Inband Signalling
Hi
I am having trouble configuring a hicom 150e, D/4PCI and VoiceGuide Enterprise edition to work properly with inband signalling.
I have included the my definition file text:
;1---------External Party calls over analog trunk [needed incase the called number is not propogated]
;format is ***[type of call][calling party]*[info]
;the inband called RV is not necessary but I have included it so it is initalised and won't cause errors later
Pattern=[*][*][*]??????[*]?
RV=Inband_TOC,4,1,Inband_Calling,5,5,Inband_Called,10,0,Inband_Info,11,1
;2---------External party calls over ISDN [most likely scenario]
;format is ***[type of call][calling party][called party]*[info]
Pattern=[*][*][*]???????????[*]?
RV=Inband_TOC,4,1,Inband_Calling,5,5,Inband_Called,10,5,Inband_Info,17,1
I have got it working but all calls are thought of as external party direct call to Voice Mail, so I think the called number is not sent. I am trying to write a switchbard script that would allow a number of simultaneous IVR campaigns for example:
179 and 180 are external extensions, that are called by the punters.
I set up a Hunt group with 300-307 as members, which are also the 8 lines going to my dialogic and system.
179 and 180 are forwarded to this hunt group.
Voiceguide runs this 'switchboard' script which then identifies 179 or 180 as the called extension and transfers to the relevant script
I have 'inherited' the job of configuringthe PBX. I can set up phones etc but I am not much more than an amateur. Would you be able to provide me with the right definition file, and possibly provide pointers on what I need to do to the PBX?
Could you please post a copy of VoiceGuide's Debug Printout which captures the start of the different types of calls.
This will allow us to see what Inband Signaling messages the PBX is sending depending on what type of call arrives.
You can enable the automatic saving of the logs to files in \log\ directory as well.
The following is the log output when I call externally.
100316.70 7 linedevstate 2048 0 0
100316.70 7 callstate OFFERING 66317 0 4
100316.70 7 rv clear
100316.70 7 Answer the call at 16/05/2005 10:03:16 AM
100316.71 7 lineAnswer(66317) => 65768
100316.71 7 callinfo CALLEDID
100316.71 7 callinfo ORIGIN
100316.71 7 ring 0
100317.25 7 callstate CONNECTED 66317 1 0
100317.25 7 callstate CONNECTED 66317,1,0
100317.25 7 WorkingModeTAPI@Connected=
100317.25 7 WorkingModeScript@Connected=
100317.29 7 Inband detection start (2 patterns loaded)
100317.29 7 timer set 5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100317.29 7 tapi Reply (LineEvReply) ok 65768 0
100317.29 7 callinfo MONITORMODES
100317.38 7 dtmf * (66317,42,2)
100317.38 7 ScriptEventCode 42 iLineState=4100
100317.38 7 LsIndialSignalCapture *
100317.38 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100317.57 7 dtmf * (66317,42,2)
100317.57 7 ScriptEventCode 42 iLineState=4100
100317.57 7 LsIndialSignalCapture * *
100317.57 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100317.64 0 dial start any summary:|5:dok=0|6:dok=0|7:hc>0|8:dok=0|9:dok=0|10:dok=0|11:dok=0|12:dok=0|
100317.75 7 dtmf 2 (66317,50,2)
100317.75 7 ScriptEventCode 50 iLineState=4100
100317.75 7 LsIndialSignalCapture 2 **
100317.75 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100317.93 7 dtmf 0 (66317,48,2)
100317.93 7 ScriptEventCode 48 iLineState=4100
100317.93 7 LsIndialSignalCapture 0 **2
100317.93 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100318.13 7 dtmf 2 (66317,50,2)
100318.13 7 ScriptEventCode 50 iLineState=4100
100318.13 7 LsIndialSignalCapture 2 **20
100318.13 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100318.32 7 dtmf 2 (66317,50,2)
100318.32 7 ScriptEventCode 50 iLineState=4100
100318.32 7 LsIndialSignalCapture 2 **202
100318.32 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100318.51 7 dtmf 2 (66317,50,2)
100318.52 7 ScriptEventCode 50 iLineState=4100
100318.52 7 LsIndialSignalCapture 2 **2022
100318.52 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100318.69 7 dtmf 2 (66317,50,2)
