Call Transfere
Hello
Im using the "Transfere Call" module with "Dial and Conference" option, the senario is when VG dials the the number on other chanel, if it finds the the destination number is busy, it hangs up!!, but i want to take control so I want to try dialing another number, how can I control that?
I have VG 5.2.3b running on windows 2000 and D/41JCT-LS PCI dialogic card
Use a path :
on {busy} goto [newmoduletitle]
If you still experience problems when using that path please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going on.
You can enable the automatic saving of the logs to files in \log\ directory as well.
my script simply welcomes the caller, the caller presses DTMF 3, he will be taken to the transfere call module, the module dials the number on other channel, then the caller hears the busy tone which tells that the dialed number is busy, then vg hangs up.
the Transfere Call module has 3 pathes defined
on {success} goto [connected]
on {busy} goto [person busy]
on {noanswer} goto [no answer]
094207.00 5 linedevstate 2048 0 0
094207.02 5 callstate OFFERING 66101 0 4
094207.02 5 rv clear
094207.02 5 Answer the call at 5/16/2005 9:42:07 AM
094207.02 5 lineAnswer(66101) => 66118
094207.02 5 callinfo CALLEDID
094207.02 5 callinfo ORIGIN
094207.02 5 ring 0
094207.50 0 dial start any summary:|5:hc>0|6:idx=0|7:idx=0|8:idx=0|
094207.55 5 callstate CONNECTED 66101 1 0
094207.55 5 callstate CONNECTED 66101,1,0
094207.55 5 WorkingModeTAPI@Connected=
094207.55 5 WorkingModeScript@Connected=
094207.56 5 Inband detection not enabled
094207.56 5 StartLoadedVgs at 5/16/2005 9:42:07 AM, v5.2.3063
094207.56 5 AddRVns [scriptsPath]{C:\IslamToday\}
094207.56 5 AddRVns [scriptPath]{C:\IslamToday}
094207.56 5 rv add [$RV_STARTTIME]{5/16/2005 9:42:07 AM}
094207.56 5 rv add [$RV_DEVICEID]{5}
094207.56 5 rv add [$RV_CIDNAME]{}
094207.58 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
094207.58 5 rv add [$RV_CIDNUMBER]{}
094207.58 5 tapi Reply (LineEvReply) ok 66118 0
094207.58 5 timer clear
094207.58 5 [Welcome] Playing
094207.58 5 [Welcome] Playing (C:\IslamToday\islam sound\welcome.wav)
094207.58 5 play set playid=638312
094207.59 5 PlaySoundStart ok [C:\IslamToday\islam sound\welcome.wav]
094207.59 5 timer clear
094207.59 5 RunModule PLAY end
094207.59 5 wa(17294,63831200)
094207.59 5 callinfo MONITORMODES
094212.19 5 dtmf 1 (66101,49,2)
094212.19 5 ScriptEventCode 49 iLineState=1100
094212.19 5 LsPlayMsg 1
094212.23 5 PlaySoundStop err=0
094212.23 5 rv add [Welcome]{1}
094212.23 5 timer clear
094212.23 5 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
094212.61 5 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
094212.61 5 ScriptEventCode 9012 iLineState=1900
094212.61 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
094212.61 5 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
