 1 tts generate finish
151447.31 1 state [Welcome] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
151447.31 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
151447.31 1 timer clear
151447.38 1 tw wav->vox convert end 224437,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
151447.39 1 play start ok, lPlayId=224500
151455.25 1 tw PlayEnd 1 224500
151455.25 1 play end id=224500, (current ID)
151455.25 1 event EV_PLAY_FINISHED, code=8001, state=1300
151455.25 1 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
151455.27 1 path {EV_PLAY_FINISHED} not found
151455.27 1 timer set 5 EV_TIMEOUT_REPLAYMSG
151455.27 1 tw DialogicEvent 129,TDX_PLAY,224500,0,0,,,
151455.27 1 event TDX_PLAY, code=129, state=1301
151455.27 1 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
151455.27 1 path {TDX_PLAY} not found
151459.77 1 event callstate DISCONNECTED 1 0 0
151459.77 1 event EV_REMOTEPARTY_DISCONNECT, code=9250, state=1301
151459.77 1 LsGetNbrsRxDigits EV_REMOTEPARTY_DISCONNECT,EV_REMOTEPARTY_DISCONNECT
151459.77 1 path {EV_REMOTEPARTY_DISCONNECT} not found
151459.77 1 state Hanging up call...
151459.79 1 HangupCall_Common hCall=1
151459.79 1 rec RecSoundStop ok
151459.79 1 play PlaySoundStop ok
151459.79 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
151459.79 1 fnHangupCall end
151459.79 1 tw DialogicEvent 134,TDX_CST,1261,0,0,DE_LCOF,,
151459.79 1 event TDX_CST, code=134, state=900
151459.80 1 LsAwaitingCalls EV_UNKNOWN_134
151459.83 1 event callstate IDLE 1 0 0
151459.83 1 WorkingMode@Idle=
151459.83 1 timer clear
151459.83 1 rec RecSoundStop ok
151459.85 1 play PlaySoundStop ok
151459.85 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
151459.85 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
151459.85 1 event TDX_SETHOOK, code=135, state=900
151459.85 1 LsAwaitingCalls EV_UNKNOWN_135
151500.83 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
151500.83 1 init atidle reinit : start
151500.83 1 init atidle reinit iConferenceOtherLegLid=-1
151500.83 1 init atidle reinit : reset all LineState variables
151500.83 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
151500.83 1 state Waiting for a call...
151501.16 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
151501.52 1 event callstate OFFERING 1 0 0
151501.52 1 script interpretor: VgMulti v6.0.2028
151501.52 1 ERROR 6.0.2028 TW__LineEvCallState_Error:Subscript out of range
151501.52 1 tw ring 1
151501.54 1 ring time since last ring (ms): 0
151501.54 1 rv clear all
151501.54 1 init LineState ResetAtStartOfNewCall.
151501.54 1 answer the call
151501.54 1 timer clear
151501.54 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
151501.55 1 event TDX_CST, code=134, state=6001
151501.96 0 sys cleanup Start
151501.96 0 sys cleanup End
151502.08 1 event callstate CONNECTED 1 0 0
151502.08 1 WorkingModes tapi= script=
151502.08 1 Inband detection not enabled
151502.10 1 StartLoadedVgs at 8/11/2005 3:15:02 PM
151502.10 1 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
151502.10 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
151502.10 1 fn RunModule start
151502.10 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
151502.10 1 event TDX_SETHOOK, code=135, state=6001
151502.10 1 tw DialogicEvent 134,TDX_CST,231,0,0,DE_LCON,,
151502.11 1 event TDX_CST, code=134, state=6001
151502.11 1 timer clear
151502.11 1 state [Zero CustNumber Retries] Evaluate [0]
151502.11 1 eval[0]
151502.11 1 Eval Expr result:[0] stored in $RV[CustNoCounter]
151502.11 1 path {0} not found
151502.13 1 fn RunModule start
151502.13 1 timer clear
151502.13 1 state [Welcome] Number Input
151502.13 1 tts generate start[Welcome to the TMG OneSource Phone Ordering system. Please enter your customer number followed by the pound sign. ]
151502.13 1 tts generate wait
151502.21 1 tts generate finish
151502.21 1 state [Welcome] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
151502.21 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
151502.21 1 timer clear
151502.27 1 tw wav->vox convert end 239328,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
151502.29 1 play start ok, lPlayId=239390
151510.14 1 tw PlayEnd 1 239390
151510.14 1 play end id=239390, (current ID)
151510.16 1 event EV_PLAY_FINISHED, code=8001, state=1300
151510.16 1 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
151510.16 1 path {EV_PLAY_FINISHED} not found
151510.16 1 timer set 5 EV_TIMEOUT_REPLAYMSG
151510.16 1 tw DialogicEvent 129,TDX_PLAY,239390,0,0,,,
151510.16 1 event TDX_PLAY, code=129, state=1301
151510.16 1 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
We can see in trace tha that the Dialogic card is reporting ringing on the line:
about 2 seconds after VG hangs up (151459.77 1 state Hanging up call...).