100318.70 7 ScriptEventCode 50 iLineState=4100
100318.70 7 LsIndialSignalCapture 2 **20222
100318.70 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100318.89 7 dtmf * (66317,42,2)
100318.89 7 ScriptEventCode 42 iLineState=4100
100318.89 7 LsIndialSignalCapture * **202222
100318.89 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100319.08 7 dtmf 4 (66317,52,2)
100319.08 7 ScriptEventCode 52 iLineState=4100
100319.08 7 LsIndialSignalCapture 4 **202222*
100319.08 7 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100319.00 7 timer fired EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100319.00 7 ScriptEventCode 9011 iLineState=4100
100319.00 7 LsIndialSignalCapture EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT **202222*4
100319.00 7 Inband **202222*4 not matched by any patterns
100319.00 7 StartLoadedVgs at 16/05/2005 10:03:19 AM, v5.2.3063
100319.00 7 AddRVns [scriptsPath]{C:\icontact\SWITCHBOARD\VoiceGuideScript\}
100320.01 7 AddRVns [scriptPath]{C:\icontact\SWITCHBOARD\VoiceGuideScript}
100320.01 7 rv add [$RV_STARTTIME]{16/05/2005 10:03:19 AM}
100320.01 7 rv add [$RV_DEVICEID]{7}
100320.01 7 rv add [$RV_CIDNAME]{}
100320.01 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
100320.02 7 rv add [$RV_CIDNUMBER]{}
100320.03 7 timer clear
100320.03 7 [vbsGlobals] Running VB Script...
100320.03 7 rv replace start: [dim vg
dim TOC
dim Calling
dim Called
TOC="$RV[inband_TOC]"
msgbox("TOC is:" & TOC)
Calling="$RV[inband_Calling]"
msgbox("Calling is:" & Calling)
Called="$RV[inband_Called]"
msgbox("Called is:" & Called)
set vg=nothing
100320.04 7 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\icontact\SWITCHBOARD\VoiceGuideScript\}[scriptPath]{C:\icontact\SWITCHBOARD\VoiceGuideScript}[$RV_STARTTIME]{16/05/2005 10:03:19 AM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
100320.04 7 eng run vbs [wscript "C:\Program Files\VoiceGuide\data\vbs_7_1.vbs" //I] copy of script in: vbs_7_1.vbs
100320.06 7 Run Script waiting. iRunWait=1 (shellid=1776, process=1340)
100320.06 7 timer set 1 EV_TIMEOUT_CHECKONSTATE
100321.06 7 timer fired EV_TIMEOUT_CHECKONSTATE
100321.06 7 ScriptEventCode 9007 iLineState=1501
100321.06 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100321.06 7 task still running (shellid=1776, process=1340)
100321.07 7 timer set 1 EV_TIMEOUT_CHECKONSTATE
100322.13 7 timer fired EV_TIMEOUT_CHECKONSTATE
100322.13 7 ScriptEventCode 9007 iLineState=1501
100322.13 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100322.13 7 task still running (shellid=1776, process=1340)
100322.13 7 timer set 1 EV_TIMEOUT_CHECKONSTATE
100323.16 7 timer fired EV_TIMEOUT_CHECKONSTATE
100323.17 7 ScriptEventCode 9007 iLineState=1501
100323.17 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100323.17 7 task still running (shellid=1776, process=1340)
100323.17 7 timer set 1 EV_TIMEOUT_CHECKONSTATE
100324.18 7 timer fired EV_TIMEOUT_CHECKONSTATE
100324.18 7 ScriptEventCode 9007 iLineState=1501
100324.18 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100324.18 7 task completed (shellid=1776, process=1340) vgm=1, iRunWait=1, iRunWait_ExeResult_NextVgm=0
100324.20 7 No information returned from program to VG (no VGRUNRESULT_7.TXT or SHLRESLT.TXT)
100324.20 7 rv add [Hangup Time]{16/05/2005 10:03:24 AM}
100324.20 7 Hanging up call... [WaitTillFinished - next module not specified]
100324.20 7 RecSoundStop ok
100324.20 7 PlaySoundStop err=0
100324.20 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
100324.20 7 fnHangupCall end
100324.24 7 linedevstate 2048 0 0
100324.24 7 callstate IDLE 66317 0 0
100324.24 7 WorkingMode@Idle=
100324.25 7 timer clear
100324.25 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
100324.27 7 tapi Reply (LineEvReply) ok 65884 0
100325.21 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
100325.21 7 ScriptEventCode 9008 iLineState=900
100325.21 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
100325.21 7 ReinitTelephony due to IDLE
100325.21 7 tapic lineDeallocateCall(MainCall:66317) 0
100325.39 7 lineOpen(7)=>
100325.39 7 Waiting for a call...