094212.61 5 [Dial Person] Dial and Conference to 0795034748 (Generate)
094212.61 0 Search for free lines in LineID range [5-8]
094212.61 5 dial busy: active call
094212.61 6 dial reserving [dxxxB1C2] as no list specified
094212.61 5 dial found free dev=2 (LineId=6)
094212.61 6 Calling 0795034748 (related LineId=5)
094212.61 5 MakeCallEx => 66135
094212.61 6 TapiCbTrigSet 66135 7003
094212.61 5 timer set 3600 EV_TIMEOUT_HANGUP
094212.63 6 timer set 3600 EV_TIMEOUT_HANGUP
094213.16 6 tapi Reply (LineEvReply) ok 66135 0
094213.16 6 TcTrig.lTrigType = TcTrig_MakeCallForConferenceFinished
094213.16 6 Setting conference to occur in 3 seconds (not waiting for PROCEEDING)
094213.16 6 timer set 3 EV_TIMEOUT_BRIDGEAFTERDIALING
094213.16 6 TapiCbTrigClear
094213.16 6 linedevstate 2048 0 0
094213.16 6 callstate DIALTONE 66510 0 0
094213.16 6 callstate DIALING 66510 0 0
094213.16 6 callstate PROCEEDING 66510 0 0
094213.16 6 callinfo CALLEDID
094213.17 6 callinfo REASON
094213.17 6 Lev_CallerID [0000,,0795034748]
094213.17 6 rv add [DNIS]{0795034748}
094213.17 6 callinfo ORIGIN
094213.52 0 dial start any summary:|5:hc>0|6:hc>0|7:idx=0|8:idx=0|
094216.34 6 timer fired EV_TIMEOUT_BRIDGEAFTERDIALING
094216.34 6 ScriptEventCode 9014 iLineState=1910
094216.34 6 LsXferWaitEndCall EV_TIMEOUT_BRIDGEAFTERDIALING
094216.34 5 AddRVns [Conf_DevName_1]{dxxxB1C1}
094216.34 5 AddRVns [Conf_LineId_1]{5}
094216.34 5 rv add [Conf_DevName_2]{dxxxB1C2}
094216.34 5 rv add [Conf_LineId_2]{6}
094216.34 6 AddRVns [Conf_DevName_1]{dxxxB1C1}
094216.34 6 AddRVns [Conf_LineId_1]{5}
094216.34 6 rv add [Conf_DevName_2]{dxxxB1C2}
094216.34 6 rv add [Conf_LineId_2]{6}
094216.34 6 DialogicScRoute dxxxB1C1<=>dxxxB1C2 call
094216.36 6 DialogicScRoute dxxxB1C1<=>dxxxB1C2 SC_FULLDUP:
094216.36 6 Conferenced to 5 (dxxxB1C2) at 9:42:16 AM
094216.36 5 [Dial Person] Conferenced to 6 (dxxxB1C1) at 9:42:16 AM
094217.95 6 callstate CONNECTED 66510 1 0
094217.95 6 callstate CONNECTED 66510,1,0
094217.95 6 WorkingModeTAPI@Connected=
094217.95 6 WorkingModeScript@Connected=
094217.95 6 2nd leg of call recieved CONNECTED event
094233.30 6 callstate DISCONNECTED 66510 0 0
094233.30 6 ScriptEventCode 9250 iLineState=1910
094233.30 6 LsXferWaitEndCall EV_REMOTEPARTY_DISCONNECT
094233.30 6 rv add [Hangup Time]{5/16/2005 9:42:33 AM}
094233.30 6 Hanging up call...
094233.30 6 DialogicScUnroute dxxxB1C2</>dxxxB1C1 MATCH_ call
094233.31 6 DialogicScUnroute dxxxB1C2</>dxxxB1C1 MATCH_
094233.31 5 rv add [Hangup Time]{5/16/2005 9:42:33 AM}
094233.31 5 Hanging up call... [2nd leg]
094233.31 5 RecSoundStop ok
094233.31 5 PlaySoundStop err=0
094233.31 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
094233.31 5 fnHangupCall end
094233.31 6 RecSoundStop ok
094233.31 6 PlaySoundStop err=0
094233.31 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
094233.41 6 Waiting for a call...
