Vb Script Not Returning Values In Rs
Hello,
We have recently purchase 4 port board enterprise license from you and making this test program.
I need help in this script urgently.
UsrPhone_no corresponds to $RV_CIDNUMBER. I have it stored in Restult variable.
I am getting SQL properly and when I run this script in SQL Query Analyzer, I am getting result.
I have to pass number back to SQL and get Unique ID back from DB. I have worked on ASP pages extensivly so I am familier with VB Script too.
Please advice what I am doing wrong, it is urgent.
Thanks in advance.
Regards
Alok
VB Script below:
Dim cn
Dim rs
Dim sSQL
Dim conStr
set cn = CreateObject("ADODB.Connection")
conStr = "Provider=SQLOLEDB.1;Persist Security Info=False;" _
& " Data Source=MHIVR;" _
& " Initial Catalog=MHungry; User ID=Alok;" _
& " Password=Alok123"
cn.Open conStr
if cn.State <> 1 then
vg.RvSet $RV_LINEID, "Usr_ID", 0
vg.Run_ResultReturn iLineId, "fail"
set rs = Nothing
set cn = Nothing
WScript.Quit
end if
sSQL = "SELECT TOP 1 Usr_ID FROM UsrPhone WHERE UsrPhone_No = '$RV[usrPhone_No]'"
vg.RvSet $RV_LINEID, "csSQL", sSQL
set rs = cn.Execute(sSQL)
if rs.RecordCount <= 0 then
rs.Close
vg.RvSet $RV_LINEID, "Usr_ID", -1
else
vg.RvSet $RV_LINEID, "Usr_ID", rs.Fields("Usr_ID").Value
rs.Close
end if
cn.Close
set rs = Nothing
set cn = Nothing
set vg = Nothing
WScript.Quit
I assume that you are getting rs.RecordCount <= 0 as a result?
Best for you to use the error reporting functions within ADODB to see what error is being returned for you (if that's where the problems lies).
This is more of an MS ADODB programming question rather then a VoiceGuide related question...
