Can't Play Wav In D4pci
Please help!
32968 5 tapie ring 2
32968 5 Answer the call
32968 5 lineAnswer(65540) => 65608
33515 5 tapie callstate CONNECTED 65540,1,0
33515 5 WorkingModeTAPI=
33531 5 WorkingModeScript=
33546 5 Inband detection not enabled
33562 5 tapi Reply 65608 0
33562 5 [Play 2] Playing
33562 5 [Play 2] Playing (VoiceGuide\system\voicedlgc\VmbWelcomeMsgDefault.wav)
33578 5 Play Start line[5] err=[0 wavec waveOutOpen(0x0, 0x1, 0x1ec7a0, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] file[D:\VoiceGuide\system\voicedlgc\VmbWelcomeMsgDefault.wav]
33578 5 PlaySoundStart line[5] err=[0 wavec waveOutOpen(0x0, 0x1, 0x1ec7a0, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [D:\VoiceGuide\system\voicedlgc\ErrorPlayingFile.wav]
33593 5 For Dialogic use: PCM 11Khz 8bit Mono
33593 5 HangupCall called from [srlib 609]
33609 5 Hanging up call...
33609 5 PlaySoundStop ok
33625 5 fnHangupCall end
33625 5 RunModule PLAY end
35546 5 tapie linedevstate 2048 0 0
35562 5 tapie callstate IDLE 65540 0 0
35562 5 WorkingMode@Idle=
35578 5 set EV_TIMEOUT_TIMETOREINITLINE 2
35578 5 tapi Reply 65762 0
36578 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
36578 5 ReinitTelephony due to IDLE start
36578 5 tapic lineDeallocateCall(MainCall:65540) 0
36734 5 lineOpen(5) => 0
36734 5 Waiting for a call...
36734 5 lineOpen(5)LineHandle=66411
The .WAV sound files need to be recorded in this format:
PCM 11Khz 8bit Mono
There is even a line in the log trace file advising of this:
Also, which version of VG are you using?