That's why VoiceGuide picks up the phone and starts the script.
Some PBXs and switches have 'auto-callback' features - are you sure that the PBX or Switch is not actually dialing Voiceguide's extension again?
There is a remote chance that the Dialoigc card is faulty - but the 'auto-callback' is probably what is happening here...
I now have a Vonage line hooked up and no longer get the redial problem However now it will not detect a hangup.
Here is the log
170006.12 1 tw dtmf 2 (1,50,50)
170006.12 1 event 2, code=50, state=1300
170006.12 1 LsGetNbrsPlayWelcMsg 2,2
170006.14 1 play PlaySoundStop ok
170006.14 1 state [Welcome] Number Input 2
170006.14 1 path {2} not found
170006.14 1 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
170006.14 1 event TDX_CST, code=134, state=1301
170006.14 1 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
170006.14 1 path {TDX_CST} not found
170006.14 1 tw PlayEnd 1 138531
170006.14 1 play end id=138531, (current ID)
170006.14 1 event EV_PLAY_FINISHED, code=8001, state=1301
170006.14 1 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
170006.14 1 path {EV_PLAY_FINISHED} not found
170006.14 1 tw DialogicEvent 129,TDX_PLAY,138531,0,0,,,
170006.14 1 event TDX_PLAY, code=129, state=1301
170006.14 1 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
170006.15 1 path {TDX_PLAY} not found
170006.48 1 tw dtmf 0 (1,48,48)
170006.48 1 event 0, code=48, state=1301
170006.48 1 LsGetNbrsRxDigits 0,0
170006.48 1 state [Welcome] Number Input 20
170006.48 1 path {20} not found
170006.48 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
170006.50 1 event TDX_CST, code=134, state=1301
170006.50 1 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
170006.50 1 path {TDX_CST} not found
170006.70 1 tw dtmf 0 (1,48,48)
170006.70 1 event 0, code=48, state=1301
170006.70 1 LsGetNbrsRxDigits 0,0
170006.70 1 state [Welcome] Number Input 200
170006.70 1 path {200} not found
170006.70 1 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,,
170006.70 1 event TDX_CST, code=134, state=1301
170006.70 1 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
170006.71 1 path {TDX_CST} not found
170006.87 1 tw dtmf # (1,35,35)
170006.87 1 event #, code=35, state=1301
170006.87 1 LsGetNbrsRxDigits #,#
170006.87 1 path {200} not found
170006.89 1 fn RunModule start
170006.89 1 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
170006.89 1 event TDX_CST, code=134, state=6001
170006.89 1 state [CheckCustNumber] DB Query
170006.89 1 db ODBC mode used
170006.90 1 rv replace start: [select 1, CustName From TarCustomer Where Custkey=$RV[Welcome]]
170006.90 1 rv replace end: [select 1, CustName From TarCustomer Where Custkey=200]
170006.90 1 db About to execute a Retrieve type operation [select 1, CustName From TarCustomer Where Custkey=200]
170006.92 1 db [CheckCustNumber] row count=1
170006.92 1 db get RecordsetGetRowsMax
170006.92 1 db get 999 records. (row count=1)
170006.92 1 db update RVs
170006.92 1 db about to close dbDbqDatabase
170006.92 1 db going down path [True]
170006.93 1 fn RunModule start
170006.93 1 state [Clear Location Number Counter] Evaluate [0]
170006.93 1 eval[0]
170006.93 1 Eval Expr result:[0] stored in $RV[LocNoCounter]
170006.93 1 state [GetLocationNo] Number Input
170006.93 1 tts generate start[Please enter your location number followed by the pound sign. ]
170006.93 1 tts generate wait
170006.00 1 tts generate finish
170006.00 1 state [GetLocationNo] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
170006.00 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
170007.03 1 tw wav->vox convert end 147140,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
