Database Return Code
I'm connecting to oracle 9i using ODBC; scripts can follow path from success or fail. my question is, is there any way to get the oracle database return value?
I need it to monitor why can a module fail, storage, constraints and so.
Thank you.
FM.
What type of errors/conditions are you trying to capture/intercept?
Could you please post a copy of VoiceGuide's Debug Printout which captures the query made to Oracle which results in this condition/error being returned, this will allow us to see what is going wrong.
You can enable the automatic saving of the logs to files in \log\ directory as well.
I mean general database return codes, an example is:
ORA-00001 unique constraint (string.string) violated
I know that i need to test the system against this kind of errors, but there is a very long list of events that can happen with oracle database and handling every condition is impossible, so i'm looking for a solution to this problem.
I think manually checking the log can be part of the solution because I need alerts in real time, kind of triggering an event when database error occurs.
Any idea?
FM
Could you please post a copy of VoiceGuide's Debug Printout which captures the query made to Oracle which results in a condition/error being returned that you want to intercept.
112740.64 7 db DBEngine.Error 1:23000: [Oracle][ODBC][Ora]ORA-00001: unique constraint (APP.PK_TEMP) violated
:ODBC.Database
This line has the information I need: ORA-00001
Complete log as attachment.
FM
VGLog.txt
Using the current version you should be able to trigger on the error number, which in this case is 3146
Try using this path:
on {3146} goto [play error message]
where play error message is your module that is to be ran when error occurs.
112740.59  7 ERROR 5.2.4000 DB Execute: 3146,ODBC--call failed.
112740.59  7 rv    lg add [Database Query 19_20_RowCount]{0}
:ODBC.Database
112740.64  7 db    DBEngine.Error 3146:ODBC--call failed.:DAO.Database
Also this should work:
on {ODBC--call failed.} goto [play error message]
If you update to the attached .exe you should be able to use paths like these as well:
on {23000} goto [play error message]
on {[Oracle][ODBC][Ora]ORA-00001: unique constraint (APP.PK_TEMP) violated} goto [play error message]
Which I think is the more specific error that you want to intercept...
VgMulti_5.2.4006.zip
Were you using the .exe supplied in our previous post?
Could you please post a copy of VoiceGuide's Debug Printout which captures the query made to Oracle.
