Calls And Hangs Up
Hi
I'm trying to use the Phone Nomber Loader to call a number and play a wav file.
It calls out and the other phone rings one time and then stops ringing.
What am i doing wrong
TIA_Yona
**************** This is the log from the loader
130601.50 0 init saving dialer settings
130601.52 0 db database opened
130601.52 0 info Do Not Call List Loading...
130601.52 0 dnc Do No Call List file not specified
130601.52 0 info Do Not Call List Load Finished 0
130601.52 0 load text box numbers start
130601.52 0 info Text Box Numbers Loading...
130601.55 0 load text box numbers end
130601.55 0 db database closed
130601.56 0 info Finished queued:1 rejected:0
130601.70 0 info file : 0 explicittly listed loaded OK
130601.70 0 info file : 0 explicittly listed rejected (Do Not Call List)
130601.70 0 info file : 0 explicittly listed rejected (Other)
130601.70 0 info file : 0 expanded from template loaded OK
130601.70 0 info file : 0 expanded from template rejected (Do Not Call List)
130601.70 0 info file : 0 expanded from template rejected (Other)
130601.70 0 info text : 0 explicittly listed loaded OK
130601.70 0 info text : 0 explicittly listed rejected (Do Not Call List)
130601.70 0 info text : 0 explicittly listed rejected (Other)
130601.70 0 info text : 1 expanded from template loaded OK
130601.70 0 info text : 0 expanded from template rejected (Do Not Call List)
130601.70 0 info text : 0 expanded from template rejected (Other)
130601.70 0 info TOTAL : 1 loaded OK
130601.70 0 info TOTAL : 0 rejected
**************** This is the log from the VG
130603.19 8 dial [1,1,9177092401,505131305,1,2359,MoTuWeThFrSaSu,,dxxxB1C4,,1,C:\vgwav\simen.wav,C:\vgwav\Line.wav,C:\vgwav\message.wav,none,120,0,120,,none]
130603.22 8 rv clear
130603.22 8 dial callque update id=1 next call time 0505131506
130603.22 8 dial callque DB update returned
130603.22 8 amchk set AMdet=False in DialOnLine
130603.22 8 dial found entry: tel[1,9177092401] ann[C:\vgwav\simen.wav] vgs[C:\vgwav\Line.wav] am[C:\vgwav\message.wav] LineSelection:[,dxxxB1C4,]
130603.22 8 Dialing: 1,9177092401
130603.22 8 MakeCall => 66191
130603.22 8 script interpretor: VgMulti v5.2.4000
130603.22 8 timer set 120 EV_TIMEOUT_MAKECALL_NORESPONSE
130603.22 8 TapiCbTrigSet 66191 7002
130603.22 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:dial=0|
130603.86 8 tapi Reply (LineEvReply) ok 66191 0
130603.86 8 TapiCbTrigClear
130603.86 8 linedevstate 2048 0 0
130603.86 8 callstate DIALTONE 66106 0 0
130603.86 8 callstate DIALING 66106 0 0
130603.86 8 callstate PROCEEDING 66106 0 0
130603.86 8 callinfo CALLEDID
130603.86 8 callinfo REASON
130603.86 8 Lev_CallerID [0000,,1,9177092401]
130603.86 8 rv lg add [DNIS]{1,9177092401}
130603.88 8 callinfo ORIGIN
130604.23 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:hc>0|
130616.42 8 callstate BUSY 66106 4 0
130616.42 0 dial callque delete id=1
130616.42 8 rv ns add [OutDial_Result]{Uncontactable_Busy}
130616.42 8 timer clear
130616.44 8 dial no escalation info
130616.44 8 rv lg add [Hangup Time]{5/13/2005 1:06:16 PM}
130616.44 8 Hanging up call... [busy]
130616.44 8 RecSoundStop ok
130616.44 8 PlaySoundStop err=0
130616.44 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
130616.44 8 Waiting for a call...
130616.44 8 fnHangupCall end
130616.47 8 linedevstate 2048 0 0
130616.47 8 callstate IDLE 66106 0 0
130616.47 8 WorkingMode@Idle=
130616.47 8 timer clear
130616.47 8 LineState(iLineId).iVgsIdx = 0
130616.47 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
130616.47 8 tapi Reply (LineEvReply) ok 66157 0
130617.56 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
130617.56 8 ScriptEventCode 9008 iLineState=900
130617.56 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
130617.56 8 ReinitTelephony due to IDLE
130617.56 8 tapic lineDeallocateCall(MainCall:66106) 0
130617.64 8 lineOpen(8)=>
130617.64 8 Waiting for a call...
130617.64 8 LineHandle=66413
130617.64 8 amchk set AMdet=False in Reinit@idle
130617.64 8 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
130618.45 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:rdy=0|
130620.92 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
130620.92 8 ScriptEventCode 9013 iLineState=900
130621.50 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:idx=0|
130626.44 0 sys cleanup Start
130626.44 0 sys cleanup End
130935.19 6 linedevstate 2048 0 0
130935.19 6 callstate OFFERING 66038 0 4
130935.20 6 callinfo CALLEDID
130935.20 6 callinfo ORIGIN
130935.20 6 ring 0
130935.70 0 dial start any summary:|5:idx=0|6:hc>0|7:idx=0|8:idx=0|
130941.20 6 ring 2
other incoming calls
As you can see from the trace the telephony device you are using thinks that is has heard a busy tone after dialing out, it informs VG of that and VG hangs up.
To fix this change the configuration of the Busy tone so that it will not mistake a ringback for a busy.
the telephone device I'm using is a Dialogic D/41EPCI VG-PRO 5.2.400
How would I set the proper bussy signal
TIA_Yona
