Vg Wont Playback Text
I've setup VG using the trial version and installed the SAPI 5 for TTS. However,
when I call into the script, the text in the "Text to Speak" box doesn't playback to the caller. I'm using a D/4PCIUF card, Win XP, and system 5.11 release FP1 with the Dialogic patch installed.
I call the IVR, it answers and nothing else happens.
The event trace log shows the following:
162842.15 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range
162934.52 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range
163644.14 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range
163719.75 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range
what am I missing?
Detail trace events
165747.95 1 timer fired EV_TIMEOUT_REPLAYMSG
165747.95 1 event EV_TIMEOUT_REPLAYMSG, code=9005, state=1101
165747.96 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
165747.96 1 path {EV_TIMEOUT_REPLAYMSG} not found
165747.98 1 tts generate reuse
165747.98 1 state [Play Introduction] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
165747.98 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
165747.98 1 timer clear
165748.03 1 tw wav->vox convert end 377921,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
165748.04 1 play start ok, lPlayId=377968
165748.11 1 tw PlayEnd 1 377968
165748.11 1 play end id=377968, (current ID)
165748.11 1 event EV_PLAY_FINISHED, code=8001, state=1100
165748.12 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
165748.12 1 path {EV_PLAY_FINISHED} not found
165748.12 1 timer set 10 EV_TIMEOUT_HANGUP
165748.14 1 tw DialogicEvent 129,TDX_PLAY,377968,0,0,,,
165748.14 1 event TDX_PLAY, code=129, state=1101
165748.14 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
165748.14 1 path {TDX_PLAY} not found
165758.90 1 timer fired EV_TIMEOUT_HANGUP
165758.90 1 event EV_TIMEOUT_HANGUP, code=9001, state=1101
165758.90 1 LsPlayMsgFinished EV_TIMEOUT_HANGUP,EV_TIMEOUT_HANGUP
165758.90 1 path {EV_TIMEOUT_HANGUP} not found
165758.92 1 rv add [Hangup Time]{5/12/2005 4:57:58 PM}
165758.92 1 state Hanging up call...
165758.92 1 HangupCall_Common hCall=1
165758.93 1 rec RecSoundStop ok
165758.93 1 play PlaySoundStop ok
165758.93 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
165758.95 1 fnHangupCall end
165758.98 1 event callstate IDLE 1 0 0
165758.00 1 WorkingMode@Idle=
165758.00 1 timer clear
165758.00 1 rec RecSoundStop ok
165759.01 1 play PlaySoundStop ok
165759.01 1 rv add [CallEndTime]{5/12/2005 4:57:59 PM}
165759.03 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
165759.03 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
165759.03 1 event TDX_SETHOOK, code=135, state=900
165759.04 1 LsAwaitingCalls EV_UNKNOWN_135
165800.03 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
165800.03 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
165800.03 1 init atidle reinit : start
165800.05 1 init atidle reinit iConferenceOtherLegLid=-1
165800.05 1 init atidle reinit : reset all LineState variables
165800.05 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
165800.05 1 state Waiting for a call...
165800.39 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
165800.39 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
165810.53 1 event callstate OFFERING 1 0 0
165810.54 1 script interpretor: VgMulti v6.0.2000
165810.54 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range
165810.56 1 tw ring 1
165810.56 1 ring time since last ring (ms): 0
165810.56 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
165810.57 1 event TDX_CST, code=134, state=900
165810.57 1 LsAwaitingCalls EV_UNKNOWN_134
165816.55 1 tw ring 2
165816.57 1 ring time since last ring (ms): 6.007813
165816.57 1 ring match against loaded ring patterns
165816.57 1 rv clear all
165816.58 1 init LineState ResetAtStartOfNewCall.
165816.58 1 answer the call
165816.58 1 timer clear
165816.60 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
165816.60 1 event TDX_CST, code=134, state=6001
165817.13 1 event callstate CONNECTED 1 0 0
165817.14 1 WorkingModes tapi= script=
165817.14 1 Inband detection not enabled
165817.14 1 StartLoadedVgs at 5/12/2005 4:58:17 PM
165817.16 1 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
165817.16 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
165817.16 1 rv add [$RV_STARTTIME]{5/12/2005 4:58:17 PM}
165817.17 1 rv add [$RV_DEVICEID]{1}
165817.17 1 rv add [$RV_CIDNAME]{}
165817.17 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
165817.19 1 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\IVRjobapp\}
165817.19 1 rv add [$RV_CIDNUMBER]{}
165817.19 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
165817.20 1 event TDX_SETHOOK, code=135, state=6001
165817.20 1 tw DialogicEvent 134,TDX_CST,1833,0,0,DE_LCON,,
165817.20 1 event TDX_CST, code=134, state=6001
165817.22 1 timer clear
165817.22 1 state [Play Introduction] Playing
165817.23 1 tts generate start[if you want to apply for job with MB then please press or say one or if you do not want to apply for a position and only wish to check on the status of an application please press two. To exit press the pound key.]
