If Then Else
I wish to write a statement via built in module or VbScript that uses a result variable from a previous module, Say $RV[sampleModule] as a play file module and I want to use the result of the if, then statement in a query. I was trying to do a VbScript module named GetDescription like....
Dim ItemKey
Dim Choice
Choice=$RV[sampleModule]
If Choice=1 then
ItemKey=1359
else
if Choice=2 then
ItemKey=1360
else
if Choice=3 then
ItemKey=1500
else ItemKey=0
end if
end if
end if
vg.RvSet $RV_LINEID, "ItemKey", ItemKey
set vg = Nothing '
Then reference the result in a query module like so....
SELECT Description FROM ItemDesc WHERE Key=$RV[itemKey]
I may be far off base with the way I am approaching this, I there is a better way feel free to suggest it or point me to a location in which I can find my answer.
Thank you
From looking at it, it all seems spot on. The script should work just the way you wrote it.
Have you tried it in VG yet?
When I run this in VG when it hits thre VBScript it takes the fail path.
At level 0 this is the only error I receive.
091324.32 1 ERROR 6.0.2028 TW__LineEvCallState_Error:Subscript out of range
091346.74 1 ERROR 6.0.2028 TW__LineEvCallState_Error:Subscript out of range
Is the VBScript returning an explicit 'Success' result or RV list to VG?
If you are still haveing problems please increase level to 8 or higher and post trace and the VG script itself.
This is the log at level 8 around the VbScript
100534.04 1 event TDX_PLAY, code=129, state=6001
100534.04 1 timer clear
100534.04 1 state [GetItemKey] Running VB Script...
100534.04 1 rv replace start: [Dim ItemKey
Dim Choice
Choice=$RV[ProductChoice]
If Choice=1 then
ItemKey=1359
else
if Choice=2 then
ItemKey=1360
else
if Choice=3 then
ItemKey=1500
else ItemKey=0
end if
end if
end if
100534.05 1 vbs ran [vbs_1_1.vbs], cmd [wscript "C:\Program Files\VoiceGuide\data\vbs_1_1.vbs" //I //T:60]
100534.07 1 Run Script waiting. iRunWait=1 (shellid=2396, process=6212)
100534.07 1 timer set 1 EV_TIMEOUT_CHECKONSTATE
100535.07 1 event EV_TIMEOUT_CHECKONSTATE, code=9007, state=1501
100535.07 1 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100535.07 1 task completed (shellid=2396, process=6212) vgm=29, iRunWait=1, iRunWait_ExeResult_NextVgm=0
100535.07 1 no result file returned from program (VGRUNRESULT_1.TXT or SHLRESLT.TXT)
100535.07 1 task completed LsRunWaitChooseNext iNextVgm=12
100535.08 1 fn RunModule start
100535.08 1 timer clear
The VBScript is not returning an explicit 'Success' result or RV list to VG...
From: http://www.voiceguide.com/vghelp/html/modVbs.htm
A "Success" or Result Variable list must be returned to VoiceGuide (either though a Run_ResultReturn COM function or a Result File) in order for it to go down the Success path.
If no result is returned then the "Fail" path is taken after the VBScript completes.
Calls to Script_Gosub(), Script_Goto() and Script_Return() functions result in immediate running of the next module.
I used:
Dim Key
Dim Choice
If Choice=1 then
Key="1300"
else
if Choice=2 then
Key="1500"
else
if Choice=3 then
Key="1600"
else Key=0
end if
end if
end if
vg.Run_ResultReturn $RV_LINEID, "[itemKey]{Key}"
set vg = Nothing
And it returned Key as the result variable not the 'value of Key. Is there anyway to fix that?
Change:
to:
vg.Run_ResultReturn $RV_LINEID, "[itemKey]{" & Key & "}"
You have to "build" the string by patching in the variable value.