094233.41 6 fnHangupCall end
094233.41 5 linedevstate 2048 0 0
094233.41 5 callstate IDLE 66101 0 0
094233.41 5 WorkingMode@Idle=
094233.41 5 timer clear
094233.41 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
094233.41 5 tapi Reply (LineEvReply) ok 65998 0
094233.42 6 linedevstate 2048 0 0
094233.42 6 callstate IDLE 66510 0 0
094233.42 6 WorkingMode@Idle=
094233.42 6 timer clear
094233.42 6 LineState(iLineId).iVgsIdx = 0
094233.42 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
094233.42 6 tapi Reply (LineEvReply) ok 66015 0
094234.50 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
094234.50 5 ScriptEventCode 9008 iLineState=900
094234.50 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
094234.50 5 ReinitTelephony due to IDLE
094234.50 5 tapic lineDeallocateCall(MainCall:66101) 0
094234.55 5 lineOpen(5)=>
094234.55 5 Waiting for a call...
094234.55 5 LineHandle=66203
094234.55 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
094234.55 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
094234.56 6 ScriptEventCode 9008 iLineState=900
094234.56 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
094234.56 6 ReinitTelephony due to IDLE
094234.56 0 dial start any summary:|5:rdy=0|6:hc>0|7:idx=0|8:idx=0|
094234.56 6 tapic lineDeallocateCall(MainCall:66510) 0
094234.63 6 lineOpen(6)=>
094234.63 6 Waiting for a call...
094234.63 6 LineHandle=65777
094234.63 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
094235.56 0 dial start any summary:|5:rdy=0|6:rdy=0|7:idx=0|8:idx=0|
094237.91 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
094237.91 5 ScriptEventCode 9013 iLineState=900
094237.91 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
094237.91 6 ScriptEventCode 9013 iLineState=900
094238.56 0 dial start any summary:|5:dok=0|6:idx=0|7:idx=0|8:idx=0|
Please update your system to use "VoiceGuide for Dialogic".
See our WWW downloads page.
I have downloaded and implemented "VoiceGuide for Dialogic" as described
now im having the following inqueries
-Now VG plays the wave files in a very slow & unclear manner, these wave files I used to play normally before upgrading to "VoiceGuide for Dialogic"
-Now the "transfere Call" module have changed, and many options were added to this module, buut the attached help file remained the same, how can I get the help file which is crossponding to this update.
-What is the best composition of these options is best to chose from those newly added options to apply in my case, the transfre and bridging options?
-Now it shows my version of VG is 6.0.2000, I dont need to install V5.2.4 as long as im using the "VoiceGuide for Dialogic" ?
VoiceGuide for Dialogic uses 8kHz sound files, whereas the TAPI version used 11kHz with Dialogic cards... This is mentioned in the installation notes for "VoiceGuide for Dialogic".
The "monitored" transfers basically just wait until a human or answering machine is heard before completing the call.
Some more info on paths can be found here: http://www.voiceguide.com/vghelp/html/modXfer.htm
I'd try using "Dial and Conference - Blind" option first.
No. Again, installation instructions are listed in the readme.txt file that comes with "VG for Dialogic"
Is there away that i can prevent the caller from hearing the tones which come from the dialed number when I'm transfering the call? like i don't want here to know if the dialed number is busy or ringing back, I want to take action without him knowing? I tried using the onhold sound file, but did not get results.
In the "Transfere Call" module the "Dial and Conference" Tap, the "Bridge calls to gother when :" option does not get saved, it returns to the default value when ever you reselect the script, or restart VG.
Do i have to configure all the tones' frequencies in the "ConfigLine.xml" of my VG for dialgic? this edition does not recognize the TSP any more? as vg does not recognize it when its ringin back, so the path "on {noanswer} goto [no answer]" is never being taken.
what is the "Dialout and Conference - Announced" ?
The original caller should be placed on hold while the transfer is being made, so they will not hear what is happening on the line. If they are not placed on hold this means that the hookflash is incorrect length. see: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm
Please update your system with attached .EXE, overwriting existing file. This should fix the problem which you have found. Please let us know if you come across any other issues.
Yes.
No. TSP is only for the version which uses TAPI/Wave drivers.
Please see: http://www.voiceguide.com/vghelp/html/modXfer.htm
VgGsd_5.2.3513.zip
im not using any PBX, im using the telephone network directly, so hookflash is a service I have to add to my line? or its there by default?