100325.39 7 LineHandle=65979
100325.39 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
100325.66 0 dial start any summary:|5:dok=0|6:dok=0|7:rdy=0|8:dok=0|9:dok=0|10:dok=0|11:dok=0|12:dok=0|
100328.40 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
100328.41 7 ScriptEventCode 9013 iLineState=900
100328.66 0 dial start any summary:|5:dok=0|6:dok=0|7:dok=0|8:dok=0|9:dok=0|10:dok=0|11:dok=0|12:dok=0|
And the following is an internal call to the same extension. So in the previous example I dial xx xxxx x 179 and in this example I dial 179. This number is then forwarded to a huntgoup that contains the 8 lines that go to the dialogic, and then to voiceguide.
100452.15 6 linedevstate 2048 0 0
100452.16 6 callstate OFFERING 66324 0 4
100452.16 6 rv clear
100452.16 6 Answer the call at 16/05/2005 10:04:52 AM
100452.18 6 lineAnswer(66324) => 65925
100452.18 6 callinfo CALLEDID
100452.19 6 callinfo ORIGIN
100452.19 6 ring 0
100452.72 6 callstate CONNECTED 66324 1 0
100452.72 6 callstate CONNECTED 66324,1,0
100452.72 6 WorkingModeTAPI@Connected=
100452.72 6 WorkingModeScript@Connected=
100452.76 6 Inband detection start (2 patterns loaded)
100452.76 6 timer set 5 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100452.76 6 tapi Reply (LineEvReply) ok 65925 0
100452.78 6 callinfo MONITORMODES
100452.78 0 dial start any summary:|5:dok=0|6:hc>0|7:dok=0|8:dok=0|9:dok=0|10:dok=0|11:dok=0|12:dok=0|
100452.88 6 dtmf * (66324,42,2)
100452.88 6 ScriptEventCode 42 iLineState=4100
100452.88 6 LsIndialSignalCapture *
100452.89 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100453.06 6 dtmf * (66324,42,2)
100453.06 6 ScriptEventCode 42 iLineState=4100
100453.06 6 LsIndialSignalCapture * *
100453.07 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100453.25 6 dtmf 1 (66324,49,2)
100453.25 6 ScriptEventCode 49 iLineState=4100
100453.25 6 LsIndialSignalCapture 1 **
100453.26 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100453.44 6 dtmf * (66324,42,2)
100453.44 6 ScriptEventCode 42 iLineState=4100
100453.45 6 LsIndialSignalCapture * **1
100453.45 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100453.63 6 dtmf * (66324,42,2)
100453.64 6 ScriptEventCode 42 iLineState=4100
100453.64 6 LsIndialSignalCapture * **1*
100453.64 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100453.81 6 dtmf 1 (66324,49,2)
100453.82 6 ScriptEventCode 49 iLineState=4100
100453.82 6 LsIndialSignalCapture 1 **1**
100453.82 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100454.01 6 dtmf 1 (66324,49,2)
100454.01 6 ScriptEventCode 49 iLineState=4100
100454.01 6 LsIndialSignalCapture 1 **1**1
100454.01 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100454.20 6 dtmf 8 (66324,56,2)
100454.20 6 ScriptEventCode 56 iLineState=4100
100454.20 6 LsIndialSignalCapture 8 **1**11
100454.20 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100454.40 6 dtmf * (66324,42,2)
100454.40 6 ScriptEventCode 42 iLineState=4100
100454.41 6 LsIndialSignalCapture * **1**118
100454.41 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100454.58 6 dtmf 1 (66324,49,2)
100454.58 6 ScriptEventCode 49 iLineState=4100
100454.58 6 LsIndialSignalCapture 1 **1**118*
100454.59 6 timer set 1 EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100455.57 6 timer fired EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT
100455.57 6 ScriptEventCode 9011 iLineState=4100
100455.57 6 LsIndialSignalCapture EV_TIMEOUT_INBANDSIGNAL_INTERDIGIT **1**118*1
100455.59 6 Inband **1**118*1 not matched by any patterns
100455.59 6 StartLoadedVgs at 16/05/2005 10:04:55 AM, v5.2.3063
100455.59 6 AddRVns [scriptsPath]{C:\icontact\SWITCHBOARD\VoiceGuideScript\}
100455.59 6 AddRVns [scriptPath]{C:\icontact\SWITCHBOARD\VoiceGuideScript}
100455.59 6 rv add [$RV_STARTTIME]{16/05/2005 10:04:55 AM}
100455.59 6 rv add [$RV_DEVICEID]{6}
100455.59 6 rv add [$RV_CIDNAME]{}
100455.59 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
100455.59 6 rv add [$RV_CIDNUMBER]{}
100455.61 6 timer clear
100455.61 6 [vbsGlobals] Running VB Script...