170007.03 1 play start ok, lPlayId=147171
170008.82 1 tw dtmf 5 (1,53,53)
170008.82 1 event 5, code=53, state=1300
170008.82 1 LsGetNbrsPlayWelcMsg 5,5
170008.84 1 play PlaySoundStop ok
170008.84 1 state [GetLocationNo] Number Input 5
170008.84 1 path {5} not found
170008.86 1 tw DialogicEvent 134,TDX_CST,53,0,0,DE_DIGITS,,
170008.86 1 event TDX_CST, code=134, state=1301
170008.86 1 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
170008.86 1 path {TDX_CST} not found
170008.86 1 tw PlayEnd 1 147171
170008.86 1 play end id=147171, (current ID)
170008.86 1 event EV_PLAY_FINISHED, code=8001, state=1301
170008.86 1 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
170008.86 1 path {EV_PLAY_FINISHED} not found
170008.87 1 tw DialogicEvent 129,TDX_PLAY,147171,0,0,,,
170008.87 1 event TDX_PLAY, code=129, state=1301
170008.87 1 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
170008.87 1 path {TDX_PLAY} not found
170009.39 1 tw dtmf 2 (1,50,50)
170009.39 1 event 2, code=50, state=1301
170009.39 1 LsGetNbrsRxDigits 2,2
170009.39 1 state [GetLocationNo] Number Input 52
170009.39 1 path {52} not found
170009.39 1 tw DialogicEvent 134,TDX_CST,50,0,0,DE_DIGITS,,
170009.39 1 event TDX_CST, code=134, state=1301
170009.40 1 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
170009.40 1 path {TDX_CST} not found
170010.89 1 tw dtmf # (1,35,35)
170010.90 1 event #, code=35, state=1301
170010.90 1 LsGetNbrsRxDigits #,#
170010.90 1 path {52} not found
170010.90 1 fn RunModule start
170010.90 1 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
170010.90 1 event TDX_CST, code=134, state=6001
170010.90 1 state [CheckLocationNumber] DB Query
170010.90 1 db ODBC mode used
170010.92 1 rv replace start: [sELECT 1, AddrLine1, tarCustAddr.AddrKey, AddrName, CustName,City, StateID, StoreNumber FROM tarCustomer Inner Join tarCustAddr On tarCustomer.Custkey=tarCustAddr.Custkey Inner Join tarCustAddrTMG On tarCustAddrTMG.AddrKey=tarCustAddr.AddrKey Inner Join tciAddress On tarCustAddr.AddrKey = tciAddress.AddrKey WHERE tarCustAddr.Custkey=$RV[Welcome] AND StoreNumber=$RV[GetLocationNo]]
170010.93 1 db About to execute a Retrieve type operation [sELECT 1, AddrLine1, tarCustAddr.AddrKey, AddrName, CustName,City, StateID, StoreNumber FROM tarCustomer Inner Join tarCustAddr On tarCustomer.Custkey=tarCustAddr.Custkey Inner Join tarCustAddrTMG On tarCustAddrTMG.AddrKey=tarCustAddr.AddrKey Inner Join tciAddress On tarCustAddr.AddrKey = tciAddress.AddrKey WHERE tarCustAddr.Custkey=200 AND StoreNumber=52]
170010.93 1 db [CheckLocationNumber] row count=1
170010.95 1 db get RecordsetGetRowsMax
170010.95 1 db get 999 records. (row count=1)
170010.95 1 db update RVs
170010.95 1 db about to close dbDbqDatabase
170010.95 1 db going down path [True]
170010.95 1 fn RunModule start
170010.96 1 state [Location] Running VB Script...
170010.96 1 rv replace start: [Dim CaseLocation
CaseLocation = "$RV[CheckLocationNumber_4_1]"
CaseLocation = LCase(CaseLocation)
vg.Run_ResultReturn $RV_LINEID, "[ALocation]{" & CaseLocation & "}"
set vg = Nothing
170010.96 1 vbs ran [vbs_1_1.vbs], cmd [wscript "C:\Program Files\VoiceGuide\data\vbs_1_1.vbs" //I //T:60]
170010.98 1 Run Script waiting. iRunWait=1 (shellid=4924, process=5228)
170011.01 1 cl Run_ResultReturn >>[ALocation]{52 - huntington}<<
170011.03 1 cl module's runwait=1, WavPlayHasNowFinished=0
170011.03 1 fn RunModule start
170011.03 1 Play Module start
170011.03 1 state [sayLocation] Playing
170011.03 1 rv replace start: [You are placing an order for store number $RV[CheckLocationNumber_8_1] in $RV[CheckLocationNumber_6_1] If this is correct press 1, If this is not correct press 2..]