The link you provided describes how to set the hookflash for PBXs and VG TAPI version, also through TSP, but TSP is ignored when you have VG for dialogic, so where do I have to set this hookflash value?
Please, I would appreciate it, if you provide all the related materials to my problem and situation, all updates for VG and all articles regarding line configurations and settings for "VG for dialogic" to get the "dial and conference" working probably
thanx for your support.
You need to speak with your phone company to see if they support this service.
Config.xml. Look for the "Flash Time" setting,
No need to set hookflash to use Dial and Conference - for Dial and conference a call is made on another line. see: http://www.voiceguide.com/vghelp/html/modXfer.htm
I know the call is made on another line, but this was you suggestion to solve my problem, but seems u were refering to normal call transfere!
Anyway, again my problem is that when im using "dial and conference" the original caller hears the tones coming from the dialed number, so he hears if the dialed number is ringing back or busy, I dont want the original caller hears that, I want to only connect the tow channels if the the dialed number was picked up, if not i waould take other action like dialing another number, is it possible???
That's how standard "Dial and Conference" works. Immediately after dialing the two lines are connected together.
You will need to use "VoiceGuide for Dialogic" and select the "Dial and Conference Monitored" or "Dial and Conference Announced" options.
Thanks for the hints
Now my original caller does not hear what's going on on the other channel, using the "Dialout and Conference - Monitored"
Now im having this issues
- The caller does not hear the On-Hold wave file during dialing on the other line.
- When the the number which is being dialed on the other line is busy, VG does not take {busy} path, it simply waits for 30 seconds (the value in the vg.ini) then it hangs up, I need VG to take the busy path immediately when it detectes a busy line.
Attahced is the Log file
Thanx for the help
log.txt
Please update to attached .exe - this wikll fix that bug.
Have you modified the ConfigLine.xml file with the correct value of frequency/cadence of your busy tone?
Please post your current ConfigLine.xml file and the recording of the busy tone.
VgMulti_6.0.2002.zip
The problem remained, still the On-Hold file is not being played while dialing on other line.
I have analyzed my tones and updated the ConfigLine.xml according to that, attached "vg01.rar" which contains:
the busy tone, the disconnection tone, the ring-back tone, the ConfigLine.xml , and the Log file.
in the log file, it did not take the {busy} path when the destination mumber is busy, and also it does not connect the channels of i picked up!
Note: I hear the dialed DTMFs on the origianl line!
vg01.rar
OK, attached .ZIP one should play the the On-Hold file correctly...
Trace shows that the outgoing leg of the call did detect a busy tone about 18 seconds after the number was started to be dialed, and that's why the transfer was abandoned:
161713.53   2 state dialing 0795034748   (for conference with dxxxB1C1)
161731.69   2       LsXferWaitOutcomeOutgoingCall_DialingSide : 133,[TDX_CALLP],7,0,0,CR_BUSY,,
VgMulti_6.0.2003.zip
yeah, so whats the solution? why it did not detect the busy tone for 18 seconds?
did you analyze the tones i attached in my last post?
Are you asking why did it take up to 18 seconds to detect the busy tone?
18 seconds is not unusual - add up the time it takes to dial and time before tone starts playing and the then how long the busy cadence is and how many cadences the system is configured to wait for...
For instant info on whether a number is busy you should use T1/E1 ISDN lines.
again, what is the solution? my script is not geting completed, the {busy} path is not being taken?
I tried ur last update file, now it does not take 18 seconds to detect the busy tone, VG hanfs up immediately when it finds out that the dialed number is busy, my {busy} path is not being taken! here is the log file...
log1.txt
I applied the suggested patch, here are the logs
free_number.txt : this is when VG dialed on a free number, it connetced the 2 channles after the line was picked up, but the conversation lasted for FEW seconds, then vg hanged up.
busy_number.txt :this is when VG dialed on a busy number, it hanged the second leg up, and put the origianl call on-hold for SO long, then it hanged up with out taking any path.
vg02.rar
Please ensure that in the Call Transfer module, tab "Dial and Conference" the option "Bridge calls together when" is set to: "Voice or Answering Machine is detected. Listen for disconnect tones. (DX_PAMDOPTEN)".