100455.61 6 rv replace start: [dim vg
dim TOC
dim Calling
dim Called
set vg=nothing
100455.61 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\icontact\SWITCHBOARD\VoiceGuideScript\}[scriptPath]{C:\icontact\SWITCHBOARD\VoiceGuideScript}[$RV_STARTTIME]{16/05/2005 10:04:55 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
100455.63 6 eng run vbs [wscript "C:\Program Files\VoiceGuide\data\vbs_6_1.vbs" //I] copy of script in: vbs_6_1.vbs
100455.64 6 Run Script waiting. iRunWait=1 (shellid=1776, process=1340)
100455.64 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
100456.64 6 timer fired EV_TIMEOUT_CHECKONSTATE
100456.64 6 ScriptEventCode 9007 iLineState=1501
100456.64 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100456.64 6 task still running (shellid=1776, process=1340)
100456.66 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
100457.66 6 timer fired EV_TIMEOUT_CHECKONSTATE
100457.66 6 ScriptEventCode 9007 iLineState=1501
100457.66 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100457.67 6 task still running (shellid=1776, process=1340)
100457.67 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
100458.78 6 timer fired EV_TIMEOUT_CHECKONSTATE
100458.78 6 ScriptEventCode 9007 iLineState=1501
100458.78 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100458.78 6 task still running (shellid=1776, process=1340)
100458.79 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
100459.79 6 timer fired EV_TIMEOUT_CHECKONSTATE
100459.79 6 ScriptEventCode 9007 iLineState=1501
100459.79 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
100459.79 6 task completed (shellid=1776, process=1340) vgm=1, iRunWait=1, iRunWait_ExeResult_NextVgm=0
100459.80 6 No information returned from program to VG (no VGRUNRESULT_6.TXT or SHLRESLT.TXT)
100459.80 6 rv add [Hangup Time]{16/05/2005 10:04:59 AM}
100459.80 6 Hanging up call... [WaitTillFinished - next module not specified]
100459.80 6 RecSoundStop ok
100459.81 6 PlaySoundStop err=0
100459.81 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
100459.81 6 fnHangupCall end
100459.85 6 linedevstate 2048 0 0
100459.85 6 callstate IDLE 66324 0 0
100459.86 6 WorkingMode@Idle=
100459.86 6 timer clear
100459.86 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
100459.87 6 tapi Reply (LineEvReply) ok 65839 0
100500.81 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
100500.81 6 ScriptEventCode 9008 iLineState=900
100500.81 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
100500.81 6 ReinitTelephony due to IDLE
100500.82 6 tapic lineDeallocateCall(MainCall:66324) 0
100500.99 6 lineOpen(6)=>
100500.99 6 Waiting for a call...
100501.00 6 LineHandle=65663
100501.00 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
100501.00 0 dial start any summary:|5:dok=0|6:rdy=0|7:dok=0|8:dok=0|9:dok=0|10:dok=0|11:dok=0|12:dok=0|
100504.01 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
100504.01 6 ScriptEventCode 9013 iLineState=900
100504.02 0 dial start any summary:|5:dok=0|6:dok=0|7:dok=0|8:dok=0|9:dok=0|10:dok=0|11:dok=0|12:dok=0|
In both instances, the calling number is present according to the logs but not present in the RV parameters. I have replaced my signalling config file with the examples from this website ie:
Pattern=***??????*[1-4]
Pattern=***???????????*[1-4]
I have also consulted the helpfile for hicom 150 and it should send the called party info, when forwarding to voicemail. All of my IVR lines are configured as 5 number voicemail extensions.