170011.03 1 tts generate start[You are placing an order for store number 52 in Huntington If this is correct press 1, If this is not correct press 2..]
170011.03 1 tts generate wait
170011.12 1 tts generate finish
170011.12 1 state [sayLocation] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
170011.12 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
170011.15 1 tw wav->vox convert end 151265,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
170011.17 1 play start ok, lPlayId=151296
170019.29 1 tw PlayEnd 1 151296
170019.29 1 play end id=151296, (current ID)
170019.29 1 event EV_PLAY_FINISHED, code=8001, state=1100
170019.31 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
170019.31 1 path {EV_PLAY_FINISHED} not found
170019.31 1 tw DialogicEvent 129,TDX_PLAY,151296,0,0,,,
170019.31 1 event TDX_PLAY, code=129, state=1101
170019.31 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
170019.32 1 path {TDX_PLAY} not found
170024.78 1 event EV_TIMEOUT_REPLAYMSG, code=9005, state=1101
170024.78 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
170024.78 1 path {EV_TIMEOUT_REPLAYMSG} not found
170024.79 1 tts generate reuse
170024.79 1 state [sayLocation] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
170024.81 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
170024.82 1 tw wav->vox convert end 164953,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
170024.84 1 play start ok, lPlayId=164968
170032.96 1 tw PlayEnd 1 164968
170032.96 1 play end id=164968, (current ID)
170032.98 1 event EV_PLAY_FINISHED, code=8001, state=1100
170032.98 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
170032.98 1 path {EV_PLAY_FINISHED} not found
170032.00 1 tw DialogicEvent 129,TDX_PLAY,164968,0,0,,,
170032.00 1 event TDX_PLAY, code=129, state=1101
170033.01 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
170033.01 1 path {TDX_PLAY} not found
170038.37 1 event EV_TIMEOUT_REPLAYMSG, code=9005, state=1101
170038.37 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
170038.37 1 path {EV_TIMEOUT_REPLAYMSG} not found
170038.39 1 tts generate reuse
170038.39 1 state [sayLocation] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
170038.40 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
170038.43 1 tw wav->vox convert end 178546,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
170038.45 1 play start ok, lPlayId=178578
170046.57 1 tw PlayEnd 1 178578
170046.57 1 play end id=178578, (current ID)
170046.59 1 event EV_PLAY_FINISHED, code=8001, state=1100
170046.61 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
170046.62 1 path {EV_PLAY_FINISHED} not found
170046.64 1 tw DialogicEvent 129,TDX_PLAY,178578,0,0,,,
170046.65 1 event TDX_PLAY, code=129, state=1101
170046.65 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
170046.67 1 path {TDX_PLAY} not found
170057.51 1 event EV_TIMEOUT_HANGUP, code=9001, state=1101
170057.51 1 LsPlayMsgFinished EV_TIMEOUT_HANGUP,EV_TIMEOUT_HANGUP
170057.53 1 path {EV_TIMEOUT_HANGUP} not found
170057.53 1 state Hanging up call...
170057.54 1 HangupCall_Common hCall=1
170057.56 1 rec RecSoundStop ok
170057.56 1 play PlaySoundStop ok
170057.57 1 fnHangupCall end
170057.62 1 event callstate IDLE 1 0 0
170057.62 1 WorkingMode@Idle=
170057.64 1 rec RecSoundStop ok
170057.65 1 play PlaySoundStop ok
170057.65 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
170057.67 1 event TDX_SETHOOK, code=135, state=900
170057.68 1 LsAwaitingCalls EV_UNKNOWN_135
170058.68 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
170058.68 1 init atidle reinit : start
170058.70 1 init atidle reinit iConferenceOtherLegLid=-1
170058.70 1 init atidle reinit : reset all LineState variables
170058.71 1 state Waiting for a call...
170059.06 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
170235.90 0 load start [C:\Program Files\VoiceGuide\Scripts\BrookshireBros.vgs]
170235.93 0 loaded Script Id 3: C:\Program Files\VoiceGuide\Scripts\BrookshireBros.vgs
170235.93 0 Erasing Script (new loaded) Id 2
