Retrieve Menu
Iam new to voice guide, downloaded the trial version. Iam using the defaults scripts but the retrieve menu on the voice mail script is not working, can any one assist
What in the menu is not working?
When i press the * key i get the prompts to enter mail box number, when I enetr the mail box Number, i get the prompt to enter the pin after enetring pin there is no other prompts just silence. I recorede messages in the Box which I can listen to or email out. So there is messages I just cant recieve then via the messages retrieve function, when i dial in. I trying using the numbers in the PDF file to access but no success.
I will send log in next correspondence
The VBScript in module [VmMmMsgCountsCalc] appears to hang on this system. This is the part of the voicemail system which tries to count how many messages are left in the voicemail box.
Have you modified the Voicemail scripts in any way?
Please reproduce the call just like you've done when you created the trace and the post the file "C:\Program Files\VoiceGuide\data\vbs_0_3.vbs" - contents of that file may show us why the script does not count the messages immediately.
182050.02  0 [VmLoginCheckPin] Running VB Script...
182050.03  0 rv    replace start (strlen>500)
182050.03  0 rv    ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server}[$RV_STARTTIME]{7/11/2005 6:19:55 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[scriptStart_Time]{7/11/2005 6:20:26 PM}[scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\Voicemail Server.vgs}[scriptStart_CalledFrom_Module]{Welcome}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[Welcome]{*}[Welcome_PathTaken]{star}[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsg
]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMmAdminPin]{4}[Key_VmMmAdminForwardPhone]{5
[Key_VmMmRecMessage]{6}[Key_VmMmAdminName]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmEx
t]{0}[Key_VmMmPlayMessageCounts]{#}[Key_VmRmReplayCurrent]{1}[Key_VmRmSaveAndPla
Next]{2}[Key_VmRmDeleteAndPlayNext]{3}[Key_VmRmPlayPrevious]{4}[Key_VmRmPlayCurr
nt]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPlayMessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Ke
_VmRmExitRetrieveMessages]{0}[Key_VmAdminWelcMsgPlayCurrent]{1}[Key_VmAdminWelcM
gDeleteAndRecNew]{2}[Key_VmAdminWelcMsgSaveAndReturn]{3}[Key_VmAdminWelcMsgDelet
AndReturn]{4}[Key_VmSendMsg_StopRecAndPlay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Ke
_VmSendMsg_SaveRecAndAddress]{3}[Key_VmSendMsg_DelRecAndReturn]{4}[Key_VmSendMsg
DelRecAndReturn2]{0}[Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLogi
Intro]{none}[VmLoginAskVmb]{0001}[VmLoginAskVmb_PathTaken]{success}[VmLoginAskPi
]{2222}[VmLoginAskPin_PathTaken]{success}
182050.08  0 eng  run vbs [wscript "C:\Program Files\VoiceGuide\data\vbs_0_2.vbs" //I] copy of script in: vbs_0_2.vbs
182050.17  0 Run Script waiting. iRunWait=1 (shellid=1460, process=1288)
182050.17  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
182050.34  0 cl    Vm_VmbConfig_Get 0001, Pin
182050.34  0 cl    Script_Goto 0, , VmMmMsgCountsCalc, [VmbId]{0001}
182050.36  2 tr    NewVgsVgm_Goto ,VmMmMsgCountsCalc,[VmbId]{0001},,,0
182050.36  0 rv    lg add [VmbId]{0001}
182050.38  0 timer clear
182050.38  0 [VmMmMsgCountsCalc] Running VB Script...
182050.39  0 rv    replace start (strlen>500)
182050.41  0 rv    ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server}[$RV_STARTTIME]{7/11/2005 6:19:55 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[scriptStart_Time]{7/11/2005 6:20:26 PM}[scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\Voicemail Server.vgs}[scriptStart_CalledFrom_Module]{Welcome}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[Welcome]{*}[Welcome_PathTaken]{star}[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsg
]{2222}[VmLoginAskPin_PathTaken]{success}[VmbId]{0001}
182050.47  0 eng  run vbs [wscript "C:\Program Files\VoiceGuide\data\vbs_0_3.vbs" //I] copy of script in: vbs_0_3.vbs
182050.58  0 Run Script waiting. iRunWait=1 (shellid=1448, process=1360)
182050.58  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
182051.58  0 timer fired EV_TIMEOUT_CHECKONSTATE
182051.58  0 ScriptEventCode 9007 iLineState=1501
182051.59  0      LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
182051.59  0 task still running (shellid=1448, process=1360)
182051.61  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
182052.70  0 timer fired EV_TIMEOUT_CHECKONSTATE
182052.70  0 ScriptEventCode 9007 iLineState=1501
182052.72  0      LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
182052.72  0 task still running (shellid=1448, process=1360)
182052.73  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
182053.84  0 timer fired EV_TIMEOUT_CHECKONSTATE
182053.84  0 ScriptEventCode 9007 iLineState=1501
182053.86  0      LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
182053.86  0 task still running (shellid=1448, process=1360)
182053.88  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
182054.97  0 timer fired EV_TIMEOUT_CHECKONSTATE
182054.97  0 ScriptEventCode 9007 iLineState=1501
182054.98  0      LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
182054.98  0 task still running (shellid=1448, process=1360)
182055.00  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
182056.09  0 timer fired EV_TIMEOUT_CHECKONSTATE
Ok I have notice an issue with the recived menu now that I have been using it for 1 week now.
When ever i restart the computer or computer accidentally shut down due to power loss and program was running. I can no longer retreive my messages or change pin. As a matter of fact the same problem as before reoccurs. I have to reinstall voice guide to resolve issue.
ANyt ideas how i can mitigate this as it is a reall problem for my bussiness with parties losing there messages.
Please post the trace so that we can confirm that it is the same type of problem.
Especially a trace of when you are trying to change your PIN...
Are you still using an evaluation version of the software, or are you now using a registered version?
