D/41d Text To Speech
as to works D/41D with text speech if it does not recognize format PCM? It has like causing that the archives text to spech tts0.wav have Mu-Law format?
I think most TTS engines will create the PCM .WAV file...
Send an email to sales@voiceguide.com - you should be using "VG for Dialogic" - that will let you use TTS on the sound card you have.
