Return Var From Excel
Just a question about using a variable in excel.
I used the RV$[Module] to look for the numbers in an Excel file.
This all works well, and now I like to use that variable (Pinnumber) in my voiceguide module again.
How to use it in Voiceguide in for example an evualate module, cause It seems not to pass it as a number!
I trying to check it with an evualatemodule but it seems it won;t see it as a number at all?
Thank U.
Can you please post your script which shows what you are trying to do - also could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is happening on your system.
what I want is to use this variable (Pin5) in an evaluatemodule.
It doesn't check really, no matter what the pin5 variable is is always says true.
seems to me that it doesn't tranfer to voiceguide and makes it 0 .
so how to tranfer this variable to Voiceguide?
here the trace
55687 6 tapie linedevstate 2048 0 0
55703 6 tapie callstate OFFERING 65964 0 4
55703 6 tapie callinfo CALLEDID
55718 6 tapie callinfo ORIGIN
55718 6 tapie ring 0
55718 6 Start without answering the call
55718 6 CID at StartLoadedVgs []
55718 6 CID at RunModule% []
55718 6 [Welkom] Playing
55718 6 lineAnswer(65964) => 65930
56265 6 tapie callstate CONNECTED 65964,1,0
56265 6 WorkingModeTAPI=
56265 6 WorkingModeScript=BeforeAnswerRun
56312 6 tapi Reply 65930 0
56312 6 CID at RunModule% []
56312 6 [Welkom] Playing
56312 6 [Welkom] Playing (D:\gidstekst\Welkom\4_MAIN.WAV)
56328 6 PlaySoundStart ok [D:\gidstekst\Welkom\4_MAIN.WAV]
56328 6 RunModule PLAY end
58187 6 tapie monitordigits 50 2
58187 6 LsPlayMsg [2]
58234 6 PlaySoundStop ok
58234 6 CID at RunModule% []
58234 6 [Keuze] Evaluate $RV[Welkom] < 4
58234 6 RVreplace start: [$RV[Welkom] < 4]
58234 6 CID at RvProcessAndReplace []
58234 6 RVreplace end: [2 < 4]
58234 6 .Eval(2 < 4)
58250 6 Eval Expr result:[True]
58250 6 CID at RunModule% []
58250 6 [Check_01] Running VB Script...
58250 6 CID at RvProcessAndReplace []
58265 6 VBScript Run continuing...
58281 6 CID at RunModule% []
58281 6 [Check] Evaluate pin5 < 200
58281 6 .Eval(pin5 < 200)
58281 6 Eval Expr result:[True]
58296 6 CID at RunModule% []
58296 6 [Goed] Playing
58296 6 [Goed] Playing (D:\gidstekst\hoofdtekst\3_complex onderbrengen.wav)
58359 6 PlaySoundStart ok [D:\gidstekst\hoofdtekst\3_complex onderbrengen.wav]
58359 6 RunModule PLAY end
64390 6 tapie callstate DISCONNECTED 65964,0,0
64390 6 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
64437 6 PlaySoundStop ok
64437 6 Hanging up call...
64437 6 fnHangupCall end
64484 6 tapie linedevstate 2048 0 0
64484 6 tapie callstate IDLE 65964 0 0
64484 6 WorkingMode@Idle=
64484 6 tapi Reply 65947 0
65578 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
65578 6 Initialise telephony (due to IDLE)
65578 6 tapic lineDeallocateCall(MainCall:65964) 0
65718 6 Waiting for a call...
65718 6 hLine=65896
I assume that "pin5" was some variable used in the VB Script which was ran in the previous module ("[Check_01]"), correct?
If you want to return some Result Variables from a VB Script back to VoiceGuide you need create a "Result File" and save any returned result variables into that file... Please see the VoiceGuide Help file's section of "Run VB Script" module for more information on this...