Also please update your system with attached .exe
Continue to use the "Monitored Dial and Connect" setting at this stage.
We've replicated the exact scenario that you are doing and it all works on our test system with this version.
Lets get this working on your system now and from there we can move on to other scenarios.
VgMulti_6.0.2014.zip
Im working with the exact settings you've mentioned, now with the new update, VG can detect the busy tone and react correctly, it also bridges the 2 channels when the dialed number is picked up.
if you want us to move forward, now the path {noanswer} is not recognized, VG just hangs up both lines if no one picked up the dialed number.
Thanx for the good support.
Keeping everything else the same please update your system with attached .exe and then test all the scenarios.
If any problems arise please post .ZIPed up trace.
VgMulti_6.0.2027.zip
Hello
I tried the last update with the same previous settings, but the {no answer} path was not taken, more worse, VG has bridged the 2 channles after few "ring backs" even the option "Voice or Answering Machine is detected. Listen for disconnect tones. (DX_PAMDOPTEN)" is set
attached is a log file for two consecutive tries which behaved the same.
log.zip
Trace shows that Dialogic card signaled the outgoing call was answered as the ringbacks seemed to have gone away.
When no ringbacks are heard anymore the Dialogic card assumes that the call has been answered.
Ringback tone was heard at 120849.42 :
120849.42 2 tw DialogicEvent 134,TDX_CST,200,0,0,DE_TONEON,TID_RNGBK2,
and looks like it was not heard again for 14 seconds, so the Dialoigc decided call must have been answered...
120903.41 2 tw DialogicEvent 133,TDX_CALLP,10,1,0,TDX_CALLP,CR_CNCT,CON_CAD
I think you will find the same results with wither version of VG as what you are seeing here is determined by the tone definitions in LinesConfig.xml - you may want to experiment with different settings for ringback tone definitions...
You really should look at using T1/E1 ISDN lines - only ISDN telephone lines will give you immediate notification when the remote side has picked up a call. When using analog lines you rely on tone analysis to determine that and this may be difficult to set up if you intend to be able to call out to a variety of different numbers on different networks
Please refere to my post May 23 2005, 11:34 PM
find attached the zip file, do me a favor and analyse the tones for me please.
I raised this issue before in other post, the guys replied that they believe that as long as all the lines which are connected to my dialogic card are from the same compamy, then i donty have to worry about what numbers im calling weather they are from the same company or any different company, elaborate on this please.
To analyse the tone frequencies:
Use Audacity http://audacity.sourceforge.net/ to find out the frequencies and cadence.
Open the sound file in Audacity, then highlight the section when tone is playing and then goto "View"->"Plot Spectrum" menu.
Audacity also displays the interval lengths of highlighed sections, so you just need to highlight the entire section when tone is ON and check the interval, and hightlight entire section whern tone is OFF and chect that interval.
For allowed variances (frequency and time) it's usually appropriate to use about 10% of the value for variance.
Some phone companies regenerate the ringback and some do not.
Are you finding that a different ringback is played depending on what number is called?
I did analyse my tones before, i wanted to take the anylasis from your side as i believe it would be more accurate.
all of them generate ring backs, but I don't know if different networks play different frequencies, but seems this is what you mean when u said its difficult to setup analog lines to call different companies. isn't it?
Anyhow, to slove my problem, im now testing with the lines which I have posted their tones vg01.rar above, i wont be using any other lines to avoid the confusing, so would you please suggest the frequency values, I want all the available pathes to be taken.
The ringback tone recorded in vg01.rar is:
Freq1: 380Hz
Freq2: 460Hz
On : 1200ms
Off: 4800ms
