Vb Script Problem
Nira wrote:
My vb script:
Sub random()
Randomize
Dim cond As String
If Rnd() <= 0.25 Then
cond = "music"
ElseIf 0.25 < Rnd() And Rnd() <= 0.5 Then
cond = "apology_cond"
ElseIf 0.5 < Rnd() And Rnd() <= 0.75 Then
cond = "no_8"
Else
cond = "birth_year"
End If
Open "c:\Program Files\ivg\data\SHRESULT.txt" For Output As 1
Write #1, cond
Close 1
End Sub
The error message is:
Windows Script Host
Script: C:\Program Files\ivg\data\vbs_0.vbs
Char: 10
Error: Expected end of statement
Code: 800A0401
Source: Microsoft VBScript compilation error
What I have done wrong?
Many thanks in advance,
Nira
VB Script does not reqire you to specify variable types, and you're better off using the FileSystemObject for any file I/O. Try using this script instead:
Randomize
Dim cond
cond = "music"
cond = "no_8"
Else
cond = "birth_year"
End If
WriteResultFile cond
function WriteResultFile(strResult)
const ForReading=1, ForWriting=2, ForAppending=8
Dim filename, fso, ts, outdata, outdata2, outdata3
filename = "c:\Program Files\ivg\data\SHRESULT.txt"
set ts = fso.OpenTextFile(filename, ForWriting, True)
ts.WriteLine(strResult)
ts.Close
WriteResultFile = 0
end function
I've tried it and it worked fine for me - creating the file and writing appropriate result into it.
