Voice Modem Incoming Call Detection Problem
I am using a voice modem for testing. The voice modem I used is an HSP56. VoiceGuide seems to recognize it OK but for some reason it cannot detect incoming calls. I tried to use the modem to answer incoming data calls, it won't work either. It will, however, initial data calls OK. I tried other modems, they, too, failed to answer incoming calls. Any idea as to what seems the problem.
Could you please post a copy of VoiceGuide's Debug Printout which captures the incoming call, this will allow us to see what is happening.
I did that already. Nothing. It is acting as if the ring voltage is not at a level where neither the modem nor VG can detect it. But this is not the case. Because when I replace the modem with another one from SmartLink, for example, it detects an incoming call just fine.
Sounds like that modem is broken...
