Voiceguide Dialogic
Install for VoiceGuide Dialogic. I cannot work with configwizard. It says to me that I must form a file lineconfig.xml but that file does not exist.
Hello, already it installs the application(VG for Dialogic) but it was
put well unstable. That I must do so that works configwizard?
The files Config.xml and ConfigLine.xml came in the .ZIP archinve you would have recieved...
VoiceGuide for Dialogic does not use Config Wizard - this is stated in the intructions (Readme.txt) supplied.
Sounds like you have not even been able to start the software so what to you mean by "it was put well unstable" ? There are no stabuility issues with the software that we know of and that version of VG has now been running for a fairly long time in a large number of sites.
Please read the Readme.txt file supplied - it contains instructions on what you need to edit in the Config.xml file.