165817.25 1 tts generate wait
165817.33 1 tts generate finish
165817.33 1 state [Play Introduction] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
165817.34 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
165817.34 1 timer clear
165817.38 1 tw wav->vox convert end 407609,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
165817.39 1 play start ok, lPlayId=407640
165817.45 1 tw PlayEnd 1 407640
165817.45 1 play end id=407640, (current ID)
165817.47 1 event EV_PLAY_FINISHED, code=8001, state=1100
165817.47 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
165817.47 1 path {EV_PLAY_FINISHED} not found
165817.48 1 timer set 5 EV_TIMEOUT_REPLAYMSG
165817.48 1 tw DialogicEvent 129,TDX_PLAY,407640,0,0,,,
165817.48 1 event TDX_PLAY, code=129, state=1101
165817.50 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
165817.50 1 path {TDX_PLAY} not found
165822.87 1 timer fired EV_TIMEOUT_REPLAYMSG
165822.87 1 event EV_TIMEOUT_REPLAYMSG, code=9005, state=1101
165822.87 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
165822.89 1 path {EV_TIMEOUT_REPLAYMSG} not found
165822.89 1 tts generate reuse
165822.89 1 state [Play Introduction] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
165822.90 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
165822.90 1 timer clear
165822.93 1 tw wav->vox convert end 413203,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
165822.95 1 play start ok, lPlayId=413234
165823.03 1 tw PlayEnd 1 413234
165823.03 1 play end id=413234, (current ID)
165823.04 1 event EV_PLAY_FINISHED, code=8001, state=1100
165823.04 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
165823.04 1 path {EV_PLAY_FINISHED} not found
165823.06 1 timer set 5 EV_TIMEOUT_REPLAYMSG
165823.06 1 tw DialogicEvent 129,TDX_PLAY,413234,0,0,,,
165823.06 1 event TDX_PLAY, code=129, state=1101
165823.07 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
165823.07 1 path {TDX_PLAY} not found
165828.45 1 timer fired EV_TIMEOUT_REPLAYMSG
165828.45 1 event EV_TIMEOUT_REPLAYMSG, code=9005, state=1101
165828.45 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
165828.46 1 path {EV_TIMEOUT_REPLAYMSG} not found
165828.46 1 tts generate reuse
165828.46 1 state [Play Introduction] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
165828.48 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
165828.48 1 timer clear
165828.49 1 tw wav->vox convert end 418812,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
165828.51 1 play start ok, lPlayId=418828
165828.59 1 tw PlayEnd 1 418828
165828.59 1 play end id=418828, (current ID)
165828.59 1 event EV_PLAY_FINISHED, code=8001, state=1100
165828.60 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
165828.60 1 path {EV_PLAY_FINISHED} not found
165828.60 1 timer set 10 EV_TIMEOUT_HANGUP
165828.62 1 timer set 10 EV_TIMEOUT_HANGUP
165828.62 1 tw DialogicEvent 129,TDX_PLAY,418828,0,0,,,
165828.62 1 event TDX_PLAY, code=129, state=1101
165828.63 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
165828.63 1 path {TDX_PLAY} not found
165839.46 1 timer fired EV_TIMEOUT_HANGUP
165839.46 1 event EV_TIMEOUT_HANGUP, code=9001, state=1101
165839.46 1 LsPlayMsgFinished EV_TIMEOUT_HANGUP,EV_TIMEOUT_HANGUP
165839.47 1 path {EV_TIMEOUT_HANGUP} not found
165839.47 1 rv add [Hangup Time]{5/12/2005 4:58:39 PM}
165839.47 1 state Hanging up call...
165839.49 1 HangupCall_Common hCall=1
165839.49 1 rec RecSoundStop ok
165839.50 1 play PlaySoundStop ok
165839.50 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
165839.50 1 fnHangupCall end
165839.55 1 event callstate IDLE 1 0 0
165839.55 1 WorkingMode@Idle=
165839.57 1 timer clear
165839.57 1 rec RecSoundStop ok
165839.58 1 play PlaySoundStop ok
165839.58 1 rv add [CallEndTime]{5/12/2005 4:58:39 PM}
165839.60 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
165839.60 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
165839.60 1 event TDX_SETHOOK, code=135, state=900
165839.61 1 LsAwaitingCalls EV_UNKNOWN_135
165840.61 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
165840.61 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
165840.61 1 init atidle reinit : start
165840.62 1 init atidle reinit iConferenceOtherLegLid=-1
165840.62 1 init atidle reinit : reset all LineState variables
165840.62 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
165840.64 1 state Waiting for a call...
165840.96 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
165840.96 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
It looks like the TTS is not generating any sound. Best to probably try re-installing the TTS. Which TTS are you using?
To confirm if TTS is working see what is in file C:\Program Files\VoiceGuide\data\tts1.wav - that's the file into which the TTS system saved it's TTS converted sound and that's the file which VG then played..
I'm using the standard Microsoft SAPI 5. Is there some configuration that has to be done to make it work with VG? I'm only using it until I get the ATT natural voices. I assumed that once I installed the SAPI 5 for Microsoft that it would work.
What else is needed?
Does the VG recognize that the TTS is installed automatically?
Can you use demo tools that came with the TTS to play text over your speakers? have you used anything else to confirm that TTS works?
Best to just try re-installing it.
Yes.
Do I need to install Visual Basic as well?
No.
I have re-installed the Microsoft SPEECH SDK and the VG is working properly.
Thanks for your excellent support!
