Capture Entered Number Module Not Working?
When I test the script "Credit Card Payment.vgs" the VG fall to get the number and Hangup?
I'm using 3com U.S. Rebotics 56 Message modem ?
140436.20 6 callstate OFFERING 65766 0 4
140436.20 6 rv clear
140436.20 6 Answer the call at 18/04/2005 02:04:36 م
140436.22 6 lineAnswer(65766) => 66296
140436.22 6 ring 1
140436.22 6 callstate ACCEPTED 65766 0 0
140436.34 0 dial start any summary:|6:hc>0|
140439.59 6 tapi Reply (LineEvReply) ok 66296 0
140439.59 6 callstate CONNECTED 65766 0 0
140439.59 6 callstate CONNECTED 65766,0,0
140439.59 6 WorkingModeTAPI@Connected=
140439.59 6 WorkingModeScript@Connected=
140439.61 6 Inband detection not enabled
140439.61 6 StartLoadedVgs at 18/04/2005 02:04:39 م, v5.2.3063
140439.61 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\}
140439.61 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment}
140439.61 6 rv add [$RV_STARTTIME]{18/04/2005 02:04:39 م}
140439.61 6 rv add [$RV_DEVICEID]{6}
140439.61 6 rv add [$RV_CIDNAME]{}
140439.63 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
140439.63 6 rv add [$RV_CIDNUMBER]{}
140439.63 6 timer clear
140439.63 6 [Get Client ID] Number Input
140439.63 6 [Get Client ID] Playing (PayGetId.wav)
140439.64 6 play set playid=450234
140440.28 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav]
140440.30 6 timer clear
140440.30 6 wa(8358,45023400)
140448.81 6 play end current play (playid=450234)
140448.81 6 ScriptEventCode 8001 iLineState=1300
140448.81 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
140448.83 6 timer set 10 EV_TIMEOUT_HANGUP
140448.83 6 timer set 6 EV_TIMEOUT_ENTERDATA
140455.28 6 timer fired EV_TIMEOUT_ENTERDATA
140455.28 6 ScriptEventCode 9006 iLineState=1301
140455.28 6 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
140455.28 6 rv add [Get Client ID]{}
140455.28 6 AddRVns [Get Client ID_PathTaken]{fail}
140455.30 6 rv add [Hangup Time]{18/04/2005 02:04:55 م}
140455.30 6 Hanging up call... [No data entered]
140455.30 6 RecSoundStop ok
140455.30 6 PlaySoundStop err=0
140455.30 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
140455.31 6 fnHangupCall end
140456.14 6 callstate DISCONNECTED 65766 1 0
140456.16 6 ScriptEventCode 9250 iLineState=900
140456.16 6 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
140456.16 6 rv add [Hangup Time]{18/04/2005 02:04:56 م}
140456.16 6 Hanging up call...
140456.17 6 RecSoundStop ok
140456.17 6 PlaySoundStop err=0
140456.17 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
140456.17 6 fnHangupCall end
140456.17 6 callstate IDLE 65766 0 0
140456.19 6 WorkingMode@Idle=
140456.19 6 timer clear
140456.19 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
140456.19 6 tapi Reply (LineEvReply) ok 65578 0
140456.20 6 tapi Reply (LineEvReply) ok 66415 0
140457.19 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
140457.19 6 ScriptEventCode 9008 iLineState=900
140457.19 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
140457.19 6 ReinitTelephony due to IDLE
140457.19 6 tapic lineDeallocateCall(MainCall:65766) 0
140457.22 6 lineOpen(6)=>
140457.22 6 Waiting for a call...
140457.22 6 LineHandle=65818
140457.22 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
140457.34 0 dial start any summary:|6:rdy=0|
140500.50 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
140500.50 6 ScriptEventCode 9013 iLineState=900
140501.34 0 dial start any summary:|6:dok=0|
Trace shows modem did not report any keypresses being made, so VG hung up the call.