Inband Signal which arrived in first trace was **202222*4 and the second trace shows the inband signaling pattern as **1**118*1
Both were not matched by any patters specified in the inband definition file:
Looking at what info was sent and knowing from where the calls arrived you should be able to identify which positions in the sent info hold the information that you want to use.
One immediate comment we can make is that it looks like in your case the PBX seems to be sending two * characters at the beginning instead of 3 - so you could try adding these two entries to the inband definition file:
;**[type of call][calling party]*[info]
Pattern=**??????*[1-4]
RV=Inband_TOC,3,1,Inband_Calling,4,5,Inband_Called,9,0,Inband_Info,10,1
;format is **[type of call][calling party][called party]*[info]
Pattern=**???????????*[1-4]
RV=Inband_TOC,3,1,Inband_Calling,4,5,Inband_Called,9,5,Inband_Info,15,1
Here is something that may help:
; Inband Signaling definition file for:
; Siemens HiPath 3000 v1.3
; Each Inband Signal definition entry consists of two lines: Pattern and RV
; Pattern :
; Any string expression conforming to the pattern-matching conventions described in
; Visual Basic for Applications LIKE operator pattern definition.
; Used to match the incoming Inband Signalling data.
; RV :
; VoiceGuide Result Variables extracted from the matched Inband Signalling stream
; multiple RV's are specified using 3 fields per RV:
; 1. Name
; 2. Start Postion
; 3. Length
; Result Variables extracted
; List of Result Variables extracted using this definition file:
; Inband_TOC = Type of call (TOC)
; Inband_Calling = Calling party
; Inband_Called = Called party
; Inband_Info = Additional calling party information
;3 digit station numbers, forwarded call 2 stars
Pattern=[*][*]??????**???[*][1-4]
RV=Inband_TOC,3,1,Inband_Calling,4,5,Inband_Called,11,3,Inband_Info,16,1
;4 digit station numbers, forwarded call 2 stars
Pattern=[*][*]??????*????[*][1-4]
RV=Inband_TOC,3,1,Inband_Calling,4,5,Inband_Called,10,4,Inband_Info,16,1
;5 digit station numbers, forwarded call 2 stars
Pattern=[*][*]???????????[*][1-4]
RV=Inband_TOC,3,1,Inband_Calling,4,5,Inband_Called,9,5,Inband_Info,16,1
Pattern=[*][*][*]??????**???[*][1-4]
RV=Inband_TOC,4,1,Inband_Calling,5,5,Inband_Called,12,3,Inband_Info,17,1
Pattern=[*][*][*]??????*????[*][1-4]
RV=Inband_TOC,4,1,Inband_Calling,5,5,Inband_Called,11,4,Inband_Info,17,1
Pattern=[*][*][*]???????????[*][1-4]
;3 digit station numbers, direct call 2 stars
Pattern=[*][*]?**???[*][1-4]
RV=Inband_TOC,3,1,Inband_Calling,6,3,Inband_Called,9,0,Inband_Info,10,1
;4 digit station numbers, direct call 2 stars
Pattern=[*][*][*]?*????[*][1-4]
RV=Inband_TOC,3,1,Inband_Calling,5,4,Inband_Called,9,0,Inband_Info,10,1
;5 digit station numbers, direct call 2 stars
Pattern=[*][*][*]??????[*][1-4]
Pattern=[*][*][*]?**???[*][1-4]
RV=Inband_TOC,4,1,Inband_Calling,7,3,Inband_Called,10,0,Inband_Info,11,1
RV=Inband_TOC,4,1,Inband_Calling,6,4,Inband_Called,10,0,Inband_Info,11,1
Admin,
Thanks, I am now picking up all of the info from inband signalling except for the called number.
Since the Inband_Info imediately follows Inband_calling, my guess is that the PBX does not send the Inband_Called.
Do you have any ideas on how I can tweak the PBX to do that?
Ask your PBX distributor on how the PBX can be setup to send the info you need via inband signaling.
