Rv_get Help
I'm using VG 5.2.3018
I'm using the Outdial_New.xml file to initiate dialing. I purposefully set the AnswerTimeout to very short for testing. Here are the contents of the file.
<OutDialEntry>
<PhoneNumber>9132270335</PhoneNumber>
<OnAnswer>C:\Program Files\VoiceGuide\Scripts\XT Monitoring System\xt.vgs</OnAnswer>
<LineSelection>5</LineSelection>
<CallRetries>0</CallRetries>
<AnswerTimeout>10</AnswerTimeout>
<OnNotConnected>C:\Program Files\VoiceGuide\testing.vbs</OnNotConnected>
</OutDialEntry>
Here are the contents of my VBS script (testing.vbs)
' set vg to the calling VoiceGuide object
CurrentNumber = vg.RvGet (5, "$RV_CALLEDNUMBER")
msgbox(CurrentNumber)
For some reason it's not getting the correct number returned. My message box is empty. What might be the problem? Any help is greatly appreciated!
Here is my log file
104900.32 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.xml
104900.32 0 dial callque insert tel:9132270335 scr:C:\Program Files\VoiceGuide\Scripts\XT Monitoring System\xt.vgs time:506021049 esc:none
104900.33 0 dial DialListParseInputXML no <PhoneNumber>
104900.33 0 Loaded 1 entries.
104901.33 5 dial [55,9132270335,506021049,0,2359,MoTuWeThFrSaSu,,5,,0,,C:\Program Files\VoiceGuide\Scripts\XT Monitoring System\xt.vgs,C:\Program Files\VoiceGuide\Scripts\XT Monitoring System\xt.vgs,none,10,0,5,C:\Program Files\VoiceGuide\testing.vbs,none]
104901.35 0 dial callque update id=55 next call time 0506021054
104901.35 0 dial callque DB update returned
104901.36 5 dial found entry: tel[9132270335] ann[] vgs[C:\Program Files\VoiceGuide\Scripts\XT Monitoring System\xt.vgs] am[C:\Program Files\VoiceGuide\Scripts\XT Monitoring System\xt.vgs]
104901.36 5 Dialing: 9132270335
104901.36 5 MakeCall => 66061
104901.38 5 timer set 10 EV_TIMEOUT_MAKECALL_NORESPONSE
104901.38 5 TapiCbTrigSet 66061 7002
104901.39 0 dial start any summary:|5:dial=0|6:idx=0|
104902.11 5 tapi Reply (LineEvReply) ok 66061 0
104902.11 5 TapiCbTrigClear
104902.16 5 linedevstate 2048 0 0
104902.18 5 callstate DIALTONE 66319 0 0
104902.19 5 callstate DIALING 66319 0 0
104902.19 5 callstate PROCEEDING 66319 0 0
104902.19 5 callinfo CALLEDID
104902.21 5 callinfo REASON
104902.21 5 Lev_CallerID [913-227-0318,,9132270335]
104902.21 5 rv add [DNIS]{9132270335}
104902.22 5 callinfo ORIGIN
104912.29 5 timer fired EV_TIMEOUT_MAKECALL_NORESPONSE
104912.29 5 ScriptEventCode 9020 iLineState=5200
104912.29 5 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE
104912.30 0 dial callque delete id=55
104912.30 5 AddRVns [OutDial_Result]{Uncontactable_NoAnswer}
104912.30 5 timer clear
104912.32 5 eng run vbscript [C:\Program Files\VoiceGuide\testing.vbs]
104912.36 5 dial no escalation info
104912.36 5 rv add [Hangup Time]{6/2/2005 10:49:12 AM}
104912.38 5 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE]
104912.38 5 RecSoundStop ok
104912.38 5 PlaySoundStop err=0
104912.39 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104912.41 5 Waiting for a call...
104912.41 5 fnHangupCall end
104912.46 5 cl RvGet $RV_CALLEDNUMBER
104912.46 5 rv replace start: [$RV_CALLEDNUMBER]
104912.47 5 rv ns none[OutDial_RetriesLeft]{0}[DNIS]{9132270335}[OutDial_Result]{Uncontactable_NoA
swer}[Hangup Time]{6/2/2005 10:49:12 AM}
104912.47 5 rv replace end: []
104912.49 5 linedevstate 2048 0 0
104912.50 5 callstate IDLE 66319 0 0
104912.50 5 WorkingMode@Idle=
104912.52 5 timer clear
104912.52 5 LineState(iLineId).iVgsIdx = 0
104912.54 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104912.54 5 tapi Reply (LineEvReply) ok 65738 0
104913.54 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
104913.54 5 ScriptEventCode 9008 iLineState=900
104913.54 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
104913.55 5 ReinitTelephony due to IDLE
104913.57 5 tapic lineDeallocateCall(MainCall:66319) 0
104913.72 5 lineOpen(5)=>
104913.72 5 Waiting for a call...
104913.74 5 LineHandle=66025
104913.74 5 timer set 10 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104914.43 0 dial start any summary:|5:rdy=0|6:idx=0|
104915.43 0 dial start any summary:|5:rdy=0|6:idx=0|
104916.43 0 dial start any summary:|5:rdy=0|6:idx=0|
104917.43 0 dial start any summary:|5:rdy=0|6:idx=0|
104918.44 0 dial start any summary:|5:rdy=0|6:idx=0|
104919.44 0 dial start any summary:|5:rdy=0|6:idx=0|
104920.44 0 dial start any summary:|5:rdy=0|6:idx=0|
104921.44 0 dial start any summary:|5:rdy=0|6:idx=0|
104922.44 0 dial start any summary:|5:rdy=0|6:idx=0|
104923.44 0 dial start any summary:|5:rdy=0|6:idx=0|
104924.44 0 dial start any summary:|5:rdy=0|6:idx=0|
104924.69 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104924.69 5 ScriptEventCode 9013 iLineState=900
$RV_CALLEDNUMBER is only set which the call is active - and trace shows testing.vbs was ran after outgoing call timed out...
Try using "$RV[DNIS]" or "RV[DNIS]"
